CurveCreator_Operation Class Reference
This is the support class that describes a modification operation that can be applied to CurveCreator_Curve.
#include <CurveCreator_Operation.hxx>
enum  Type {
  Unknown = 0 , AddPoints , RemovePoints , InsertPoints ,
  SetType , Clear , SetCoordinates , SetClosed ,
  MoveSection , Join , AddSection , RemoveSection ,
  RenameSection , SetColorSection
 This is a type of CurveCreator_Curve modification operation. More...
 CurveCreator_Operation ()
 Empty constructor. More...
 ~CurveCreator_Operation ()
bool init (const Type theType)
 This method initializes the object with an operation without parameters. More...
bool init (const Type theType, const int theIntParam)
 This method initializes the object with an operation with one integer parameter. More...
bool init (const Type theType, const int theIntParam1, const int theIntParam2)
 This method initializes the object with an operation with two integer parameters. More...
bool init (const Type theType, const int theIntParam1, const int theIntParam2[3])
 This method initializes the object with an operation with 4 integer parameter (1 as first param + 3 as interger array) More...
bool init (const Type theType, const std::list< int > theParamList)
bool init (const Type theType, const CurveCreator_ICurve::SectionToPointList &theParamList1)
 This method initializes the object with an operation with list of pairs of integer parameters. More...
bool init (const Type theType, const CurveCreator::Coordinates &theCoords, const int theIntParam)
 This method initializes the object with an operation with one CurveCreator::Coordinates parameter and one integer parameter. More...
bool init (const Type theType, const CurveCreator_ICurve::SectionToPointCoordsList &theParamList1)
 This method initializes the object with an operation with list of pairs of integer parameters and CurveCreator::Coordinates parameters. More...
bool init (const CurveCreator_Operation::Type theType, const std::string &theName, const CurveCreator::Coordinates &theCoords, const int theIntParam1, const int theIntParam2)
 This method initializes the object with an operation with one string, one CurveCreator::Coordinates parameter and two integer parameters. More...
bool init (const CurveCreator_Operation::Type theType, const std::string &theName, const int theIntParam1)
 This method initializes the object with an operation with one string parameter and one integer. More...
void apply (CurveCreator_Curve *theCurve)
 This method applies the current operation to theCurve. More...
void * allocate (const size_t theSize)
 This method allocates required memory for the operation data. More...
void clear ()
 This method clears initialized data pointers. More...
void getCoords (int *thePInt, CurveCreator::Coordinates &theCoords) const
 This method returns the coordinates read from thePInt. More...
Type myType
void * myPData
◆ Type
Unknown
Unknown method.
AddPoints
Method CurveCreator_Curve::addPoints.
RemovePoints
Method CurveCreator_Curve::removePoints.
InsertPoints
Method CurveCreator_Curve::insertPoints.
SetType
Method CurveCreator_Curve::setType.
Clear
Method CurveCreator_Curve::clear.
SetCoordinates
Method CurveCreator_Curve::setCoordinates.
SetClosed
Method CurveCreator_Curve::setClosed.
MoveSection
Method CurveCreator_Curve::moveSection.
Join
Method CurveCreator_Curve::join.
AddSection
Method CurveCreator_Curve::addSection.
RemoveSection
Method CurveCreator_Curve::removeSection.
RenameSection
Method CurveCreator_Curve::renameSection.
SetColorSection
Method CurveCreator_Curve::setColorSection.
◆ CurveCreator_Operation()
CurveCreator_Operation::CurveCreator_Operation ( )
◆ ~CurveCreator_Operation()
CurveCreator_Operation::~CurveCreator_Operation ( )
References clear().
◆ allocate()
void * CurveCreator_Operation::allocate ( const size_t  theSize)
Returns myPData for convenience purpose.
References clear(), and myPData.
◆ apply()
◆ clear()
void CurveCreator_Operation::clear ( )
References myPData, myType, and Unknown.
◆ getCoords()
void CurveCreator_Operation::getCoords ( int *  thePInt,
CurveCreator::Coordinates &  theCoords
◆ init() [1/10]
bool CurveCreator_Operation::init ( const CurveCreator_Operation::Type  theType,
const std::string &  theName,
const CurveCreator::Coordinates &  theCoords,
It is applicable to the following operations:
  • AddSection
  • InsertPoints
  • SetCoordinates
true in case of success; false otherwise.
References AddSection, allocate(), and myType.
◆ init() [2/10]
  • RenameSection
References allocate(), myType, and RenameSection.
◆ init() [3/10]
bool CurveCreator_Operation::init ( const Type  theType)
  • Clear
References Clear, clear(), and myType.
◆ init() [4/10]
bool CurveCreator_Operation::init ( const Type  theType,
  • AddPoints
References AddPoints, allocate(), and myType.
◆ init() [5/10]
const CurveCreator_ICurve::SectionToPointCoordsList &  theParamList1
  • InsertPoints
References allocate(), InsertPoints, myType, and SetCoordinates.
◆ init() [6/10]
const CurveCreator_ICurve::SectionToPointList &  theParamList1
  • RemovePoints
References allocate(), myType, and RemovePoints.
◆ init() [7/10]
  • RemoveSection
References allocate(), myType, and RemoveSection.
◆ init() [8/10]
  • SetType
  • SetClosed
  • MoveSection
  • Join (with 2 int arguments)
References allocate(), Join, MoveSection, myType, SetClosed, and SetType.
◆ init() [9/10]
References allocate(), myType, and SetColorSection.
◆ init() [10/10]
  • Join (with a list of int arguments)
References allocate(), Join, and myType.
◆ myPData
void* CurveCreator_Operation::myPData
◆ myType
Type CurveCreator_Operation::myType
