CurveCreator_ICurve Class Referenceabstract
The CurveCreator_ICurve object is represented as one or more sets of connected points; thus CurveCreator_ICurve object can contain several not connected curves (polylines or b-splines), each such curve has two only ends "start and end points" in other words non-manifold curves are not supported.
#include <CurveCreator_ICurve.hxx>
Inheritance diagram for CurveCreator_ICurve:
typedef std::pair< int, int > SectionToPoint
typedef std::deque< SectionToPoint > SectionToPointList
typedef std::deque< std::pair< SectionToPoint, CurveCreator::Coordinates > > SectionToPointCoordsList
virtual ~CurveCreator_ICurve ()
 The destructor. More...
virtual int getNbUndo () const =0
 Get number of available undo operations. More...
virtual bool undo ()=0
 Undo previous operation. More...
virtual int getNbRedo () const =0
 Get number of available redo operations. More...
virtual bool redo ()=0
 Redo last previously "undone" operation. More...
virtual bool clear ()=0
 Clear the polyline (remove all sections) More...
virtual bool join (const std::list< int > &theSections)=0
 Join list of sections to one section (join all if the list is empty) More...
virtual int getNbSections () const =0
 Get number of sections. More...
virtual int addSection (const std::string &theName, const CurveCreator::SectionType theType, const bool theIsClosed)=0
 Add a new section. More...
virtual bool removeSection (const int theISection)=0
 Removes the given sections. More...
virtual bool isClosed (const int theISection) const =0
 Get "closed" flag of the specified section. More...
virtual bool setClosed (const int theISection, const bool theIsClosed)=0
 Set "closed" flag of the specified section (all sections if theISection is -1). More...
virtual std::string getSectionName (const int theISection) const =0
 Returns specifyed section name. More...
virtual bool setSectionName (const int theISection, const std::string &theName)=0
 Set name of the specified section. More...
virtual CurveCreator::SectionType getSectionType (const int theISection) const =0
 Get type of the specified section. More...
virtual bool setSectionType (const int theISection, const CurveCreator::SectionType theType)=0
 Set type of the specified section (or all sections if theISection is -1). More...
virtual const CurveCreator_ISection * getSection (const int theSectionIndex) const =0
 Returns the curve section with the index. More...
virtual CurveCreator_ISection * getSection (const int theSectionIndex)=0
virtual CurveCreator::Dimension getDimension () const =0
 Get the dimension. More...
virtual bool addPoints (const CurveCreator::Coordinates &theCoords, const int theISection, const int theIPnt=-1)=0
 Insert one or several points to the specified section starting from the given theIPnt index (or add these at the end of section points if theIPnt is -1). More...
virtual bool setPoint (const int theISection, const int theIPnt, const CurveCreator::Coordinates &theNewCoords)=0
 Set coordinates of specified point. More...
virtual bool setSeveralPoints (const SectionToPointCoordsList &theSectionToPntCoords, const bool theIsToSaveDiff=true)=0
 Set coordinates of specified points from different sections. More...
virtual bool removePoint (const int theISection, const int theIPnt=-1)=0
 Remove point with given id. More...
virtual bool removeSeveralPoints (const SectionToPointList &theSectionToPntIDs)=0
 Remove several points from different sections. More...
virtual CurveCreator::Coordinates getPoint (const int theISection, const int theIPnt) const =0
 Get coordinates of specified point. More...
virtual Handle (TColgp_HArray1OfPnt) GetDifferentPoints(int theISection
 Get points of a section (the total points in Curve if theISection is equal to -1). More...
virtual int getNbPoints (const int theISection) const =0
 Get number of points in specified section or (the total number of points in Curve if theISection is equal to -1). More...
virtual void setSkipSorting (const bool)=0
 Set skip sorting flag. More...
virtual bool canPointsBeSorted ()=0
 Indicates whether the points can be sorted. More...
virtual void saveCoordDiff (const SectionToPointCoordsList &theOldCoords)=0
 Saves points coordinates difference. More...
virtual Handle (AIS_InteractiveObject) getAISObject(const bool theNeedToBuild
virtual void constructAISObject ()=0
◆ SectionToPoint
typedef std::pair<int,int> CurveCreator_ICurve::SectionToPoint
◆ SectionToPointCoordsList
◆ SectionToPointList
◆ ~CurveCreator_ICurve()
virtual CurveCreator_ICurve::~CurveCreator_ICurve ( )
◆ addPoints()
virtual bool CurveCreator_ICurve::addPoints ( const CurveCreator::Coordinates &  theCoords,
const int  theIPnt = -1
pure virtual
Implemented in CurveCreator_Curve.
◆ addSection()
virtual int CurveCreator_ICurve::addSection ( const std::string &  theName,
pure virtual
◆ canPointsBeSorted()
virtual bool CurveCreator_ICurve::canPointsBeSorted ( )
pure virtual
◆ clear()
virtual bool CurveCreator_ICurve::clear ( )
pure virtual
◆ constructAISObject()
virtual void CurveCreator_ICurve::constructAISObject ( )
protectedpure virtual
◆ getDimension()
virtual CurveCreator::Dimension CurveCreator_ICurve::getDimension ( ) const
pure virtual
◆ getNbPoints()
virtual int CurveCreator_ICurve::getNbPoints ( const int  theISection) const
pure virtual
◆ getNbRedo()
virtual int CurveCreator_ICurve::getNbRedo ( ) const
pure virtual
◆ getNbSections()
virtual int CurveCreator_ICurve::getNbSections ( ) const
pure virtual
◆ getNbUndo()
virtual int CurveCreator_ICurve::getNbUndo ( ) const
pure virtual
◆ getPoint()
virtual CurveCreator::Coordinates CurveCreator_ICurve::getPoint ( const int  theISection,
const int  theIPnt
pure virtual
◆ getSection() [1/2]
virtual const CurveCreator_ISection * CurveCreator_ICurve::getSection ( const int  theSectionIndex) const
pure virtual
◆ getSection() [2/2]
virtual CurveCreator_ISection * CurveCreator_ICurve::getSection ( const int  theSectionIndex)
pure virtual
◆ getSectionName()
virtual std::string CurveCreator_ICurve::getSectionName ( const int  theISection) const
pure virtual
◆ getSectionType()
virtual CurveCreator::SectionType CurveCreator_ICurve::getSectionType ( const int  theISection) const
pure virtual
◆ Handle() [1/2]
virtual CurveCreator_ICurve::Handle ( AIS_InteractiveObject  ) const
Reimplemented in CurveCreator_Curve.
◆ Handle() [2/2]
virtual CurveCreator_ICurve::Handle ( TColgp_HArray1OfPnt  )
◆ isClosed()
virtual bool CurveCreator_ICurve::isClosed ( const int  theISection) const
pure virtual
◆ join()
virtual bool CurveCreator_ICurve::join ( const std::list< int > &  theSections)
pure virtual
◆ redo()
virtual bool CurveCreator_ICurve::redo ( )
pure virtual
◆ removePoint()
virtual bool CurveCreator_ICurve::removePoint ( const int  theISection,
pure virtual
◆ removeSection()
virtual bool CurveCreator_ICurve::removeSection ( const int  theISection)
pure virtual
◆ removeSeveralPoints()
virtual bool CurveCreator_ICurve::removeSeveralPoints ( const SectionToPointList &  theSectionToPntIDs)
pure virtual
◆ saveCoordDiff()
virtual void CurveCreator_ICurve::saveCoordDiff ( const SectionToPointCoordsList &  theOldCoords)
pure virtual
theOldCoordsthe old points coordinates
◆ setClosed()
virtual bool CurveCreator_ICurve::setClosed ( const int  theISection,
pure virtual
◆ setPoint()
virtual bool CurveCreator_ICurve::setPoint ( const int  theISection,
const int  theIPnt,
const CurveCreator::Coordinates &  theNewCoords
pure virtual
◆ setSectionName()
virtual bool CurveCreator_ICurve::setSectionName ( const int  theISection,
pure virtual
◆ setSectionType()
virtual bool CurveCreator_ICurve::setSectionType ( const int  theISection,
pure virtual
◆ setSeveralPoints()
virtual bool CurveCreator_ICurve::setSeveralPoints ( const SectionToPointCoordsList &  theSectionToPntCoords,
const bool  theIsToSaveDiff = true
pure virtual
◆ setSkipSorting()
virtual void CurveCreator_ICurve::setSkipSorting ( const bool  )
pure virtual
If the flag is true - points sorting will be skipped.
◆ undo()
virtual bool CurveCreator_ICurve::undo ( )
pure virtual
