Interface for shapes transforming. More...
import"GEOM_Gen.idl";
| GEOM_Object | TranslateTwoPoints (in GEOM_Object theObject, in GEOM_Object thePoint1, in GEOM_Object thePoint2) |
| Translate the given object along the vector, specified by its end points. More... | |
| GEOM_Object | TranslateTwoPointsCopy (in GEOM_Object theObject, in GEOM_Object thePoint1, in GEOM_Object thePoint2) |
| Translate the given object along the vector, specified by its end points, creating its copy before the translation. More... | |
| GEOM_Object | TranslateDXDYDZ (in GEOM_Object theObject, in double theDX, in double theDY, in double theDZ) |
| Translate the given object along the vector, specified by its components. More... | |
| GEOM_Object | TranslateDXDYDZCopy (in GEOM_Object theObject, in double theDX, in double theDY, in double theDZ) |
| Translate the given object along the vector, specified by its components, creating its copy before the translation. More... | |
| GEOM_Object | TranslateVector (in GEOM_Object theObject, in GEOM_Object theVector) |
| Translate the given object along the given vector. More... | |
| GEOM_Object | TranslateVectorCopy (in GEOM_Object theObject, in GEOM_Object theVector) |
| Translate the given object along the given vector, creating its copy before the translation. More... | |
| GEOM_Object | TranslateVectorDistance (in GEOM_Object theObject, in GEOM_Object theVector, in double theDistance, in boolean theCopy) |
| Translate the given object along the given vector on given distance, creating its copy before the translation. More... | |
| GEOM_Object | MultiTranslate1D (in GEOM_Object theObject, in GEOM_Object theVector, in double theStep, in long theNbTimes) |
| Translate the given object along the given vector a given number times. More... | |
| GEOM_Object | MultiTranslate2D (in GEOM_Object theObject, in GEOM_Object theVector1, in double theStep1, in long theNbTimes1, in GEOM_Object theVector2, in double theStep2, in long theNbTimes2) |
| Conseqently apply two specified translations to theObject specified number of times. More... | |
| GEOM_Object | RotateThreePoints (in GEOM_Object theObject, in GEOM_Object theCentPoint, in GEOM_Object thePoint1, in GEOM_Object thePoint2) |
| Rotate given object around vector perpendicular to plane containing three points. More... | |
| GEOM_Object | RotateThreePointsCopy (in GEOM_Object theObject, in GEOM_Object theCentPoint, in GEOM_Object thePoint1, in GEOM_Object thePoint2) |
| GEOM_Object | Rotate (in GEOM_Object theObject, in GEOM_Object theAxis, in double theAngle) |
| Rotate the given object around the given axis on the given angle. More... | |
| GEOM_Object | RotateCopy (in GEOM_Object theObject, in GEOM_Object theAxis, in double theAngle) |
| GEOM_Object | MultiRotate1D (in GEOM_Object theObject, in GEOM_Object theAxis, in long theNbObjects) |
| Rotate the given object around the given axis a given number times. More... | |
| GEOM_Object | MultiRotate1DByStep (in GEOM_Object theObject, in GEOM_Object theAxis, in double theAngleStep, in long theNbSteps) |
| Rotate the given object around the given axis a given number times on the given angle. More... | |
| GEOM_Object | MultiRotate2DNbTimes (in GEOM_Object theObject, in GEOM_Object theAxis, in long theNbObjects, in double theRadialStep, in long theNbSteps) |
| Rotate the given object around the given axis a given number times and multi-translate each rotation result. More... | |
| GEOM_Object | MultiRotate2DByStep (in GEOM_Object theObject, in GEOM_Object theAxis, in double theAngleStep, in long theNbSteps1, in double theRadialStep, in long theNbSteps2) |
| Rotate the given object around the given axis on the given angle a given number times and multi-translate each rotation result. More... | |
| GEOM_Object | MultiRotate2D (in GEOM_Object theObject, in GEOM_Object theAxis, in double theAngleStep, in long theNbSteps1, in double theRadialStep, in long theNbSteps2) |
| GEOM_Object | MirrorPlane (in GEOM_Object theObject, in GEOM_Object thePlane) |
| Replace the given object by an object, symmetrical to it relatively the given plane. More... | |
| GEOM_Object | MirrorPlaneCopy (in GEOM_Object theObject, in GEOM_Object thePlane) |
| Create an object, symmetrical to the given one relatively the given plane. More... | |
| GEOM_Object | MirrorAxis (in GEOM_Object theObject, in GEOM_Object theAxis) |
| Replace the given object by an object, symmetrical to it relatively the given axis. More... | |
| GEOM_Object | MirrorAxisCopy (in GEOM_Object theObject, in GEOM_Object theAxis) |
| Create an object, symmetrical to the given one relatively the given axis. More... | |
| GEOM_Object | MirrorPoint (in GEOM_Object theObject, in GEOM_Object thePoint) |
| Replace the given object by an object, symmetrical to it relatively the given point. More... | |
| GEOM_Object | MirrorPointCopy (in GEOM_Object theObject, in GEOM_Object thePoint) |
| Create an object, symmetrical to the given one relatively the given point. More... | |
| GEOM_Object | OffsetShape (in GEOM_Object theObject, in double theOffset, in boolean theJoinByPipes) |
| Replace the given object by its offset. More... | |
| GEOM_Object | OffsetShapeCopy (in GEOM_Object theObject, in double theOffset, in boolean theJoinByPipes) |
| Create new object as offset of the given one. More... | |
| GEOM_Object | OffsetShapePartialCopy (in GEOM_Object theObject, in double theOffset, in ListOfLong theFacesIDs) |
| Create new object as offset of the given one. Only indexed faces are offset, others keep they original location. More... | |
| GEOM_Object | ProjectShapeCopy (in GEOM_Object theSource, in GEOM_Object theTarget) |
| Create new object as projection of the given one on a 2D surface. More... | |
| double | ProjectPointOnWire (in GEOM_Object thePoint, in GEOM_Object theWire, out GEOM_Object thePointOnEdge, out long theEdgeInWireIndex) |
| Create a projection projection of the given point on a wire or an edge. More... | |
| GEOM_Object | ScaleShape (in GEOM_Object theObject, in GEOM_Object thePoint, in double theFactor) |
| Scale the given object by the factor. More... | |
| GEOM_Object | ScaleShapeCopy (in GEOM_Object theObject, in GEOM_Object thePoint, in double theFactor) |
| Scale the given object by the factor, creating its copy before the scaling. More... | |
| GEOM_Object | ScaleShapeAlongAxes (in GEOM_Object theObject, in GEOM_Object thePoint, in double theFactorX, in double theFactorY, in double theFactorZ) |
| Scale the given object by different factors along coordinate axes. More... | |
| GEOM_Object | ScaleShapeAlongAxesCopy (in GEOM_Object theObject, in GEOM_Object thePoint, in double theFactorX, in double theFactorY, in double theFactorZ) |
| Scale the given object by different factors along coordinate axes, creating its copy before the scaling. More... | |
| GEOM_Object | PositionShape (in GEOM_Object theObject, in GEOM_Object theStartLCS, in GEOM_Object theEndLCS) |
| Modify the Location of the given object by LCS. More... | |
| GEOM_Object | PositionShapeCopy (in GEOM_Object theObject, in GEOM_Object theStartLCS, in GEOM_Object theEndLCS) |
| Modify the Location of the given object by LCS, creating its copy before the setting. More... | |
| GEOM_Object | PositionAlongPath (in GEOM_Object theObject, in GEOM_Object thePath, in double theDistance, in boolean theCopy, in boolean theReverse) |
| Modify the Location of the given object by Path,. More... | |
| GEOM_Object | RecomputeObject (in GEOM_Object theObject) |
| Recompute the shape from its arguments. More... | |
| GEOM_Object | MakeProjectionOnCylinder (in GEOM_Object theObject, in double theRadius, in double theStartAngle, in double theAngleLength, in double theAngleRotation) |
| Compute the projection of a wire or a face on a cylinder. More... | |
Public Member Functions inherited from GEOM::GEOM_IOperations | |
| boolean | IsDone () |
| To know, if the operation was successfully performed. More... | |
| void | SetErrorCode (in string theErrorID) |
| Set the operation error code. More... | |
| string | GetErrorCode () |
| Get the operation error code. More... | |
| void | StartOperation () |
| Opens a new transaction. More... | |
| void | FinishOperation () |
| Closes the previously opened transaction. More... | |
| void | AbortOperation () |
| Aborts the previously opened transaction. More... | |
Translation, rotation, scaling, mirroring, offset, projection, recomputing.
| GEOM_Object GEOM::GEOM_ITransformOperations::MakeProjectionOnCylinder | ( | in GEOM_Object | theObject, |
| in double | theRadius, | ||
| in double | theStartAngle, | ||
| in double | theAngleLength, | ||
| in double | theAngleRotation | ||
This method computes a wire or a face or a compound of faces that represents a projection of the source shape onto cylinder. The cylinder's coordinate system is the same as the global coordinate system.
| theObject | The object to be projected. It can be either a planar wire or a face. |
| theRadius | The radius of the cylinder. |
| theStartAngle | The starting angle from the cylinder's X axis around Z axis. The angle from which the projection is started. |
| theAngleLength | The projection length angle. The angle in which to project the total length of the wire. If it is negative the projection is not scaled and natural wire length is kept for the projection. |
| theAngleRotation | the desired angle between the tangent vector to the first curve at the first point of the theObject's projection in 2D space and U-direction of cylinder's 2D space. |
| GEOM_Object GEOM::GEOM_ITransformOperations::MirrorAxis | ( | in GEOM_Object | theObject, |
| in GEOM_Object | theAxis | ||
| theObject | The object to be mirrored. |
| theAxis | Axis of symmetry. |
| GEOM_Object GEOM::GEOM_ITransformOperations::MirrorAxisCopy | ( | in GEOM_Object | theObject, |
| GEOM_Object GEOM::GEOM_ITransformOperations::MirrorPlane | ( | in GEOM_Object | theObject, |
| in GEOM_Object | thePlane | ||
| thePlane | Plane of symmetry. |
| GEOM_Object GEOM::GEOM_ITransformOperations::MirrorPlaneCopy | ( | in GEOM_Object | theObject, |
| GEOM_Object GEOM::GEOM_ITransformOperations::MirrorPoint | ( | in GEOM_Object | theObject, |
| in GEOM_Object | thePoint | ||
| thePoint | Point of symmetry. |
| GEOM_Object GEOM::GEOM_ITransformOperations::MirrorPointCopy | ( | in GEOM_Object | theObject, |
| GEOM_Object GEOM::GEOM_ITransformOperations::MultiRotate1D | ( | in GEOM_Object | theObject, |
| in GEOM_Object | theAxis, | ||
| in long | theNbObjects | ||
Rotation angle will be 2*PI/theNbObjects.
| theObject | The object to be rotated. |
| theAxis | The rotation axis. DZ if None. |
| theNbObjects | Quantity of rotations to be done. |
| GEOM_Object GEOM::GEOM_ITransformOperations::MultiRotate1DByStep | ( | in GEOM_Object | theObject, |
| in double | theAngleStep, | ||
| in long | theNbSteps | ||
| theAngleStep | Rotation angle in radians. |
| theNbSteps | Quantity of rotations to be done. |
| GEOM_Object GEOM::GEOM_ITransformOperations::MultiRotate2D | ( | in GEOM_Object | theObject, |
| in long | theNbSteps1, | ||
| in double | theRadialStep, | ||
| in long | theNbSteps2 | ||
Translation direction passes through center of gravity of rotated shape and its projection on the rotation axis.
| theAxis | Rotation axis. DZ if None. |
| theAngleStep | Rotation angle in degrees. |
| theNbSteps1 | Quantity of rotations to be done. |
| theRadialStep | Translation distance. |
| theNbSteps2 | Quantity of translations to be done. |
| GEOM_Object GEOM::GEOM_ITransformOperations::MultiRotate2DByStep | ( | in GEOM_Object | theObject, |
| GEOM_Object GEOM::GEOM_ITransformOperations::MultiRotate2DNbTimes | ( | in GEOM_Object | theObject, |
| in long | theNbObjects, | ||
Rotation angle will be 2*PI/theNbObjects. Translation direction passes through center of gravity of rotated shape and its projection on the rotation axis.
| theNbSteps | Quantity of translations to be done. |
| GEOM_Object GEOM::GEOM_ITransformOperations::MultiTranslate1D | ( | in GEOM_Object | theObject, |
| in GEOM_Object | theVector, | ||
| in double | theStep, | ||
| in long | theNbTimes | ||
| theObject | The object to be translated. |
| theVector | Direction of the translation. DX if None. |
| theStep | Distance to translate on. |
| theNbTimes | Quantity of translations to be done. |
| GEOM_Object GEOM::GEOM_ITransformOperations::MultiTranslate2D | ( | in GEOM_Object | theObject, |
| in GEOM_Object | theVector1, | ||
| in double | theStep1, | ||
| in long | theNbTimes1, | ||
| in GEOM_Object | theVector2, | ||
| in double | theStep2, | ||
| in long | theNbTimes2 | ||
| theVector1 | Direction of the first translation. DX if None. |
| theStep1 | Step of the first translation. |
| theNbTimes1 | Quantity of translations to be done along theVector1. |
| theVector2 | Direction of the second translation. DY if None. |
| theStep2 | Step of the second translation. |
| theNbTimes2 | Quantity of translations to be done along theVector2. |
| GEOM_Object GEOM::GEOM_ITransformOperations::OffsetShape | ( | in GEOM_Object | theObject, |
| in double | theOffset, | ||
| in boolean | theJoinByPipes | ||
| theObject | The base object for the offset. |
| theOffset | Offset value. |
| theJoinByPipes | To join offset surfaces by pipes or by intersection. |
| GEOM_Object GEOM::GEOM_ITransformOperations::OffsetShapeCopy | ( | in GEOM_Object | theObject, |
| GEOM_Object GEOM::GEOM_ITransformOperations::OffsetShapePartialCopy | ( | in GEOM_Object | theObject, |
| in ListOfLong | theFacesIDs | ||
| theFacesIDs | The list of face IDs indicating faces to be offset. |
| GEOM_Object GEOM::GEOM_ITransformOperations::PositionAlongPath | ( | in GEOM_Object | theObject, |
| in GEOM_Object | thePath, | ||
| in double | theDistance, | ||
| in boolean | theCopy, | ||
| in boolean | theReverse | ||
| theObject | The object to be displaced. |
| thePath | Wire or Edge along that the object will be translated. |
| theDistance | progress of Path (0 = actual location, 1 = end of path location). |
| theCopy | is a true or false parameter. true is to create a copy, false to move the object. |
| theReverse | is a true or false parameter. True is to reverse direction, false is to move normal direction. |
| GEOM_Object GEOM::GEOM_ITransformOperations::PositionShape | ( | in GEOM_Object | theObject, |
| in GEOM_Object | theStartLCS, | ||
| in GEOM_Object | theEndLCS | ||
| theStartLCS | Coordinate system to perform displacement from it. If theStartLCS is NULL, displacement will be performed from global CS. If theObject itself is used as theStartLCS, its location will be changed to theEndLCS. |
| theEndLCS | Coordinate system to perform displacement to it. |
| GEOM_Object GEOM::GEOM_ITransformOperations::PositionShapeCopy | ( | in GEOM_Object | theObject, |
| double GEOM::GEOM_ITransformOperations::ProjectPointOnWire | ( | in GEOM_Object | thePoint, |
| in GEOM_Object | theWire, | ||
| out GEOM_Object | thePointOnEdge, | ||
| out long | theEdgeInWireIndex | ||
If there are no solutions or there are 2 or more solutions It throws an exception.
| thePoint | the point to be projected. |
| theWire | the wire. The edge is accepted as well. |
| thePointOnEdge | the projection point. |
| theEdgeInWireIndex | the index of an edge in a wire. |
| GEOM_Object GEOM::GEOM_ITransformOperations::ProjectShapeCopy | ( | in GEOM_Object | theSource, |
| in GEOM_Object | theTarget | ||
| theSource | The source object for the projection. It can be a point, edge or wire. |
| theTarget | The target object. It can be planar or cylindrical face. |
| GEOM_Object GEOM::GEOM_ITransformOperations::RecomputeObject | ( | in GEOM_Object | theObject | ) |
| theObject | The object to be recomputed. |
| GEOM_Object GEOM::GEOM_ITransformOperations::Rotate | ( | in GEOM_Object | theObject, |
| in double | theAngle | ||
| theAxis | Rotation axis. |
| theAngle | Rotation angle in radians. |
| GEOM_Object GEOM::GEOM_ITransformOperations::RotateCopy | ( | in GEOM_Object | theObject, |
Rotate the given object around the given axis on the given angle, creating its copy before the rotatation.
| GEOM_Object GEOM::GEOM_ITransformOperations::RotateThreePoints | ( | in GEOM_Object | theObject, |
| in GEOM_Object | theCentPoint, | ||
| in GEOM_Object | thePoint1, | ||
| in GEOM_Object | thePoint2 | ||
| theCentPoint | central point - the axis is the vector perpendicular to the plane containing the three points. |
| thePoint1,thePoint2 | - in a perpendicular plan of the axis. |
| GEOM_Object GEOM::GEOM_ITransformOperations::RotateThreePointsCopy | ( | in GEOM_Object | theObject, |
Creating its copy before the rotatation.
| GEOM_Object GEOM::GEOM_ITransformOperations::ScaleShape | ( | in GEOM_Object | theObject, |
| in GEOM_Object | thePoint, | ||
| in double | theFactor | ||
| theObject | The object to be scaled. |
| thePoint | Center point for scaling. |
| theFactor | Scaling factor value. |
| GEOM_Object GEOM::GEOM_ITransformOperations::ScaleShapeAlongAxes | ( | in GEOM_Object | theObject, |
| in double | theFactorX, | ||
| in double | theFactorY, | ||
| in double | theFactorZ | ||
| theFactorX,theFactorY,theFactorZ | Scaling factors along each axis. |
| GEOM_Object GEOM::GEOM_ITransformOperations::ScaleShapeAlongAxesCopy | ( | in GEOM_Object | theObject, |
| GEOM_Object GEOM::GEOM_ITransformOperations::ScaleShapeCopy | ( | in GEOM_Object | theObject, |
| GEOM_Object GEOM::GEOM_ITransformOperations::TranslateDXDYDZ | ( | in GEOM_Object | theObject, |
| in double | theDX, | ||
| in double | theDY, | ||
| in double | theDZ | ||
| theDX,theDY,theDZ | Components of translation vector. |
| GEOM_Object GEOM::GEOM_ITransformOperations::TranslateDXDYDZCopy | ( | in GEOM_Object | theObject, |
| GEOM_Object GEOM::GEOM_ITransformOperations::TranslateTwoPoints | ( | in GEOM_Object | theObject, |
| thePoint1 | Start point of translation vector. |
| thePoint2 | End point of translation vector. |
| GEOM_Object GEOM::GEOM_ITransformOperations::TranslateTwoPointsCopy | ( | in GEOM_Object | theObject, |
| GEOM_Object GEOM::GEOM_ITransformOperations::TranslateVector | ( | in GEOM_Object | theObject, |
| in GEOM_Object | theVector | ||
| theVector | Translation vector, giving both direction and distance. |
| GEOM_Object GEOM::GEOM_ITransformOperations::TranslateVectorCopy | ( | in GEOM_Object | theObject, |
| GEOM_Object GEOM::GEOM_ITransformOperations::TranslateVectorDistance | ( | in GEOM_Object | theObject, |
| in boolean | theCopy | ||
| theVector | Translation vector, giving a direction. |
| theDistance | Translation distance, giving a distance. |
| theCopy | Translation copy, creating its copy if true. |
