Interface of geometric object.
import"GEOM_Gen.idl";
| shape_type | GetShapeType () |
| Get a shape_type of the object value. More... | |
| shape_type | GetTopologyType () |
| Get the topology type of the object value. More... | |
| shape_type | GetCommonShapeType () |
| Get the common shape type of the top-level shapes contained in the object. More... | |
| shape_type | GetMinShapeType () |
| Get a minimal type of the top-level shapes contained in the object. More... | |
| shape_type | GetMaxShapeType () |
| Get a maximal type of the top-level shapes contained in the object. More... | |
| string | GetSubShapeName (in long subID) |
| Returns a name of a sub-shape if the sub-shape is published in the study. More... | |
| void | SetColor (in SALOMEDS::Color theColor) |
| Set color of the object. More... | |
| SALOMEDS::Color | GetColor () |
| void | SetAutoColor (in boolean theAutoColor) |
| boolean | GetAutoColor () |
| Get flag of object's auto color mode. More... | |
| void | SetMarkerStd (in marker_type theType, in marker_size theSize) |
| Set standard point marker for the object. More... | |
| void | SetMarkerTexture (in long theTextureId) |
| Set custom point marker for the object. More... | |
| marker_type | GetMarkerType () |
| Get type of the point marker assigned to the object. More... | |
| marker_size | GetMarkerSize () |
| Get size of the point marker assigned to the object. More... | |
| long | GetMarkerTexture () |
| Get texture idenifier of the point marker assigned to the object. More... | |
| long long | getShape () |
| Get the TopoDS_Shape, for colocated case only. More... | |
| SALOMEDS::TMPFile | GetShapeStream () |
| Get geometric shape of the object as a byte stream in BRep format. More... | |
| boolean | IsMainShape () |
| ListOfLong | GetSubShapeIndices () |
| GEOM_Object | GetMainShape () |
| boolean | IsParametrical () |
Public Member Functions inherited from GEOM::GEOM_BaseObject | |
| void | SetName (in string theName) |
| Set name of the object. More... | |
| string | GetName () |
| Get name of the object associated with this object. More... | |
| string | GetEntry () |
| Get internal (unique) entry of the object in the GEOM component's data tree. More... | |
| long | GetType () |
| Get internal type of operation created this object (POINT, BOX, CYLINDER, EXTRUSION...). More... | |
| long | GetTick () |
| Get value of a modification counter of the object. More... | |
| void | SetStudyEntry (in string theEntry) |
| Set a Study entry where this object was published. More... | |
| string | GetStudyEntry () |
| Get a Study entry where this object was published. More... | |
| ListOfGBO | GetDependency () |
| Get a list of all GEOM_Object on which were the arguments when this object was constructed and modified. More... | |
| ListOfGBO | GetLastDependency () |
| Get a list of GEOM_Object on which the last function that created or modified the object depends. More... | |
| boolean | IsShape () |
| boolean | IsSame (in GEOM_BaseObject other) |
| void | SetParameters (in string theParameters) |
| string | GetParameters () |
| Return list of notebook variables used for object creation separated by ":" symbol. More... | |
| CreationInformationSeq | GetCreationInformation () |
| Return name of operation and values of parameters used for object creation. More... | |
| GEOM_Gen | GetGen () |
| Return the engine creating this object. More... | |
| bool GEOM_Object::GetAutoColor | ( | ) |
GetAutoColor
References AUTO_COLOR_LABEL, and Handle().
| GEOM_Object::Color GEOM_Object::GetColor | ( | ) |
| shape_type GEOM::GEOM_Object::GetCommonShapeType | ( | ) |
In contrast to the topology type, this function returns the common type of the top-level sub-shapes of the COMPOUND or COMPSOLID, if there are multiple sub-shapes there. If there is no common shape type (GetMinShapeType() and GetMaxShapeType() return different values) for the same COMPOUND/COMPSOLID, the generic SHAPE value is returned.
| GEOM_Object GEOM::GEOM_Object::GetMainShape | ( | ) |
| double GEOM_Object::GetMarkerSize | ( | ) |
GetMarkerSize
References Handle(), MARKER_LABEL, and MARKER_LABEL_SIZE.
| int GEOM_Object::GetMarkerTexture | ( | ) |
GetMarkerTexture
References Handle(), MARKER_LABEL, and MARKER_LABEL_ID.
| Aspect_TypeOfMarker GEOM_Object::GetMarkerType | ( | ) |
GetMarkerType
References Handle(), MARKER_LABEL, and MARKER_LABEL_TYPE.
| shape_type GEOM::GEOM_Object::GetMaxShapeType | ( | ) |
This function is useful for the compounds only; for simple shapes it exactly the same value as GetShapeType(). Note, that compounds are processed recursively.
| shape_type GEOM::GEOM_Object::GetMinShapeType | ( | ) |
| long long GEOM::GEOM_Object::getShape | ( | ) |
| SALOMEDS::TMPFile GEOM::GEOM_Object::GetShapeStream | ( | ) |
| shape_type GEOM::GEOM_Object::GetShapeType | ( | ) |
| ListOfLong GEOM::GEOM_Object::GetSubShapeIndices | ( | ) |
| string GEOM::GEOM_Object::GetSubShapeName | ( | in long | subID | ) |
| subID | - sub-shape ID |
| shape_type GEOM::GEOM_Object::GetTopologyType | ( | ) |
In contrast to the shape type, this function returns type of the most top-level sub-shape of the COMPOUND or COMPSOLID, if there is only one sub-shape there.
| bool GEOM_Object::IsMainShape | ( | ) |
IsSubShape
References Handle().
| boolean GEOM::GEOM_Object::IsParametrical | ( | ) |
| void GEOM_Object::SetAutoColor | ( | in boolean | theAutoColor | ) |
Toggle auto color mode on the object.
| theAutoColor | is a flag which toggles auto color mode. |
SetAutoColor
References AUTO_COLOR_LABEL, GEOM::Color, and GEOM_ColorUtils::getPredefinedUniqueColor().
| void GEOM_Object::SetColor | ( | in SALOMEDS::Color | theColor | ) |
| void GEOM_Object::SetMarkerStd | ( | in marker_type | theType, |
| in marker_size | theSize | ||
| theType | standard marker type |
| theSize | marker relative size |
SetMarkerStd
References MARKER_LABEL, MARKER_LABEL_SIZE, and MARKER_LABEL_TYPE.
| void GEOM_Object::SetMarkerTexture | ( | in long | theTextureId | ) |
The texture can be added by LoadTexture() or AddTexture() functions.
| theTextureId | texture ID |
SetMarkerTexture
References MARKER_LABEL, MARKER_LABEL_ID, and MARKER_LABEL_TYPE.
