GEOMImpl_PolylineDumper Class Reference
This is a helper class to form a dump of a polyline 2d curves creation algorithm.
#include <GEOMImpl_PolylineDumper.hxx>
 GEOMImpl_PolylineDumper (const std::list< std::list< double > > &theCoords, const Handle(TColStd_HArray1OfExtendedString) &theNames, const Handle(TColStd_HArray1OfByte) &theTypes, const Handle(TColStd_HArray1OfByte) &theCloseds, const Handle(TColStd_HArray1OfReal) &thePlnCoords)
 This constructor initializes the object with 2D polyline creation parameters. More...
 GEOMImpl_PolylineDumper (const std::list< std::list< double > > &theCoords, const Handle(TColStd_HArray1OfExtendedString) &theNames, const Handle(TColStd_HArray1OfByte) &theTypes, const Handle(TColStd_HArray1OfByte) &theCloseds, const Handle(GEOM_Object) &theWorkingPlane)
Standard_Boolean IsDone () const
 This method returns Standard_True if the dump description is created successfully. More...
Standard_Boolean Dump (const Handle(GEOM_Object) &theObject)
 This method performs dump of the polyline. More...
void init ()
 This method generates the description required for python dump. More...
 Handle (TColStd_HArray1OfExtendedString) myNames
 Handle (TColStd_HArray1OfByte) myTypes
 Handle (TColStd_HArray1OfByte) myCloseds
 Handle (TColStd_HArray1OfReal) myPlnCoords
 Handle (GEOM_Object) myWorkingPlane
const std::list< std::list< double > > & myCoords
Standard_Boolean myIsDone
TCollection_ExtendedString myDescr
◆ GEOMImpl_PolylineDumper() [1/2]
GEOMImpl_PolylineDumper::GEOMImpl_PolylineDumper ( const std::list< std::list< double > > &  theCoords,
const Handle(TColStd_HArray1OfExtendedString) &  theNames,
const Handle(TColStd_HArray1OfByte) &  theTypes,
const Handle(TColStd_HArray1OfByte) &  theCloseds,
const Handle(TColStd_HArray1OfReal) &  thePlnCoords
theCoordsthe list of coordinates list. theCoordsList[0] is the coordinates list of the first section. theCoordsList[1] is for the second section etc.
theNamesthe list of names. The order corresponds to theCoords.
theTypesthe list of curve types. The order corresponds to theCoords.
theClosedsthe list of Closed flags. The order corresponds to theCoords.
thePlnCoords9 double values, defining origin, OZ and OX directions of the working plane.
References init().
◆ GEOMImpl_PolylineDumper() [2/2]
const Handle(GEOM_Object) &  theWorkingPlane
theWorkingPlaneplanar Face or LCS(Marker) of the working plane.
References init().
◆ Dump()
Standard_Boolean GEOMImpl_PolylineDumper::Dump ( const Handle(GEOM_Object) &  theObject)
theObjectthe newly created object.
Standard_True in case of success; Standard_False otherwise.
References Handle(), myDescr, and myIsDone.
◆ Handle() [1/5]
GEOMImpl_PolylineDumper::Handle ( GEOM_Object  )
◆ Handle() [2/5]
GEOMImpl_PolylineDumper::Handle ( TColStd_HArray1OfByte  )
◆ Handle() [3/5]
◆ Handle() [4/5]
GEOMImpl_PolylineDumper::Handle ( TColStd_HArray1OfExtendedString  )
◆ Handle() [5/5]
GEOMImpl_PolylineDumper::Handle ( TColStd_HArray1OfReal  )
◆ init()
void GEOMImpl_PolylineDumper::init ( )
◆ IsDone()
Standard_Boolean GEOMImpl_PolylineDumper::IsDone ( ) const
◆ myCoords
const std::list<std::list <double> >& GEOMImpl_PolylineDumper::myCoords
◆ myDescr
TCollection_ExtendedString GEOMImpl_PolylineDumper::myDescr
◆ myIsDone
Standard_Boolean GEOMImpl_PolylineDumper::myIsDone
