GEOMImpl_IBasicOperations Class Referenceabstract
#include <GEOMImpl_IBasicOperations.hxx>
Inheritance diagram for GEOMImpl_IBasicOperations:
Standard_EXPORT GEOMImpl_IBasicOperations (GEOM_Engine *theEngine)
Standard_EXPORT ~GEOMImpl_IBasicOperations ()
Standard_EXPORT Handle (GEOM_Object) MakePointXYZ(double theX
Standard_EXPORT Handle (GEOM_Object) MakePointWithReference(Handle(GEOM_Object) theReference
Standard_EXPORT Handle (GEOM_Object) MakePointOnCurve(Handle(GEOM_Object) theCurve
Standard_EXPORT Handle (GEOM_Object) MakePointOnCurveByLength(Handle(GEOM_Object) theCurve
Standard_EXPORT double Handle (GEOM_Object) theStartPoint)
Standard_EXPORT Handle (GEOM_Object) MakePointOnCurveByCoord(Handle(GEOM_Object) theCurve
Standard_EXPORT Handle (GEOM_Object) MakePointOnLinesIntersection(Handle(GEOM_Object) theLine1
Standard_EXPORT Handle (GEOM_Object) theLine2)
Standard_EXPORT Handle (GEOM_Object) MakePointOnSurface(Handle(GEOM_Object) theSurface
Standard_EXPORT Handle (GEOM_Object) MakePointOnSurfaceByCoord(Handle(GEOM_Object) theSurface
Standard_EXPORT Handle (GEOM_Object) MakePointOnFace(Handle(GEOM_Object) theFace
Standard_EXPORT Handle (GEOM_Object) MakeVectorDXDYDZ(double theDX
Standard_EXPORT Handle (GEOM_Object) MakeVectorTwoPnt(Handle(GEOM_Object) thePnt1
Standard_EXPORT Handle (GEOM_Object) thePnt2)
Standard_EXPORT Handle (GEOM_Object) MakeTangentOnCurve(const Handle(GEOM_Object) &theCurve
Standard_EXPORT Handle (GEOM_Object) MakeLineTwoPnt(Handle(GEOM_Object) thePnt1
Standard_EXPORT Handle (GEOM_Object) MakeLineTwoFaces(Handle(GEOM_Object) theFace1
Standard_EXPORT Handle (GEOM_Object) theFace2)
Standard_EXPORT Handle (GEOM_Object) MakeLine(Handle(GEOM_Object) thePnt
Standard_EXPORT Handle (GEOM_Object) theDir)
Standard_EXPORT Handle (GEOM_Object) MakePlaneThreePnt(Handle(GEOM_Object) thePnt1
Standard_EXPORT Handle (GEOM_Object) thePnt3
Standard_EXPORT Handle (GEOM_Object) MakePlanePntVec(Handle(GEOM_Object) thePnt
Standard_EXPORT Handle (GEOM_Object) theVec
Standard_EXPORT Handle (GEOM_Object) MakePlaneFace(Handle(GEOM_Object) theFace
Standard_EXPORT Handle (GEOM_Object) MakePlane2Vec(Handle(GEOM_Object) theVec1
Standard_EXPORT Handle (GEOM_Object) theVec2
Standard_EXPORT Handle (GEOM_Object) MakePlaneLCS(Handle(GEOM_Object) theFace
Standard_EXPORT Handle (GEOM_Object) MakeMarker(double theOX
Standard_EXPORT Handle (GEOM_Object) MakeMarkerFromShape(const Handle(GEOM_Object) &theShape)
Standard_EXPORT Handle (GEOM_Object) MakeMarkerPntTwoVec(const Handle(GEOM_Object) &theOrigin
Standard_EXPORT const Handle (GEOM_Object) &theXVec
Standard_EXPORT const const Handle (GEOM_Object) &theYVec)
Standard_EXPORT Handle (GEOM_Object) MakeTangentPlaneOnFace(const Handle(GEOM_Object) &theFace
- Public Member Functions inherited from GEOM_IOperations
Standard_EXPORT GEOM_IOperations (GEOM_Engine *theEngine)
Standard_EXPORT ~GEOM_IOperations ()
Standard_EXPORT void StartOperation ()
Standard_EXPORT void FinishOperation ()
Standard_EXPORT void AbortOperation ()
Standard_EXPORT bool IsDone ()
Standard_EXPORT void SetNotDone ()
Standard_EXPORT void SetErrorCode (const TCollection_AsciiString &theErrorCode)
Standard_EXPORT char * GetErrorCode ()
Standard_EXPORT GEOM_Engine * GetEngine ()
Standard_EXPORT GEOM_Solver * GetSolver ()
Public Attributes
Standard_EXPORT double theY
Standard_EXPORT double double theZ
Standard_EXPORT double theX
Standard_EXPORT double double theY
Standard_EXPORT double double double theZ
Standard_EXPORT double theParameter
Standard_EXPORT double bool takeOrientationIntoAccount
Standard_EXPORT double theLength
Standard_EXPORT double theXParam
Standard_EXPORT double double theYParam
Standard_EXPORT double double double theZParam
Standard_EXPORT double theUParameter
Standard_EXPORT double double theVParameter
Standard_EXPORT int theNumberOfPnts
Standard_EXPORT double theDY
Standard_EXPORT double double theDZ
Standard_EXPORT double theSize
Standard_EXPORT double int theOrientation
Standard_EXPORT double theOY
Standard_EXPORT double double theOZ
Standard_EXPORT double double double theXDX
Standard_EXPORT double double double double theXDY
Standard_EXPORT double double double double double theXDZ
Standard_EXPORT double double double double double double theYDX
Standard_EXPORT double double double double double double double theYDY
Standard_EXPORT double double double double double double double double theYDZ
Standard_EXPORT double theParamU
Standard_EXPORT double double theParamV
Standard_EXPORT double double double theSize
Private Types
enum  PointLocation {
  PointOn_CurveByParam , PointOn_CurveByCoord , PointOn_CurveByLength , PointOn_SurfaceByParam ,
  PointOn_SurfaceByCoord , PointOn_Face
 Enumeration describes point position on geometric object (curve or surface) Point location can be determined by parameter (or U, V parameters) or 3D coordinates. More...
 Handle (GEOM_Object) makePointOnGeom(Handle(GEOM_Object) theGeomObj
double double double const PointLocation int const bool Handle (GEOM_Object) theRefPoint=0)
double theParam1
double double theParam2
double double double theParam3
double double double const PointLocation theLocation
double double double const PointLocation int theNumberOfPnts = 1
double double double const PointLocation int const bool takeOrientationIntoAccount = false
◆ PointLocation
PointOn_Face
◆ GEOMImpl_IBasicOperations()
GEOMImpl_IBasicOperations::GEOMImpl_IBasicOperations ( GEOM_Engine *  theEngine)
constructor:
◆ ~GEOMImpl_IBasicOperations()
GEOMImpl_IBasicOperations::~GEOMImpl_IBasicOperations ( )
destructor
◆ Handle() [1/38]
Standard_EXPORT const GEOMImpl_IBasicOperations::Handle ( GEOM_Object  ) &
◆ Handle() [2/38]
Standard_EXPORT const const GEOMImpl_IBasicOperations::Handle ( GEOM_Object  ) &
◆ Handle() [3/38]
Standard_EXPORT GEOMImpl_IBasicOperations::Handle ( GEOM_Object  )
◆ Handle() [4/38]
◆ Handle() [5/38]
◆ Handle() [6/38]
◆ Handle() [7/38]
Standard_EXPORT GEOMImpl_IBasicOperations::Handle ( GEOM_Object  ) const &
◆ Handle() [8/38]
◆ Handle() [9/38]
◆ Handle() [10/38]
◆ Handle() [11/38]
◆ Handle() [12/38]
◆ Handle() [13/38]
◆ Handle() [14/38]
◆ Handle() [15/38]
◆ Handle() [16/38]
◆ Handle() [17/38]
◆ Handle() [18/38]
◆ Handle() [19/38]
◆ Handle() [20/38]
◆ Handle() [21/38]
◆ Handle() [22/38]
◆ Handle() [23/38]
◆ Handle() [24/38]
◆ Handle() [25/38]
◆ Handle() [26/38]
◆ Handle() [27/38]
◆ Handle() [28/38]
◆ Handle() [29/38]
◆ Handle() [30/38]
◆ Handle() [31/38]
◆ Handle() [32/38]
◆ Handle() [33/38]
◆ Handle() [34/38]
◆ Handle() [35/38]
double double double const PointLocation int const bool GEOMImpl_IBasicOperations::Handle ( GEOM_Object  )
privatepure virtual
◆ Handle() [36/38]
Standard_EXPORT double GEOMImpl_IBasicOperations::Handle ( GEOM_Object  )
◆ Handle() [37/38]
◆ Handle() [38/38]
◆ takeOrientationIntoAccount [1/2]
Standard_EXPORT double bool GEOMImpl_IBasicOperations::takeOrientationIntoAccount
◆ takeOrientationIntoAccount [2/2]
double double double const PointLocation int const bool GEOMImpl_IBasicOperations::takeOrientationIntoAccount = false
◆ theDY
Standard_EXPORT double GEOMImpl_IBasicOperations::theDY
◆ theDZ
Standard_EXPORT double double GEOMImpl_IBasicOperations::theDZ
◆ theLength
Standard_EXPORT double GEOMImpl_IBasicOperations::theLength
◆ theLocation
double double double const PointLocation GEOMImpl_IBasicOperations::theLocation
◆ theNumberOfPnts [1/2]
Standard_EXPORT int GEOMImpl_IBasicOperations::theNumberOfPnts
◆ theNumberOfPnts [2/2]
double double double const PointLocation int GEOMImpl_IBasicOperations::theNumberOfPnts = 1
◆ theOrientation
Standard_EXPORT double int GEOMImpl_IBasicOperations::theOrientation
◆ theOY
Standard_EXPORT double GEOMImpl_IBasicOperations::theOY
◆ theOZ
Standard_EXPORT double double GEOMImpl_IBasicOperations::theOZ
◆ theParam1
double GEOMImpl_IBasicOperations::theParam1
◆ theParam2
double double GEOMImpl_IBasicOperations::theParam2
◆ theParam3
double double double GEOMImpl_IBasicOperations::theParam3
◆ theParameter
Standard_EXPORT double GEOMImpl_IBasicOperations::theParameter
◆ theParamU
Standard_EXPORT double GEOMImpl_IBasicOperations::theParamU
◆ theParamV
Standard_EXPORT double double GEOMImpl_IBasicOperations::theParamV
◆ theSize [1/2]
Standard_EXPORT double GEOMImpl_IBasicOperations::theSize
◆ theSize [2/2]
Standard_EXPORT double double double GEOMImpl_IBasicOperations::theSize
◆ theUParameter
Standard_EXPORT double GEOMImpl_IBasicOperations::theUParameter
◆ theVParameter
Standard_EXPORT double double GEOMImpl_IBasicOperations::theVParameter
◆ theX
Standard_EXPORT double GEOMImpl_IBasicOperations::theX
◆ theXDX
Standard_EXPORT double double double GEOMImpl_IBasicOperations::theXDX
◆ theXDY
Standard_EXPORT double double double double GEOMImpl_IBasicOperations::theXDY
◆ theXDZ
Standard_EXPORT double double double double double GEOMImpl_IBasicOperations::theXDZ
◆ theXParam
Standard_EXPORT double GEOMImpl_IBasicOperations::theXParam
◆ theY [1/2]
Standard_EXPORT double GEOMImpl_IBasicOperations::theY
◆ theY [2/2]
Standard_EXPORT double double GEOMImpl_IBasicOperations::theY
◆ theYDX
Standard_EXPORT double double double double double double GEOMImpl_IBasicOperations::theYDX
◆ theYDY
Standard_EXPORT double double double double double double double GEOMImpl_IBasicOperations::theYDY
◆ theYDZ
Standard_EXPORT double double double double double double double double GEOMImpl_IBasicOperations::theYDZ
◆ theYParam
Standard_EXPORT double double GEOMImpl_IBasicOperations::theYParam
◆ theZ [1/2]
Standard_EXPORT double double GEOMImpl_IBasicOperations::theZ
◆ theZ [2/2]
Standard_EXPORT double double double GEOMImpl_IBasicOperations::theZ
◆ theZParam
Standard_EXPORT double double double GEOMImpl_IBasicOperations::theZParam
