XAO::XaoExporter Class Reference
Util class for import/export XAO.
#include <XAO_XaoExporter.hxx>
static bool saveToFile (Xao *xaoObject, const std::string &fileName, const std::string &shapeFileName)
 Saves the XAO object to a file. More...
static const std::string saveToXml (Xao *xaoObject)
 Saves the XAO object to a XML string. More...
static bool readFromFile (const std::string &fileName, Xao *xaoObject)
 Reads a XAO object from a file. More...
static bool setXML (const std::string &xml, Xao *xaoObject)
 Reads a XAO object from an XML string. More...
◆ readFromFile()
bool XaoExporter::readFromFile ( const std::string &  fileName,
Xao *  xaoObject
fileNamethe path of the file to read.
xaoObjectthe XAO object.
true if the XAO object was read successful, false otherwise.
◆ saveToFile()
bool XaoExporter::saveToFile ( Xao *  xaoObject,
const std::string &  shapeFileName
xaoObjectthe object to export.
fileNamethe path of the file to create.
shapeFileNameif not empty save the shape in an this external file.
true if the export was successful, false otherwise.
◆ saveToXml()
const std::string XaoExporter::saveToXml ( Xao *  xaoObject)
the XML string.
◆ setXML()
bool XaoExporter::setXML ( const std::string &  xml,
Xao *  xaoObject
xmlthe XML string.
