GEOM_Actor Class Reference
This class allows to display an OpenCASCADE CAD model in a VTK viewer.
#include <GEOM_Actor.h>
Inheritance diagram for GEOM_Actor:
enum  EDisplayMode { eWireframe , eShading , eShadingWithEdges = eShading + 2 }
 vtkTypeMacro (GEOM_Actor, SALOME_Actor) static GEOM_Actor *New()
void SetShape (const TopoDS_Shape &theShape, double theDeflection, bool theIsVector=false)
void SetDeflection (double theDeflection)
double GetDeflection () const
void AddToRender (vtkRenderer *theRenderer)
void RemoveFromRender (vtkRenderer *theRenderer)
void SetSelected (bool theIsSelected)
bool IsSelected () const
void SetHighlightProperty (vtkProperty *Prop)
void SetWireframeProperty (vtkProperty *Prop)
void SetShadingProperty (vtkProperty *Prop)
vtkProperty * GetWireframeProperty ()
vtkProperty * GetShadingProperty ()
vtkProperty * GetIsolatedEdgeProperty ()
vtkProperty * GetVertexProperty ()
vtkProperty * GetStandaloneVertexProperty ()
vtkProperty * GetSharedEdgeProperty ()
vtkProperty * GetFaceEdgeProperty ()
virtual void setDisplayMode (int thenewmode)
virtual void Render (vtkRenderer *, vtkMapper *)
void ReleaseGraphicsResources (vtkWindow *)
const TopoDS_Shape & getTopo ()
void setInputShape (const TopoDS_Shape &ashape, double adef1, int imode, bool isVector=false)
double isVector ()
void SubShapeOn ()
void SubShapeOff ()
virtual void highlight (bool theHighlight)
virtual bool hasHighlight ()
void ShallowCopy (vtkProp *prop)
void SetOpacity (double opa)
double GetOpacity ()
void SetColor (double r, double g, double b)
void GetColor (double &r, double &g, double &b)
void SetPointColor (double r, double g, double b)
 Set color of points Points actor is shown in Wireframe mode only, see SetVisibility() More...
void SetIsolatedEdgeColor (double r, double g, double b)
 Set color of standalone edges, wires, vectors This actor is shown in all display mode, see SetVisibility() TODO: check - this color seems to be used not only for standalone edges. More...
void SetSharedEdgeColor (double r, double g, double b)
 Set color of shared edges This actor is shown only in wireframe and shading+edges display modes, see SetVisibility() TODO: check - this seems to be not working currently. More...
void SetFreeEdgeColor (double r, double g, double b)
 Set color of edges for standalone faces This actor is shown only in wireframe and shading+edges display modes, see SetVisibility() TODO: this color should be used not only for faces. More...
void SetEdgesInShadingColor (double r, double g, double b)
void SetIsosColor (double r, double g, double b)
 Set color of iso-lines This actor is shown only in wireframe display mode, see SetVisibility() More...
void SetLabelColor (double r, double g, double b)
 Set color of labels This actor is shown only if 'Show name' is switched-on, see SetVisibility() More...
void SetMaterial (std::vector< vtkProperty * > theProps)
vtkProperty * GetFrontMaterial ()
vtkProperty * GetBackMaterial ()
virtual bool IsInfinitive ()
virtual void Highlight (bool theHighlight)
 To map current selection to VTK representation. More...
virtual bool PreHighlight (vtkInteractorStyle *theInteractorStyle, SVTK_SelectionEvent *theSelectionEvent, bool theIsHighlight)
 To process prehighlight (called from #SVTK_InteractorStyle) More...
virtual bool Highlight (vtkInteractorStyle *theInteractorStyle, SVTK_SelectionEvent *theSelectionEvent, bool theIsHighlight)
 To process highlight (called from #SVTK_InteractorStyle) More...
virtual void SetVisibility (int)
 Visibility management. More...
virtual void SetNbIsos (const int theNb[2])
 IsoLines management. More...
virtual void GetNbIsos (int &theNbU, int &theNbV)
virtual void SetIsosWidth (const int width)
int GetIsosWidth () const
virtual void SetWidth (const int width)
int GetWidth () const
virtual void SetVectorMode (const bool theMode)
 Vector mode management. More...
virtual bool GetVectorMode ()
virtual void SetVerticesMode (const bool theMode)
 Vertices mode management. More...
virtual bool GetVerticesMode ()
virtual void SetNameMode (const bool theMode)
 Name mode management. More...
virtual bool GetNameMode ()
virtual void SetTransform (VTKViewer_Transform *theTransform)
void SetModified ()
void GetMatrix (vtkCamera *theCam, vtkMatrix4x4 *result)
void SetShapeName ()
 GEOM_Actor ()
 ~GEOM_Actor ()
virtual void SetMapper (vtkMapper *)
 GEOM_Actor (const GEOM_Actor &)
void operator= (const GEOM_Actor &)
TopoDS_Shape myShape
bool isOnlyVertex
double myDeflection
bool myIsForced
bool myIsSelected
bool myVectorMode
bool myVerticesMode
bool myNameMode
PDeviceActor myVertexActor
PVertexSource myVertexSource
PDeviceActor myStandaloneVertexActor
PVertexSource myStandaloneVertexSource
PDeviceActor myIsolatedEdgeActor
PEdgeSource myIsolatedEdgeSource
PDeviceActor myOneFaceEdgeActor
PEdgeSource myOneFaceEdgeSource
PDeviceActor mySharedEdgeActor
PEdgeSource mySharedEdgeSource
PDeviceActor myWireframeFaceActor
PWFaceSource myWireframeFaceSource
PDeviceActor myShadingFaceActor
PSFaceSource myShadingFaceSource
PDeviceActor myHighlightActor
vtkTextActor * myTextActor
vtkSmartPointer< vtkProperty > myHighlightProp
vtkSmartPointer< vtkProperty > myPreHighlightProp
vtkSmartPointer< vtkProperty > myShadingFaceProp
vtkSmartPointer< vtkProperty > myShadingBackFaceProp
PAppendFilter myAppendFilter
PPolyGeomPainterDataMapper myPolyDataMapper
double myEdgesInWireframeColor [3]
double myEdgesInShadingColor [3]
double myIsolatedEdgeColor [3]
double mySharedEdgeColor [3]
double myOneFaceEdgeColor [3]
◆ EDisplayMode
eWireframe
eShading
eShadingWithEdges
◆ GEOM_Actor() [1/2]
◆ ~GEOM_Actor()
GEOM_Actor::~GEOM_Actor ( )
◆ GEOM_Actor() [2/2]
GEOM_Actor::GEOM_Actor ( const GEOM_Actor &  )
◆ AddToRender()
◆ GetBackMaterial()
vtkProperty * GEOM_Actor::GetBackMaterial ( )
References myShadingBackFaceProp.
◆ GetColor()
void GEOM_Actor::GetColor ( double &  r,
double &  g,
double &  b
References myShadingFaceProp.
◆ GetDeflection()
double GEOM_Actor::GetDeflection ( ) const
◆ GetFaceEdgeProperty()
vtkProperty * GEOM_Actor::GetFaceEdgeProperty ( )
References myOneFaceEdgeActor.
◆ GetFrontMaterial()
vtkProperty * GEOM_Actor::GetFrontMaterial ( )
◆ GetIsolatedEdgeProperty()
vtkProperty * GEOM_Actor::GetIsolatedEdgeProperty ( )
References myIsolatedEdgeActor.
◆ GetIsosWidth()
int GEOM_Actor::GetIsosWidth ( ) const
References myWireframeFaceActor.
◆ GetMatrix()
void GEOM_Actor::GetMatrix ( vtkCamera *  theCam,
vtkMatrix4x4 *  result
◆ GetNameMode()
bool GEOM_Actor::GetNameMode ( )
References myNameMode.
◆ GetNbIsos()
void GEOM_Actor::GetNbIsos ( int &  theNbU,
int &  theNbV
References myWireframeFaceSource.
◆ GetOpacity()
double GEOM_Actor::GetOpacity ( )
◆ GetShadingProperty()
vtkProperty * GEOM_Actor::GetShadingProperty ( )
◆ GetSharedEdgeProperty()
vtkProperty * GEOM_Actor::GetSharedEdgeProperty ( )
References mySharedEdgeActor.
◆ GetStandaloneVertexProperty()
vtkProperty * GEOM_Actor::GetStandaloneVertexProperty ( )
◆ getTopo()
const TopoDS_Shape & GEOM_Actor::getTopo ( )
References myShape.
◆ GetVectorMode()
bool GEOM_Actor::GetVectorMode ( )
References myVectorMode.
◆ GetVertexProperty()
vtkProperty * GEOM_Actor::GetVertexProperty ( )
References myVertexActor.
◆ GetVerticesMode()
bool GEOM_Actor::GetVerticesMode ( )
References myVerticesMode.
◆ GetWidth()
int GEOM_Actor::GetWidth ( ) const
◆ GetWireframeProperty()
vtkProperty * GEOM_Actor::GetWireframeProperty ( )
◆ hasHighlight()
virtual bool GEOM_Actor::hasHighlight ( )
◆ highlight()
void GEOM_Actor::highlight ( bool  theHighlight)
References highlight().
◆ Highlight() [1/2]
void GEOM_Actor::Highlight ( bool  theIsHighlight)
References myIsSelected, and SetVisibility().
◆ Highlight() [2/2]
bool GEOM_Actor::Highlight ( vtkInteractorStyle *  theInteractorStyle,
SVTK_SelectionEvent *  theSelectionEvent,
bool  theIsHighlight
To process highlight (called from SVTK_InteractorStyle)
References myIsSelected, and SetSelected().
◆ IsInfinitive()
bool GEOM_Actor::IsInfinitive ( )
References isOnlyVertex, and myShape.
◆ IsSelected()
bool GEOM_Actor::IsSelected ( ) const
◆ isVector()
double GEOM_Actor::isVector ( )
◆ operator=()
void GEOM_Actor::operator= ( const GEOM_Actor &  )
◆ PreHighlight()
bool GEOM_Actor::PreHighlight ( vtkInteractorStyle *  theInteractorStyle,
bool  theIsHighlight
To process prehighlight (called from SVTK_InteractorStyle)
References SetVisibility().
◆ ReleaseGraphicsResources()
void GEOM_Actor::ReleaseGraphicsResources ( vtkWindow *  )
◆ RemoveFromRender()
◆ Render()
void GEOM_Actor::Render ( vtkRenderer *  ren,
vtkMapper *  theMapper
◆ SetColor()
void GEOM_Actor::SetColor ( double  r,
double  g,
double  b
◆ SetDeflection()
void GEOM_Actor::SetDeflection ( double  theDeflection)
◆ setDisplayMode()
◆ SetEdgesInShadingColor()
void GEOM_Actor::SetEdgesInShadingColor ( double  r,
double  g,
double  b
References myEdgesInShadingColor.
◆ SetFreeEdgeColor()
void GEOM_Actor::SetFreeEdgeColor ( double  r,
double  g,
double  b
◆ SetHighlightProperty()
void GEOM_Actor::SetHighlightProperty ( vtkProperty *  Prop)
References myHighlightActor.
◆ setInputShape()
void GEOM_Actor::setInputShape ( const TopoDS_Shape &  ashape,
double  adef1,
int  imode,
bool  isVector = false
◆ SetIsolatedEdgeColor()
void GEOM_Actor::SetIsolatedEdgeColor ( double  r,
double  g,
double  b
◆ SetIsosColor()
void GEOM_Actor::SetIsosColor ( double  r,
double  g,
double  b
◆ SetIsosWidth()
void GEOM_Actor::SetIsosWidth ( const int  width)
◆ SetLabelColor()
void GEOM_Actor::SetLabelColor ( double  r,
double  g,
double  b
References myTextActor.
◆ SetMapper()
void GEOM_Actor::SetMapper ( vtkMapper *  theMapper)
privatevirtual
◆ SetMaterial()
void GEOM_Actor::SetMaterial ( std::vector< vtkProperty * >  theProps)
◆ SetModified()
◆ SetNameMode()
void GEOM_Actor::SetNameMode ( const bool  theMode)
◆ SetNbIsos()
void GEOM_Actor::SetNbIsos ( const int  theNb[2])
◆ SetOpacity()
void GEOM_Actor::SetOpacity ( double  opa)
◆ SetPointColor()
void GEOM_Actor::SetPointColor ( double  r,
double  g,
double  b
◆ SetSelected()
void GEOM_Actor::SetSelected ( bool  theIsSelected)
◆ SetShadingProperty()
void GEOM_Actor::SetShadingProperty ( vtkProperty *  Prop)
◆ SetShape()
◆ SetShapeName()
void GEOM_Actor::SetShapeName ( )
◆ SetSharedEdgeColor()
void GEOM_Actor::SetSharedEdgeColor ( double  r,
double  g,
double  b
◆ SetTransform()
void GEOM_Actor::SetTransform ( VTKViewer_Transform *  theTransform)
◆ SetVectorMode()
void GEOM_Actor::SetVectorMode ( const bool  theMode)
◆ SetVerticesMode()
void GEOM_Actor::SetVerticesMode ( const bool  theMode)
◆ SetVisibility()
◆ SetWidth()
void GEOM_Actor::SetWidth ( const int  width)
◆ SetWireframeProperty()
void GEOM_Actor::SetWireframeProperty ( vtkProperty *  Prop)
◆ ShallowCopy()
void GEOM_Actor::ShallowCopy ( vtkProp *  prop)
◆ SubShapeOff()
void GEOM_Actor::SubShapeOff ( )
◆ SubShapeOn()
void GEOM_Actor::SubShapeOn ( )
◆ vtkTypeMacro()
GEOM_Actor::vtkTypeMacro ( GEOM_Actor  ,
SALOME_Actor
◆ isOnlyVertex
bool GEOM_Actor::isOnlyVertex
◆ myAppendFilter
PAppendFilter GEOM_Actor::myAppendFilter
◆ myDeflection
double GEOM_Actor::myDeflection
◆ myEdgesInShadingColor
double GEOM_Actor::myEdgesInShadingColor[3]
◆ myEdgesInWireframeColor
double GEOM_Actor::myEdgesInWireframeColor[3]
◆ myHighlightActor
PDeviceActor GEOM_Actor::myHighlightActor
◆ myHighlightProp
vtkSmartPointer<vtkProperty> GEOM_Actor::myHighlightProp
◆ myIsForced
bool GEOM_Actor::myIsForced
◆ myIsolatedEdgeActor
PDeviceActor GEOM_Actor::myIsolatedEdgeActor
◆ myIsolatedEdgeColor
double GEOM_Actor::myIsolatedEdgeColor[3]
◆ myIsolatedEdgeSource
PEdgeSource GEOM_Actor::myIsolatedEdgeSource
◆ myIsSelected
bool GEOM_Actor::myIsSelected
◆ myNameMode
bool GEOM_Actor::myNameMode
◆ myOneFaceEdgeActor
PDeviceActor GEOM_Actor::myOneFaceEdgeActor
◆ myOneFaceEdgeColor
double GEOM_Actor::myOneFaceEdgeColor[3]
◆ myOneFaceEdgeSource
PEdgeSource GEOM_Actor::myOneFaceEdgeSource
◆ myPolyDataMapper
PPolyGeomPainterDataMapper GEOM_Actor::myPolyDataMapper
◆ myPreHighlightProp
vtkSmartPointer<vtkProperty> GEOM_Actor::myPreHighlightProp
◆ myShadingBackFaceProp
vtkSmartPointer<vtkProperty> GEOM_Actor::myShadingBackFaceProp
◆ myShadingFaceActor
PDeviceActor GEOM_Actor::myShadingFaceActor
◆ myShadingFaceProp
vtkSmartPointer<vtkProperty> GEOM_Actor::myShadingFaceProp
◆ myShadingFaceSource
PSFaceSource GEOM_Actor::myShadingFaceSource
◆ myShape
TopoDS_Shape GEOM_Actor::myShape
◆ mySharedEdgeActor
PDeviceActor GEOM_Actor::mySharedEdgeActor
◆ mySharedEdgeColor
double GEOM_Actor::mySharedEdgeColor[3]
◆ mySharedEdgeSource
PEdgeSource GEOM_Actor::mySharedEdgeSource
◆ myStandaloneVertexActor
PDeviceActor GEOM_Actor::myStandaloneVertexActor
◆ myStandaloneVertexSource
PVertexSource GEOM_Actor::myStandaloneVertexSource
◆ myTextActor
vtkTextActor* GEOM_Actor::myTextActor
◆ myVectorMode
bool GEOM_Actor::myVectorMode
◆ myVertexActor
PDeviceActor GEOM_Actor::myVertexActor
◆ myVertexSource
PVertexSource GEOM_Actor::myVertexSource
◆ myVerticesMode
bool GEOM_Actor::myVerticesMode
◆ myWireframeFaceActor
PDeviceActor GEOM_Actor::myWireframeFaceActor
◆ myWireframeFaceSource
PWFaceSource GEOM_Actor::myWireframeFaceSource
