GEOMImpl_Fillet1dPoint Class Reference
GEOMImpl_Fillet1dPoint is an internal class for 1D fillet algorithm to store and compare computed solutions on edges.
#include <GEOMImpl_Fillet1d.hxx>
Standard_EXPORT GEOMImpl_Fillet1dPoint (Standard_Real theParam)
 Puiblic methods. More...
Standard_EXPORT GEOMImpl_Fillet1dPoint * Copy ()
 Make copy of point WARNING: Copies only field values: myParam, myV, myD, myValid. More...
Standard_EXPORT void SetParam (Standard_Real theParam)
 Set/Get parameter. More...
Standard_EXPORT Standard_Real GetParam () const
Standard_EXPORT void SetParam2 (const Standard_Real theParam2)
Standard_EXPORT Standard_Real GetParam2 ()
Standard_EXPORT Standard_Boolean IsValid (int theIndex)
 Returns validity. More...
Standard_EXPORT Standard_Integer GetNBValues ()
 Get values. More...
Standard_EXPORT Standard_Real GetValue (Standard_Integer theIndex)
Standard_EXPORT Standard_Real GetDiff (Standard_Integer theIndex)
Standard_EXPORT Standard_Integer GetNear (Standard_Integer theIndex)
Standard_EXPORT void SetCenter (const gp_Pnt2d thePoint)
 Set/Get center point. More...
Standard_EXPORT const gp_Pnt2d GetCenter ()
Standard_EXPORT void AddValue (Standard_Real theValue, Standard_Boolean theIsValid)
Standard_EXPORT Standard_Boolean ComputeDifference (GEOMImpl_Fillet1dPoint *)
 compute difference between this and given point More...
Standard_EXPORT void FilterPoints (GEOMImpl_Fillet1dPoint *)
Standard_EXPORT Standard_Integer HasSolution (Standard_Real theRadius)
 Checks if point contains solution and returns the index of it if any. More...
void RemoveSolution (Standard_Integer theIndex)
 Remove solution by index. More...
gp_Pnt2d myCenter
 Private fields. More...
Standard_Real myParam
Standard_Real myParam2
TColStd_SequenceOfReal myV
TColStd_SequenceOfReal myD
TColStd_SequenceOfInteger myValid
TColStd_SequenceOfInteger myNear
◆ GEOMImpl_Fillet1dPoint()
Standard_EXPORT GEOMImpl_Fillet1dPoint::GEOMImpl_Fillet1dPoint ( Standard_Real  theParam)
Constructor
References myParam.
◆ AddValue()
void GEOMImpl_Fillet1dPoint::AddValue ( Standard_Real  theValue,
References myV, and myValid.
◆ ComputeDifference()
Standard_Boolean GEOMImpl_Fillet1dPoint::ComputeDifference ( GEOMImpl_Fillet1dPoint *  thePoint)
References GetParam(), myD, myParam, and myV.
◆ Copy()
GEOMImpl_Fillet1dPoint * GEOMImpl_Fillet1dPoint::Copy ( )
◆ FilterPoints()
void GEOMImpl_Fillet1dPoint::FilterPoints ( GEOMImpl_Fillet1dPoint *  thePoint)
References GetParam(), myD, myNear, myParam, myV, and myValid.
◆ GetCenter()
Standard_EXPORT const gp_Pnt2d GEOMImpl_Fillet1dPoint::GetCenter ( )
References myCenter.
◆ GetDiff()
Standard_EXPORT Standard_Real GEOMImpl_Fillet1dPoint::GetDiff ( Standard_Integer  theIndex)
References myD.
◆ GetNBValues()
Standard_EXPORT Standard_Integer GEOMImpl_Fillet1dPoint::GetNBValues ( )
References myV.
◆ GetNear()
Standard_EXPORT Standard_Integer GEOMImpl_Fillet1dPoint::GetNear ( Standard_Integer  theIndex)
References myNear.
◆ GetParam()
Standard_EXPORT Standard_Real GEOMImpl_Fillet1dPoint::GetParam ( ) const
References myParam.
◆ GetParam2()
Standard_EXPORT Standard_Real GEOMImpl_Fillet1dPoint::GetParam2 ( )
References myParam2.
◆ GetValue()
Standard_EXPORT Standard_Real GEOMImpl_Fillet1dPoint::GetValue ( Standard_Integer  theIndex)
References myV.
◆ HasSolution()
Standard_Integer GEOMImpl_Fillet1dPoint::HasSolution ( Standard_Real  theRadius)
References myV.
◆ IsValid()
Standard_EXPORT Standard_Boolean GEOMImpl_Fillet1dPoint::IsValid ( int  theIndex)
References myValid.
◆ RemoveSolution()
void GEOMImpl_Fillet1dPoint::RemoveSolution ( Standard_Integer  theIndex)
References myD, myNear, myV, and myValid.
◆ SetCenter()
Standard_EXPORT void GEOMImpl_Fillet1dPoint::SetCenter ( const gp_Pnt2d  thePoint)
◆ SetParam()
Standard_EXPORT void GEOMImpl_Fillet1dPoint::SetParam ( Standard_Real  theParam)
References myParam.
◆ SetParam2()
Standard_EXPORT void GEOMImpl_Fillet1dPoint::SetParam2 ( const Standard_Real  theParam2)
◆ myCenter
gp_Pnt2d GEOMImpl_Fillet1dPoint::myCenter
◆ myD
TColStd_SequenceOfReal GEOMImpl_Fillet1dPoint::myD
◆ myNear
TColStd_SequenceOfInteger GEOMImpl_Fillet1dPoint::myNear
◆ myParam
Standard_Real GEOMImpl_Fillet1dPoint::myParam
◆ myParam2
Standard_Real GEOMImpl_Fillet1dPoint::myParam2
◆ myV
TColStd_SequenceOfReal GEOMImpl_Fillet1dPoint::myV
◆ myValid
TColStd_SequenceOfInteger GEOMImpl_Fillet1dPoint::myValid
