GEOMImpl_Fillet1d Class Reference
GEOMImpl_Fillet1d is 1D fillet algorithm on two planar edges with given radius.
#include <GEOMImpl_Fillet1d.hxx>
Standard_EXPORT GEOMImpl_Fillet1d (const TopoDS_Edge &theEdge1, const TopoDS_Edge &theEdge2, const gp_Pln &thePlane)
 Constructor The fillet 1D algorithm is initialised by two edges and plane. More...
Standard_EXPORT Standard_Boolean Perform (const Standard_Real theRadius)
 Makes fillet with given radius. More...
Standard_EXPORT TopoDS_Edge Result (const gp_Pnt &thePoint, TopoDS_Edge &theEdge1, TopoDS_Edge &theEdge2)
 Returns result fillet edge and modified edges as out parameters. More...
void performInterval (const Standard_Real theStart, const Standard_Real theEnd, const Standard_Integer theNBSteps)
 private methods More...
void fillPoint (GEOMImpl_Fillet1dPoint *)
void fillDiff (GEOMImpl_Fillet1dPoint *, Standard_Real, Standard_Boolean)
void performNewton (GEOMImpl_Fillet1dPoint *, GEOMImpl_Fillet1dPoint *)
Standard_Boolean processPoint (GEOMImpl_Fillet1dPoint *, GEOMImpl_Fillet1dPoint *, Standard_Real)
 Handle (Geom_Plane) myPlane
 Handle (Geom2d_Curve) myCurve1
TopoDS_Edge myEdge1
 private fields More...
TopoDS_Edge myEdge2
 myCurve2
Standard_Real myStart1
Standard_Real myEnd1
Standard_Real myStart2
Standard_Real myEnd2
Standard_Real myRadius
TColStd_ListOfReal myResultParams
TColStd_SequenceOfInteger myResultOrientation
Standard_Boolean myStartSide
Standard_Boolean myEdgesExchnged
Standard_Integer myDegreeOfRecursion
◆ GEOMImpl_Fillet1d()
GEOMImpl_Fillet1d::GEOMImpl_Fillet1d ( const TopoDS_Edge &  theEdge1,
const TopoDS_Edge &  theEdge2,
const gp_Pln &  thePlane
◆ fillDiff()
void GEOMImpl_Fillet1d::fillDiff ( GEOMImpl_Fillet1dPoint *  thePoint,
Standard_Real  theDiffStep,
Standard_Boolean  theFront
◆ fillPoint()
◆ Handle() [1/2]
GEOMImpl_Fillet1d::Handle ( Geom2d_Curve  )
◆ Handle() [2/2]
GEOMImpl_Fillet1d::Handle ( Geom_Plane  )
◆ Perform()
Standard_Boolean GEOMImpl_Fillet1d::Perform ( const Standard_Real  theRadius)
Standard_True, if at least one result computed
References myCurve2, myDegreeOfRecursion, myEnd1, myRadius, myResultOrientation, myResultParams, myStart1, and performInterval().
◆ performInterval()
void GEOMImpl_Fillet1d::performInterval ( const Standard_Real  theStart,
◆ performNewton()
◆ processPoint()
Standard_Boolean GEOMImpl_Fillet1d::processPoint ( GEOMImpl_Fillet1dPoint *  theLeft,
GEOMImpl_Fillet1dPoint *  theRight,
Standard_Real  theParameter
◆ Result()
◆ myCurve2
GEOMImpl_Fillet1d::myCurve2
◆ myDegreeOfRecursion
Standard_Integer GEOMImpl_Fillet1d::myDegreeOfRecursion
◆ myEdge1
TopoDS_Edge GEOMImpl_Fillet1d::myEdge1
◆ myEdge2
TopoDS_Edge GEOMImpl_Fillet1d::myEdge2
◆ myEdgesExchnged
Standard_Boolean GEOMImpl_Fillet1d::myEdgesExchnged
◆ myEnd1
Standard_Real GEOMImpl_Fillet1d::myEnd1
◆ myEnd2
Standard_Real GEOMImpl_Fillet1d::myEnd2
◆ myRadius
Standard_Real GEOMImpl_Fillet1d::myRadius
◆ myResultOrientation
TColStd_SequenceOfInteger GEOMImpl_Fillet1d::myResultOrientation
◆ myResultParams
TColStd_ListOfReal GEOMImpl_Fillet1d::myResultParams
◆ myStart1
Standard_Real GEOMImpl_Fillet1d::myStart1
◆ myStart2
Standard_Real GEOMImpl_Fillet1d::myStart2
◆ myStartSide
Standard_Boolean GEOMImpl_Fillet1d::myStartSide
