GEOM_IBasicOperations_i Class Reference
#include <GEOM_IBasicOperations_i.hh>
Inheritance diagram for GEOM_IBasicOperations_i:
 GEOM_IBasicOperations_i (PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, ::GEOMImpl_IBasicOperations *theImpl)
 ~GEOM_IBasicOperations_i ()
GEOM::GEOM_Object_ptr MakePointXYZ (CORBA::Double theX, CORBA::Double theY, CORBA::Double theZ)
GEOM::GEOM_Object_ptr MakePointWithReference (GEOM::GEOM_Object_ptr theReference, CORBA::Double theX, CORBA::Double theY, CORBA::Double theZ)
GEOM::GEOM_Object_ptr MakePointOnCurve (GEOM::GEOM_Object_ptr theCurve, CORBA::Double theParameter, CORBA::Boolean takeOrientationIntoAccount)
GEOM::GEOM_Object_ptr MakePointOnCurveByLength (GEOM::GEOM_Object_ptr theCurve, CORBA::Double theLength, GEOM::GEOM_Object_ptr theStartPoint)
GEOM::GEOM_Object_ptr MakePointOnCurveByCoord (GEOM::GEOM_Object_ptr theCurve, CORBA::Double theXParameter, CORBA::Double theYParameter, CORBA::Double theZParameter)
GEOM::GEOM_Object_ptr MakePointOnSurface (GEOM::GEOM_Object_ptr theSurface, CORBA::Double theUParameter, CORBA::Double theVParameter)
GEOM::GEOM_Object_ptr MakePointOnSurfaceByCoord (GEOM::GEOM_Object_ptr theSurface, CORBA::Double theXParameter, CORBA::Double theYParameter, CORBA::Double theZParameter)
GEOM::GEOM_Object_ptr MakePointOnFace (GEOM::GEOM_Object_ptr theFace, CORBA::Long theNumberOfPnts)
GEOM::GEOM_Object_ptr MakePointOnLinesIntersection (GEOM::GEOM_Object_ptr theLine1, GEOM::GEOM_Object_ptr theLine2)
GEOM::GEOM_Object_ptr MakeTangentOnCurve (GEOM::GEOM_Object_ptr theRefCurve, CORBA::Double theParameter)
GEOM::GEOM_Object_ptr MakeVectorDXDYDZ (CORBA::Double theDX, CORBA::Double theDY, CORBA::Double theDZ)
GEOM::GEOM_Object_ptr MakeVectorTwoPnt (GEOM::GEOM_Object_ptr thePnt1, GEOM::GEOM_Object_ptr thePnt2)
GEOM::GEOM_Object_ptr MakeLine (GEOM::GEOM_Object_ptr thePnt, GEOM::GEOM_Object_ptr theDir)
GEOM::GEOM_Object_ptr MakeLineTwoPnt (GEOM::GEOM_Object_ptr thePnt1, GEOM::GEOM_Object_ptr thePnt2)
GEOM::GEOM_Object_ptr MakeLineTwoFaces (GEOM::GEOM_Object_ptr theFace1, GEOM::GEOM_Object_ptr theFace2)
GEOM::GEOM_Object_ptr MakePlaneThreePnt (GEOM::GEOM_Object_ptr thePnt1, GEOM::GEOM_Object_ptr thePnt2, GEOM::GEOM_Object_ptr thePnt3, CORBA::Double theTrimSize)
GEOM::GEOM_Object_ptr MakePlanePntVec (GEOM::GEOM_Object_ptr thePnt, GEOM::GEOM_Object_ptr theVec, CORBA::Double theTrimSize)
GEOM::GEOM_Object_ptr MakePlaneFace (GEOM::GEOM_Object_ptr theFace, CORBA::Double theTrimSize)
GEOM::GEOM_Object_ptr MakePlane2Vec (GEOM::GEOM_Object_ptr theVec1, GEOM::GEOM_Object_ptr theVec2, CORBA::Double theTrimSize)
GEOM::GEOM_Object_ptr MakePlaneLCS (GEOM::GEOM_Object_ptr theLCS, CORBA::Double theTrimSize, CORBA::Double theOrientation)
GEOM::GEOM_Object_ptr MakeMarker (CORBA::Double theOX, CORBA::Double theOY, CORBA::Double theOZ, CORBA::Double theXDX, CORBA::Double theXDY, CORBA::Double theXDZ, CORBA::Double theYDX, CORBA::Double theYDY, CORBA::Double theYDZ)
GEOM::GEOM_Object_ptr MakeMarkerFromShape (GEOM::GEOM_Object_ptr theShape)
GEOM::GEOM_Object_ptr MakeMarkerPntTwoVec (GEOM::GEOM_Object_ptr theOrigin, GEOM::GEOM_Object_ptr theXVec, GEOM::GEOM_Object_ptr theYVec)
GEOM::GEOM_Object_ptr MakeTangentPlaneOnFace (GEOM::GEOM_Object_ptr theFace, CORBA::Double theParameterU, CORBA::Double theParameterV, CORBA::Double theTrimSize)
::GEOMImpl_IBasicOperations * GetOperations ()
- Public Member Functions inherited from GEOM_IOperations_i
 GEOM_IOperations_i (PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, ::GEOM_IOperations *theImpl)
 ~GEOM_IOperations_i ()
virtual CORBA::Boolean IsDone ()
virtual void SetErrorCode (const char *theErrorCode)
virtual char * GetErrorCode ()
virtual GEOM::GEOM_BaseObject_ptr GetBaseObject (Handle(::GEOM_BaseObject) theObject)
virtual virtual Handle(::GEOM_BaseObject) GetBaseObjectImpl(GEOM GEOM::GEOM_Object_ptr GetObject (Handle(::GEOM_Object) theObject)
virtual virtual Handle(::GEOM_Object) GetObjectImpl(GEOM void StartOperation ()
virtual void FinishOperation ()
virtual void AbortOperation ()
::GEOM_IOperations * GetImpl ()
virtual void UpdateGUIForObject (GEOM::GEOM_Object_ptr theObj)
- Protected Member Functions inherited from GEOM_IOperations_i
Handle(TColStd_HSequenceOfTransient) GetListOfObjectsImpl(const GEOM bool GetListOfObjectsImpl (const GEOM::ListOfGO &theObjects, std::list< Handle(::GEOM_Object) > &theList)
◆ GEOM_IBasicOperations_i()
GEOM_IBasicOperations_i::GEOM_IBasicOperations_i ( PortableServer::POA_ptr  thePOA,
::GEOMImpl_IBasicOperations *  theImpl
constructor:
◆ ~GEOM_IBasicOperations_i()
GEOM_IBasicOperations_i::~GEOM_IBasicOperations_i ( )
destructor
◆ GetOperations()
::GEOMImpl_IBasicOperations * GEOM_IBasicOperations_i::GetOperations ( )
◆ MakeLine()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakeLine ( GEOM::GEOM_Object_ptr  thePnt,
◆ MakeLineTwoFaces()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakeLineTwoFaces ( GEOM::GEOM_Object_ptr  theFace1,
◆ MakeLineTwoPnt()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakeLineTwoPnt ( GEOM::GEOM_Object_ptr  thePnt1,
◆ MakeMarker()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakeMarker ( CORBA::Double  theOX,
◆ MakeMarkerFromShape()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakeMarkerFromShape ( GEOM::GEOM_Object_ptr  theShape)
◆ MakeMarkerPntTwoVec()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakeMarkerPntTwoVec ( GEOM::GEOM_Object_ptr  theOrigin,
◆ MakePlane2Vec()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePlane2Vec ( GEOM::GEOM_Object_ptr  theVec1,
◆ MakePlaneFace()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePlaneFace ( GEOM::GEOM_Object_ptr  theFace,
◆ MakePlaneLCS()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePlaneLCS ( GEOM::GEOM_Object_ptr  theLCS,
◆ MakePlanePntVec()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePlanePntVec ( GEOM::GEOM_Object_ptr  thePnt,
◆ MakePlaneThreePnt()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePlaneThreePnt ( GEOM::GEOM_Object_ptr  thePnt1,
◆ MakePointOnCurve()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePointOnCurve ( GEOM::GEOM_Object_ptr  theCurve,
◆ MakePointOnCurveByCoord()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePointOnCurveByCoord ( GEOM::GEOM_Object_ptr  theCurve,
◆ MakePointOnCurveByLength()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePointOnCurveByLength ( GEOM::GEOM_Object_ptr  theCurve,
◆ MakePointOnFace()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePointOnFace ( GEOM::GEOM_Object_ptr  theFace,
◆ MakePointOnLinesIntersection()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePointOnLinesIntersection ( GEOM::GEOM_Object_ptr  theLine1,
◆ MakePointOnSurface()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePointOnSurface ( GEOM::GEOM_Object_ptr  theSurface,
◆ MakePointOnSurfaceByCoord()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePointOnSurfaceByCoord ( GEOM::GEOM_Object_ptr  theSurface,
◆ MakePointWithReference()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePointWithReference ( GEOM::GEOM_Object_ptr  theReference,
CORBA::Double  theX,
CORBA::Double  theY,
CORBA::Double  theZ
◆ MakePointXYZ()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakePointXYZ ( CORBA::Double  theX,
CORBA::Double  theY,
CORBA::Double  theZ
◆ MakeTangentOnCurve()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakeTangentOnCurve ( GEOM::GEOM_Object_ptr  theCurve,
◆ MakeTangentPlaneOnFace()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakeTangentPlaneOnFace ( GEOM::GEOM_Object_ptr  theFace,
◆ MakeVectorDXDYDZ()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakeVectorDXDYDZ ( CORBA::Double  theDX,
CORBA::Double  theDZ
◆ MakeVectorTwoPnt()
GEOM::GEOM_Object_ptr GEOM_IBasicOperations_i::MakeVectorTwoPnt ( GEOM::GEOM_Object_ptr  thePnt1,
