Interface to access other GEOM interfaces. More...
import"GEOM_Gen.idl";
| void | Undo () |
| Undo/Redo Management. More... | |
| void | Redo () |
| SALOMEDS::SObject | AddInStudy (in GEOM_BaseObject theObject, in string theName, in GEOM_BaseObject theFather) |
| Publishing management. More... | |
| ListOfGO | RestoreSubShapesO (in GEOM_Object theObject, in ListOfGO theArgs, in find_shape_method theFindMethod, in boolean theInheritFirstArg, in boolean theAddPrefix) |
| Publish sub-shapes, standing for arguments and sub-shapes of arguments. More... | |
| ListOfGO | RestoreGivenSubShapesO (in GEOM_Object theObject, in ListOfGO theArgs, in find_shape_method theFindMethod, in boolean theInheritFirstArg, in boolean theAddPrefix) |
| ListOfGO | RestoreSubShapesSO (in SALOMEDS::SObject theSObject, in ListOfGO theArgs, in find_shape_method theFindMethod, in boolean theInheritFirstArg, in boolean theAddPrefix) |
| GEOM_IBasicOperations | GetIBasicOperations () raises (SALOME::SALOME_Exception) |
| GEOM_ITransformOperations | GetITransformOperations () raises (SALOME::SALOME_Exception) |
| GEOM_I3DPrimOperations | GetI3DPrimOperations () raises (SALOME::SALOME_Exception) |
| GEOM_IShapesOperations | GetIShapesOperations () raises (SALOME::SALOME_Exception) |
| GEOM_IBooleanOperations | GetIBooleanOperations () raises (SALOME::SALOME_Exception) |
| GEOM_ICurvesOperations | GetICurvesOperations () raises (SALOME::SALOME_Exception) |
| GEOM_ILocalOperations | GetILocalOperations () raises (SALOME::SALOME_Exception) |
| GEOM_IHealingOperations | GetIHealingOperations () raises (SALOME::SALOME_Exception) |
| GEOM_IInsertOperations | GetIInsertOperations () raises (SALOME::SALOME_Exception) |
| GEOM_IMeasureOperations | GetIMeasureOperations () raises (SALOME::SALOME_Exception) |
| GEOM_IBlocksOperations | GetIBlocksOperations () raises (SALOME::SALOME_Exception) |
| GEOM_IGroupOperations | GetIGroupOperations () raises (SALOME::SALOME_Exception) |
| GEOM_IFieldOperations | GetIFieldOperations () raises (SALOME::SALOME_Exception) |
| GEOM_ITestOperations | GetITestOperations () raises (SALOME::SALOME_Exception) |
| GEOM_ICanonicalRecognition | GetICanonicalRecognition () raises (SALOME::SALOME_Exception) |
| GEOM_IOperations | GetPluginOperations (in string theLibName) raises (SALOME::SALOME_Exception) |
| void | RemoveObject (in GEOM_BaseObject theObject) |
| Removes the object from the GEOM component. More... | |
| GEOM_BaseObject | GetObject (in string theEntry) |
| Returns an object defined by the study and its entry in the GEOM component. More... | |
| GEOM_Object | AddSubShape (in GEOM_Object theMainShape, in ListOfLong theIndices) |
| Add a sub-shape defined by indices in theIndices (contains unique IDs of sub-shapes inside theMainShape) More... | |
| GEOM_Object | GetIORFromString (in string theIOR) |
| Returns a GEOM_Object defined by its IOR. More... | |
| string | GetStringFromIOR (in GEOM_Object theObject) |
| Returns a string which contains an IOR of the GEOM_Object. More... | |
| string | GetDumpName (in string theStudyEntry) |
| Returns a name with which a GEOM_Object was dumped into python script. More... | |
| string_array | GetAllDumpNames () |
| Returns all names with which a GEOM_Object was dumped into python script to avoid the same names in SMESH script. More... | |
| ListOfGO | PublishNamedShapesInStudy (in Object theObject) |
| Publishes the named sub-shapes of given object in the study. More... | |
| SALOMEDS::SObject | CreateFolder (in string theName, in SALOMEDS::SObject theFather) |
| Creates a new folder. More... | |
| void | MoveToFolder (in GEOM_Object theObject, in SALOMEDS::SObject theFolder) |
| Moves object to the specified folder. More... | |
| void | MoveListToFolder (in ListOfGO theListOfGO, in SALOMEDS::SObject theFolder) |
| Moves list of objects to the specified folder. More... | |
| void | Move (in object_list what, in SALOMEDS::SObject where, in long row) |
| Moves objects to the specified position. More... | |
| SALOMEDS::TMPFile | GetDependencyTree (in string_array theListOfEntries) |
| Collects dependencies of the given objects from other ones. More... | |
| void | GetEntriesToReduceStudy (inout string_array theSelectedEntries, inout string_array theParentEntries, inout string_array theSubEntries, inout string_array theOtherEntries) |
| Fills 3 lists that is used to reduce study of redundant objects: More... | |
| void | BreakLink (in string theEntry) |
Also contains some methods to access and manage GEOM_Object.
| SALOMEDS::SObject GEOM::GEOM_Gen::AddInStudy | ( | in GEOM_BaseObject | theObject, |
| in string | theName, | ||
| in GEOM_BaseObject | theFather | ||
Adds in theStudy a object theObject under with a name theName, if theFather is not NULL the object is placed under thFather's SObject. Returns a SObject where theObject is placed
| GEOM_Object GEOM::GEOM_Gen::AddSubShape | ( | in GEOM_Object | theMainShape, |
| in ListOfLong | theIndices | ||
| void GEOM::GEOM_Gen::BreakLink | ( | in string | theEntry | ) |
| SALOMEDS::SObject GEOM::GEOM_Gen::CreateFolder | ( | in string | theName, |
| in SALOMEDS::SObject | theFather | ||
Creates a new container (folder) for any GEOM objects. Folder will have name theName. If theFather is not NULL, the folder is placed under theFather object. Otherwise, the folder takes place under root 'Geometry' object.
| theName | name of the folder |
| theFather | parent object |
| string_array GEOM::GEOM_Gen::GetAllDumpNames | ( | ) |
| SALOMEDS::TMPFile GEOM::GEOM_Gen::GetDependencyTree | ( | in string_array | theListOfEntries | ) |
| theListOfEntries | List of GEOM object entries in OCAF tree (not in study) |
| string GEOM::GEOM_Gen::GetDumpName | ( | in string | theStudyEntry | ) |
| theStudyEntry | is an entry of the GEOM_Object in the study |
| void GEOM::GEOM_Gen::GetEntriesToReduceStudy | ( | inout string_array | theSelectedEntries, |
| inout string_array | theParentEntries, | ||
| inout string_array | theSubEntries, | ||
| inout string_array | theOtherEntries | ||
| theSelectedEntries | List of GEOM object entries in OCAF tree |
| theParentEntries | List of GEOM object entries on which the given objects depend |
| theSubEntries | Children entries list of the given objects |
| theOtherEntries | List of GEOM object entries which are in the study, but not in parents and children lists |
| GEOM_I3DPrimOperations GEOM::GEOM_Gen::GetI3DPrimOperations | ( | ) | ||
| raises | ( | SALOME::SALOME_Exception | ||
| GEOM_IBasicOperations GEOM::GEOM_Gen::GetIBasicOperations | ( | ) | ||
| GEOM_IBlocksOperations GEOM::GEOM_Gen::GetIBlocksOperations | ( | ) | ||
| GEOM_IBooleanOperations GEOM::GEOM_Gen::GetIBooleanOperations | ( | ) | ||
| GEOM_ICanonicalRecognition GEOM::GEOM_Gen::GetICanonicalRecognition | ( | ) | ||
| GEOM_ICurvesOperations GEOM::GEOM_Gen::GetICurvesOperations | ( | ) | ||
| GEOM_IFieldOperations GEOM::GEOM_Gen::GetIFieldOperations | ( | ) | ||
| GEOM_IGroupOperations GEOM::GEOM_Gen::GetIGroupOperations | ( | ) | ||
| GEOM_IHealingOperations GEOM::GEOM_Gen::GetIHealingOperations | ( | ) | ||
| GEOM_IInsertOperations GEOM::GEOM_Gen::GetIInsertOperations | ( | ) | ||
| GEOM_ILocalOperations GEOM::GEOM_Gen::GetILocalOperations | ( | ) | ||
| GEOM_IMeasureOperations GEOM::GEOM_Gen::GetIMeasureOperations | ( | ) | ||
| GEOM_Object GEOM::GEOM_Gen::GetIORFromString | ( | in string | theIOR | ) |
| theIOR | a string containing an IOR of the requested GEOM_Object |
| GEOM_IShapesOperations GEOM::GEOM_Gen::GetIShapesOperations | ( | ) | ||
| GEOM_ITestOperations GEOM::GEOM_Gen::GetITestOperations | ( | ) | ||
| GEOM_ITransformOperations GEOM::GEOM_Gen::GetITransformOperations | ( | ) | ||
| GEOM_BaseObject GEOM::GEOM_Gen::GetObject | ( | in string | theEntry | ) |
| theEntry | is an entry of the requested GEOM_Object in the GEOM component |
| GEOM_IOperations GEOM::GEOM_Gen::GetPluginOperations | ( | in string | theLibName | ) | |
| raises | ( | SALOME::SALOME_Exception | |||
| string GEOM::GEOM_Gen::GetStringFromIOR | ( | in GEOM_Object | theObject | ) |
| theObject | is a GEOM_Object which IOR is requested |
| void GEOM::GEOM_Gen::Move | ( | in object_list | what, |
| in SALOMEDS::SObject | where, | ||
| in long | row | ||
This function is used in the drag-n-drop functionality.
| what | objects being moved |
| where | parent object where objects are moved to |
| row | position in the parent object's children list at which objects are moved |
| void GEOM::GEOM_Gen::MoveListToFolder | ( | in ListOfGO | theListOfGO, |
| in SALOMEDS::SObject | theFolder | ||
The moved objects should be first published in the study.
| theListOfGO | list of GEOM objects to move |
| theFolder | target folder |
| void GEOM::GEOM_Gen::MoveToFolder | ( | in GEOM_Object | theObject, |
The moved object should be first published in the study.
| theObject | GEOM object to move |
| ListOfGO GEOM::GEOM_Gen::PublishNamedShapesInStudy | ( | in Object | theObject | ) |
| theObject | The object which named sub-shapes are published |
| void GEOM::GEOM_Gen::Redo | ( | ) |
| void GEOM::GEOM_Gen::RemoveObject | ( | in GEOM_BaseObject | theObject | ) |
| theObject | is a GEOM_Object to be removed |
| ListOfGO GEOM::GEOM_Gen::RestoreGivenSubShapesO | ( | in GEOM_Object | theObject, |
| in ListOfGO | theArgs, | ||
| in find_shape_method | theFindMethod, | ||
| in boolean | theInheritFirstArg, | ||
| in boolean | theAddPrefix | ||
To be used from python scripts out of geompy.addToStudy (non-default usage)
| theObject | published GEOM_Object, arguments of which will be published |
| theArgs | list of GEOM_Object, operation arguments to be published. If this list is empty, all operation arguments will be published |
| theFindMethod | method to search sub-shapes, corresponding to arguments and their sub-shapes. Value from enumeration GEOM::find_shape_method. |
| theInheritFirstArg | set properties of the first argument for theObject. Do not publish sub-shapes in place of arguments, but only in place of sub-shapes of the first argument, because the whole shape corresponds to the first argument. Mainly to be used after transformations, but it also can be useful after partition with one object shape, and some other operations, where only the first argument has to be considered. If theObject has only one argument shape, this flag is automatically considered as True, not regarding really passed value. |
| theAddPrefix | add prefix "from_" to names of restored sub-shapes, and prefix "from_subshapes_of_" to names of partially restored sub-shapes. |
| ListOfGO GEOM::GEOM_Gen::RestoreSubShapesO | ( | in GEOM_Object | theObject, |
| ListOfGO GEOM::GEOM_Gen::RestoreSubShapesSO | ( | in SALOMEDS::SObject | theSObject, |
To be used from GUI and from geompy.addToStudy. Work like the above method, but accepts study object theSObject instead of GEOM_Object.
| theSObject | study object, referencing GEOM_Object, arguments of which will be published |
| void GEOM::GEOM_Gen::Undo | ( | ) |
