Interface for fillet and chamfer creation.
import"GEOM_Gen.idl";
| GEOM_Object | MakeFilletAll (in GEOM_Object theShape, in double theR) |
| Perform a fillet on all edges of the given shape. More... | |
| GEOM_Object | MakeFilletEdges (in GEOM_Object theShape, in double theR, in ListOfLong theEdges) |
| Perform a fillet on the specified edges of the given shape. More... | |
| GEOM_Object | MakeFilletEdgesR1R2 (in GEOM_Object theShape, in double theR1, in double theR2, in ListOfLong theEdges) |
| GEOM_Object | MakeFilletFaces (in GEOM_Object theShape, in double theR, in ListOfLong theFaces) |
| Perform a fillet on all edges of the specified faces of the given shape. More... | |
| GEOM_Object | MakeFilletFacesR1R2 (in GEOM_Object theShape, in double theR1, in double theR2, in ListOfLong theFaces) |
| GEOM_Object | MakeFillet2D (in GEOM_Object theShape, in double theR, in ListOfLong theVertexes) |
| Perform a fillet on a face or a shell at the specified vertexes. More... | |
| GEOM_Object | MakeFillet1D (in GEOM_Object theShape, in double theR, in ListOfLong theVertexes, in boolean doIgnoreSecantVertices) |
| Perform a fillet on edges of the specified vertexes of the given wire. More... | |
| GEOM_Object | MakeChamferAll (in GEOM_Object theShape, in double theD) |
| Perform a symmetric chamfer on all edges of the given shape. More... | |
| GEOM_Object | MakeChamferEdge (in GEOM_Object theShape, in double theD1, in double theD2, in long theFace1, in long theFace2) |
| Perform a chamfer on edges, common to the specified faces. with distance D1 on the Face1. More... | |
| GEOM_Object | MakeChamferEdgeAD (in GEOM_Object theShape, in double theD, in double theAngle, in long theFace1, in long theFace2) |
| The Same but with params theD = Chamfer Length and theAngle = Chamfer Angle (Angle in radians) More... | |
| GEOM_Object | MakeChamferFaces (in GEOM_Object theShape, in double theD1, in double theD2, in ListOfLong theFaces) |
| Perform a chamfer on all edges of the specified faces. with distance D1 on the first specified face (if several for one edge) More... | |
| GEOM_Object | MakeChamferFacesAD (in GEOM_Object theShape, in double theD, in double theAngle, in ListOfLong theFaces) |
| GEOM_Object | MakeChamferEdges (in GEOM_Object theShape, in double theD1, in double theD2, in ListOfLong theEdges) |
| Perform a chamfer on edges, with distance D1 on the first specified face (if several for one edge) More... | |
| GEOM_Object | MakeChamferEdgesAD (in GEOM_Object theShape, in double theD, in double theAngle, in ListOfLong theEdges) |
| GEOM_Object | MakeArchimede (in GEOM_Object theShape, in double theWeight, in double theWaterDensity, in double theMeshDeflection) |
| Perform an Archimde operation on the given shape with given parameters. The object presenting the resulting face is returned. More... | |
| long | GetSubShapeIndex (in GEOM_Object theShape, in GEOM_Object theSubShape) |
| Duplicates GEOM_IShapesOperations.GetSubShapeIndex(). More... | |
Public Member Functions inherited from GEOM::GEOM_IOperations | |
| boolean | IsDone () |
| To know, if the operation was successfully performed. More... | |
| void | SetErrorCode (in string theErrorID) |
| Set the operation error code. More... | |
| string | GetErrorCode () |
| Get the operation error code. More... | |
| void | StartOperation () |
| Opens a new transaction. More... | |
| void | FinishOperation () |
| Closes the previously opened transaction. More... | |
| void | AbortOperation () |
| Aborts the previously opened transaction. More... | |
| long GEOM::GEOM_ILocalOperations::GetSubShapeIndex | ( | in GEOM_Object | theShape, |
| in GEOM_Object | theSubShape | ||
Present here only for compatibility.
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeArchimede | ( | in GEOM_Object | theShape, |
| in double | theWeight, | ||
| in double | theWaterDensity, | ||
| in double | theMeshDeflection | ||
| theShape | Shape to be put in water. |
| theWeight | Weight og the shape. |
| theWaterDensity | Density of the water. |
| theMeshDeflection | Deflection od the mesh, using to compute the section. |
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeChamferAll | ( | in GEOM_Object | theShape, |
| in double | theD | ||
| theShape | Shape, to perform chamfer on. |
| theD | Chamfer size along each face. |
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeChamferEdge | ( | in GEOM_Object | theShape, |
| in double | theD1, | ||
| in double | theD2, | ||
| in long | theFace1, | ||
| in long | theFace2 | ||
| theD1 | Chamfer size along theFace1. |
| theD2 | Chamfer size along theFace2. |
| theFace1,theFace2 | Global indices of two faces of theShape. |
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeChamferEdgeAD | ( | in GEOM_Object | theShape, |
| in double | theD, | ||
| in double | theAngle, | ||
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeChamferEdges | ( | in GEOM_Object | theShape, |
| in ListOfLong | theEdges | ||
| theD1,theD2 | Chamfer size |
| theEdges | Sequence of edges of theShape. |
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeChamferEdgesAD | ( | in GEOM_Object | theShape, |
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeChamferFaces | ( | in GEOM_Object | theShape, |
| in ListOfLong | theFaces | ||
| theD1 | Chamfer size along face from theFaces. If both faces, connected to the edge, are in theFaces, theD1 will be get along face, which is nearer to theFaces beginning. |
| theD2 | Chamfer size along another of two faces, connected to the edge. |
| theFaces | Sequence of global indices of faces of theShape. |
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeChamferFacesAD | ( | in GEOM_Object | theShape, |
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeFillet1D | ( | in GEOM_Object | theShape, |
| in double | theR, | ||
| in ListOfLong | theVertexes, | ||
| in boolean | doIgnoreSecantVertices | ||
| theShape | Shape, to perform fillet on. |
| theR | Fillet radius. |
| theVertexes | Global indices of vertexes to perform fillet on. |
| doIgnoreSecantVertices | If FALSE, fillet radius is always limited by the length of the edges, nearest to the fillet vertex. But sometimes the next edge is C1 continuous with the one, nearest to the fillet point, and such two (or more) edges can be united to allow bigger radius. Set this flag to TRUE to allow collinear edges union, thus ignoring the secant vertex (vertices). |
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeFillet2D | ( | in GEOM_Object | theShape, |
| in ListOfLong | theVertexes | ||
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeFilletAll | ( | in GEOM_Object | theShape, |
| in double | theR | ||
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeFilletEdges | ( | in GEOM_Object | theShape, |
| theEdges | Global indices of edges to perform fillet on. |
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeFilletEdgesR1R2 | ( | in GEOM_Object | theShape, |
| in double | theR1, | ||
| in double | theR2, | ||
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeFilletFaces | ( | in GEOM_Object | theShape, |
| theFaces | Global indices of faces to perform fillet on. |
| GEOM_Object GEOM::GEOM_ILocalOperations::MakeFilletFacesR1R2 | ( | in GEOM_Object | theShape, |
