GEOM::GEOM_IMeasureOperations Interface Reference
Interface for measurement (distance, whatis) and properties calculation (like Centre of Mass, Inertia, etc.).
import"GEOM_Gen.idl";
Inheritance diagram for GEOM::GEOM_IMeasureOperations:
struct  CheckResult
 Structure for store result of check store type of check as number and failed shapes. More...
struct  PairOfShape
 Methods and structure for implement CheckConformity tool. More...
struct  ShapeError
 Description of a shape defect: type and incriminated sub-shapes. More...
enum  ShapeErrorType {
  InvalidPointOnCurve , InvalidPointOnCurveOnSurface , InvalidPointOnSurface , No3DCurve ,
  Multiple3DCurve , Invalid3DCurve , NoCurveOnSurface , InvalidCurveOnSurface ,
  InvalidCurveOnClosedSurface , InvalidSameRangeFlag , InvalidSameParameterFlag , InvalidDegeneratedFlag ,
  FreeEdge , InvalidMultiConnexity , InvalidRange , EmptyWire ,
  RedundantEdge , SelfIntersectingWire , NoSurface , InvalidWire ,
  RedundantWire , IntersectingWires , InvalidImbricationOfWires , EmptyShell ,
  RedundantFace , UnorientableShape , NotClosed , NotConnected ,
  SubshapeNotInShape , BadOrientation , BadOrientationOfSubshape , InvalidToleranceValue ,
  CheckFail
 Enumeration of Shape defects coming from CheckShape algorithms. More...
typedef sequence< ShapeError > ShapeErrors
 Sequence of all shape defects. More...
typedef sequence< PairOfShape > SequenceOfPairOfShape
typedef sequence< CheckResult > CheckResults
GEOM_IKindOfShape::shape_kind KindOfShape (in GEOM_Object theShape, out ListOfLong theIntegers, out ListOfDouble theDoubles)
 Get kind of theShape. More...
void GetPosition (in GEOM_Object theShape, out double Ox, out double Oy, out double Oz, out double Zx, out double Zy, out double Zz, out double Xx, out double Xy, out double Xz)
 Get position (LCS) of theShape. More...
void GetBasicProperties (in GEOM_Object theShape, in double theTolerance, out double theLength, out double theSurfArea, out double theVolume)
 Get summarized length of all wires, area of surface and volume of the given shape. More...
GEOM_Object GetCentreOfMass (in GEOM_Object theShape)
 Get a point, situated at the centre of mass of theShape. More...
GEOM_Object GetVertexByIndex (in GEOM_Object theShape, in long theIndex, in boolean theUseOri)
GEOM_Object GetNormal (in GEOM_Object theFace, in GEOM_Object theOptionalPoint)
 Get a vector, representing the normal of theFace. If the face is not planar, theOptionalPoint is obligatory. More...
void GetInertia (in GEOM_Object theShape, out double I11, out double I12, out double I13, out double I21, out double I22, out double I23, out double I31, out double I32, out double I33, out double Ix, out double Iy, out double Iz)
 Get inertia matrix and moments of inertia of theShape. More...
void GetBoundingBox (in GEOM_Object theShape, in boolean precise, out double Xmin, out double Xmax, out double Ymin, out double Ymax, out double Zmin, out double Zmax)
 Get parameters of bounding box of the given shape. More...
GEOM_Object MakeBoundingBox (in GEOM_Object theShape, in boolean precise)
 Get bounding box of the given shape. More...
void GetTolerance (in GEOM_Object theShape, out double FaceMin, out double FaceMax, out double EdgeMin, out double EdgeMax, out double VertMin, out double VertMax)
 Get min and max tolerances of sub-shapes of theShape. More...
boolean CheckShape (in GEOM_Object theShape, out ShapeErrors theErrors)
 Check a topology of the given shape. More...
boolean CheckShapeWithGeometry (in GEOM_Object theShape, out ShapeErrors theErrors)
 Check a topology and a geometry of the given shape. More...
boolean CheckShapeOpts (in GEOM_Object theShape, in boolean theWithGeometry, in boolean theExact, out ShapeErrors theErrors)
string PrintShapeErrors (in GEOM_Object theShape, in ShapeErrors theErrors)
 Convert sequence of shape errors, returned by CheckShape() or CheckShapeWithGeometry(), into string. More...
boolean CheckSelfIntersections (in GEOM_Object theShape, in long theCheckLevel, out ListOfLong theIntersections)
 Check a topology of the given shape on self-intersections presence. More...
boolean CheckSelfIntersectionsFast (in GEOM_Object theShape, in float theDeflection, in double theTolerance, out ListOfLong theIntersections)
 Detect self-intersections of the given shape with algorithm based on mesh intersections. More...
boolean CheckBOPArguments (in GEOM_Object theShape)
 Check boolean and partition operations arguments. More...
boolean FastIntersect (in GEOM_Object theShape1, in GEOM_Object theShape2, in double theTolerance, in float theDeflection, out ListOfLong theIntersections1, out ListOfLong theIntersections2)
 Detect intersections of the given shapes with algorithm based on mesh intersections. More...
string IsGoodForSolid (in GEOM_Object theShape)
 Check if the given shape can be an argument for MakeSolid operation. More...
string WhatIs (in GEOM_Object theShape)
 btain description of the given shape More...
ListOfBool AreCoordsInside (in GEOM_Object theShape, in ListOfDouble coords, in double tolerance)
 Check if points defined by coords = [x1, y1, z1, x2, y2, z2, ...] are inside or on the shape theShape. More...
double GetMinDistance (in GEOM_Object theShape1, in GEOM_Object theShape2, out double X1, out double Y1, out double Z1, out double X2, out double Y2, out double Z2)
 Get minimal distance between the given shapes. More...
long ClosestPoints (in GEOM_Object theShape1, in GEOM_Object theShape2, out ListOfDouble theCoords)
 Get closest points of the given shapes. More...
double GetAngle (in GEOM_Object theShape1, in GEOM_Object theShape2)
 Get angle between the given lines or linear edges. More...
double GetAngleBtwVectors (in GEOM_Object theShape1, in GEOM_Object theShape2)
 Get angle between the given vectors. More...
ListOfGO PatchFace (in GEOM_Object theShape)
 The function takes a single face with holes and returns a list of faces, first of them is the original face without holes, and the other faces are placed on the same surface as the original face but bounded by each hole wire. If the original face has no holes, it will be returned as an output. More...
void PointCoordinates (in GEOM_Object theShape, out double X, out double Y, out double Z)
 Get point coordinates. More...
double CurveCurvatureByParam (in GEOM_Object theShape, in double theParam)
 Get radius of curvature of curve in the point determinated by param. More...
double CurveCurvatureByPoint (in GEOM_Object theShape, in GEOM_Object thePoint)
 Get radius of curvature of curve in the given point. More...
double MaxSurfaceCurvatureByParam (in GEOM_Object theShape, in double theUParam, in double theVParam)
 Get max radius of curvature of surface in the point determinated by params. More...
double MaxSurfaceCurvatureByPoint (in GEOM_Object theShape, in GEOM_Object thePoint)
 Get max radius of curvature of surface in the given point. More...
double MinSurfaceCurvatureByParam (in GEOM_Object theShape, in double theUParam, in double theVParam)
 Get min radius of curvature of surface in the point determinated by params. More...
double MinSurfaceCurvatureByPoint (in GEOM_Object theShape, in GEOM_Object thePoint)
 Get min radius of curvature of surface in the given point. More...
GEOM_Object SurfaceCurvatureByPointAndDirection (in GEOM_Object theShape, in GEOM_Object thePoint, in GEOM_Object theDirection)
 Get vector of curvature of surface in the given point along the given direction. More...
ListOfDouble XYZtoUV (in GEOM_Object theSurf, in ListOfDouble theXYZlist, in boolean theIsNormalized)
 Convert X,Y,Z points coordinates to UV parameters on the given surface. More...
ListOfDouble UVtoXYZ (in GEOM_Object theSurf, in ListOfDouble theUVlist, in boolean theIsNormalized)
 Convert UV parameters on the given surface to 3D points coordinates. More...
CheckResults CheckConformityShape (in GEOM_Object theShape)
 Perform analyse of shape and return all failed checks. More...
SequenceOfPairOfShape SelfIntersected2D (in CheckResults theResults)
 Find all self-intersected 2D curves. More...
SequenceOfPairOfShape InterferingSubshapes (in CheckResults theResults, in long theShapeType1, in long theShapeType2)
 Find pairs of interfering sub-shapes, by default all pairs of interfering shapes are returned. Avaliable types: More...
ListOfGO SmallEdges (in CheckResults theResults)
 Find edges, which are fully covered by tolerances of vertices. More...
SequenceOfPairOfShape DistantShapes (in CheckResults theResults, in long theShapeType, in long theSubShapeType, in double theTolerance)
 find remote objects (sub-shape on a shape). Avaliable types: More...
double UpdateTolerance (in GEOM_Object theShape)
 Compute possible tolerance for the shape, minimize tolerance of shape as well as tolerance of sub-shapes as much as possible. More...
GEOM_Object ShapeProximityCalculator (in GEOM_Object theShape1, in GEOM_Object theShape2)
 Get the calculator for the proximity value between the given shapes. More...
void SetShapeSampling (in GEOM_Object theCalculator, in GEOM_Object theShape, in long theNbSamples)
 Set number sample points to compute the coarse proximity. More...
double GetCoarseProximity (in GEOM_Object theCalculator)
 Compute coarse value of the proximity basing on the polygonal representation of shapes. More...
double GetPreciseProximity (in GEOM_Object theCalculator)
 Compute precise value of the proximity basing on the exact shapes. More...
- Public Member Functions inherited from GEOM::GEOM_IOperations
boolean IsDone ()
 To know, if the operation was successfully performed. More...
void SetErrorCode (in string theErrorID)
 Set the operation error code. More...
string GetErrorCode ()
 Get the operation error code. More...
void StartOperation ()
 Opens a new transaction. More...
void FinishOperation ()
 Closes the previously opened transaction. More...
void AbortOperation ()
 Aborts the previously opened transaction. More...
◆ CheckResults
◆ SequenceOfPairOfShape
◆ ShapeErrors
◆ ShapeErrorType
InvalidPointOnCurve
No3DCurve
Multiple3DCurve
Invalid3DCurve
NoCurveOnSurface
FreeEdge
InvalidRange
EmptyWire
RedundantEdge
NoSurface
InvalidWire
RedundantWire
IntersectingWires
EmptyShell
RedundantFace
UnorientableShape
NotClosed
NotConnected
SubshapeNotInShape
BadOrientation
CheckFail
◆ AreCoordsInside()
ListOfBool GEOM::GEOM_IMeasureOperations::AreCoordsInside ( in GEOM_Object  theShape,
in double  tolerance
theShapeShape to check.
coordslist of coordinates.
tolerancetolerance.
list of boolean.
◆ CheckBOPArguments()
boolean GEOM::GEOM_IMeasureOperations::CheckBOPArguments ( in GEOM_Object  theShape)
theShapethe argument of an operation to be checked.
TRUE if the argument is valid for a boolean or partition operation; FALSE otherwise.
◆ CheckConformityShape()
CheckResults GEOM::GEOM_IMeasureOperations::CheckConformityShape ( in GEOM_Object  theShape)
theShapeShape for check.
◆ CheckSelfIntersections()
boolean GEOM::GEOM_IMeasureOperations::CheckSelfIntersections ( in GEOM_Object  theShape,
   \brief Extract and identify any problem in the source shapes used in a Boolean Operation.
   \param theShapes Shapes being used in the Boolean Operation
   \param theUseTimer Whether to chronometrize computation time
   \param theTopoOnly Whether to check topology only
   \param theRunParallel Whether to run the computations in parallel
   \param theDoExact Whether to perform exact checking
   \param theResultShape Output parameter. The result of BOP General Fuse. Indices of its sub-shapes are reported in theErrors structure.
   \param theErrors Output parameter. Structure, containing discovered errors and incriminated sub-shapes.
   \return TRUE, if the input shapes "seem to be valid" for BOP.
 &zwj;/
boolean ExtractBOPFailure (in ListOfGO theShapes, in boolean theUseTimer, in boolean theTopoOnly, in boolean theRunParallel, in boolean theDoExact, out GEOM_Object theResultShape, out ShapeErrors theErrors);
theShapeShape to check validity of.
theCheckLevelthe level of self-interference check.
theIntersectionsOutput. List of intersected sub-shapes IDs, it contains pairs of IDs.
TRUE, if the shape does not have any self-intersections.
◆ CheckSelfIntersectionsFast()
boolean GEOM::GEOM_IMeasureOperations::CheckSelfIntersectionsFast ( in GEOM_Object  theShape,
theDeflectionLinear deflection coefficient that specifies quality of tessellation.
theToleranceSpecifies a distance between sub-shapes used for detecting gaps:
  • if theTolerance <= 0, algorithm detects intersections
  • if theTolerance > 0, algorithm detects gaps
◆ CheckShape()
boolean GEOM::GEOM_IMeasureOperations::CheckShape ( in GEOM_Object  theShape,
theErrorsStructure, containing discovered errors and incriminated sub-shapes.
TRUE, if the shape "seems to be valid" from the topological point of view.
◆ CheckShapeOpts()
boolean GEOM::GEOM_IMeasureOperations::CheckShapeOpts ( in GEOM_Object  theShape,
theWithGeometryIf true, check also shape's geometry.
theExactIf true, take into account exact tolerance of edges. It can take more time. Exact tolerance can be greater than the approximate one, which is calculated only in some points of edge.
TRUE, if the shape "seems to be valid".
◆ CheckShapeWithGeometry()
boolean GEOM::GEOM_IMeasureOperations::CheckShapeWithGeometry ( in GEOM_Object  theShape,
◆ ClosestPoints()
long GEOM::GEOM_IMeasureOperations::ClosestPoints ( in GEOM_Object  theShape1,
theShape1,theShape2Shapes to find closest points of.
theCoordsOutput. List of (X, Y, Z) coordinates for all couples of points.
The number of found solutions (-1 in case of infinite number of solutions).
◆ CurveCurvatureByParam()
double GEOM::GEOM_IMeasureOperations::CurveCurvatureByParam ( in GEOM_Object  theShape,
in double  theParam
theShape- curve.
theParam- parameter on curve
Value of curvature.
◆ CurveCurvatureByPoint()
double GEOM::GEOM_IMeasureOperations::CurveCurvatureByPoint ( in GEOM_Object  theShape,
theShape- curve.
thePoint- point
Value of curvature.
◆ DistantShapes()
SequenceOfPairOfShape GEOM::GEOM_IMeasureOperations::DistantShapes ( in CheckResults  theResults,
  • vertex far from edge;
  • vertex far from face;
  • edge far from face
theResultsresult of check - list of failed checks and sub-shapes.
theShapeTypeType of shape.
theSubShapeTypeType of sub-shape.
theTolerancetolerance, by default used tolerance of sub-shape.
◆ FastIntersect()
boolean GEOM::GEOM_IMeasureOperations::FastIntersect ( in GEOM_Object  theShape1,
theShape1First source object
theShape2Second source object
theToleranceSpecifies a distance between shapes used for detecting gaps:
theDeflectionLinear deflection coefficient that specifies quality of tessellation:
  • if theDeflection <= 0, default deflection 0.001 is used
theIntersections1Output: contains list of sub-shapes IDs from 1st shape that localize intersection
theIntersections2Output: contains list of sub-shapes IDs from 2nd shape that localize intersection
TRUE, if the are intersections (gaps) between source shapes
◆ GetAngle()
double GEOM::GEOM_IMeasureOperations::GetAngle ( in GEOM_Object  theShape1,
theShape1,theShape2Shapes to find angle between. Lines or linear edges.
Value of the angle between the given shapes.
◆ GetAngleBtwVectors()
double GEOM::GEOM_IMeasureOperations::GetAngleBtwVectors ( in GEOM_Object  theShape1,
theShape1,theShape2Vectors to find angle between.
Value of the angle between the given vectors.
◆ GetBasicProperties()
void GEOM::GEOM_IMeasureOperations::GetBasicProperties ( in GEOM_Object  theShape,
theShapeShape to define properties of.
theTolerancemaximal relative error of area and volume computation.
theLengthOutput. Summarized length of all wires of the given shape.
theSurfAreaOutput. Area of surface of the given shape.
theVolumeOutput. Volume of the given shape.
Returns shape properties through the last three arguments.
◆ GetBoundingBox()
void GEOM::GEOM_IMeasureOperations::GetBoundingBox ( in GEOM_Object  theShape,
in boolean  precise,
out double  Xmin,
out double  Xmax,
out double  Ymin,
out double  Ymax,
out double  Zmin,
out double  Zmax
theShapeShape to obtain bounding box of.
preciseTRUE for precise computation; FALSE for fast one.
Xmin,XmaxOutput. Limits of shape along OX axis.
Ymin,YmaxOutput. Limits of shape along OY axis.
Zmin,ZmaxOutput. Limits of shape along OZ axis.
Returns parameters of bounding box through the last six arguments.
◆ GetCentreOfMass()
GEOM_Object GEOM::GEOM_IMeasureOperations::GetCentreOfMass ( in GEOM_Object  theShape)
theShapeShape to define centre of mass of.
New GEOM_Object, containing the created point.
◆ GetCoarseProximity()
double GEOM::GEOM_IMeasureOperations::GetCoarseProximity ( in GEOM_Object  theCalculator)
theCalculatorProximity calculator.
Proximity value.
◆ GetInertia()
void GEOM::GEOM_IMeasureOperations::GetInertia ( in GEOM_Object  theShape,
out double  I11,
out double  I12,
out double  I13,
out double  I21,
out double  I22,
out double  I23,
out double  I31,
out double  I32,
out double  I33,
out double  Ix,
out double  Iy,
out double  Iz
theShapeShape to calculate inertia of.
I11,I12,I13,I21,I22,I23,I31,I32,I33Output. Components of the inertia matrix of the given shape.
Ix,Iy,IzOutput. Moments of inertia of the given shape.
Returns inertia through the last twelve arguments.
◆ GetMinDistance()
double GEOM::GEOM_IMeasureOperations::GetMinDistance ( in GEOM_Object  theShape1,
out double  X1,
out double  Y1,
out double  Z1,
out double  X2,
out double  Y2,
out double  Z2
theShape1,theShape2Shapes to find minimal distance between.
X1,Y1,Z1Output. Coordinates of point on theShape1, nearest to theShape2.
X2,Y2,Z2Output. Coordinates of point on theShape2, nearest to theShape1.
Value of the minimal distance between the given shapes.
◆ GetNormal()
GEOM_Object GEOM::GEOM_IMeasureOperations::GetNormal ( in GEOM_Object  theFace,
theFaceShape (face) to define the normal of.
theOptionalPointShape (point) to define the normal at. Can be NULL in case of planar face.
New GEOM_Object, containing the created normal vector.
◆ GetPosition()
void GEOM::GEOM_IMeasureOperations::GetPosition ( in GEOM_Object  theShape,
out double  Ox,
out double  Oy,
out double  Oz,
out double  Zx,
out double  Zy,
out double  Zz,
out double  Xx,
out double  Xy,
out double  Xz
theShapeShape to calculate position of.
Ox,Oy,OzOutput. Coordinates of shape's location origin. Origin of the LCS is situated at the shape's center of mass.
Zx,Zy,ZzOutput. Coordinates of shape's location normal(main) direction.
Xx,Xy,XzOutput. Coordinates of shape's location X direction. Axes of the LCS are obtained from shape's location or, if the shape is a planar face, from position of its plane.
Returns position of the shape through the last nine arguments.
◆ GetPreciseProximity()
double GEOM::GEOM_IMeasureOperations::GetPreciseProximity ( in GEOM_Object  theCalculator)
Proximity value.
◆ GetTolerance()
void GEOM::GEOM_IMeasureOperations::GetTolerance ( in GEOM_Object  theShape,
out double  FaceMin,
out double  FaceMax,
out double  EdgeMin,
out double  EdgeMax,
out double  VertMin,
out double  VertMax
theShapeShape, to get tolerances of.
FaceMin,FaceMaxOutput. Min and max tolerances of the faces.
EdgeMin,EdgeMaxOutput. Min and max tolerances of the edges.
VertMin,VertMaxOutput. Min and max tolerances of the vertices.
Returns shape tolerances through the last six arguments.
◆ GetVertexByIndex()
GEOM_Object GEOM::GEOM_IMeasureOperations::GetVertexByIndex ( in GEOM_Object  theShape,
in long  theIndex,
◆ InterferingSubshapes()
SequenceOfPairOfShape GEOM::GEOM_IMeasureOperations::InterferingSubshapes ( in CheckResults  theResults,
  • vertices touched by tolerance;
  • vertex touching an edge in the inner point;
  • vertex lying on the inner point of a face;
  • edges intersecting by inner points;
  • edge touching/intersecting face in the inner point;
  • faces intersection by inner point
theShapeType1Type of shape.
theShapeType2Type of shape.
◆ IsGoodForSolid()
string GEOM::GEOM_IMeasureOperations::IsGoodForSolid ( in GEOM_Object  theShape)
theShapeShape to be described.
Empty string if a solid can be made on this shape, error code otherwise.
◆ KindOfShape()
GEOM_IKindOfShape::shape_kind GEOM::GEOM_IMeasureOperations::KindOfShape ( in GEOM_Object  theShape,
theShapeShape to get a kind of.
theIntegersOutput. Integer and enumerated shape's parameters (kind of surface, closed/unclosed, number of edges, etc.)
theDoublesOutput. Double shape's parameters (coordinates, dimensions, etc.)
Concrete meaning of each value, returned via theIntegers or theDoubles list depends on the kind of the shape.
Returns a kind of shape in terms of GEOM_IKindOfShape.shape_kind enumeration.
◆ MakeBoundingBox()
GEOM_Object GEOM::GEOM_IMeasureOperations::MakeBoundingBox ( in GEOM_Object  theShape,
in boolean  precise
New GEOM_Object, containing the created bounding box.
◆ MaxSurfaceCurvatureByParam()
double GEOM::GEOM_IMeasureOperations::MaxSurfaceCurvatureByParam ( in GEOM_Object  theShape,
in double  theVParam
theShape- surface.
theUParam- U-parameter on surface
theVParam- V-parameter on surface
Value of curvature.
◆ MaxSurfaceCurvatureByPoint()
double GEOM::GEOM_IMeasureOperations::MaxSurfaceCurvatureByPoint ( in GEOM_Object  theShape,
theShape- surface.
thePoint- point
Value of curvature.
◆ MinSurfaceCurvatureByParam()
double GEOM::GEOM_IMeasureOperations::MinSurfaceCurvatureByParam ( in GEOM_Object  theShape,
in double  theVParam
theShape- surface.
Value of curvature.
◆ MinSurfaceCurvatureByPoint()
double GEOM::GEOM_IMeasureOperations::MinSurfaceCurvatureByPoint ( in GEOM_Object  theShape,
theShape- surface.
thePoint- point
Value of curvature.
◆ PatchFace()
ListOfGO GEOM::GEOM_IMeasureOperations::PatchFace ( in GEOM_Object  theShape)
theShapeface, to perform operation.
ListOfGO, containing the result original face and faces from holes.
◆ PointCoordinates()
void GEOM::GEOM_IMeasureOperations::PointCoordinates ( in GEOM_Object  theShape,
out double  X,
out double  Y,
out double  Z
◆ PrintShapeErrors()
string GEOM::GEOM_IMeasureOperations::PrintShapeErrors ( in GEOM_Object  theShape,
theShapethe invalid shape.
theErrorsThe sequence of theShape errors.
String, describing all the errors in form, suitable for printing.
◆ SelfIntersected2D()
SequenceOfPairOfShape GEOM::GEOM_IMeasureOperations::SelfIntersected2D ( in CheckResults  theResults)
◆ SetShapeSampling()
void GEOM::GEOM_IMeasureOperations::SetShapeSampling ( in GEOM_Object  theCalculator,
theShapeShape to be samples.
theNbSamplesNumber of samples points.
◆ ShapeProximityCalculator()
GEOM_Object GEOM::GEOM_IMeasureOperations::ShapeProximityCalculator ( in GEOM_Object  theShape1,
theShape1,theShape2Shapes to find proximity.
The calculator object.
◆ SmallEdges()
ListOfGO GEOM::GEOM_IMeasureOperations::SmallEdges ( in CheckResults  theResults)
◆ SurfaceCurvatureByPointAndDirection()
GEOM_Object GEOM::GEOM_IMeasureOperations::SurfaceCurvatureByPointAndDirection ( in GEOM_Object  theShape,
theShape- face.
thePoint- point.
theDirection- direction.
Before the calculation of curvature, the point and the direction are projected to the face, if the point does not lay on it or the direction is not tangent to it initially.
Vector of curvature. The returned vector is codirectional with the normal to the face in the given point in case of positive curvature value and opposite to the normal in case of negative curvature. The normal of the returned vector is equal to the absolute value of the curvature.
◆ UpdateTolerance()
double GEOM::GEOM_IMeasureOperations::UpdateTolerance ( in GEOM_Object  theShape)
theShapeShape for update.
◆ UVtoXYZ()
ListOfDouble GEOM::GEOM_IMeasureOperations::UVtoXYZ ( in GEOM_Object  theSurf,
theSurfthe given face. It can be also a shell or a compound with one face.
theUVlistfloat list of size 2*N where N is the number of points for which we want their X,Y,Z coordinates. If the user enters a list of non-even size an exception will be thrown.
theIsNormalizedif True, the input parameters are expected to be in range [0, 1].
list of float of size 3*N.
◆ WhatIs()
string GEOM::GEOM_IMeasureOperations::WhatIs ( in GEOM_Object  theShape)
O
Description of the given shape.
◆ XYZtoUV()
ListOfDouble GEOM::GEOM_IMeasureOperations::XYZtoUV ( in GEOM_Object  theSurf,
theXYZlistfloat list of size 3*N where N is the number of points for which we want their U,V coordinates. If the user enters a list of size not divisible by 3 an exception will be thrown.
theIsNormalizedif True, the returned parameters will be in range [0, 1].
list of float of size 2*N.
The documentation for this interface was generated from the following file:
