GEOM::GenericObjPtr< TInterface > Class Template Reference
A smart pointer for the SALOME GenericObj interface. More...
#include <GEOM_GenericObjPtr.h>
 GenericObjPtr ()
 Initialize pointer to nil generic object reference. More...
 GenericObjPtr (TInterfacePtr theObject)
 Initialize pointer to the given generic object reference. More...
 GenericObjPtr (const GenericObjPtr &thePointer)
 Initialize pointer with a new reference to the same object referenced by given pointer. More...
 ~GenericObjPtr ()
 Destroy pointer and remove the reference to the object. More...
GenericObjPtr & operator= (TInterfacePtr theObject)
 Assign object to reference and remove reference to an old object. More...
GenericObjPtr & operator= (const GenericObjPtr &thePointer)
bool operator== (TInterfacePtr theObject)
 Check equivalence. More...
bool operator== (const GenericObjPtr &thePointer)
bool operator!= (TInterfacePtr theObject)
 Check difference. More...
bool operator!= (const GenericObjPtr &thePointer)
TInterfacePtr operator-> () const
 Provides normal pointer target member access using operator ->. More...
 operator bool () const
 Check validity of the pointer. More...
void take (TInterfacePtr theObject)
 Initialize pointer to the given generic object reference and take ownership on it. More...
TInterfacePtr get () const
 Get the contained object. More...
TInterfacePtr copy () const
 Make the copy of the contained object and return it (caller becomes owner of the CORBA reference). More...
bool isNull () const
 Check if pointer is null. More...
void nullify ()
 Nullify pointer. More...
bool isSame (GEOM::GEOM_Object_ptr theLeft, GEOM::GEOM_Object_ptr theRight)
static bool isSame (TInterfacePtr theLeft, TInterfacePtr theRight)
Private Types
typedef TInterface::_var_type TInterfaceVar
typedef TInterface::_ptr_type TInterfacePtr
void Register ()
 Increment counter for the object. More...
void UnRegister ()
 Decrement counter for the object. More...
TInterfaceVar myObject
template<typename TInterface>
class GEOM::GenericObjPtr< TInterface >
This class can be used in conjunction with the references to the CORBA objects which interfaces are inherited from the SALOME::GenericObj CORBA interface.
The smart pointer class automatically invokes Register() / UnRegister() functions of th interface in order to prevent memory leaks and other such problems caused by improper usage of the CORBA references.
Smart pointers can be easily copied, stored within class as data members, passed to the functions requiring native CORBA reference as parameters, etc.
Usage:
  • If you want to assign the smart pointer to the CORBA _var type variable, use copy() function to make a copy of the stored CORBA object. Otherwise you might cause Segmentation Fault error.
  • To pass the smart pointer to the function that requires CORBA _ptr type parameter, use get() function.
  • If you want to take an ownership on the CORBA object, use take() function. In case of SALOME Generic object this is useful when some function returns newly created object that should be removed by the caller as soon as the object is no more required. For example, function GetSubShape() of the GEOM_IShapesOperation interface always creates new servant object and returns new object reference to it. If the object is not published in the study, it has to be destroyed and the corresponding servant should be deleted.
Examples:
void MyInterface_ptr foo();
void MyInterface_ptr bar( MyInterface_ptr p );
MyIPtr v1; // create empty (nil) pointer
MyIPtr v2 = foo(); // get some CORBA reference and store it within the smart pointer
v1 = v2; // copy smart pointer (reference counter is incremented)
v2 = bar( v1.get() ); // pass smart pointer to the function
MyInterface_var var = v2.copy(); // initialize _var variable with the smart pointer contents
v1.take( foo() ); // take ownership on the newly created object
Definition: GEOM_GenericObjPtr.h:78
◆ TInterfacePtr
template<typename TInterface >
typedef TInterface::_ptr_type GEOM::GenericObjPtr< TInterface >::TInterfacePtr
◆ TInterfaceVar
typedef TInterface::_var_type GEOM::GenericObjPtr< TInterface >::TInterfaceVar
◆ GenericObjPtr() [1/3]
GEOM::GenericObjPtr< TInterface >::GenericObjPtr ( )
◆ GenericObjPtr() [2/3]
GEOM::GenericObjPtr< TInterface >::GenericObjPtr ( TInterfacePtr  theObject)
◆ GenericObjPtr() [3/3]
GEOM::GenericObjPtr< TInterface >::GenericObjPtr ( const GenericObjPtr< TInterface > &  thePointer)
◆ ~GenericObjPtr()
GEOM::GenericObjPtr< TInterface >::~GenericObjPtr ( )
◆ copy()
TInterfacePtr GEOM::GenericObjPtr< TInterface >::copy ( ) const
◆ get()
TInterfacePtr GEOM::GenericObjPtr< TInterface >::get ( ) const
◆ isNull()
bool GEOM::GenericObjPtr< TInterface >::isNull ( ) const
◆ isSame() [1/3]
bool GEOM::GenericObjPtr< GEOM::GEOM_Object >::isSame ( GEOM::GEOM_Object_ptr  theLeft,
◆ isSame() [2/3]
◆ isSame() [3/3]
static bool GEOM::GenericObjPtr< TInterface >::isSame ( TInterfacePtr  theLeft,
inlinestatic
◆ nullify()
void GEOM::GenericObjPtr< TInterface >::nullify ( )
◆ operator bool()
GEOM::GenericObjPtr< TInterface >::operator bool ( ) const
◆ operator!=() [1/2]
bool GEOM::GenericObjPtr< TInterface >::operator!= ( const GenericObjPtr< TInterface > &  thePointer)
◆ operator!=() [2/2]
bool GEOM::GenericObjPtr< TInterface >::operator!= ( TInterfacePtr  theObject)
◆ operator->()
TInterfacePtr GEOM::GenericObjPtr< TInterface >::operator-> ( ) const
◆ operator=() [1/2]
GenericObjPtr & GEOM::GenericObjPtr< TInterface >::operator= ( const GenericObjPtr< TInterface > &  thePointer)
◆ operator=() [2/2]
GenericObjPtr & GEOM::GenericObjPtr< TInterface >::operator= ( TInterfacePtr  theObject)
◆ operator==() [1/2]
bool GEOM::GenericObjPtr< TInterface >::operator== ( const GenericObjPtr< TInterface > &  thePointer)
◆ operator==() [2/2]
bool GEOM::GenericObjPtr< TInterface >::operator== ( TInterfacePtr  theObject)
◆ Register()
void GEOM::GenericObjPtr< TInterface >::Register ( )
inlineprivate
◆ take()
void GEOM::GenericObjPtr< TInterface >::take ( TInterfacePtr  theObject)
◆ UnRegister()
void GEOM::GenericObjPtr< TInterface >::UnRegister ( )
inlineprivate
◆ myObject
TInterfaceVar GEOM::GenericObjPtr< TInterface >::myObject
