XAOPlugin_IOperations_i Class Reference
#include <XAOPlugin_IOperations_i.hh>
Inheritance diagram for XAOPlugin_IOperations_i:
 XAOPlugin_IOperations_i (PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, XAOPlugin_IOperations *theImpl)
 ~XAOPlugin_IOperations_i ()
CORBA::Boolean ExportXAO (GEOM::GEOM_Object_ptr shape, const GEOM::ListOfGO &groups, const GEOM::ListOfFields &fields, const char *author, const char *fileName, const char *shapeFileName)
SALOMEDS::TMPFile * ExportXAOMem (GEOM::GEOM_Object_ptr shape, const GEOM::ListOfGO &groups, const GEOM::ListOfFields &fields, const char *author)
CORBA::Boolean ImportXAO (const char *fileName, GEOM::GEOM_Object_out shape, GEOM::ListOfGO_out subShapes, GEOM::ListOfGO_out groups, GEOM::ListOfFields_out fields)
CORBA::Boolean ImportXAOMem (const SALOMEDS::TMPFile &theBuff, GEOM::GEOM_Object_out shape, GEOM::ListOfGO_out subShapes, GEOM::ListOfGO_out groups, GEOM::ListOfFields_out fields)
XAOPlugin_IOperations * GetOperations ()
- Public Member Functions inherited from GEOM_IOperations_i
 GEOM_IOperations_i (PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, ::GEOM_IOperations *theImpl)
 ~GEOM_IOperations_i ()
virtual CORBA::Boolean IsDone ()
virtual void SetErrorCode (const char *theErrorCode)
virtual char * GetErrorCode ()
virtual GEOM::GEOM_BaseObject_ptr GetBaseObject (Handle(::GEOM_BaseObject) theObject)
virtual virtual Handle(::GEOM_BaseObject) GetBaseObjectImpl(GEOM GEOM::GEOM_Object_ptr GetObject (Handle(::GEOM_Object) theObject)
virtual virtual Handle(::GEOM_Object) GetObjectImpl(GEOM void StartOperation ()
virtual void FinishOperation ()
virtual void AbortOperation ()
::GEOM_IOperations * GetImpl ()
virtual void UpdateGUIForObject (GEOM::GEOM_Object_ptr theObj)
std::string exportXAO (GEOM::GEOM_Object_ptr shape, const GEOM::ListOfGO &groups, const GEOM::ListOfFields &fields, const char *author, const bool toFile, const char *fileName, const char *shapeFileName)
CORBA::Boolean importXAO (const bool isFile, const char *fileName, const SALOMEDS::TMPFile &theBuff, GEOM::GEOM_Object_out shape, GEOM::ListOfGO_out subShapes, GEOM::ListOfGO_out groups, GEOM::ListOfFields_out fields)
- Protected Member Functions inherited from GEOM_IOperations_i
Handle(TColStd_HSequenceOfTransient) GetListOfObjectsImpl(const GEOM bool GetListOfObjectsImpl (const GEOM::ListOfGO &theObjects, std::list< Handle(::GEOM_Object) > &theList)
◆ XAOPlugin_IOperations_i()
XAOPlugin_IOperations_i::XAOPlugin_IOperations_i ( PortableServer::POA_ptr  thePOA,
XAOPlugin_IOperations *  theImpl
constructor:
◆ ~XAOPlugin_IOperations_i()
XAOPlugin_IOperations_i::~XAOPlugin_IOperations_i ( )
destructor
◆ exportXAO()
std::string XAOPlugin_IOperations_i::exportXAO ( GEOM::GEOM_Object_ptr  shape,
const GEOM::ListOfGO &  groups,
const GEOM::ListOfFields &  fields,
const char *  author,
const bool  toFile,
const char *  fileName,
const char *  shapeFileName
Export a shape to XAO format
shapeThe shape to export
groupsThe list of groups to export
fieldsThe list of fields to export
authorThe author of the export
toFileExport to file if true, otherwise export to memory buffer (the returned string)
fileNameThe name of the exported file
shapeFileNameIf not empty, save the BREP shape to this external file
string The exported buffer if toFile=false, otherwise an empty string
References XAOPlugin_IOperations::ExportXAO(), XAOPlugin_IOperations::ExportXAOMem(), GetOperations(), Handle(), and GEOM_IOperations::SetNotDone().
◆ ExportXAO()
CORBA::Boolean XAOPlugin_IOperations_i::ExportXAO ( GEOM::GEOM_Object_ptr  shape,
Export a shape to XAO format file
boolean indicating if export was successful.
References exportXAO(), and GEOM_IOperations_i::IsDone().
◆ ExportXAOMem()
SALOMEDS::TMPFile * XAOPlugin_IOperations_i::ExportXAOMem ( GEOM::GEOM_Object_ptr  shape,
const char *  author
Export a shape to XAO format buffer
The output buffer
References exportXAO().
◆ GetOperations()
XAOPlugin_IOperations * XAOPlugin_IOperations_i::GetOperations ( )
◆ importXAO()
CORBA::Boolean XAOPlugin_IOperations_i::importXAO ( const bool  isFile,
const SALOMEDS::TMPFile &  theBuff,
Import a shape from XAO format
isFileBoolean flag to switch between import from file or from buffer
fileNameThe name of the file to import from if isFile=true
theBuffThe buffer to import from if isFile=false
shapeThe imported shape
subShapesThe list of imported subShapes
groupsThe list of imported groups
fieldsThe list of imported fields
boolean indicating if import was successful.
References GEOM_IOperations_i::GetBaseObject(), GEOM_IOperations_i::GetObject(), GetOperations(), Handle(), XAOPlugin_IOperations::ImportXAO(), XAOPlugin_IOperations::ImportXAOMem(), GEOM_IOperations_i::IsDone(), and GEOM_IOperations::SetNotDone().
◆ ImportXAO()
CORBA::Boolean XAOPlugin_IOperations_i::ImportXAO ( const char *  fileName,
References importXAO(), and GEOM_IOperations_i::IsDone().
◆ ImportXAOMem()
CORBA::Boolean XAOPlugin_IOperations_i::ImportXAOMem ( const SALOMEDS::TMPFile &  theBuff,
Import a shape from XAO format memory buffer
