23#ifndef _GEOMImpl_Fillet1d_HeaderFile
24#define _GEOMImpl_Fillet1d_HeaderFile
26#include <TopoDS_Edge.hxx>
28#include <Geom_Plane.hxx>
29#include <Geom2d_Curve.hxx>
33#include <TColStd_ListOfReal.hxx>
34#include <TColStd_SequenceOfReal.hxx>
35#include <TColStd_SequenceOfInteger.hxx>
49 const TopoDS_Edge& theEdge2,
50 const gp_Pln& thePlane);
53 Standard_EXPORT Standard_Boolean
Perform(
const Standard_Real theRadius);
56 Standard_EXPORT TopoDS_Edge
Result(
const gp_Pnt& thePoint, TopoDS_Edge& theEdge1, TopoDS_Edge& theEdge2);
61 const Standard_Real theEnd,
62 const Standard_Integer theNBSteps);
100 Standard_EXPORT
inline void SetParam(Standard_Real theParam)
102 Standard_EXPORT
inline Standard_Real
GetParam()
const
104 Standard_EXPORT
inline void SetParam2(
const Standard_Real theParam2)
110 Standard_EXPORT
inline Standard_Boolean
IsValid(
int theIndex)
111 {
return (Standard_Boolean)
myValid.Value(theIndex);}
115 Standard_EXPORT
GetValue(Standard_Integer theIndex)
116 {
return myV.Value(theIndex);}
117 Standard_EXPORT
GetDiff(Standard_Integer theIndex)
118 {
return myD.Value(theIndex);}
119 Standard_EXPORT
inline Standard_Integer
GetNear(Standard_Integer theIndex)
120 {
return myNear.Value(theIndex);}
123 Standard_EXPORT
inline void SetCenter(
const gp_Pnt2d thePoint)
128 Standard_EXPORT
void AddValue(Standard_Real theValue, Standard_Boolean theIsValid);
135 Standard_EXPORT Standard_Integer
HasSolution(Standard_Real theRadius);
GEOMImpl_Fillet1dPoint is an internal class for 1D fillet algorithm to store and compare computed sol...
Definition: GEOMImpl_Fillet1d.hxx:87
TColStd_SequenceOfReal myV
Definition: GEOMImpl_Fillet1d.hxx:143
Standard_EXPORT const gp_Pnt2d GetCenter()
Definition: GEOMImpl_Fillet1d.hxx:125
Standard_EXPORT Standard_Integer GetNBValues()
Get values.
Definition: GEOMImpl_Fillet1d.hxx:114
gp_Pnt2d myCenter
Private fields.
Definition: GEOMImpl_Fillet1d.hxx:141
Standard_Real myParam2
Definition: GEOMImpl_Fillet1d.hxx:142
Standard_EXPORT Standard_Boolean IsValid(int theIndex)
Returns validity.
Definition: GEOMImpl_Fillet1d.hxx:110
TColStd_SequenceOfInteger myValid
Definition: GEOMImpl_Fillet1d.hxx:144
Standard_EXPORT void AddValue(Standard_Real theValue, Standard_Boolean theIsValid)
Definition: GEOMImpl_Fillet1d.cxx:694
Standard_EXPORT Standard_Integer HasSolution(Standard_Real theRadius)
Checks if point contains solution and returns the index of it if any.
Definition: GEOMImpl_Fillet1d.cxx:888
Standard_EXPORT Standard_Integer GetNear(Standard_Integer theIndex)
Definition: GEOMImpl_Fillet1d.hxx:119
Standard_EXPORT void FilterPoints(GEOMImpl_Fillet1dPoint *)
Definition: GEOMImpl_Fillet1d.cxx:760
Standard_EXPORT void SetParam2(const Standard_Real theParam2)
Definition: GEOMImpl_Fillet1d.hxx:104
void RemoveSolution(Standard_Integer theIndex)
Remove solution by index.
Definition: GEOMImpl_Fillet1d.cxx:903
TColStd_SequenceOfReal myD
TColStd_SequenceOfInteger myNear
Standard_EXPORT Standard_Real GetParam2()
Definition: GEOMImpl_Fillet1d.hxx:106
Standard_EXPORT Standard_Boolean ComputeDifference(GEOMImpl_Fillet1dPoint *)
compute difference between this and given point
Definition: GEOMImpl_Fillet1d.cxx:714
Standard_EXPORT GEOMImpl_Fillet1dPoint(Standard_Real theParam)
Puiblic methods.
Definition: GEOMImpl_Fillet1d.hxx:92
Standard_EXPORT GEOMImpl_Fillet1dPoint * Copy()
Make copy of point WARNING: Copies only field values: myParam, myV, myD, myValid.
Definition: GEOMImpl_Fillet1d.cxx:871
Standard_EXPORT Standard_Real GetValue(Standard_Integer theIndex)
Definition: GEOMImpl_Fillet1d.hxx:115
Standard_EXPORT void SetCenter(const gp_Pnt2d thePoint)
Set/Get center point.
Definition: GEOMImpl_Fillet1d.hxx:123
Standard_EXPORT void SetParam(Standard_Real theParam)
Set/Get parameter.
Definition: GEOMImpl_Fillet1d.hxx:100
Standard_EXPORT Standard_Real GetParam() const
Definition: GEOMImpl_Fillet1d.hxx:102
Standard_EXPORT Standard_Real GetDiff(Standard_Integer theIndex)
Definition: GEOMImpl_Fillet1d.hxx:117
GEOMImpl_Fillet1d is 1D fillet algorithm on two planar edges with given radius.
Definition: GEOMImpl_Fillet1d.hxx:44
Handle(Geom2d_Curve) myCurve1
Standard_Boolean myStartSide
Definition: GEOMImpl_Fillet1d.hxx:76
Standard_Real myRadius
Definition: GEOMImpl_Fillet1d.hxx:73
Standard_Boolean processPoint(GEOMImpl_Fillet1dPoint *, GEOMImpl_Fillet1dPoint *, Standard_Real)
Definition: GEOMImpl_Fillet1d.cxx:427
Standard_Real myStart1
TColStd_ListOfReal myResultParams
Definition: GEOMImpl_Fillet1d.hxx:74
TopoDS_Edge myEdge1
private fields
Definition: GEOMImpl_Fillet1d.hxx:70
Standard_EXPORT Standard_Boolean Perform(const Standard_Real theRadius)
Makes fillet with given radius.
Definition: GEOMImpl_Fillet1d.cxx:262
Standard_EXPORT GEOMImpl_Fillet1d(const TopoDS_Edge &theEdge1, const TopoDS_Edge &theEdge2, const gp_Pln &thePlane)
Constructor The fillet 1D algorithm is initialised by two edges and plane.
Definition: GEOMImpl_Fillet1d.cxx:101
Standard_EXPORT TopoDS_Edge Result(const gp_Pnt &thePoint, TopoDS_Edge &theEdge1, TopoDS_Edge &theEdge2)
Returns result fillet edge and modified edges as out parameters.
Definition: GEOMImpl_Fillet1d.cxx:570
Standard_Integer myDegreeOfRecursion
Definition: GEOMImpl_Fillet1d.hxx:77
Standard_Boolean myEdgesExchnged
void performInterval(const Standard_Real theStart, const Standard_Real theEnd, const Standard_Integer theNBSteps)
private methods
Definition: GEOMImpl_Fillet1d.cxx:387
TopoDS_Edge myEdge2
void fillPoint(GEOMImpl_Fillet1dPoint *)
Definition: GEOMImpl_Fillet1d.cxx:194
myCurve2
Definition: GEOMImpl_Fillet1d.hxx:72
Standard_Real myEnd1
Standard_Real myEnd2
Standard_Real myStart2
Handle(Geom_Plane) myPlane
void performNewton(GEOMImpl_Fillet1dPoint *, GEOMImpl_Fillet1dPoint *)
Definition: GEOMImpl_Fillet1d.cxx:481
TColStd_SequenceOfInteger myResultOrientation
Definition: GEOMImpl_Fillet1d.hxx:75
void fillDiff(GEOMImpl_Fillet1dPoint *, Standard_Real, Standard_Boolean)
Definition: GEOMImpl_Fillet1d.cxx:244
