XAO::Field Class Referenceabstract
A geometrical Field.
#include <XAO_Field.hxx>
Inheritance diagram for XAO::Field:
 Field (XAO::Dimension dimension, int nbElements, int nbComponents, const std::string &name)
the name of the field.
Creates a Field of the given type.
typethe type of the field to create.
dimensionthe dimension.
nbElementsthe number of geometrical elements.
nbComponentsthe number of components.
the created field.
std::string m_name
 The name of the Field. More...
XAO::Dimension m_dimension
 The dimension of the Field. More...
int m_nbComponents
 The number of components. More...
std::vector< std::string > m_components
 The components of the field. More...
int m_nbElements
 The number of elements. More...
std::vector< Step * > m_steps
 The list of steps. More...
void checkComponent (int component)
void checkStepIndex (int step)
static Field * createField (XAO::Type type, XAO::Dimension dimension, int nbElements, int nbComponents, const std::string &name=std::string(""))
virtual ~Field ()
virtual XAO::Type getType ()=0
 Gets the Type of the field. More...
const std::string getName () const
 Gets the name of the Field. More...
 Sets the name of the Field. More...
XAO::Dimension getDimension () const
 Gets the Dimension of the Field. More...
int countElements () const
 Gets the number of elements of each step. More...
int countComponents () const
 Gets the number of components. More...
int countValues () const
 Gets the number of values for each step. More...
int countSteps () const
 Gets the number of the steps. More...
const std::string getComponentName (int index)
 Gets the name of a component. More...
void setComponentName (int componentIndex, const std::string &name)
 Sets the name of a component. More...
void setComponentsNames (const std::vector< std::string > &names)
 Sets the name of the components. More...
virtual Step * addNewStep (int number)=0
 Adds a new step of the same type than the field. More...
bool removeStep (Step *step)
 Remove a step. More...
bool hasStep (int step)
 Verifies if the field has a step with the given step number. More...
stepIterator begin ()
 Returns the first step. More...
stepIterator end ()
 Returns the last step. More...
◆ Field()
Field::Field ( XAO::Dimension  dimension,
int  nbElements,
int  nbComponents,
const std::string &  name
dimensionthe dimension of the field.
nbElementsthe number of elements.
namethe name of the field.
◆ ~Field()
Field::~Field ( )
References m_steps.
◆ addNewStep()
virtual Step * XAO::Field::addNewStep ( int  number)
pure virtual
numberthe numer of the step.
the new create step.
Implemented in XAO::BooleanField, XAO::DoubleField, XAO::IntegerField, and XAO::StringField.
◆ begin()
stepIterator XAO::Field::begin ( )
an iterator on the first step.
◆ checkComponent()
void Field::checkComponent ( int  component)
References m_nbComponents.
◆ checkStepIndex()
void Field::checkStepIndex ( int  step)
References m_steps.
◆ countComponents()
int XAO::Field::countComponents ( ) const
◆ countElements()
int XAO::Field::countElements ( ) const
◆ countSteps()
int XAO::Field::countSteps ( ) const
the number of steps.
◆ countValues()
int XAO::Field::countValues ( ) const
◆ createField()
Field * Field::createField ( XAO::Type  type,
int  nbElements,
int  nbComponents,
const std::string &  name = std::string("")
◆ end()
stepIterator XAO::Field::end ( )
an iterator on the last step.
◆ getComponentName()
const std::string Field::getComponentName ( int  index)
indexthe index of the component to get.
the name of the component for the given index.
References checkComponent(), and m_components.
◆ getDimension()
XAO::Dimension XAO::Field::getDimension ( ) const
◆ getName()
const std::string XAO::Field::getName ( ) const
◆ getType()
virtual XAO::Type XAO::Field::getType ( )
pure virtual
◆ hasStep()
bool Field::hasStep ( int  step)
stepthe step number.
true if the field has a step for the given number.
References XAO::Step::getStep(), and m_steps.
◆ removeStep()
bool Field::removeStep ( Step *  step)
stepthe step to remove.
true if the step has been removed, false otherwise.
References m_steps.
◆ setComponentName()
void Field::setComponentName ( int  componentIndex,
componentIndexthe index of the component to set.
namethe name to set.
◆ setComponentsNames()
void Field::setComponentsNames ( const std::vector< std::string > &  names)
namesthe names to set.
References m_components, and m_nbComponents.
◆ setName()
void XAO::Field::setName ( const std::string &  name)
◆ m_components
std::vector<std::string> XAO::Field::m_components
◆ m_dimension
XAO::Dimension XAO::Field::m_dimension
◆ m_name
std::string XAO::Field::m_name
◆ m_nbComponents
int XAO::Field::m_nbComponents
◆ m_nbElements
int XAO::Field::m_nbElements
◆ m_steps
std::vector<Step*> XAO::Field::m_steps
