GEOMImpl_IBlocksOperations Class Reference
#include <GEOMImpl_IBlocksOperations.hxx>
Inheritance diagram for GEOMImpl_IBlocksOperations:
struct  BCError
enum  BCErrorType {
  NOT_BLOCK , EXTRA_EDGE , INVALID_CONNECTION , NOT_CONNECTED ,
  NOT_GLUED
Standard_EXPORT GEOMImpl_IBlocksOperations (GEOM_Engine *theEngine)
Standard_EXPORT ~GEOMImpl_IBlocksOperations ()
Standard_EXPORT Handle (GEOM_Object) MakeQuad(Handle(GEOM_Object) theEdge1
Standard_EXPORT Handle (GEOM_Object) theEdge2
Standard_EXPORT Handle (GEOM_Object) theEdge3
Standard_EXPORT Handle (GEOM_Object) theEdge4)
Standard_EXPORT Handle (GEOM_Object) MakeQuad2Edges(Handle(GEOM_Object) theEdge1
Standard_EXPORT Handle (GEOM_Object) theEdge2)
Standard_EXPORT Handle (GEOM_Object) MakeQuad4Vertices(Handle(GEOM_Object) thePoint1
Standard_EXPORT Handle (GEOM_Object) thePoint2
Standard_EXPORT Handle (GEOM_Object) thePoint3
Standard_EXPORT Handle (GEOM_Object) thePoint4)
Standard_EXPORT Handle (GEOM_Object) MakeHexa(Handle(GEOM_Object) theFace1
Standard_EXPORT Handle (GEOM_Object) theFace2
Standard_EXPORT Handle (GEOM_Object) theFace3
Standard_EXPORT Handle (GEOM_Object) theFace4
Standard_EXPORT Handle (GEOM_Object) theFace5
Standard_EXPORT Handle (GEOM_Object) theFace6)
Standard_EXPORT Handle (GEOM_Object) MakeHexa2Faces(Handle(GEOM_Object) theFace1
Standard_EXPORT Handle (GEOM_Object) theFace2)
Standard_EXPORT Handle (GEOM_Object) MakeBlockCompound(Handle(GEOM_Object) theCompound)
Standard_EXPORT Handle (GEOM_Object) GetPoint(Handle(GEOM_Object) theShape
Standard_EXPORT Handle (GEOM_Object) GetVertexNearPoint(Handle(GEOM_Object) theShape
Standard_EXPORT Handle (GEOM_Object) thePoint)
Standard_EXPORT Handle (GEOM_Object) GetEdge(Handle(GEOM_Object) theShape
Standard_EXPORT Handle (GEOM_Object) thePoint1
Standard_EXPORT Handle (GEOM_Object) thePoint2)
Standard_EXPORT Handle (GEOM_Object) GetEdgeNearPoint(Handle(GEOM_Object) theBlock
Standard_EXPORT Handle (GEOM_Object) GetFaceByPoints(Handle(GEOM_Object) theShape
Standard_EXPORT Handle (GEOM_Object) GetFaceByEdges(Handle(GEOM_Object) theShape
Standard_EXPORT Handle (GEOM_Object) theEdge1
Standard_EXPORT Handle (GEOM_Object) GetOppositeFace(Handle(GEOM_Object) theBlock
Standard_EXPORT Handle (GEOM_Object) theFace)
Standard_EXPORT Handle (GEOM_Object) GetFaceNearPoint(Handle(GEOM_Object) theBlock
Standard_EXPORT Handle (GEOM_Object) GetFaceByNormale(Handle(GEOM_Object) theBlock
Standard_EXPORT Handle (GEOM_Object) theVector)
Standard_EXPORT Handle (GEOM_Object) GetShapesNearPoint(Handle(GEOM_Object) theShape
Standard_EXPORT Standard_Boolean IsCompoundOfBlocks (Handle(GEOM_Object) theCompound, const Standard_Integer theMinNbFaces, const Standard_Integer theMaxNbFaces, Standard_Integer &theNbBlocks)
Standard_EXPORT Standard_Boolean CheckCompoundOfBlocks (Handle(GEOM_Object) theCompound, const Standard_Real theToleranceC1, std::list< BCError > &theErrors)
Standard_EXPORT TCollection_AsciiString PrintBCErrors (Handle(GEOM_Object) theCompound, const std::list< BCError > &theErrors)
Standard_EXPORT Handle (GEOM_Object) GetNonBlocks(Handle(GEOM_Object) theShape
Standard_EXPORT const Standard_Real Handle (GEOM_Object) &theNonQuads)
Standard_EXPORT Handle (GEOM_Object) RemoveExtraEdges(Handle(GEOM_Object) theShape
Standard_EXPORT Handle (GEOM_Object) UnionFaces(Handle(GEOM_Object) theShape)
Standard_EXPORT Handle (GEOM_Object) CheckAndImprove(Handle(GEOM_Object) theCompound)
Standard_EXPORT Handle (TColStd_HSequenceOfTransient) ExplodeCompoundOfBlocks(Handle(GEOM_Object) theCompound
Standard_EXPORT Handle (GEOM_Object) GetBlockNearPoint(Handle(GEOM_Object) theCompound
Standard_EXPORT Handle (GEOM_Object) GetBlockByParts(Handle(GEOM_Object) theCompound
Standard_EXPORT const Handle (TColStd_HSequenceOfTransient) &theParts)
Standard_EXPORT Handle (TColStd_HSequenceOfTransient) GetBlocksByParts(Handle(GEOM_Object) theCompound
Standard_EXPORT Handle (GEOM_Object) MakeMultiTransformation1D(Handle(GEOM_Object) theBlock
Standard_EXPORT Handle (GEOM_Object) MakeMultiTransformation2D(Handle(GEOM_Object) theBlock
Standard_EXPORT Handle (TColStd_HSequenceOfTransient) Propagate(Handle(GEOM_Object) theShape)
- Public Member Functions inherited from GEOM_IOperations
Standard_EXPORT GEOM_IOperations (GEOM_Engine *theEngine)
Standard_EXPORT ~GEOM_IOperations ()
Standard_EXPORT void StartOperation ()
Standard_EXPORT void FinishOperation ()
Standard_EXPORT void AbortOperation ()
Standard_EXPORT bool IsDone ()
Standard_EXPORT void SetNotDone ()
Standard_EXPORT void SetErrorCode (const TCollection_AsciiString &theErrorCode)
Standard_EXPORT char * GetErrorCode ()
Standard_EXPORT GEOM_Engine * GetEngine ()
Standard_EXPORT GEOM_Solver * GetSolver ()
static Standard_EXPORT void AddBlocksFrom (const TopoDS_Shape &theShape, TopTools_ListOfShape &BLO, TopTools_ListOfShape &NOT, TopTools_ListOfShape &EXT, TopTools_ListOfShape &NOQ, const Standard_Real theToleranceC1=-1.)
Public Attributes
Standard_EXPORT const Standard_Real theX
Standard_EXPORT const Standard_Real const Standard_Real theY
Standard_EXPORT const Standard_Real const Standard_Real const Standard_Real theZ
Standard_EXPORT const Standard_Real const Standard_Real const Standard_Real const Standard_Real theEpsilon
Standard_EXPORT const Standard_Integer theShapeType
Standard_EXPORT const Standard_Integer const Standard_Real theTolerance
Standard_EXPORT const Standard_Real theToleranceC1
Standard_EXPORT const Standard_Integer theOptimumNbFaces = 6)
Standard_EXPORT const Standard_Integer theMinNbFaces
Standard_EXPORT const Standard_Integer const Standard_Integer theMaxNbFaces
Standard_EXPORT const Standard_Integer theDirFace1
Standard_EXPORT const Standard_Integer const Standard_Integer theDirFace2
Standard_EXPORT const Standard_Integer const Standard_Integer const Standard_Integer theNbTimes
Standard_EXPORT const Standard_Integer theDirFace1U
Standard_EXPORT const Standard_Integer const Standard_Integer theDirFace2U
Standard_EXPORT const Standard_Integer const Standard_Integer const Standard_Integer theNbTimesU
Standard_EXPORT const Standard_Integer const Standard_Integer const Standard_Integer const Standard_Integer theDirFace1V
Standard_EXPORT const Standard_Integer const Standard_Integer const Standard_Integer const Standard_Integer const Standard_Integer theDirFace2V
Standard_EXPORT const Standard_Integer const Standard_Integer const Standard_Integer const Standard_Integer const Standard_Integer const Standard_Integer theNbTimesV
◆ BCErrorType
NOT_BLOCK
EXTRA_EDGE
INVALID_CONNECTION
NOT_CONNECTED
NOT_GLUED
◆ GEOMImpl_IBlocksOperations()
GEOMImpl_IBlocksOperations::GEOMImpl_IBlocksOperations ( GEOM_Engine *  theEngine)
constructor:
◆ ~GEOMImpl_IBlocksOperations()
GEOMImpl_IBlocksOperations::~GEOMImpl_IBlocksOperations ( )
destructor
◆ AddBlocksFrom()
void GEOMImpl_IBlocksOperations::AddBlocksFrom ( const TopoDS_Shape &  theShape,
TopTools_ListOfShape &  BLO,
TopTools_ListOfShape &  NOT,
TopTools_ListOfShape &  EXT,
TopTools_ListOfShape &  NOQ,
const Standard_Real  theToleranceC1 = -1.
Set of functions, used by CheckCompoundOfBlocks() method
References AddBlocksFrom(), IsQuadrangle(), and theToleranceC1.
◆ CheckCompoundOfBlocks()
Standard_Boolean GEOMImpl_IBlocksOperations::CheckCompoundOfBlocks ( Handle(GEOM_Object)  theCompound,
std::list< BCError > &  theErrors
◆ Handle() [1/58]
Standard_EXPORT const Standard_Real GEOMImpl_IBlocksOperations::Handle ( GEOM_Object  ) &
◆ Handle() [2/58]
Standard_EXPORT GEOMImpl_IBlocksOperations::Handle ( GEOM_Object  )
◆ Handle() [3/58]
◆ Handle() [4/58]
◆ Handle() [5/58]
◆ Handle() [6/58]
◆ Handle() [7/58]
◆ Handle() [8/58]
◆ Handle() [9/58]
◆ Handle() [10/58]
◆ Handle() [11/58]
◆ Handle() [12/58]
◆ Handle() [13/58]
◆ Handle() [14/58]
◆ Handle() [15/58]
◆ Handle() [16/58]
◆ Handle() [17/58]
◆ Handle() [18/58]
◆ Handle() [19/58]
◆ Handle() [20/58]
◆ Handle() [21/58]
◆ Handle() [22/58]
◆ Handle() [23/58]
◆ Handle() [24/58]
◆ Handle() [25/58]
◆ Handle() [26/58]
◆ Handle() [27/58]
◆ Handle() [28/58]
◆ Handle() [29/58]
◆ Handle() [30/58]
◆ Handle() [31/58]
◆ Handle() [32/58]
◆ Handle() [33/58]
◆ Handle() [34/58]
◆ Handle() [35/58]
◆ Handle() [36/58]
◆ Handle() [37/58]
◆ Handle() [38/58]
◆ Handle() [39/58]
◆ Handle() [40/58]
◆ Handle() [41/58]
◆ Handle() [42/58]
◆ Handle() [43/58]
◆ Handle() [44/58]
◆ Handle() [45/58]
◆ Handle() [46/58]
◆ Handle() [47/58]
◆ Handle() [48/58]
◆ Handle() [49/58]
◆ Handle() [50/58]
◆ Handle() [51/58]
◆ Handle() [52/58]
◆ Handle() [53/58]
◆ Handle() [54/58]
Standard_EXPORT const GEOMImpl_IBlocksOperations::Handle ( TColStd_HSequenceOfTransient  ) &
◆ Handle() [55/58]
◆ Handle() [56/58]
Standard_EXPORT GEOMImpl_IBlocksOperations::Handle ( TColStd_HSequenceOfTransient  )
◆ Handle() [57/58]
◆ Handle() [58/58]
◆ IsCompoundOfBlocks()
Standard_Boolean GEOMImpl_IBlocksOperations::IsCompoundOfBlocks ( Handle(GEOM_Object)  theCompound,
Standard_Integer &  theNbBlocks
IsCompoundOfBlocks
References KO, OK, GEOM_IOperations::SetErrorCode(), theMaxNbFaces, and theMinNbFaces.
◆ PrintBCErrors()
TCollection_AsciiString GEOMImpl_IBlocksOperations::PrintBCErrors ( Handle(GEOM_Object)  theCompound,
const std::list< BCError > &  theErrors
◆ theDirFace1
Standard_EXPORT const Standard_Integer GEOMImpl_IBlocksOperations::theDirFace1
◆ theDirFace1U
Standard_EXPORT const Standard_Integer GEOMImpl_IBlocksOperations::theDirFace1U
◆ theDirFace1V
Standard_EXPORT const Standard_Integer const Standard_Integer const Standard_Integer const Standard_Integer GEOMImpl_IBlocksOperations::theDirFace1V
◆ theDirFace2
Standard_EXPORT const Standard_Integer const Standard_Integer GEOMImpl_IBlocksOperations::theDirFace2
◆ theDirFace2U
Standard_EXPORT const Standard_Integer const Standard_Integer GEOMImpl_IBlocksOperations::theDirFace2U
◆ theDirFace2V
Standard_EXPORT const Standard_Integer const Standard_Integer const Standard_Integer const Standard_Integer const Standard_Integer GEOMImpl_IBlocksOperations::theDirFace2V
◆ theEpsilon
Standard_EXPORT const Standard_Real const Standard_Real const Standard_Real const Standard_Real GEOMImpl_IBlocksOperations::theEpsilon
◆ theMaxNbFaces
Standard_EXPORT const Standard_Integer const Standard_Integer GEOMImpl_IBlocksOperations::theMaxNbFaces
◆ theMinNbFaces
Standard_EXPORT const Standard_Integer GEOMImpl_IBlocksOperations::theMinNbFaces
◆ theNbTimes
Standard_EXPORT const Standard_Integer const Standard_Integer const Standard_Integer GEOMImpl_IBlocksOperations::theNbTimes
◆ theNbTimesU
Standard_EXPORT const Standard_Integer const Standard_Integer const Standard_Integer GEOMImpl_IBlocksOperations::theNbTimesU
◆ theNbTimesV
Standard_EXPORT const Standard_Integer const Standard_Integer const Standard_Integer const Standard_Integer const Standard_Integer const Standard_Integer GEOMImpl_IBlocksOperations::theNbTimesV
◆ theOptimumNbFaces
Standard_EXPORT const Standard_Integer GEOMImpl_IBlocksOperations::theOptimumNbFaces = 6)
◆ theShapeType
Standard_EXPORT const Standard_Integer GEOMImpl_IBlocksOperations::theShapeType
◆ theTolerance
Standard_EXPORT const Standard_Integer const Standard_Real GEOMImpl_IBlocksOperations::theTolerance
◆ theToleranceC1
Standard_EXPORT const Standard_Real GEOMImpl_IBlocksOperations::theToleranceC1
◆ theX
Standard_EXPORT const Standard_Real GEOMImpl_IBlocksOperations::theX
◆ theY
Standard_EXPORT const Standard_Real const Standard_Real GEOMImpl_IBlocksOperations::theY
◆ theZ
Standard_EXPORT const Standard_Real const Standard_Real const Standard_Real GEOMImpl_IBlocksOperations::theZ
