GEOMToolsGUI_MaterialPropertiesDlg Class Reference
GEOM material properties dialog box class. More...
#include <GEOMToolsGUI_MaterialPropertiesDlg.h>
Inheritance diagram for GEOMToolsGUI_MaterialPropertiesDlg:
struct  Reflection
Signals
void changed ()
 GEOMToolsGUI_MaterialPropertiesDlg (QWidget *=0, bool=true, bool=false, const int=Standard)
 ~GEOMToolsGUI_MaterialPropertiesDlg ()
void accept ()
 Called when "OK" button is clicked. More...
bool eventFilter (QObject *, QEvent *)
 Event filter. More...
Private Types
enum  { Current , Global , User }
enum  { TypeRole = Qt::UserRole + 123 , NameRole }
Private Slots
void onChanged ()
 Called when any material parameter is changed by the user. More...
void onMaterialChanged ()
 Called when user selects any material item in the materials list. More...
void onItemChanged (QListWidgetItem *)
 Called when user material is renamed by the user. More...
void onContextMenu (QContextMenuEvent *)
 Process context menu event from materials list. More...
void onDeleteMaterial ()
 Delete currently selected user model. More...
void onAddMaterial ()
 Add new user material model. More...
void onApply ()
 Called when "Apply" button is pressed. More...
void onHelp ()
 Called when "Help" button is pressed. More...
void SetEditCurrentArgument ()
void SelectionIntoArgument ()
 Called when selection as changed or other case. More...
void updateState ()
 Update buttons state. More...
void toModel (Material_Model &) const
 Save values from dialog box widgets to material model. More...
void fromModel (const Material_Model &)
 Initialize dialog box widgets from material model. More...
QString findUniqueName (const QString &, QListWidgetItem *=0, bool=false)
 Find unique name for the material name. More...
GEOMToolsGUI_MaterialList * myMaterials
QCheckBox * myPhysical
QList< Reflection > myReflection
QtxDoubleSpinBox * myFrontShininess
QtxDoubleSpinBox * myBackShininess
QLabel * myColorLab
QtxColorButton * myColor
QPushButton * myAddButton
QPushButton * myDelButton
Material_ResourceMgr myResourceMgr
Material_Model myCurrentModel
bool myShowSelWidget
QLineEdit * myLineEditCurArg
QPushButton * myPushBtn
The dialog box is used to set material properties for the presentation objects.
◆ anonymous enum
anonymous enum
Current
Global
User
◆ anonymous enum
anonymous enum
TypeRole
NameRole
◆ GEOMToolsGUI_MaterialPropertiesDlg()
◆ ~GEOMToolsGUI_MaterialPropertiesDlg()
GEOMToolsGUI_MaterialPropertiesDlg::~GEOMToolsGUI_MaterialPropertiesDlg ( )
◆ accept()
void GEOMToolsGUI_MaterialPropertiesDlg::accept ( )
References onApply().
◆ changed
void GEOMToolsGUI_MaterialPropertiesDlg::changed ( )
signal
◆ eventFilter()
bool GEOMToolsGUI_MaterialPropertiesDlg::eventFilter ( QObject *  o,
QEvent *  e
osender
eevent
References myMaterials, and onDeleteMaterial().
◆ findUniqueName()
QString GEOMToolsGUI_MaterialPropertiesDlg::findUniqueName ( const QString &  name,
QListWidgetItem *  item = 0,
bool  addSuffix = false
namematerial name template
itemthe item to be ignored when browsing through the materials list
addSuffixif true, the integrer suffix is always added to the material name (otherwise suffix is added only if item name is not unique)
new unique material name
References myMaterials.
◆ fromModel()
◆ onAddMaterial
void GEOMToolsGUI_MaterialPropertiesDlg::onAddMaterial ( )
privateslot
◆ onApply
◆ onChanged
◆ onContextMenu
void GEOMToolsGUI_MaterialPropertiesDlg::onContextMenu ( QContextMenuEvent *  e)
privateslot
◆ onDeleteMaterial
void GEOMToolsGUI_MaterialPropertiesDlg::onDeleteMaterial ( )
privateslot
◆ onHelp
void GEOMToolsGUI_MaterialPropertiesDlg::onHelp ( )
privateslot
◆ onItemChanged
void GEOMToolsGUI_MaterialPropertiesDlg::onItemChanged ( QListWidgetItem *  item)
privateslot
◆ onMaterialChanged
void GEOMToolsGUI_MaterialPropertiesDlg::onMaterialChanged ( )
privateslot
◆ SelectionIntoArgument
void GEOMToolsGUI_MaterialPropertiesDlg::SelectionIntoArgument ( )
privateslot
◆ SetEditCurrentArgument
void GEOMToolsGUI_MaterialPropertiesDlg::SetEditCurrentArgument ( )
privateslot
◆ toModel()
void GEOMToolsGUI_MaterialPropertiesDlg::toModel ( Material_Model &  model) const
◆ updateState()
void GEOMToolsGUI_MaterialPropertiesDlg::updateState ( )
◆ myAddButton
QPushButton* GEOMToolsGUI_MaterialPropertiesDlg::myAddButton
◆ myBackShininess
QtxDoubleSpinBox* GEOMToolsGUI_MaterialPropertiesDlg::myBackShininess
◆ myColor
QtxColorButton* GEOMToolsGUI_MaterialPropertiesDlg::myColor
◆ myColorLab
QLabel* GEOMToolsGUI_MaterialPropertiesDlg::myColorLab
◆ myCurrentModel
Material_Model GEOMToolsGUI_MaterialPropertiesDlg::myCurrentModel
◆ myDelButton
QPushButton* GEOMToolsGUI_MaterialPropertiesDlg::myDelButton
◆ myFrontShininess
QtxDoubleSpinBox* GEOMToolsGUI_MaterialPropertiesDlg::myFrontShininess
◆ myLineEditCurArg
QLineEdit* GEOMToolsGUI_MaterialPropertiesDlg::myLineEditCurArg
◆ myMaterials
GEOMToolsGUI_MaterialList* GEOMToolsGUI_MaterialPropertiesDlg::myMaterials
◆ myPhysical
QCheckBox* GEOMToolsGUI_MaterialPropertiesDlg::myPhysical
◆ myPushBtn
QPushButton* GEOMToolsGUI_MaterialPropertiesDlg::myPushBtn
◆ myReflection
QList<Reflection> GEOMToolsGUI_MaterialPropertiesDlg::myReflection
◆ myResourceMgr
Material_ResourceMgr GEOMToolsGUI_MaterialPropertiesDlg::myResourceMgr
◆ myShowSelWidget
bool GEOMToolsGUI_MaterialPropertiesDlg::myShowSelWidget
