XAO::Xao Class Reference
The Xao class describes the XAO format.
#include <XAO_Xao.hxx>
 Xao ()
 Default constructor. More...
 Xao (const std::string &author, const std::string &version)
 Constructor with author and version. More...
virtual ~Xao ()
const std::string getAuthor () const
 Gets the author of the file. More...
void setAuthor (const std::string &author)
 Sets the author of the file. More...
const std::string getVersion () const
 Gets the version of the file. More...
void setVersion (const std::string &version)
 Sets the version of the file. More...
Geometry * getGeometry () const
 Gets the geometry. More...
void setGeometry (Geometry *geometry)
 Sets the geometry. More...
int countGroups () const
 Gets the number of groups. More...
Group * getGroup (int index)
 Gets a group. More...
Group * addGroup (XAO::Dimension dim, const std::string &name=std::string(""))
 Adds a group. More...
bool removeGroup (Group *group)
 Removes a group. More...
int countFields () const
 Gets the number of fields. More...
XAO::Type getFieldType (int index)
 Gets the type of a field. More...
Field * getField (int index)
 Gets a field. More...
BooleanField * getBooleanField (int index)
DoubleField * getDoubleField (int index)
IntegerField * getIntegerField (int index)
StringField * getStringField (int index)
Field * addField (XAO::Type type, XAO::Dimension dim, int nbComponents, const std::string &name=std::string(""))
 Adds a field. More...
BooleanField * addBooleanField (XAO::Dimension dim, int nbComponents, const std::string &name=std::string(""))
IntegerField * addIntegerField (XAO::Dimension dim, int nbComponents, const std::string &name=std::string(""))
DoubleField * addDoubleField (XAO::Dimension dim, int nbComponents, const std::string &name=std::string(""))
StringField * addStringField (XAO::Dimension dim, int nbComponents, const std::string &name=std::string(""))
bool removeField (Field *field)
 Removes a field. More...
bool exportXAO (const std::string &fileName, const std::string &shapeFileName)
 Exports this XAO object to a file. More...
const std::string getXML ()
 Gets the XML corresponding to this XAO. More...
bool importXAO (const std::string &fileName)
 Imports an XAO file into this object. More...
bool setXML (const std::string &xml)
 Sets an XML describing an XAO format to this object. More...
void checkGeometry () const
void checkGroupIndex (int index) const
void checkFieldIndex (int index) const
void checkGroupDimension (XAO::Dimension dim) const
std::string m_author
 The author of the file. More...
std::string m_version
 The version of the file. More...
Geometry * m_geometry
 The geometry. More...
std::list< Group * > m_groups
 The list of groups. More...
std::list< Field * > m_fields
 The list of fields. More...
◆ Xao() [1/2]
Xao::Xao ( )
◆ Xao() [2/2]
Xao::Xao ( const std::string &  author,
const std::string &  version
authorthe author of the file.
versionthe version of the XAO format.
References m_author, m_geometry, and m_version.
◆ ~Xao()
Xao::~Xao ( )
References m_fields, m_geometry, and m_groups.
◆ addBooleanField()
BooleanField * Xao::addBooleanField ( XAO::Dimension  dim,
int  nbComponents,
const std::string &  name = std::string("")
◆ addDoubleField()
DoubleField * Xao::addDoubleField ( XAO::Dimension  dim,
int  nbComponents,
◆ addField()
Field * Xao::addField ( XAO::Type  type,
XAO::Dimension  dim,
int  nbComponents,
typethe type of the field.
dimthe dimension of the field.
nbComponentsthe number of components in the field.
namethe name of the field.
the created field.
References checkGeometry(), XAO::Geometry::countElements(), XAO::Field::createField(), m_fields, and m_geometry.
◆ addGroup()
Group * Xao::addGroup ( XAO::Dimension  dim,
dimthe dimension of the group.
namethe name of the group.
the created group.
References checkGeometry(), checkGroupDimension(), XAO::Geometry::countElements(), m_geometry, and m_groups.
◆ addIntegerField()
IntegerField * Xao::addIntegerField ( XAO::Dimension  dim,
int  nbComponents,
◆ addStringField()
StringField * Xao::addStringField ( XAO::Dimension  dim,
int  nbComponents,
◆ checkFieldIndex()
void Xao::checkFieldIndex ( int  index) const
References countFields().
◆ checkGeometry()
void Xao::checkGeometry ( ) const
References m_geometry.
◆ checkGroupDimension()
void Xao::checkGroupDimension ( XAO::Dimension  dim) const
References XAO::WHOLE.
◆ checkGroupIndex()
void Xao::checkGroupIndex ( int  index) const
References countGroups().
◆ countFields()
int Xao::countFields ( ) const
References m_fields.
◆ countGroups()
int Xao::countGroups ( ) const
References m_groups.
◆ exportXAO()
bool Xao::exportXAO ( const std::string &  fileName,
const std::string &  shapeFileName
fileNamethe name of the file to create.
shapeFileNameif not empty, export the shape to this external file.
true is the export is successful.
References XAO::XaoExporter::saveToFile().
◆ getAuthor()
const std::string XAO::Xao::getAuthor ( ) const
◆ getBooleanField()
BooleanField * Xao::getBooleanField ( int  index)
◆ getDoubleField()
DoubleField * Xao::getDoubleField ( int  index)
◆ getField()
Field * Xao::getField ( int  index)
indexthe index of the wanted field.
the field.
References checkFieldIndex(), and m_fields.
◆ getFieldType()
XAO::Type Xao::getFieldType ( int  index)
References getField(), and XAO::Field::getType().
◆ getGeometry()
Geometry * XAO::Xao::getGeometry ( ) const
the geometry.
◆ getGroup()
Group * Xao::getGroup ( int  index)
indexthe index of the wanted group.
the group.
References checkGroupIndex(), and m_groups.
◆ getIntegerField()
IntegerField * Xao::getIntegerField ( int  index)
◆ getStringField()
StringField * Xao::getStringField ( int  index)
◆ getVersion()
const std::string XAO::Xao::getVersion ( ) const
◆ getXML()
const std::string Xao::getXML ( )
the XML as a string.
References XAO::XaoExporter::saveToXml().
◆ importXAO()
bool Xao::importXAO ( const std::string &  fileName)
fileNamethe name of the file to import.
true if the import is successful.
References XAO::XaoExporter::readFromFile().
◆ removeField()
bool Xao::removeField ( Field *  field)
fieldthe field to remove.
true if the field has been removed, false otherwise.
References countFields(), and m_fields.
◆ removeGroup()
bool Xao::removeGroup ( Group *  group)
groupthe group to remove.
true if the group has been removed, false otherwise.
References countGroups(), and m_groups.
◆ setAuthor()
void XAO::Xao::setAuthor ( const std::string &  author)
authorthe author to set.
◆ setGeometry()
void XAO::Xao::setGeometry ( Geometry *  geometry)
geometrythe geometry to set.
References XAO::Geometry::setReadOnly().
◆ setVersion()
void XAO::Xao::setVersion ( const std::string &  version)
versionthe version to set.
◆ setXML()
bool Xao::setXML ( const std::string &  xml)
xmlthe XML to set.
References XAO::XaoExporter::setXML().
◆ m_author
std::string XAO::Xao::m_author
◆ m_fields
std::list<Field*> XAO::Xao::m_fields
◆ m_geometry
Geometry* XAO::Xao::m_geometry
◆ m_groups
std::list<Group*> XAO::Xao::m_groups
◆ m_version
std::string XAO::Xao::m_version
