XAOPlugin_IOperations Class Reference
#include <XAOPlugin_IOperations.hxx>
Inheritance diagram for XAOPlugin_IOperations:
 XAOPlugin_IOperations (GEOM_Engine *)
 ~XAOPlugin_IOperations ()
bool ExportXAO (Handle(GEOM_Object) shape, std::list< Handle(GEOM_Object)> groupList, std::list< Handle(GEOM_Field)> fieldList, const char *author, const char *fileName, const char *shapeFileName)
std::string ExportXAOMem (Handle(GEOM_Object) shape, std::list< Handle(GEOM_Object)> groupList, std::list< Handle(GEOM_Field)> fieldList, const char *author)
bool ImportXAO (const char *fileName, Handle(GEOM_Object)&shape, Handle(TColStd_HSequenceOfTransient)&subShapes, Handle(TColStd_HSequenceOfTransient)&groups, Handle(TColStd_HSequenceOfTransient)&fields)
bool ImportXAOMem (const std::string &theXML, Handle(GEOM_Object)&shape, Handle(TColStd_HSequenceOfTransient)&subShapes, Handle(TColStd_HSequenceOfTransient)&groups, Handle(TColStd_HSequenceOfTransient)&fields)
- Public Member Functions inherited from GEOMImpl_IBaseIEOperations
Standard_EXPORT GEOMImpl_IBaseIEOperations (GEOM_Engine *theEngine)
Standard_EXPORT ~GEOMImpl_IBaseIEOperations ()
- Public Member Functions inherited from GEOM_IOperations
Standard_EXPORT GEOM_IOperations (GEOM_Engine *theEngine)
Standard_EXPORT ~GEOM_IOperations ()
Standard_EXPORT void StartOperation ()
Standard_EXPORT void FinishOperation ()
Standard_EXPORT void AbortOperation ()
Standard_EXPORT bool IsDone ()
Standard_EXPORT void SetNotDone ()
Standard_EXPORT void SetErrorCode (const TCollection_AsciiString &theErrorCode)
Standard_EXPORT char * GetErrorCode ()
Standard_EXPORT GEOM_Engine * GetEngine ()
Standard_EXPORT GEOM_Solver * GetSolver ()
std::string exportXAO (Handle(GEOM_Object) shape, std::list< Handle(GEOM_Object)> groupList, std::list< Handle(GEOM_Field)> fieldList, const char *author, const char *fileName, const char *shapeFileName)
bool importXAO (const char *fileName, const std::string &theXML, Handle(GEOM_Object)&shape, Handle(TColStd_HSequenceOfTransient)&subShapes, Handle(TColStd_HSequenceOfTransient)&groups, Handle(TColStd_HSequenceOfTransient)&fields)
void importSubShapes (XAO::Geometry *xaoGeometry, Handle(GEOM_Function) function, int shapeType, int dim, Handle(TColStd_HSequenceOfTransient)&subshapeList)
void exportSubshapes (const Handle(GEOM_Object)&shape, XAO::BrepGeometry *geometry)
void exportFields (std::list< Handle(GEOM_Field)> fieldList, XAO::Xao *xaoObject, XAO::BrepGeometry *geometry)
bool exportGroups (std::list< Handle(GEOM_Object)> groupList, XAO::Xao *xaoObject, XAO::BrepGeometry *geometry)
- Protected Member Functions inherited from GEOMImpl_IBaseIEOperations
Standard_EXPORT void MakeMaterialGroups (const Handle(GEOM_Object) &theObject, const Handle(TColStd_HSequenceOfTransient) &theSeq)
 Handle (GEOM_Object) MakeGroup(const Handle(GEOM_Object) &theObject
- Protected Attributes inherited from GEOMImpl_IBaseIEOperations
const TCollection_ExtendedString & theName
const TCollection_ExtendedString const NCollection_List< TopoDS_Shape > & theShapes
GEOMImpl_IGroupOperations * myGroupOperations
GEOMImpl_IFieldOperations * myFieldOperations
GEOMImpl_IShapesOperations * myShapesOperations
◆ XAOPlugin_IOperations()
XAOPlugin_IOperations::XAOPlugin_IOperations ( GEOM_Engine *  theEngine)
Constructor
◆ ~XAOPlugin_IOperations()
XAOPlugin_IOperations::~XAOPlugin_IOperations ( )
Destructor
◆ exportFields()
◆ exportGroups()
◆ exportSubshapes()
◆ ExportXAO()
bool XAOPlugin_IOperations::ExportXAO ( Handle(GEOM_Object)  shape,
const char *  author,
const char *  fileName,
const char *  shapeFileName
Export a shape to XAO format file.
shapeThe shape to export.
groupsThe list of groups to export.
fieldsThe list of fields to export.
fileNameThe name of the file to be exported.
shapeFileNameThe name of the file for shape, if it should be exported separately.
boolean indicating if export was successful.
References exportXAO(), GEOM_IOperations::IsDone(), and GEOM_IOperations::SetErrorCode().
◆ exportXAO()
std::string XAOPlugin_IOperations::exportXAO ( Handle(GEOM_Object)  shape,
Export a shape to XAO format file or string.
fileNameThe name of the file to be exported. If empty, export to string.
The exported string, if fileName is empty, or empty string.
References XAO::BREP, XAO::Geometry::createGeometry(), EXPORT_SHAPE, exportFields(), exportGroups(), exportSubshapes(), XAO::Xao::exportXAO(), GEOM_IMPORT, GEOM_IOperations::GetEngine(), XAO::Xao::getXML(), GEOMImpl_IBaseIEOperations::Handle(), KO, OK, XAO::Xao::setAuthor(), GEOM_IOperations::SetErrorCode(), XAO::Xao::setGeometry(), XAO::Geometry::setName(), and XAO::BrepGeometry::setTopoDS_Shape().
◆ ExportXAOMem()
std::string XAOPlugin_IOperations::ExportXAOMem ( Handle(GEOM_Object)  shape,
const char *  author
Export a shape to XAO format string.
The exported string.
References exportXAO().
◆ importSubShapes()
◆ importXAO()
bool XAOPlugin_IOperations::importXAO ( const char *  fileName,
const std::string &  theXML,
Handle(GEOM_Object)&  shape,
Handle(TColStd_HSequenceOfTransient)&  subShapes,
Handle(TColStd_HSequenceOfTransient)&  groups,
Handle(TColStd_HSequenceOfTransient)&  fields
Import a shape from XAO format file.
fileNameThe name of the file to import.
shapeThe imported shape.
subShapesThe list of imported sub-shapes.
groupsThe list of imported groups.
fieldsThe list of imported fields.
boolean indicating if import was successful.
References XAO::Group::begin(), XAO::BOOLEAN, XAO::BREP, XAO::Group::count(), XAO::Field::countComponents(), XAO::Xao::countFields(), XAO::Xao::countGroups(), XAO::Field::countSteps(), XAO::Step::countValues(), XAO::DOUBLE, XAO::EDGE, XAO::Group::end(), XAO::FACE, GEOM_EDGE, GEOM_FACE, GEOM_GROUP, GEOM_IMPORT, GEOM_POINT, GEOM_SOLID, XAO::Field::getComponentName(), XAO::Group::getDimension(), XAO::Field::getDimension(), XAO::Geometry::getElementReference(), GEOM_IOperations::GetEngine(), XAO::Xao::getField(), XAO::Geometry::getFormat(), XAO::Xao::getGeometry(), XAO::Xao::getGroup(), getGroupDimension(), XAO::Geometry::getName(), XAO::Group::getName(), XAO::Field::getName(), XAO::Step::getStamp(), XAO::Step::getStep(), XAO::BooleanField::getStep(), XAO::DoubleField::getStep(), XAO::IntegerField::getStep(), XAO::StringField::getStep(), XAO::BrepGeometry::getTopoDS_Shape(), XAO::Field::getType(), XAO::BooleanStep::getValues(), XAO::DoubleStep::getValues(), XAO::IntegerStep::getValues(), XAO::StringStep::getValues(), GEOMImpl_IBaseIEOperations::Handle(), IMPORT_SHAPE, importSubShapes(), XAO::Xao::importXAO(), XAO::INTEGER, KO, GEOMImpl_IBaseIEOperations::myFieldOperations, OK, GEOM_IOperations::SetErrorCode(), XAO::Xao::setXML(), XAO::SOLID, XAO::STRING, XAO::XaoUtils::stringToInt(), XAO::VERTEX, and XAO::XAO_Exception::what().
◆ ImportXAO()
bool XAOPlugin_IOperations::ImportXAO ( const char *  fileName,
References importXAO(), GEOM_IOperations::IsDone(), and GEOM_IOperations::SetErrorCode().
◆ ImportXAOMem()
bool XAOPlugin_IOperations::ImportXAOMem ( const std::string &  theXML,
Import a shape from XAO format string.
theXMLThe input buffer.
References importXAO(), and GEOM_IOperations::IsDone().
