CurveCreator_Diff Class Reference
This is the support class for store/retrieve differences of undo/redo operations. More...
#include <CurveCreator_Diff.hxx>
 CurveCreator_Diff ()
 ~CurveCreator_Diff ()
bool init (const CurveCreator_Curve *theCurve)
 This method initializes the difference with an operation without parameters. More...
bool init (const CurveCreator_Curve *theCurve, const CurveCreator_Operation::Type theType, const int theIntParam)
 This method initializes the difference with an operation with one integer parameter. More...
bool init (const CurveCreator_Curve *theCurve, const CurveCreator_Operation::Type theType, const int theIntParam1, const int theIntParam2)
 This method initializes the difference with an operation with two integer parameters. More...
bool init (const CurveCreator_Curve *theCurve, const CurveCreator_Operation::Type theType, const std::list< int > &theParams)
bool init (const CurveCreator_Curve *theCurve, const CurveCreator_Operation::Type theType, const std::string &theName, const CurveCreator::Coordinates &theCoords, const int theIntParam1, const int theIntParam2)
 This method initializes the difference with an operation with one Name, one CurveCreator::Coordinates parameter and two integer parameters. More...
bool init (const CurveCreator_Curve *theCurve, const CurveCreator_Operation::Type theType, const std::string &theName, const int theIntParam1)
 This method initializes the difference with an operation with one string and one integer parameters. More...
bool init (const CurveCreator_Curve *theCurve, const CurveCreator_Operation::Type theType, const CurveCreator_ICurve::SectionToPointList &theParamList)
 This method initializes the difference with an operation with list of pairs of integer parameters. More...
bool init (const CurveCreator_Curve *theCurve, const CurveCreator_Operation::Type theType, const CurveCreator_ICurve::SectionToPointCoordsList &theParamList)
 This method initializes the difference with an operation with list of pairs of integer parameters with point coordinates. More...
bool init (const CurveCreator_Curve *theCurve, const CurveCreator_ICurve::SectionToPointCoordsList &theOldParamList)
bool init (const CurveCreator_Curve *theCurve, const CurveCreator_Operation::Type theType, const int theIntParam1, const int theIntParam2[3])
 This method initializes the difference with an operation with one integer and one array of integer[3] parameters. More...
void applyUndo (CurveCreator_Curve *theCurve)
 This method applies undo operation to theCurve. More...
void applyRedo (CurveCreator_Curve *theCurve)
 This method applies redo operation to theCurve. More...
void clear ()
 This method clears initialized data pointers. More...
void setNbUndos (const int theNbUndos)
 This method sets the number of undos and allocates the required space for myPUndo. More...
int getSectionIndex (const CurveCreator_Curve *theCurve, const int theIndex) const
 This method returns the section index. More...
bool addSectionToUndo (const CurveCreator_Curve *theCurve, const int theIndex, CurveCreator_Operation &theOperation) const
 Convert theIndex'th section of theCurve into AddSection command and store it in theOperation. More...
bool setTypeOrClosedToUndo (const CurveCreator_Curve *theCurve, const CurveCreator_Operation::Type theType, const int theIntParam1, const int theIntParam2)
 Construct undos for SetType and SetClosed operations. More...
int myNbUndos
CurveCreator_Operation * myPUndo
CurveCreator_Operation * myPRedo
To fill the difference it is necessary to create it with an appropriate type and to call the method initialize with required parameters.
◆ CurveCreator_Diff()
CurveCreator_Diff::CurveCreator_Diff ( )
◆ ~CurveCreator_Diff()
CurveCreator_Diff::~CurveCreator_Diff ( )
References clear().
◆ addSectionToUndo()
bool CurveCreator_Diff::addSectionToUndo ( const CurveCreator_Curve *  theCurve,
const int  theIndex,
CurveCreator_Operation &  theOperation
◆ applyRedo()
void CurveCreator_Diff::applyRedo ( CurveCreator_Curve *  theCurve)
◆ applyUndo()
void CurveCreator_Diff::applyUndo ( CurveCreator_Curve *  theCurve)
◆ clear()
void CurveCreator_Diff::clear ( )
References myNbUndos, myPRedo, and myPUndo.
◆ getSectionIndex()
int CurveCreator_Diff::getSectionIndex ( const CurveCreator_Curve *  theCurve,
const int  theIndex
It returns theIndex if it is a real index and the last section's index if theIndex is equal to -1.
References CurveCreator_Curve::getNbSections().
◆ init() [1/10]
bool CurveCreator_Diff::init ( const CurveCreator_Curve *  theCurve)
◆ init() [2/10]
bool CurveCreator_Diff::init ( const CurveCreator_Curve *  theCurve,
const CurveCreator_ICurve::SectionToPointCoordsList &  theOldParamList
theCurvethe modified curve
theOldParamListthe old parameters (to be saved for undo)
References clear(), CurveCreator_Curve::getPoint(), CurveCreator_Operation::init(), myPRedo, myPUndo, CurveCreator_Operation::SetCoordinates, and setNbUndos().
◆ init() [3/10]
◆ init() [4/10]
const CurveCreator_ICurve::SectionToPointList &  theParamList
◆ init() [5/10]
◆ init() [6/10]
◆ init() [7/10]
It is applicable to the following operations:
  • ColorSection
References clear(), CurveCreator_Utils::colorConv(), CurveCreator_Curve::getColorSection(), CurveCreator_Operation::init(), myPRedo, myPUndo, and setNbUndos().
◆ init() [8/10]
const std::list< int > &  theParams
◆ init() [9/10]
const std::string &  theName,
const CurveCreator::Coordinates &  theCoords,
◆ init() [10/10]
◆ setNbUndos()
void CurveCreator_Diff::setNbUndos ( const int  theNbUndos)
References myNbUndos, and myPUndo.
◆ setTypeOrClosedToUndo()
bool CurveCreator_Diff::setTypeOrClosedToUndo ( const CurveCreator_Curve *  theCurve,
Note: the algorithm is optimized taking into account that there are only 2 types and 2 values of isClosed flag. If the number of types is increased, this algorithm should be re-implemented.
References CurveCreator_Curve::getNbSections(), CurveCreator_Curve::getSectionType(), CurveCreator_Operation::init(), CurveCreator_Curve::isClosed(), myPUndo, setNbUndos(), and CurveCreator_Operation::SetType.
◆ myNbUndos
int CurveCreator_Diff::myNbUndos
◆ myPRedo
CurveCreator_Operation* CurveCreator_Diff::myPRedo
◆ myPUndo
CurveCreator_Operation* CurveCreator_Diff::myPUndo
