XAO::Geometry Class Referenceabstract
Base class for geometries.
#include <XAO_Geometry.hxx>
Inheritance diagram for XAO::Geometry:
static Geometry * createGeometry (XAO::Format format)
 Creates a geometry. More...
 Geometry (const std::string &name)
name the name of the geometry.
Creates a geometry.
the created geometry.
std::string m_name
GeometricElementList m_vertices
GeometricElementList m_edges
GeometricElementList m_faces
GeometricElementList m_solids
bool m_readOnly
void checkReadOnly ()
static Geometry * createGeometry (XAO::Format format, const std::string &name)
virtual ~Geometry ()
const std::string getName ()
 Gets the name of the geometry. More...
 Sets the name of the geometry. More...
virtual XAO::Format getFormat ()=0
 Gets the format of the geometry. More...
virtual const std::string getShapeString ()=0
virtual void setShapeString (const std::string &shape)=0
virtual void writeShapeFile (const std::string &fileName)=0
virtual void readShapeFile (const std::string &fileName)=0
int countElements (XAO::Dimension dim) const
int countVertices () const
int countEdges () const
int countFaces () const
int countSolids () const
void setCountVertices (int nb)
void setCountEdges (int nb)
void setCountFaces (int nb)
void setCountSolids (int nb)
const std::string getVertexName (int index)
const std::string getEdgeName (int index)
const std::string getFaceName (int index)
const std::string getSolidName (int index)
void setVertexName (int index, const std::string &name)
void setEdgeName (int index, const std::string &name)
void setFaceName (int index, const std::string &name)
void setSolidName (int index, const std::string &name)
bool hasVertexName (int index)
bool hasEdgeName (int index)
bool hasFaceName (int index)
bool hasSolidName (int index)
const std::string getVertexReference (int index)
const std::string getEdgeReference (int index)
const std::string getFaceReference (int index)
const std::string getSolidReference (int index)
const std::string getElementReference (XAO::Dimension dim, int index)
void setVertexReference (int index, const std::string &reference)
void setEdgeReference (int index, const std::string &reference)
void setFaceReference (int index, const std::string &reference)
void setSolidReference (int index, const std::string &reference)
void setVertex (int index, const std::string &name, const std::string &reference)
void setEdge (int index, const std::string &name, const std::string &reference)
void setFace (int index, const std::string &name, const std::string &reference)
void setSolid (int index, const std::string &name, const std::string &reference)
int getVertexIndexByReference (const std::string &reference)
int getEdgeIndexByReference (const std::string &reference)
int getFaceIndexByReference (const std::string &reference)
int getSolidIndexByReference (const std::string &reference)
int getElementIndexByReference (XAO::Dimension dim, const std::string &reference)
GeometricElementList::iterator begin (XAO::Dimension dim)
GeometricElementList::iterator end (XAO::Dimension dim)
bool isReadOnly ()
 Verifies if the geometry is read only. More...
void setReadOnly ()
 Sets the geometry read only. More...
◆ Geometry()
Geometry::Geometry ( const std::string &  name)
namethe name of the Geometry.
References m_readOnly.
◆ ~Geometry()
Geometry::~Geometry ( )
◆ begin()
◆ checkReadOnly()
void Geometry::checkReadOnly ( )
◆ countEdges()
int XAO::Geometry::countEdges ( ) const
◆ countElements()
int Geometry::countElements ( XAO::Dimension  dim) const
◆ countFaces()
int XAO::Geometry::countFaces ( ) const
◆ countSolids()
int XAO::Geometry::countSolids ( ) const
◆ countVertices()
int XAO::Geometry::countVertices ( ) const
◆ createGeometry() [1/2]
Geometry * Geometry::createGeometry ( XAO::Format  format)
formatthe format of the geometry.
References createGeometry().
◆ createGeometry() [2/2]
Geometry * Geometry::createGeometry ( XAO::Format  format,
References XAO::BREP.
◆ end()
◆ getEdgeIndexByReference()
int XAO::Geometry::getEdgeIndexByReference ( const std::string &  reference)
◆ getEdgeName()
const std::string XAO::Geometry::getEdgeName ( int  index)
◆ getEdgeReference()
const std::string XAO::Geometry::getEdgeReference ( int  index)
◆ getElementIndexByReference()
int Geometry::getElementIndexByReference ( XAO::Dimension  dim,
◆ getElementReference()
const std::string Geometry::getElementReference ( XAO::Dimension  dim,
int  index
◆ getFaceIndexByReference()
int XAO::Geometry::getFaceIndexByReference ( const std::string &  reference)
◆ getFaceName()
const std::string XAO::Geometry::getFaceName ( int  index)
◆ getFaceReference()
const std::string XAO::Geometry::getFaceReference ( int  index)
◆ getFormat()
virtual XAO::Format XAO::Geometry::getFormat ( )
pure virtual
Implemented in XAO::BrepGeometry.
◆ getName()
const std::string XAO::Geometry::getName ( )
◆ getShapeString()
virtual const std::string XAO::Geometry::getShapeString ( )
pure virtual
◆ getSolidIndexByReference()
int XAO::Geometry::getSolidIndexByReference ( const std::string &  reference)
◆ getSolidName()
const std::string XAO::Geometry::getSolidName ( int  index)
◆ getSolidReference()
const std::string XAO::Geometry::getSolidReference ( int  index)
◆ getVertexIndexByReference()
int XAO::Geometry::getVertexIndexByReference ( const std::string &  reference)
◆ getVertexName()
const std::string XAO::Geometry::getVertexName ( int  index)
◆ getVertexReference()
const std::string XAO::Geometry::getVertexReference ( int  index)
◆ hasEdgeName()
bool XAO::Geometry::hasEdgeName ( int  index)
◆ hasFaceName()
bool XAO::Geometry::hasFaceName ( int  index)
◆ hasSolidName()
bool XAO::Geometry::hasSolidName ( int  index)
◆ hasVertexName()
bool XAO::Geometry::hasVertexName ( int  index)
◆ isReadOnly()
bool XAO::Geometry::isReadOnly ( )
true if the geometry is read only.
◆ readShapeFile()
virtual void XAO::Geometry::readShapeFile ( const std::string &  fileName)
pure virtual
◆ setCountEdges()
void Geometry::setCountEdges ( int  nb)
◆ setCountFaces()
void Geometry::setCountFaces ( int  nb)
◆ setCountSolids()
void Geometry::setCountSolids ( int  nb)
◆ setCountVertices()
void Geometry::setCountVertices ( int  nb)
◆ setEdge()
void Geometry::setEdge ( int  index,
const std::string &  name,
◆ setEdgeName()
void XAO::Geometry::setEdgeName ( int  index,
◆ setEdgeReference()
void Geometry::setEdgeReference ( int  index,
◆ setFace()
void Geometry::setFace ( int  index,
◆ setFaceName()
void XAO::Geometry::setFaceName ( int  index,
◆ setFaceReference()
void Geometry::setFaceReference ( int  index,
◆ setName()
void XAO::Geometry::setName ( const std::string &  name)
namethe name to set.
◆ setReadOnly()
void XAO::Geometry::setReadOnly ( )
◆ setShapeString()
virtual void XAO::Geometry::setShapeString ( const std::string &  shape)
pure virtual
◆ setSolid()
void Geometry::setSolid ( int  index,
◆ setSolidName()
void XAO::Geometry::setSolidName ( int  index,
◆ setSolidReference()
void Geometry::setSolidReference ( int  index,
◆ setVertex()
void Geometry::setVertex ( int  index,
◆ setVertexName()
void XAO::Geometry::setVertexName ( int  index,
◆ setVertexReference()
void Geometry::setVertexReference ( int  index,
◆ writeShapeFile()
virtual void XAO::Geometry::writeShapeFile ( const std::string &  fileName)
pure virtual
◆ m_edges
GeometricElementList XAO::Geometry::m_edges
◆ m_faces
GeometricElementList XAO::Geometry::m_faces
◆ m_name
std::string XAO::Geometry::m_name
◆ m_readOnly
bool XAO::Geometry::m_readOnly
◆ m_solids
GeometricElementList XAO::Geometry::m_solids
◆ m_vertices
GeometricElementList XAO::Geometry::m_vertices
