Material_ResourceMgr Class Reference
Material properties resources manager. More...
#include <Material_ResourceMgr.h>
Inheritance diagram for Material_ResourceMgr:
class  Updater
 Updates the contents of the resource manager as soon as user materials database file is changed. More...
enum  MaterialType { Global , User , All }
 Material type. More...
Signals
void changed ()
 Material_ResourceMgr ()
 ~Material_ResourceMgr ()
QStringList materials (MaterialType=All, bool=true)
 Get list of available materials. More...
static Material_ResourceMgr * resourceMgr ()
 Get shared instance of resources manager. More...
Private Slots
void update ()
 Update user database slot. More...
void watchUserFile (bool)
 Start/stop this resource manager watching the user materials database file. More...
void saved ()
 This function is called after user configuration file is saved. More...
QFileSystemWatcher * myWatcher
QMutex myMutex
Friends
class Material_Model
This class is used to manage the material properties throughout the application in the similar way as QtxResourceMgr does it with application preferences.
Standard material types are stored in the global application settings files (named as SalomeMaterial.xml). User-defined materials are stored in user's home directory - in the file .SalomeMaterialrc.
The Material_ResourceMgr class is used by material properties dialog box (GEOMToolsGUI_MaterialPropertiesDlg class).
◆ MaterialType
Global
Global materials.
User
User materials.
All
All materials.
◆ Material_ResourceMgr()
Material_ResourceMgr::Material_ResourceMgr ( )
◆ ~Material_ResourceMgr()
Material_ResourceMgr::~Material_ResourceMgr ( )
References watchUserFile().
◆ changed
void Material_ResourceMgr::changed ( )
signal
◆ materials()
QStringList Material_ResourceMgr::materials ( MaterialType  theType = All,
bool  theSort = true
theTypematerial type
theSortif true (default), returns a list of materials sorted by name
list of available materials names
References All, Global, myMutex, and User.
◆ resourceMgr()
Material_ResourceMgr * Material_ResourceMgr::resourceMgr ( )
This instance of resource manager is global for the application; it watches for changes in the user materials database file to maintain the fresh version of the materials data.
References Material_ResourceMgr(), and watchUserFile().
◆ saved()
void Material_ResourceMgr::saved ( )
◆ update
void Material_ResourceMgr::update ( )
privateslot
References changed().
◆ watchUserFile()
void Material_ResourceMgr::watchUserFile ( bool  on)
References myWatcher, and update().
◆ Material_Model
friend class Material_Model
friend
◆ myMutex
QMutex Material_ResourceMgr::myMutex
◆ myWatcher
QFileSystemWatcher* Material_ResourceMgr::myWatcher
