GEOM_ICurvesOperations_i Class Reference
#include <GEOM_ICurvesOperations_i.hh>
Inheritance diagram for GEOM_ICurvesOperations_i:
 GEOM_ICurvesOperations_i (PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, ::GEOMImpl_ICurvesOperations *theImpl)
 ~GEOM_ICurvesOperations_i ()
GEOM::GEOM_Object_ptr MakeCirclePntVecR (GEOM::GEOM_Object_ptr theCenter, GEOM::GEOM_Object_ptr theVector, double theR)
GEOM::GEOM_Object_ptr MakeCircleThreePnt (GEOM::GEOM_Object_ptr thePnt1, GEOM::GEOM_Object_ptr thePnt2, GEOM::GEOM_Object_ptr thePnt3)
GEOM::GEOM_Object_ptr MakeCircleCenter2Pnt (GEOM::GEOM_Object_ptr thePnt1, GEOM::GEOM_Object_ptr thePnt2, GEOM::GEOM_Object_ptr thePnt3)
GEOM::GEOM_Object_ptr MakeEllipse (GEOM::GEOM_Object_ptr theCenter, GEOM::GEOM_Object_ptr theVector, double theRMajor, double theRMinor)
GEOM::GEOM_Object_ptr MakeEllipseVec (GEOM::GEOM_Object_ptr theCenter, GEOM::GEOM_Object_ptr theVector, double theRMajor, double theRMinor, GEOM::GEOM_Object_ptr theVectorMajor)
GEOM::GEOM_Object_ptr MakeArc (GEOM::GEOM_Object_ptr thePnt1, GEOM::GEOM_Object_ptr thePnt2, GEOM::GEOM_Object_ptr thePnt3)
GEOM::GEOM_Object_ptr MakeArcCenter (GEOM::GEOM_Object_ptr thePnt1, GEOM::GEOM_Object_ptr thePnt2, GEOM::GEOM_Object_ptr thePnt3, bool theSense)
GEOM::GEOM_Object_ptr MakeArcOfEllipse (GEOM::GEOM_Object_ptr thePnt1, GEOM::GEOM_Object_ptr thePnt2, GEOM::GEOM_Object_ptr thePnt3)
GEOM::GEOM_Object_ptr MakePolyline (const GEOM::ListOfGO &thePoints, CORBA::Boolean theIsClosed)
GEOM::GEOM_Object_ptr MakeSplineBezier (const GEOM::ListOfGO &thePoints, CORBA::Boolean theIsClosed)
GEOM::GEOM_Object_ptr MakeSplineInterpolation (const GEOM::ListOfGO &thePoints, CORBA::Boolean theIsClosed, CORBA::Boolean theDoReordering)
GEOM::GEOM_Object_ptr MakeSplineInterpolWithTangents (const GEOM::ListOfGO &thePoints, GEOM::GEOM_Object_ptr theFirstVec, GEOM::GEOM_Object_ptr theLastVec)
GEOM::GEOM_Object_ptr MakeCurveParametric (const char *thexExpr, const char *theyExpr, const char *thezExpr, double theParamMin, double theParamMax, double theParamStep, GEOM::curve_type theCurveType)
GEOM::GEOM_Object_ptr MakeCurveParametricNew (const char *thexExpr, const char *theyExpr, const char *thezExpr, double theParamMin, double theParamMax, CORBA::Long theParamNbStep, GEOM::curve_type theCurveType)
GEOM::GEOM_Object_ptr MakeIsoline (GEOM::GEOM_Object_ptr theFace, CORBA::Boolean IsUIsoline, double theParameter)
GEOM::GEOM_Object_ptr MakeSketcher (const char *theCommand, const GEOM::ListOfDouble &theWorkingPlane)
GEOM::GEOM_Object_ptr MakeSketcherOnPlane (const char *theCommand, GEOM::GEOM_Object_ptr theWorkingPlane)
GEOM::GEOM_Object_ptr Make3DSketcherCommand (const char *theCommand)
GEOM::GEOM_Object_ptr Make3DSketcher (const GEOM::ListOfDouble &theCoordinates)
GEOM::GEOM_Object_ptr MakePolyline2D (const GEOM::ListOfListOfDouble &theCoordsList, const GEOM::string_array &theNamesList, const GEOM::short_array &theTypesList, const GEOM::ListOfBool &theClosedList, const GEOM::ListOfDouble &theWorkingPlane)
GEOM::GEOM_Object_ptr MakePolyline2DOnPlane (const GEOM::ListOfListOfDouble &theCoordsList, const GEOM::string_array &theNamesList, const GEOM::short_array &theTypesList, const GEOM::ListOfBool &theClosedList, GEOM::GEOM_Object_ptr theWorkingPlane)
::GEOMImpl_ICurvesOperations * GetOperations ()
- Public Member Functions inherited from GEOM_IOperations_i
 GEOM_IOperations_i (PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, ::GEOM_IOperations *theImpl)
 ~GEOM_IOperations_i ()
virtual CORBA::Boolean IsDone ()
virtual void SetErrorCode (const char *theErrorCode)
virtual char * GetErrorCode ()
virtual GEOM::GEOM_BaseObject_ptr GetBaseObject (Handle(::GEOM_BaseObject) theObject)
virtual virtual Handle(::GEOM_BaseObject) GetBaseObjectImpl(GEOM GEOM::GEOM_Object_ptr GetObject (Handle(::GEOM_Object) theObject)
virtual virtual Handle(::GEOM_Object) GetObjectImpl(GEOM void StartOperation ()
virtual void FinishOperation ()
virtual void AbortOperation ()
::GEOM_IOperations * GetImpl ()
virtual void UpdateGUIForObject (GEOM::GEOM_Object_ptr theObj)
Handle(TColStd_HArray1OfByte) ConvertEnumArray(const GEOM Handle(TColStd_HArray1OfByte) ConvertBoolArray(const GEOM void ConvertListListDouble (const GEOM::ListOfListOfDouble &theCoordsList, std::list< std::list< double > > &theCoords)
- Protected Member Functions inherited from GEOM_IOperations_i
Handle(TColStd_HSequenceOfTransient) GetListOfObjectsImpl(const GEOM bool GetListOfObjectsImpl (const GEOM::ListOfGO &theObjects, std::list< Handle(::GEOM_Object) > &theList)
◆ GEOM_ICurvesOperations_i()
GEOM_ICurvesOperations_i::GEOM_ICurvesOperations_i ( PortableServer::POA_ptr  thePOA,
::GEOMImpl_ICurvesOperations *  theImpl
constructor:
◆ ~GEOM_ICurvesOperations_i()
GEOM_ICurvesOperations_i::~GEOM_ICurvesOperations_i ( )
destructor
◆ ConvertListListDouble()
void GEOM_ICurvesOperations_i::ConvertListListDouble ( const GEOM::ListOfListOfDouble &  theInList,
std::list< std::list< double > > &  theOutList
◆ GetOperations()
::GEOMImpl_ICurvesOperations * GEOM_ICurvesOperations_i::GetOperations ( )
◆ Make3DSketcher()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::Make3DSketcher ( const GEOM::ListOfDouble &  theCoordinates)
◆ Make3DSketcherCommand()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::Make3DSketcherCommand ( const char *  theCommand)
◆ MakeArc()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeArc ( GEOM::GEOM_Object_ptr  thePnt1,
◆ MakeArcCenter()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeArcCenter ( GEOM::GEOM_Object_ptr  thePnt1,
bool  theSense
◆ MakeArcOfEllipse()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeArcOfEllipse ( GEOM::GEOM_Object_ptr  thePnt1,
◆ MakeCircleCenter2Pnt()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeCircleCenter2Pnt ( GEOM::GEOM_Object_ptr  thePnt1,
◆ MakeCirclePntVecR()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeCirclePntVecR ( GEOM::GEOM_Object_ptr  theCenter,
double  theR
◆ MakeCircleThreePnt()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeCircleThreePnt ( GEOM::GEOM_Object_ptr  thePnt1,
◆ MakeCurveParametric()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeCurveParametric ( const char *  thexExpr,
const char *  theyExpr,
const char *  thezExpr,
double  theParamMin,
double  theParamMax,
◆ MakeCurveParametricNew()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeCurveParametricNew ( const char *  thexExpr,
double  theParamMin,
double  theParamMax,
◆ MakeEllipse()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeEllipse ( GEOM::GEOM_Object_ptr  theCenter,
double  theRMajor,
double  theRMinor
◆ MakeEllipseVec()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeEllipseVec ( GEOM::GEOM_Object_ptr  theCenter,
double  theRMajor,
double  theRMinor,
◆ MakeIsoline()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeIsoline ( GEOM::GEOM_Object_ptr  theFace,
double  theParameter
◆ MakePolyline()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakePolyline ( const GEOM::ListOfGO &  thePoints,
◆ MakePolyline2D()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakePolyline2D ( const GEOM::ListOfListOfDouble &  theCoordsList,
const GEOM::string_array &  theNamesList,
const GEOM::short_array &  theTypesList,
const GEOM::ListOfBool &  theClosedList,
const GEOM::ListOfDouble &  theWorkingPlane
◆ MakePolyline2DOnPlane()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakePolyline2DOnPlane ( const GEOM::ListOfListOfDouble &  theCoordsList,
◆ MakeSketcher()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeSketcher ( const char *  theCommand,
◆ MakeSketcherOnPlane()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeSketcherOnPlane ( const char *  theCommand,
◆ MakeSplineBezier()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeSplineBezier ( const GEOM::ListOfGO &  thePoints,
◆ MakeSplineInterpolation()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeSplineInterpolation ( const GEOM::ListOfGO &  thePoints,
◆ MakeSplineInterpolWithTangents()
GEOM::GEOM_Object_ptr GEOM_ICurvesOperations_i::MakeSplineInterpolWithTangents ( const GEOM::ListOfGO &  thePoints,
