GEOM::GEOM_IShapesOperations Interface Reference
Interface for Shapes creation: More...
import"GEOM_Gen.idl";
Inheritance diagram for GEOM::GEOM_IShapesOperations:
struct  ExtractionStat
enum  ExtractionStatType { EST_Removed , EST_Modified , EST_Added }
 This enumeration represents an extraction statistics type. More...
typedef sequence< ExtractionStat > ExtractionStats
GEOM_Object MakeEdge (in GEOM_Object thePnt1, in GEOM_Object thePnt2)
 Create a linear edge with specified ends. More...
GEOM_Object MakeEdgeOnCurveByLength (in GEOM_Object theRefCurve, in double theLength, in GEOM_Object theStartPoint)
 Create an edge on another edge, corresponding to the given length on the given edge. More...
GEOM_Object MakeEdgeWire (in GEOM_Object theWire, in double theLinearTolerance, in double theAngularTolerance)
 Create an edge from specified wire. More...
GEOM_Object MakeWire (in ListOfGO theEdgesAndWires, in double theTolerance, in wire_build_mode theMode)
 Create a wire from the set of edges and wires. More...
GEOM_Object MakeFace (in GEOM_Object theWire, in boolean isPlanarWanted)
 Create a face on the given wire. More...
GEOM_Object MakeFaceWires (in ListOfGO theWires, in boolean isPlanarWanted)
 Create a face on the given wires set. More...
GEOM_Object MakeFaceFromSurface (in GEOM_Object theFace, in GEOM_Object theWire)
 Create a face based on surface of theFace limited by theWire. More...
GEOM_Object MakeWrappedFace (in ListOfGO theEdges, in ListOfGO theVertices, in double theTolerance)
 Create a bounded face with list of edges and list of vertices. More...
GEOM_Object MakeFaceWithConstraints (in ListOfGO theConstraints)
 Create a face from a set of edges with the given constraints. More...
GEOM_Object MakeShell (in ListOfGO theFacesAndShells)
 Create a shell from the set of faces and shells. More...
GEOM_Object MakeSolidShell (in GEOM_Object theShell)
 Create a solid, bounded by the given shell. More...
GEOM_Object MakeSolidShells (in ListOfGO theShells)
 Create a solid, bounded by the given shells. More...
GEOM_Object MakeCompound (in ListOfGO theShapes)
 Create a compound of the given shapes. More...
GEOM_Object MakeSolidFromConnectedFaces (in ListOfGO theFacesOrShells, in boolean isIntersect)
 Make a solid (or solids) from connected set of faces and/or shells. More...
GEOM_Object MakeGlueFaces (in ListOfGO theShapes, in double theTolerance, in boolean doKeepNonSolids)
 Replace coincident faces in theShapes by one face. More...
ListOfGO GetGlueFaces (in ListOfGO theShapes, in double theTolerance)
GEOM_Object MakeGlueFacesByList (in ListOfGO theShapes, in double theTolerance, in ListOfGO theFaces, in boolean doKeepNonSolids, in boolean doGlueAllEdges)
 Replace coincident faces in theShapes by one face in compliance with given list of faces. More...
GEOM_Object MakeGlueEdges (in ListOfGO theShapes, in double theTolerance)
 Replace coincident edges in theShapes by one edge. More...
ListOfGO GetGlueEdges (in ListOfGO theShapes, in double theTolerance)
GEOM_Object MakeGlueEdgesByList (in ListOfGO theShapes, in double theTolerance, in ListOfGO theEdges)
 Replace coincident edges in theShapes by one edge in compliance with given list of edges. More...
ListOfGO GetExistingSubObjects (in GEOM_Object theShape, in boolean theGroupsOnly)
 Get all sub-shapes and groups of theShape, that were created already by any other methods. More...
ListOfGO MakeExplode (in GEOM_Object theShape, in long theShapeType, in boolean isSorted)
 Deprecated method. More...
ListOfGO MakeAllSubShapes (in GEOM_Object theShape, in long theShapeType, in boolean isSorted)
 Explode a shape on sub-shapes of a given type. More...
ListOfGO ExtractSubShapes (in GEOM_Object theShape, in long theShapeType, in boolean isSorted)
 Extract all sub-shapes of the given type from the given shape, excluding the shape itself. More...
ListOfLong SubShapeAllIDs (in GEOM_Object theShape, in long theShapeType, in boolean isSorted)
 Deprecated method. Use GetAllSubShapesIDs() instead. More...
ListOfLong GetAllSubShapesIDs (in GEOM_Object theShape, in long theShapeType, in boolean isSorted)
GEOM_Object GetSubShape (in GEOM_Object theMainShape, in long theID)
 Get a sub-shape defined by its unique ID inside theMainShape. More...
ListOfGO MakeSubShapes (in GEOM_Object theMainShape, in ListOfLong theIndices)
 Get a set of sub-shapes defined by their unique IDs inside theMainShape. More...
long GetSubShapeIndex (in GEOM_Object theMainShape, in GEOM_Object theSubShape)
ListOfLong GetSubShapesIndices (in GEOM_Object theMainShape, in ListOfGO theSubShapes)
long GetTopologyIndex (in GEOM_Object theMainShape, in GEOM_Object theSubShape)
 Get index of theSubShape in theMainShape, unique among sub-shapes of the same type. More...
string GetShapeTypeString (in GEOM_Object theShape)
 Get name of type of theShape. More...
boolean IsSubShapeBelongsTo (in GEOM_Object theSubObject, in long theSubObjectIndex, in GEOM_Object theObject, in long theObjectIndex)
 Check if the object is a sub-object of another GEOM object. More...
long NumberOfFaces (in GEOM_Object theShape)
 Count number of faces in the given shape. More...
long NumberOfEdges (in GEOM_Object theShape)
 Count number of edges in the given shape. More...
long NumberOfSubShapes (in GEOM_Object theShape, in long theShapeType)
 Count number of sub-shapes of type theShapeType in the given shape. More...
GEOM_Object ChangeOrientation (in GEOM_Object theShape)
ListOfLong GetFreeFacesIDs (in GEOM_Object theShape)
 Retrieve all free faces from the given shape. More...
ListOfGO GetSharedShapes (in GEOM_Object theShape1, in GEOM_Object theShape2, in long theShapeType)
 Get all sub-shapes of theShape1 of the given type, shared with theShape2. More...
ListOfGO GetSharedShapesMulti (in ListOfGO theShapes, in long theShapeType, in boolean theMultiShare)
 Get sub-shapes, shared by input shapes. More...
ListOfGO GetShapesOnPlane (in GEOM_Object theShape, in long theShapeType, in GEOM_Object theAx1, in shape_state theState)
 Find in theShape all sub-shapes of type theShapeType, situated relatively the specified plane by the certain way, defined through theState parameter. More...
ListOfGO GetShapesOnPlaneWithLocation (in GEOM_Object theShape, in long theShapeType, in GEOM_Object theAx1, in GEOM_Object thePnt, in shape_state theState)
ListOfGO GetShapesOnCylinder (in GEOM_Object theShape, in long theShapeType, in GEOM_Object theAxis, in double theRadius, in shape_state theState)
 Find in theShape all sub-shapes of type theShapeType, situated relatively the specified cylinder by the certain way, defined through theState parameter. More...
ListOfGO GetShapesOnCylinderWithLocation (in GEOM_Object theShape, in long theShapeType, in GEOM_Object theAxis, in GEOM_Object thePnt, in double theRadius, in shape_state theState)
ListOfGO GetShapesOnSphere (in GEOM_Object theShape, in long theShapeType, in GEOM_Object theCenter, in double theRadius, in shape_state theState)
 Find in theShape all sub-shapes of type theShapeType, situated relatively the specified sphere by the certain way, defined through theState parameter. More...
ListOfGO GetShapesOnQuadrangle (in GEOM_Object theShape, in long theShapeType, in GEOM_Object theTopLeftPoint, in GEOM_Object theTopRightPoint, in GEOM_Object theBottomLeftPoint, in GEOM_Object theBottomRightPoint, in shape_state theState)
 Find in theShape all sub-shapes of type theShapeType, situated relatively the specified quadrangle by the certain way, defined through theState parameter. More...
ListOfLong GetShapesOnPlaneIDs (in GEOM_Object theShape, in long theShapeType, in GEOM_Object theAx1, in shape_state theState)
ListOfLong GetShapesOnPlaneWithLocationIDs (in GEOM_Object theShape, in long theShapeType, in GEOM_Object theAx1, in GEOM_Object thePnt, in shape_state theState)
ListOfLong GetShapesOnCylinderIDs (in GEOM_Object theShape, in long theShapeType, in GEOM_Object theAxis, in double theRadius, in shape_state theState)
ListOfLong GetShapesOnCylinderWithLocationIDs (in GEOM_Object theShape, in long theShapeType, in GEOM_Object theAxis, in GEOM_Object thePnt, in double theRadius, in shape_state theState)
ListOfLong GetShapesOnSphereIDs (in GEOM_Object theShape, in long theShapeType, in GEOM_Object theCenter, in double theRadius, in shape_state theState)
ListOfLong GetShapesOnQuadrangleIDs (in GEOM_Object theShape, in long theShapeType, in GEOM_Object theTopLeftPoint, in GEOM_Object theTopRightPoint, in GEOM_Object theBottomLeftPoint, in GEOM_Object theBottomRightPoint, in shape_state theState)
ListOfLong GetShapesOnBoxIDs (in GEOM_Object theBox, in GEOM_Object theShape, in long theShapeType, in shape_state theState)
 Find sub-shapes complying with given status. More...
ListOfGO GetShapesOnBox (in GEOM_Object theBox, in GEOM_Object theShape, in long theShapeType, in shape_state theState)
ListOfLong GetShapesOnShapeIDs (in GEOM_Object theCheckShape, in GEOM_Object theShape, in short theShapeType, in shape_state theState)
ListOfGO GetShapesOnShape (in GEOM_Object theCheckShape, in GEOM_Object theShape, in short theShapeType, in shape_state theState)
GEOM_Object GetShapesOnShapeAsCompound (in GEOM_Object theCheckShape, in GEOM_Object theShape, in short theShapeType, in shape_state theState)
GEOM_Object GetInPlace (in GEOM_Object theShapeWhere, in GEOM_Object theShapeWhat)
 Get sub-shape(s) of theShapeWhere, which are coincident with theShapeWhat or could be a part of it. More...
GEOM_Object GetInPlaceOld (in GEOM_Object theShapeWhere, in GEOM_Object theShapeWhat)
GEOM_Object GetInPlaceByHistory (in GEOM_Object theShapeWhere, in GEOM_Object theShapeWhat)
ListOfListOfLong GetInPlaceMap (in GEOM_Object theShapeWhere, in GEOM_Object theShapeWhat)
 A sort of GetInPlace functionality, returning for each sub-shape ID of theShapeWhat a list of corresponding sub-shape IDs of theShapeWhere. For example, if theShapeWhat is a box and theShapeWhere is this box cut into two parts by a plane, then the result can be as this: len( result_list ) = 35, result_list[ 1 ] = [ 2, 36 ], which means that the box turned into two solids with IDs 2 and 36 within theShapeWhere. More...
GEOM_Object GetSame (in GEOM_Object theShapeWhere, in GEOM_Object theShapeWhat)
 Get sub-shape of theShapeWhere, which are coincident with theShapeWhat that can either SOLID, FACE, EDGE or VERTEX. More...
ListOfLong GetSameIDs (in GEOM_Object theShapeWhere, in GEOM_Object theShapeWhat)
 Get sub-shape Ids of theShapeWhere, which are coincident with theShapeWhat that can either SOLID, FACE, EDGE or VERTEX. More...
GEOM_Object ExtendEdge (in GEOM_Object theEdge, in double theMin, in double theMax)
 Resize the input edge with the new Min and Max parameters. The input edge parameters range is [0, 1]. If theMin parameter is negative, the input edge is extended, otherwise it is shrinked by theMin parameter. If theMax is greater than 1, the edge is extended, otherwise it is shrinked by theMax parameter. More...
GEOM_Object ExtendFace (in GEOM_Object theFace, in double theUMin, in double theUMax, in double theVMin, in double theVMax)
 Resize the input face with the new UMin, UMax, VMin and VMax parameters. The input face U and V parameters range is [0, 1]. If theUMin parameter is negative, the input face is extended, otherwise it is shrinked along U direction by theUMin parameter. If theUMax is greater than 1, the face is extended, otherwise it is shrinked along U direction by theUMax parameter. So as for theVMin, theVMax and V direction of the input face. More...
GEOM_Object MakeSurfaceFromFace (in GEOM_Object theFace)
 Make a surface from a face. This function takes some face as input parameter and creates new GEOM_Object, i.e. topological shape by extracting underlying surface of the source face and limiting it by the Umin, Umax, Vmin, Vmax parameters of the source face (in the parametrical space). More...
ListOfGO GetSubShapeEdgeSorted (in GEOM_Object theShape, in GEOM_Object theStartPoint)
 Explode a shape into edges sorted in a row from a starting point. More...
ListOfGO GetSubShapesWithTolerance (in GEOM_Object theShape, in short theShapeType, in comparison_condition theCondition, in double theTolerance)
 Return the list of subshapes that satisfies a certain tolerance criterion. The user defines the type of shapes to be returned, the condition and the tolerance value. The operation is defined for faces, edges and vertices only. E.g. for theShapeType FACE, theCondition CC_GT and theTolerance 1.e-7 this method returns all faces of theShape that have tolerances greater then 1.e7. More...
GEOM_Object MakeExtraction (in GEOM_Object theShape, in ListOfLong theSubShapeIDs, out ExtractionStats theStats)
 Return the shape that is constructed from theShape without extracted sub-shapes from the input list. More...
- Public Member Functions inherited from GEOM::GEOM_IOperations
boolean IsDone ()
 To know, if the operation was successfully performed. More...
void SetErrorCode (in string theErrorID)
 Set the operation error code. More...
string GetErrorCode ()
 Get the operation error code. More...
void StartOperation ()
 Opens a new transaction. More...
void FinishOperation ()
 Closes the previously opened transaction. More...
void AbortOperation ()
 Aborts the previously opened transaction. More...
Edge from two points, Wire from edges, Face from wire, Shell from faces, Solid from shells, Compound from shapes
◆ ExtractionStats
◆ ExtractionStatType
It is used in the interface GEOM_IShapesOperations::MakeExtraction.
EST_Removed
Removed sub-shapes.
EST_Modified
Modified sub-shapes.
EST_Added
Newly created sub-shapes.
◆ ChangeOrientation()
GEOM_Object GEOM::GEOM_IShapesOperations::ChangeOrientation ( in GEOM_Object  theShape)
Reverses an orientation the given shape.
theShapeShape to be reversed.
The reversed copy of theShape.
◆ ExtendEdge()
GEOM_Object GEOM::GEOM_IShapesOperations::ExtendEdge ( in GEOM_Object  theEdge,
in double  theMin,
in double  theMax
theEdgethe input edge to be resized.
theMinthe minimal parameter value.
theMaxthe maximal parameter value.
a newly created edge.
◆ ExtendFace()
GEOM_Object GEOM::GEOM_IShapesOperations::ExtendFace ( in GEOM_Object  theFace,
in double  theUMin,
in double  theUMax,
in double  theVMin,
in double  theVMax
theFacethe input face to be resized.
theUMinthe minimal U parameter value.
theUMaxthe maximal U parameter value.
theVMinthe minimal V parameter value.
theVMaxthe maximal V parameter value.
a newly created face.
◆ ExtractSubShapes()
ListOfGO GEOM::GEOM_IShapesOperations::ExtractSubShapes ( in GEOM_Object  theShape,
in boolean  isSorted
theShapeShape to be exploded.
theShapeTypeType of sub-shapes to be retrieved.
isSortedIf this parameter is TRUE, sub-shapes will be sorted by coordinates of their gravity centers.
List of sub-shapes of type theShapeType, contained in theShape.
◆ GetAllSubShapesIDs()
ListOfLong GEOM::GEOM_IShapesOperations::GetAllSubShapesIDs ( in GEOM_Object  theShape,
in boolean  isSorted
Does the same, as MakeAllSubShapes, but returns IDs of sub-shapes, not GEOM_Object. It works faster.
List of IDs of sub-shapes of type theShapeType, contained in theShape.
◆ GetExistingSubObjects()
ListOfGO GEOM::GEOM_IShapesOperations::GetExistingSubObjects ( in GEOM_Object  theShape,
theShapeAny shape.
theGroupsOnlyIf this parameter is TRUE, only groups will be returned, else all found sub-shapes and groups.
List of existing sub-objects of theShape.
◆ GetFreeFacesIDs()
ListOfLong GEOM::GEOM_IShapesOperations::GetFreeFacesIDs ( in GEOM_Object  theShape)
Free face is a face, which is not shared between two shells of the shape.
theShapeShape to find free faces in.
List of IDs of all free faces, contained in theShape.
◆ GetGlueEdges()
ListOfGO GEOM::GEOM_IShapesOperations::GetGlueEdges ( in ListOfGO  theShapes,
Find coincident edges in theShapes for possible gluing.
theShapesInitial shapes.
theToleranceMaximum distance between edges, which can be considered as coincident.
ListOfGO
◆ GetGlueFaces()
ListOfGO GEOM::GEOM_IShapesOperations::GetGlueFaces ( in ListOfGO  theShapes,
Find coincident faces in theShapes for possible gluing.
theToleranceMaximum distance between faces, which can be considered as coincident.
ListOfGO
◆ GetInPlace()
GEOM_Object GEOM::GEOM_IShapesOperations::GetInPlace ( in GEOM_Object  theShapeWhere,
theShapeWhereShape to find sub-shapes of.
theShapeWhatShape, specifying what to find.
Compound which includes all found sub-shapes if they have different types; or group of all found shapes of the equal type; or a single found sub-shape.
◆ GetInPlaceByHistory()
GEOM_Object GEOM::GEOM_IShapesOperations::GetInPlaceByHistory ( in GEOM_Object  theShapeWhere,
Implementation of this method is based on a saved history of an operation, produced theShapeWhere. The theShapeWhat must be among this operation's arguments (an argument shape or a sub-shape of an argument shape). The operation could be the Partition or one of boolean operations, performed on simple shapes (not on compounds).
◆ GetInPlaceMap()
ListOfListOfLong GEOM::GEOM_IShapesOperations::GetInPlaceMap ( in GEOM_Object  theShapeWhere,
◆ GetInPlaceOld()
GEOM_Object GEOM::GEOM_IShapesOperations::GetInPlaceOld ( in GEOM_Object  theShapeWhere,
Old implementation of GetInPlace functionality, based on shape properties.
◆ GetSame()
GEOM_Object GEOM::GEOM_IShapesOperations::GetSame ( in GEOM_Object  theShapeWhere,
found sub-shape.
◆ GetSameIDs()
ListOfLong GEOM::GEOM_IShapesOperations::GetSameIDs ( in GEOM_Object  theShapeWhere,
found sub-shape Ids.
◆ GetShapesOnBox()
ListOfGO GEOM::GEOM_IShapesOperations::GetShapesOnBox ( in GEOM_Object  theBox,
theBox- the box to check state of sub-shapes against
theShape- the shape to explore
theShapeType- type of sub-shape of theShape
theState- required state
List of all found sub-shapes.
◆ GetShapesOnBoxIDs()
ListOfLong GEOM::GEOM_IShapesOperations::GetShapesOnBoxIDs ( in GEOM_Object  theBox,
List of IDs of all found sub-shapes.
◆ GetShapesOnCylinder()
ListOfGO GEOM::GEOM_IShapesOperations::GetShapesOnCylinder ( in GEOM_Object  theShape,
theShapeShape to find sub-shapes of.
theAxisVector (or line, or linear edge), specifying axis of the cylinder to find shapes on.
theRadiusRadius of the cylinder to find shapes on.
theStateThe state of the sub-shapes to find.
◆ GetShapesOnCylinderIDs()
ListOfLong GEOM::GEOM_IShapesOperations::GetShapesOnCylinderIDs ( in GEOM_Object  theShape,
◆ GetShapesOnCylinderWithLocation()
ListOfGO GEOM::GEOM_IShapesOperations::GetShapesOnCylinderWithLocation ( in GEOM_Object  theShape,
thePntPoint specifying location of the bottom of the cylinder.
◆ GetShapesOnCylinderWithLocationIDs()
ListOfLong GEOM::GEOM_IShapesOperations::GetShapesOnCylinderWithLocationIDs ( in GEOM_Object  theShape,
List of IDs all found sub-shapes.
◆ GetShapesOnPlane()
ListOfGO GEOM::GEOM_IShapesOperations::GetShapesOnPlane ( in GEOM_Object  theShape,
theAx1Vector (or line, or linear edge), specifying normal direction and location of the plane to find shapes on.
◆ GetShapesOnPlaneIDs()
ListOfLong GEOM::GEOM_IShapesOperations::GetShapesOnPlaneIDs ( in GEOM_Object  theShape,
◆ GetShapesOnPlaneWithLocation()
ListOfGO GEOM::GEOM_IShapesOperations::GetShapesOnPlaneWithLocation ( in GEOM_Object  theShape,
theAx1Vector (or line, or linear edge), specifying normal direction of the plane to find shapes on.
thePntPoint specifying location of the plane to find shapes on.
◆ GetShapesOnPlaneWithLocationIDs()
ListOfLong GEOM::GEOM_IShapesOperations::GetShapesOnPlaneWithLocationIDs ( in GEOM_Object  theShape,
◆ GetShapesOnQuadrangle()
ListOfGO GEOM::GEOM_IShapesOperations::GetShapesOnQuadrangle ( in GEOM_Object  theShape,
theTopLeftPointTop left quadrangle corner
theTopRightPointTop right quadrangle corner
theBottomLeftPointBottom left quadrangle corner
theBottomRightPointBottom right quadrangle corner
◆ GetShapesOnQuadrangleIDs()
ListOfLong GEOM::GEOM_IShapesOperations::GetShapesOnQuadrangleIDs ( in GEOM_Object  theShape,
◆ GetShapesOnShape()
ListOfGO GEOM::GEOM_IShapesOperations::GetShapesOnShape ( in GEOM_Object  theCheckShape,
theCheckShape- the shape to check state of sub-shapes against. It must be a solid.
◆ GetShapesOnShapeAsCompound()
GEOM_Object GEOM::GEOM_IShapesOperations::GetShapesOnShapeAsCompound ( in GEOM_Object  theCheckShape,
compound includes all found sub-shapes.
◆ GetShapesOnShapeIDs()
ListOfLong GEOM::GEOM_IShapesOperations::GetShapesOnShapeIDs ( in GEOM_Object  theCheckShape,
◆ GetShapesOnSphere()
ListOfGO GEOM::GEOM_IShapesOperations::GetShapesOnSphere ( in GEOM_Object  theShape,
theCenterPoint, specifying center of the sphere to find shapes on.
theRadiusRadius of the sphere to find shapes on.
◆ GetShapesOnSphereIDs()
ListOfLong GEOM::GEOM_IShapesOperations::GetShapesOnSphereIDs ( in GEOM_Object  theShape,
◆ GetShapeTypeString()
string GEOM::GEOM_IShapesOperations::GetShapeTypeString ( in GEOM_Object  theShape)
Use wide type notation, taking into consideration both topology and geometry of the shape. Together with method GetTopologyIndex() it can be used to generate automatic names for sub-shapes, when publishing them in a study.
theShapeThe shape to get a type of.
String, containing a type name of theShape.
◆ GetSharedShapes()
ListOfGO GEOM::GEOM_IShapesOperations::GetSharedShapes ( in GEOM_Object  theShape1,
theShape1Shape to find sub-shapes in.
theShape2Shape to find shared sub-shapes with.
List of sub-shapes of theShape1, shared with theShape2.
◆ GetSharedShapesMulti()
ListOfGO GEOM::GEOM_IShapesOperations::GetSharedShapesMulti ( in ListOfGO  theShapes,
theShapesShapes to find common sub-shapes of.
theMultiShareSpecifies what type of shares should be checked:
  • TRUE: search sub-shapes from 1st input shape shared with all other input shapes;
  • FALSE: causes to search sub-shapes shared between couples of input shapes.
If theShapes contains single compound, the shares between all possible couples of its top-level shapes are returned; otherwise, only shares between 1st input shape and all rest input shapes are returned.
◆ GetSubShape()
GEOM_Object GEOM::GEOM_IShapesOperations::GetSubShape ( in GEOM_Object  theMainShape,
in long  theID
theMainShapeMain shape.
theIDUnique ID of sub-shape inside theMainShape.
GEOM_Object, corresponding to found sub-shape.
The sub-shape GEOM_Object can has ONLY ONE function. Don't try to apply modification operations (without copy) on them.
◆ GetSubShapeEdgeSorted()
ListOfGO GEOM::GEOM_IShapesOperations::GetSubShapeEdgeSorted ( in GEOM_Object  theShape,
theShape- the shape to be exploded on edges.
theStartPoint- the starting point.
Ordered list of edges sorted in a row from a starting point.
◆ GetSubShapeIndex()
long GEOM::GEOM_IShapesOperations::GetSubShapeIndex ( in GEOM_Object  theMainShape,
Get global index of theSubShape in theMainShape.
theSubShapeSub-shape of the main shape.
◆ GetSubShapesIndices()
ListOfLong GEOM::GEOM_IShapesOperations::GetSubShapesIndices ( in GEOM_Object  theMainShape,
Get global indices of theSubShapes in theMainShape.
theSubShapesList of sub-shapes of the main shape.
list of global indices of theSubShapes in theMainShape.
◆ GetSubShapesWithTolerance()
ListOfGO GEOM::GEOM_IShapesOperations::GetSubShapesWithTolerance ( in GEOM_Object  theShape,
theShapethe shape to be exploded
theShapeTypethe type of shapes to be returned. Can have the values FACE, EDGE and VERTEX only.
theConditionthe condition type.
theTolerancethe tolerance filter.
the list of shapes that satisfy the conditions.
◆ GetTopologyIndex()
long GEOM::GEOM_IShapesOperations::GetTopologyIndex ( in GEOM_Object  theMainShape,
Together with method GetShapeTypeString() it can be used to generate automatic names for sub-shapes, when publishing them in a study.
index of theSubShape in a list of all sub-shapes of theMainShape of the same type.
◆ IsSubShapeBelongsTo()
boolean GEOM::GEOM_IShapesOperations::IsSubShapeBelongsTo ( in GEOM_Object  theSubObject,
theSubObjectChecked sub-object (or its parent object, in case if theSubObjectIndex is non-zero).
theSubObjectIndexWhen non-zero, specifies a sub-shape index that identifies a sub-object within its parent specified via theSubObject.
theObjectAn object that is checked for ownership (or its parent object, in case if theObjectIndex is non-zero).
theObjectIndexWhen non-zero, specifies a sub-shape index that identifies an object within its parent specified via theObject.
TRUE, if the given object contains sub-object.
◆ MakeAllSubShapes()
ListOfGO GEOM::GEOM_IShapesOperations::MakeAllSubShapes ( in GEOM_Object  theShape,
in boolean  isSorted
If the shape itself has the given type, it is also returned.
◆ MakeCompound()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeCompound ( in ListOfGO  theShapes)
theShapesList of shapes to put in compound.
New GEOM_Object, containing the created compound.
◆ MakeEdge()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeEdge ( in GEOM_Object  thePnt1,
thePnt1Point for the first end of edge.
thePnt2Point for the second end of edge.
New GEOM_Object, containing the created edge.
◆ MakeEdgeOnCurveByLength()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeEdgeOnCurveByLength ( in GEOM_Object  theRefCurve,
theRefCurveThe referenced edge.
theLengthLength on the referenced edge. It can be negative for extrapolation on base curve.
theStartPointAny vertex close to one of edge's ends to select start point among them. If NULL, fist vertex is used.
◆ MakeEdgeWire()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeEdgeWire ( in GEOM_Object  theWire,
theWiresource Wire.
theLinearTolerancelinear tolerance value
theAngularToleranceangular tolerance value
◆ MakeExplode()
ListOfGO GEOM::GEOM_IShapesOperations::MakeExplode ( in GEOM_Object  theShape,
in boolean  isSorted
Use MakeAllSubShapes() instead.
◆ MakeExtraction()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeExtraction ( in GEOM_Object  theShape,
theShapethe original shape.
theSubShapeIDsthe list of sub-shape IDs to be extracted from the original shape.
theStatsthe operation statistics. Output parameter.
the shape without extracted sub-shapes.
◆ MakeFace()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeFace ( in GEOM_Object  theWire,
theWireclosed Wire or Edge to build the face on.
isPlanarWantedIf TRUE, only planar face will be built. If impossible, NULL object will be returned.
New GEOM_Object, containing the created face.
◆ MakeFaceFromSurface()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeFaceFromSurface ( in GEOM_Object  theFace,
theFacethe face whose surface is used to create a new face.
theWireclosed Wire build the face.
◆ MakeFaceWires()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeFaceWires ( in ListOfGO  theWires,
theWiresList of closed wires or edges to build the face on.
◆ MakeFaceWithConstraints()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeFaceWithConstraints ( in ListOfGO  theConstraints)
theConstraintsList of edges and constraint faces (as a sequence of a Edge + Face couples):
  • edges should form a closed wire;
  • for each edge, constraint face is optional: if a constraint face is missing for some edge, this means that there no constraint associated with this edge.
◆ MakeGlueEdges()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeGlueEdges ( in ListOfGO  theShapes,
New GEOM_Object containing copies of theShapes without coincident edges.
◆ MakeGlueEdgesByList()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeGlueEdgesByList ( in ListOfGO  theShapes,
theEdgesList of edges for gluing.
New GEOM_Object containing copies of theShapes without some edges.
◆ MakeGlueFaces()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeGlueFaces ( in ListOfGO  theShapes,
doKeepNonSolidsIf FALSE, only solids will present in the result, otherwise all initial shapes.
New GEOM_Object containing copies of theShapes without coincident faces.
◆ MakeGlueFacesByList()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeGlueFacesByList ( in ListOfGO  theShapes,
theFacesList of faces for gluing.
doGlueAllEdgesIf TRUE, all coincident edges of theShape will be glued, otherwise only the edges, belonging to theFaces.
◆ MakeShell()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeShell ( in ListOfGO  theFacesAndShells)
theFacesAndShellsList of faces and/or shells.
New GEOM_Object, containing the created shell.
◆ MakeSolidFromConnectedFaces()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeSolidFromConnectedFaces ( in ListOfGO  theFacesOrShells,
theFacesOrShellsList of faces and/or shells.
isIntersectIf TRUE, forces performing intersections between arguments.
New GEOM_Object, containing the created solid (or compound of solids).
◆ MakeSolidShell()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeSolidShell ( in GEOM_Object  theShell)
theShellBounding shell.
New GEOM_Object, containing the created solid.
◆ MakeSolidShells()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeSolidShells ( in ListOfGO  theShells)
theShellsBounding shells.
◆ MakeSubShapes()
ListOfGO GEOM::GEOM_IShapesOperations::MakeSubShapes ( in GEOM_Object  theMainShape,
theIndicesList of unique IDs of sub-shapes inside theMainShape.
List of GEOM_Object, corresponding to found sub-shapes.
◆ MakeSurfaceFromFace()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeSurfaceFromFace ( in GEOM_Object  theFace)
theFacethe input face.
◆ MakeWire()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeWire ( in ListOfGO  theEdgesAndWires,
theEdgesAndWiresList of edge and/or wires.
theToleranceMaximum distance between vertices, that will be merged. Values less than 1e-07 are equivalent to 1e-07 (Precision::Confusion()).
theModeMode of gaps filling.
New GEOM_Object, containing the created wire.
◆ MakeWrappedFace()
GEOM_Object GEOM::GEOM_IShapesOperations::MakeWrappedFace ( in ListOfGO  theEdges,
The list of edges defines the boundary of the desired face and all vertices should lie on it. The result can be a COMPOUND shape with multiple faces, if the underlying surface is somehow split within the given boundary, e.g. by the seam edge of a sphere.
theEdgeslist of Edges defining the boundary of the result face (must be closed but not nesessarily belong to the same plane) .
theVerticeslist of vertices through which the result face must pass (within the given tolerance).
theTolerancetolerance.
New GEOM_Object, containing the created shape (FACE or COMPOUND).
◆ NumberOfEdges()
long GEOM::GEOM_IShapesOperations::NumberOfEdges ( in GEOM_Object  theShape)
theShapeShape to count edges in.
Number of edges in theShape.
◆ NumberOfFaces()
long GEOM::GEOM_IShapesOperations::NumberOfFaces ( in GEOM_Object  theShape)
theShapeShape to count faces in.
Number of faces in the given shape.
◆ NumberOfSubShapes()
long GEOM::GEOM_IShapesOperations::NumberOfSubShapes ( in GEOM_Object  theShape,
theShapeShape to count sub-shapes in.
theShapeTypeThe type of sub-shapes to count.
Number of sub-shapes of type theShapeType in theShape.
◆ SubShapeAllIDs()
ListOfLong GEOM::GEOM_IShapesOperations::SubShapeAllIDs ( in GEOM_Object  theShape,
in boolean  isSorted
The documentation for this interface was generated from the following file:
