GEOMImpl_ICurvesOperations Class Reference
#include <GEOMImpl_ICurvesOperations.hxx>
Inheritance diagram for GEOMImpl_ICurvesOperations:
enum  CurveType { Polyline , Bezier , Interpolation }
Standard_EXPORT GEOMImpl_ICurvesOperations (GEOM_Engine *theEngine)
Standard_EXPORT ~GEOMImpl_ICurvesOperations ()
Standard_EXPORT Handle (GEOM_Object) MakeCircleThreePnt(Handle(GEOM_Object) thePnt1
Standard_EXPORT Handle (GEOM_Object) thePnt2
Standard_EXPORT Handle (GEOM_Object) thePnt3)
Standard_EXPORT Handle (GEOM_Object) MakeCircleCenter2Pnt(Handle(GEOM_Object) thePnt1
Standard_EXPORT Handle (GEOM_Object) MakeCirclePntVecR(Handle(GEOM_Object) thePnt
Standard_EXPORT Handle (GEOM_Object) theVec
Standard_EXPORT Handle (GEOM_Object) MakeEllipse(Handle(GEOM_Object) thePnt
Standard_EXPORT double double Handle (GEOM_Object) theVecMaj)
Standard_EXPORT Handle (GEOM_Object) MakeArc(Handle(GEOM_Object) thePnt1
Standard_EXPORT Handle (GEOM_Object) MakeArcCenter(Handle(GEOM_Object) thePnt1
Standard_EXPORT Handle (GEOM_Object) MakeArcOfEllipse(Handle(GEOM_Object) thePnt1
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT Handle (GEOM_Object) MakeCurveParametric(const char *thexExpr
Standard_EXPORT Handle (GEOM_Object) MakeSketcher(const char *theCommand
Standard_EXPORT Handle (GEOM_Object) MakeSketcherOnPlane(const char *theCommand
Standard_EXPORT Handle (GEOM_Object) theWorkingPlane)
Standard_EXPORT Handle (GEOM_Object) Make3DSketcherCommand(const char *theCommand)
Standard_EXPORT Handle(GEOM_Object) Make3DSketcher(std Standard_EXPORT Handle (GEOM_Object) MakeIsoline(const Handle(GEOM_Object) &theFace
- Public Member Functions inherited from GEOM_IOperations
Standard_EXPORT GEOM_IOperations (GEOM_Engine *theEngine)
Standard_EXPORT ~GEOM_IOperations ()
Standard_EXPORT void StartOperation ()
Standard_EXPORT void FinishOperation ()
Standard_EXPORT void AbortOperation ()
Standard_EXPORT bool IsDone ()
Standard_EXPORT void SetNotDone ()
Standard_EXPORT void SetErrorCode (const TCollection_AsciiString &theErrorCode)
Standard_EXPORT char * GetErrorCode ()
Standard_EXPORT GEOM_Engine * GetEngine ()
Standard_EXPORT GEOM_Solver * GetSolver ()
Public Attributes
Standard_EXPORT double theR
Standard_EXPORT double theRMajor
Standard_EXPORT double double theRMinor
Standard_EXPORT bool theSense
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char * theyExpr
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char * thezExpr
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char double theParamMin
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char double double theParamMax
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char double double double theParamStep
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char double double double CurveType theCurveType
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char double double double CurveType int theParamNbStep =0
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char double double double CurveType int bool theNewMethod =false)
Standard_EXPORT std::list< double > theWorkingPlane
Standard_EXPORT Handle(GEOM_Object) Make3DSketcher(std Standard_EXPORT const bool IsUIso
Standard_EXPORT Handle(GEOM_Object) Make3DSketcher(std Standard_EXPORT const bool const double theParameter
◆ CurveType
Polyline
Bezier
Interpolation
◆ GEOMImpl_ICurvesOperations()
GEOMImpl_ICurvesOperations::GEOMImpl_ICurvesOperations ( GEOM_Engine *  theEngine)
constructor:
◆ ~GEOMImpl_ICurvesOperations()
GEOMImpl_ICurvesOperations::~GEOMImpl_ICurvesOperations ( )
destructor
◆ Handle() [1/26]
Standard_EXPORT GEOMImpl_ICurvesOperations::Handle ( GEOM_Object  ) const
◆ Handle() [2/26]
◆ Handle() [3/26]
◆ Handle() [4/26]
◆ Handle() [5/26]
◆ Handle() [6/26]
◆ Handle() [7/26]
◆ Handle() [8/26]
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT GEOMImpl_ICurvesOperations::Handle ( GEOM_Object  ) const
◆ Handle() [9/26]
◆ Handle() [10/26]
Standard_EXPORT Handle(GEOM_Object) Make3DSketcher(std Standard_EXPORT GEOMImpl_ICurvesOperations::Handle ( GEOM_Object  ) const &
◆ Handle() [11/26]
◆ Handle() [12/26]
◆ Handle() [13/26]
◆ Handle() [14/26]
◆ Handle() [15/26]
◆ Handle() [16/26]
◆ Handle() [17/26]
◆ Handle() [18/26]
◆ Handle() [19/26]
◆ Handle() [20/26]
◆ Handle() [21/26]
◆ Handle() [22/26]
◆ Handle() [23/26]
◆ Handle() [24/26]
◆ Handle() [25/26]
Standard_EXPORT double double GEOMImpl_ICurvesOperations::Handle ( GEOM_Object  )
◆ Handle() [26/26]
◆ IsUIso
Standard_EXPORT Handle(GEOM_Object) Make3DSketcher(std Standard_EXPORT const bool GEOMImpl_ICurvesOperations::IsUIso
◆ theCurveType
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char double double double CurveType GEOMImpl_ICurvesOperations::theCurveType
◆ theNewMethod
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char double double double CurveType int bool GEOMImpl_ICurvesOperations::theNewMethod =false)
◆ theParameter
Standard_EXPORT Handle(GEOM_Object) Make3DSketcher(std Standard_EXPORT const bool const double GEOMImpl_ICurvesOperations::theParameter
◆ theParamMax
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char double double GEOMImpl_ICurvesOperations::theParamMax
◆ theParamMin
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char double GEOMImpl_ICurvesOperations::theParamMin
◆ theParamNbStep
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char double double double CurveType int GEOMImpl_ICurvesOperations::theParamNbStep =0
◆ theParamStep
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char double double double GEOMImpl_ICurvesOperations::theParamStep
◆ theR
Standard_EXPORT double GEOMImpl_ICurvesOperations::theR
◆ theRMajor
Standard_EXPORT double GEOMImpl_ICurvesOperations::theRMajor
◆ theRMinor
Standard_EXPORT double double GEOMImpl_ICurvesOperations::theRMinor
◆ theSense
Standard_EXPORT bool GEOMImpl_ICurvesOperations::theSense
◆ theWorkingPlane
Standard_EXPORT std::list<double> GEOMImpl_ICurvesOperations::theWorkingPlane
◆ theyExpr
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char* GEOMImpl_ICurvesOperations::theyExpr
◆ thezExpr
Standard_EXPORT Handle(GEOM_Object) MakePolyline(std Standard_EXPORT Handle(GEOM_Object) MakeSplineBezier(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolation(std Standard_EXPORT Handle(GEOM_Object) MakeSplineInterpolWithTangents(std Standard_EXPORT const char const char* GEOMImpl_ICurvesOperations::thezExpr
