CurveCreator_Curve Class Reference
The CurveCreator_Curve object is represented as one or more sets of connected points; thus CurveCreator_Curve object can contain several not connected curves (polylines or b-splines), each such curve has two only ends "start and end points" in other words non-manifold curves are not supported.
#include <CurveCreator_Curve.hxx>
Inheritance diagram for CurveCreator_Curve:
 CurveCreator_Curve (const CurveCreator::Dimension theDimension)
 Constructor of the curve. More...
virtual ~CurveCreator_Curve ()
virtual CurveCreator::Dimension getDimension () const
 Get the dimension. More...
virtual std::string getUniqSectionName () const
 Return unique section name. More...
virtual void setDisplayer (CurveCreator_Displayer *theDisplayer)
 Set curve creator Displayer object. More...
CurveCreator_Displayer * getDisplayer ()
 Return curve creator Displayer object. More...
virtual void removeDisplayer ()
 Remove curve creator Displayer object. More...
virtual void setUndoDepth (const int theDepth=-1)
 Set depth of undo operations (unlimited if theDepth is -1 or disabled if theDepth is 0) More...
virtual int getUndoDepth () const
 Get depth of undo operations. More...
virtual void finishOperation ()
virtual int toICoord (const int theIPnt) const
 This method converts the point index to the index in an array of coordinates. More...
virtual bool moveSectionInternal (const int theISection, const int theNewIndex)
 For internal use only! Undo/Redo are not used here. More...
virtual bool moveSection (const int theISection, const int theNewIndex)
 Move section to new position in list. More...
void getCoordinates (int theISection, int theIPoint, double &theX, double &theY, double &theZ) const
virtual int getNbUndo () const
 Get number of available undo operations. More...
virtual bool undo ()
 Undo previous operation. More...
virtual int getNbRedo () const
 Get number of available redo operations. More...
virtual bool redo ()
 Redo last previously "undone" operation. More...
virtual bool clearInternal ()
virtual bool clear ()
 Clear the polyline (remove all sections) More...
void SetEraseAllState (bool toEraseAll)
 set erase-all state if true => erase all objects from viever, else remove only the current curve More...
bool GetEraseAllState () const
 get erase-all state if true => erase all objects from viever, else remove only the current curve More...
virtual bool joinInternal (const std::list< int > &theSections)
virtual bool join (const std::list< int > &theSections)
 Join list of sections to one section (join all if the list is empty) More...
virtual int getNbSections () const
 Get number of sections. More...
virtual int addSectionInternal (const std::string &theName, const CurveCreator::SectionType theType, const bool theIsClosed, const CurveCreator::Coordinates &thePoints, const Quantity_Color &aColor)
virtual int addSection (const std::string &theName, const CurveCreator::SectionType theType, const bool theIsClosed)
 Add a new section. More...
virtual int addSection (const std::string &theName, const CurveCreator::SectionType theType, const bool theIsClosed, const CurveCreator::Coordinates &thePoints)
virtual bool removeSectionInternal (const int theISection)
virtual bool removeSection (const int theISection)
 Removes the given sections. More...
virtual bool isClosed (const int theISection) const
 Get "closed" flag of the specified section. More...
virtual bool setClosedInternal (const int theISection, const bool theIsClosed)
virtual bool setClosed (const int theISection, const bool theIsClosed)
 Set "closed" flag of the specified section (all sections if theISection is -1). More...
virtual bool setColorSection (int SectInd, Quantity_Color theNewColor)
 Sets color of section by index. More...
virtual void setColorSectionInternal (int SectInd, Quantity_Color theNewColor)
virtual Quantity_Color getLastRemovedColor () const
virtual void popLastRemovedColor ()
virtual Quantity_Color getColorSection (int SectInd) const
 Gets color of section by index. More...
virtual std::string getSectionName (const int theISection) const
 Returns specifyed section name. More...
virtual bool setSectionNameInternal (const int theISection, const std::string &theName)
virtual bool setSectionName (const int theISection, const std::string &theName)
 Set name of the specified section. More...
virtual CurveCreator::SectionType getSectionType (const int theISection) const
 Get type of the specified section. More...
virtual bool setSectionTypeInternal (const int theISection, const CurveCreator::SectionType theType)
virtual bool setSectionType (const int theISection, const CurveCreator::SectionType theType)
 Set type of the specified section (or all sections if theISection is -1). More...
const CurveCreator_ISection * getSection (const int theSectionIndex) const
 A virtual method. More...
virtual bool addPointsInternal (const CurveCreator::SectionsMap &theSectionsMap)
virtual bool addPoints (const CurveCreator::Coordinates &theCoords, const int theISection, const int theIPnt=-1)
 Add one point to the specified section starting from the given theIPnt index (or at the end of points if theIPnt is -1). More...
virtual bool setPointInternal (const CurveCreator::SectionsMap &theSectionsMap)
virtual bool setPoint (const int theISection, const int theIPnt, const CurveCreator::Coordinates &theNewCoords)
 Set coordinates of specified point. More...
virtual bool setSeveralPoints (const SectionToPointCoordsList &theSectionToPntCoords, const bool theIsToSaveDiff=true)
 Set coordinates of specified points from different sections. More...
virtual bool removePointsInternal (const SectionToPointList &thePoints)
virtual bool removePoint (const int theISection, const int theIPnt=-1)
 Remove point with given id. More...
virtual bool removeSeveralPoints (const SectionToPointList &theSectionToPntIDs)
 Remove several points from different sections with given ids. More...
virtual CurveCreator::Coordinates getPoint (const int theISection, const int theIPnt) const
 Get coordinates of specified point. More...
virtual Handle (TColgp_HArray1OfPnt) GetDifferentPoints(int theISection
 Get points of a section (the total points in Curve if theISection is equal to -1). More...
CurveCreator::Coordinates getCoords (int theISection=-1) const
virtual int getNbPoints (const int theISection) const
 Get number of points in specified section or (the total number of points in Curve if theISection is equal to -1). More...
virtual void setSkipSorting (const bool theIsToSkip)
 Set skip sorting flag. More...
virtual bool canPointsBeSorted ()
 Indicates whether the points can be sorted. More...
virtual void saveCoordDiff (const SectionToPointCoordsList &theOldCoords)
 Saves points coordinates difference. More...
virtual Handle (AIS_InteractiveObject) getAISObject(const bool theNeedToBuild
 Get the curve AIS object. More...
- Public Member Functions inherited from CurveCreator_ICurve
virtual ~CurveCreator_ICurve ()
 The destructor. More...
virtual int getNbUndo () const =0
virtual bool undo ()=0
virtual int getNbRedo () const =0
virtual bool redo ()=0
virtual bool clear ()=0
virtual bool join (const std::list< int > &theSections)=0
virtual int getNbSections () const =0
virtual int addSection (const std::string &theName, const CurveCreator::SectionType theType, const bool theIsClosed)=0
virtual bool removeSection (const int theISection)=0
virtual bool isClosed (const int theISection) const =0
virtual bool setClosed (const int theISection, const bool theIsClosed)=0
virtual std::string getSectionName (const int theISection) const =0
virtual bool setSectionName (const int theISection, const std::string &theName)=0
virtual CurveCreator::SectionType getSectionType (const int theISection) const =0
virtual bool setSectionType (const int theISection, const CurveCreator::SectionType theType)=0
virtual const CurveCreator_ISection * getSection (const int theSectionIndex) const =0
 Returns the curve section with the index. More...
virtual CurveCreator_ISection * getSection (const int theSectionIndex)=0
virtual CurveCreator::Dimension getDimension () const =0
virtual bool addPoints (const CurveCreator::Coordinates &theCoords, const int theISection, const int theIPnt=-1)=0
 Insert one or several points to the specified section starting from the given theIPnt index (or add these at the end of section points if theIPnt is -1). More...
virtual bool setPoint (const int theISection, const int theIPnt, const CurveCreator::Coordinates &theNewCoords)=0
virtual bool setSeveralPoints (const SectionToPointCoordsList &theSectionToPntCoords, const bool theIsToSaveDiff=true)=0
virtual bool removePoint (const int theISection, const int theIPnt=-1)=0
virtual bool removeSeveralPoints (const SectionToPointList &theSectionToPntIDs)=0
 Remove several points from different sections. More...
virtual CurveCreator::Coordinates getPoint (const int theISection, const int theIPnt) const =0
virtual int getNbPoints (const int theISection) const =0
virtual void setSkipSorting (const bool)=0
virtual bool canPointsBeSorted ()=0
virtual void saveCoordDiff (const SectionToPointCoordsList &theOldCoords)=0
Public Attributes
bool myIsLocked
CurveCreator::Sections mySections
 curve data More...
CurveCreator::Dimension myDimension
 curve dimension More...
CurveCreator_Displayer * myDisplayer
 curve displayer More...
Quantity_Color myPointAspectColor
double myLineWidth
NCollection_IndexedDataMap< int, TopoDS_Shape > mySect2Shape
std::vector< int > myCurSectInd
Protected Types
typedef std::list< CurveCreator_Diff > ListDiff
virtual bool addEmptyDiff ()
 This method updates all undo/redo information required to be updated after curve modification operation. More...
void redisplayCurve (bool preEraseAllObjects=true)
bool removeSectionPoints (const int theSectionId, const std::list< int > &thePointIds)
 Removes the points from the section. More...
void convert (const SectionToPointList &thePoints, std::map< int, std::list< int > > &theConvPoints)
 Converts the list of pairs of section to point into map of a section to list of points. More...
virtual void constructAISObject ()
virtual void constructAISObject ()=0
bool mySkipSorting
AIS_Shape * myAISShape
 AIS shape. More...
int myNbUndos
int myNbRedos
ListDiff::iterator myCurrenPos
ListDiff myListDiffs
int myUndoDepth
int myOpLevel
bool myEraseAll
std::vector< Quantity_Color > myRemColors
- Public Types inherited from CurveCreator_ICurve
typedef std::pair< int, int > SectionToPoint
typedef std::deque< SectionToPoint > SectionToPointList
typedef std::deque< std::pair< SectionToPoint, CurveCreator::Coordinates > > SectionToPointCoordsList
◆ ListDiff
typedef std::list<CurveCreator_Diff> CurveCreator_Curve::ListDiff
◆ CurveCreator_Curve()
CurveCreator_Curve::CurveCreator_Curve ( const CurveCreator::Dimension  theDimension)
The dimension is explicitly specified in the constructor and cannot be changed later.
◆ ~CurveCreator_Curve()
CurveCreator_Curve::~CurveCreator_Curve ( )
References clear().
◆ addEmptyDiff()
bool CurveCreator_Curve::addEmptyDiff ( )
It returns false if undo/redo is disabled and true otherwise.
References myCurrenPos, myListDiffs, myNbRedos, myNbUndos, and myUndoDepth.
◆ addPoints()
bool CurveCreator_Curve::addPoints ( const CurveCreator::Coordinates &  theCoords,
const int  theIPnt = -1
◆ addPointsInternal()
bool CurveCreator_Curve::addPointsInternal ( const CurveCreator::SectionsMap &  theSectionsMap)
◆ addSection() [1/2]
int CurveCreator_Curve::addSection ( const std::string &  theName,
◆ addSection() [2/2]
const CurveCreator::Coordinates &  thePoints
◆ addSectionInternal()
int CurveCreator_Curve::addSectionInternal ( const std::string &  theName,
const CurveCreator::Coordinates &  thePoints,
const Quantity_Color &  aColor
◆ canPointsBeSorted()
bool CurveCreator_Curve::canPointsBeSorted ( )
Implements CurveCreator_ICurve.
◆ clear()
bool CurveCreator_Curve::clear ( )
◆ clearInternal()
◆ constructAISObject()
virtual void CurveCreator_Curve::constructAISObject ( )
◆ convert()
void CurveCreator_Curve::convert ( const SectionToPointList &  thePoints,
std::map< int, std::list< int > > &  theConvPoints
thePointsan source list
theConvPointsa converted map
◆ finishOperation()
void CurveCreator_Curve::finishOperation ( )
References myOpLevel.
◆ getColorSection()
Quantity_Color CurveCreator_Curve::getColorSection ( int  SectInd) const
◆ getCoordinates()
void CurveCreator_Curve::getCoordinates ( int  theISection,
int  theIPoint,
double &  theX,
double &  theY,
double &  theZ
◆ getCoords()
CurveCreator::Coordinates CurveCreator_Curve::getCoords ( int  theISection = -1) const
◆ getDimension()
CurveCreator::Dimension CurveCreator_Curve::getDimension ( ) const
References myDimension.
◆ getDisplayer()
CurveCreator_Displayer * CurveCreator_Curve::getDisplayer ( )
References myDisplayer.
◆ GetEraseAllState()
bool CurveCreator_Curve::GetEraseAllState ( ) const
References myEraseAll.
◆ getLastRemovedColor()
Quantity_Color CurveCreator_Curve::getLastRemovedColor ( ) const
References myRemColors.
◆ getNbPoints()
int CurveCreator_Curve::getNbPoints ( const int  theISection) const
◆ getNbRedo()
int CurveCreator_Curve::getNbRedo ( ) const
References myNbRedos.
◆ getNbSections()
int CurveCreator_Curve::getNbSections ( ) const
References mySections.
◆ getNbUndo()
int CurveCreator_Curve::getNbUndo ( ) const
References myNbUndos.
◆ getPoint()
CurveCreator::Coordinates CurveCreator_Curve::getPoint ( const int  theISection,
const int  theIPnt
◆ getSection() [1/2]
CurveCreator_ISection * CurveCreator_Curve::getSection ( const int  theSectionIndex)
◆ getSection() [2/2]
const CurveCreator_ISection * CurveCreator_Curve::getSection ( const int  theSectionIndex) const
◆ getSectionName()
std::string CurveCreator_Curve::getSectionName ( const int  theISection) const
Returns specified section name.
References getSection(), and CurveCreator_Section::myName.
◆ getSectionType()
CurveCreator::SectionType CurveCreator_Curve::getSectionType ( const int  theISection) const
◆ getUndoDepth()
int CurveCreator_Curve::getUndoDepth ( ) const
References myUndoDepth.
◆ getUniqSectionName()
std::string CurveCreator_Curve::getUniqSectionName ( ) const
◆ Handle() [1/2]
virtual CurveCreator_Curve::Handle ( AIS_InteractiveObject  ) const
Reimplemented from CurveCreator_ICurve.
◆ Handle() [2/2]
virtual CurveCreator_Curve::Handle ( TColgp_HArray1OfPnt  )
◆ isClosed()
bool CurveCreator_Curve::isClosed ( const int  theISection) const
◆ join()
bool CurveCreator_Curve::join ( const std::list< int > &  theSections)
◆ joinInternal()
bool CurveCreator_Curve::joinInternal ( const std::list< int > &  theSections)
◆ moveSection()
bool CurveCreator_Curve::moveSection ( const int  theISection,
◆ moveSectionInternal()
bool CurveCreator_Curve::moveSectionInternal ( const int  theISection,
References getSection(), and mySections.
◆ popLastRemovedColor()
void CurveCreator_Curve::popLastRemovedColor ( )
◆ redisplayCurve()
void CurveCreator_Curve::redisplayCurve ( bool  preEraseAllObjects = true)
◆ redo()
bool CurveCreator_Curve::redo ( )
References myCurrenPos, myNbRedos, and myNbUndos.
◆ removeDisplayer()
void CurveCreator_Curve::removeDisplayer ( )
◆ removePoint()
bool CurveCreator_Curve::removePoint ( const int  theISection,
◆ removePointsInternal()
bool CurveCreator_Curve::removePointsInternal ( const SectionToPointList &  thePoints)
◆ removeSection()
bool CurveCreator_Curve::removeSection ( const int  theISection)
◆ removeSectionInternal()
bool CurveCreator_Curve::removeSectionInternal ( const int  theISection)
◆ removeSectionPoints()
bool CurveCreator_Curve::removeSectionPoints ( const int  theSectionId,
const std::list< int > &  thePointIds
It sortes the points and remove them in the decreasing order
theSectionIda section index
thePointIdsa list of section points
◆ removeSeveralPoints()
bool CurveCreator_Curve::removeSeveralPoints ( const SectionToPointList &  theSectionToPntIDs)
◆ saveCoordDiff()
void CurveCreator_Curve::saveCoordDiff ( const SectionToPointCoordsList &  theOldCoords)
theOldCoordsthe old points coordinates
References addEmptyDiff(), finishOperation(), myListDiffs, and startOperation().
◆ setClosed()
bool CurveCreator_Curve::setClosed ( const int  theISection,
◆ setClosedInternal()
bool CurveCreator_Curve::setClosedInternal ( const int  theISection,
◆ setColorSection()
bool CurveCreator_Curve::setColorSection ( int  SectInd,
◆ setColorSectionInternal()
void CurveCreator_Curve::setColorSectionInternal ( int  SectInd,
◆ setDisplayer()
void CurveCreator_Curve::setDisplayer ( CurveCreator_Displayer *  theDisplayer)
◆ SetEraseAllState()
void CurveCreator_Curve::SetEraseAllState ( bool  toEraseAll)
◆ setPoint()
bool CurveCreator_Curve::setPoint ( const int  theISection,
const int  theIPnt,
const CurveCreator::Coordinates &  theNewCoords
◆ setPointInternal()
bool CurveCreator_Curve::setPointInternal ( const CurveCreator::SectionsMap &  theSectionsMap)
◆ setSectionName()
bool CurveCreator_Curve::setSectionName ( const int  theISection,
◆ setSectionNameInternal()
bool CurveCreator_Curve::setSectionNameInternal ( const int  theISection,
◆ setSectionType()
bool CurveCreator_Curve::setSectionType ( const int  theISection,
◆ setSectionTypeInternal()
bool CurveCreator_Curve::setSectionTypeInternal ( const int  theISection,
◆ setSeveralPoints()
bool CurveCreator_Curve::setSeveralPoints ( const SectionToPointCoordsList &  theSectionToPntCoords,
const bool  theIsToSaveDiff = true
◆ setSkipSorting()
void CurveCreator_Curve::setSkipSorting ( const bool  theIsToSkip)
If the flag is true - points sorting will be skipped.
References mySkipSorting.
◆ setUndoDepth()
void CurveCreator_Curve::setUndoDepth ( const int  theDepth = -1)
◆ startOperation()
void CurveCreator_Curve::startOperation ( )
◆ toICoord()
int CurveCreator_Curve::toICoord ( const int  theIPnt) const
◆ undo()
bool CurveCreator_Curve::undo ( )
◆ myAISShape
AIS_Shape* CurveCreator_Curve::myAISShape
◆ myCurrenPos
ListDiff::iterator CurveCreator_Curve::myCurrenPos
◆ myCurSectInd
std::vector<int> CurveCreator_Curve::myCurSectInd
◆ myDimension
CurveCreator::Dimension CurveCreator_Curve::myDimension
◆ myDisplayer
CurveCreator_Displayer* CurveCreator_Curve::myDisplayer
◆ myEraseAll
bool CurveCreator_Curve::myEraseAll
◆ myIsLocked
bool CurveCreator_Curve::myIsLocked
◆ myLineWidth
double CurveCreator_Curve::myLineWidth
◆ myListDiffs
ListDiff CurveCreator_Curve::myListDiffs
◆ myNbRedos
int CurveCreator_Curve::myNbRedos
◆ myNbUndos
int CurveCreator_Curve::myNbUndos
◆ myOpLevel
int CurveCreator_Curve::myOpLevel
◆ myPointAspectColor
Quantity_Color CurveCreator_Curve::myPointAspectColor
◆ myRemColors
std::vector<Quantity_Color> CurveCreator_Curve::myRemColors
◆ mySect2Shape
NCollection_IndexedDataMap<int, TopoDS_Shape> CurveCreator_Curve::mySect2Shape
◆ mySections
CurveCreator::Sections CurveCreator_Curve::mySections
◆ mySkipSorting
bool CurveCreator_Curve::mySkipSorting
◆ myUndoDepth
int CurveCreator_Curve::myUndoDepth
