XAO::Step Class Referenceabstract
Base class for steps.
#include <XAO_Step.hxx>
Inheritance diagram for XAO::Step:
virtual ~Step ()
virtual XAO::Type getType ()=0
 Gets the type of the step. More...
int getStep ()
 Gets the step index. More...
void setStep (int step)
 Sets the number of the step. More...
int getStamp ()
 Gets the stamp of the index. More...
void setStamp (int stamp)
 Sets the stamp of the index. More...
int countComponents ()
 Gets the number of components of the step. More...
int countElements ()
 Gets the number of elements for the step. More...
int countValues ()
 Gets the number of values for the step. More...
virtual const std::string getStringValue (int element, int component)=0
 Gets a value as a string. More...
virtual void setStringValue (int element, int component, const std::string &value)=0
 Sets a value as a string. More...
 Step ()
 Default constructor. More...
void checkElementIndex (int element)
 Checks that given element index is in the range of element indexes. More...
void checkComponentIndex (int component)
 Checks that given component index is in the range of component indexes. More...
void checkNbElements (int nbElements)
 Checks that the given number of elements is correct. More...
void checkNbComponents (int nbComponents)
 Checks that the given number of components is correct. More...
void checkNbValues (int nbValues)
 checks that the given number of values is correct. More...
int m_step
 the index of the step. More...
int m_stamp
 The stamp of the step. More...
int m_nbComponents
 The number of components. More...
int m_nbElements
 The number of elements. More...
◆ Step()
XAO::Step::Step ( )
inlineprotected
◆ ~Step()
virtual XAO::Step::~Step ( )
◆ checkComponentIndex()
void Step::checkComponentIndex ( int  component)
componentthe index to check.
References m_nbComponents.
◆ checkElementIndex()
void Step::checkElementIndex ( int  element)
elementthe index to check.
References m_nbElements.
◆ checkNbComponents()
void Step::checkNbComponents ( int  nbComponents)
nbComponentsthe number of components to check.
◆ checkNbElements()
void Step::checkNbElements ( int  nbElements)
nbElementsthe number of elements to check.
◆ checkNbValues()
void Step::checkNbValues ( int  nbValues)
nbValuesthe number of values to check.
References m_nbComponents, and m_nbElements.
◆ countComponents()
int XAO::Step::countComponents ( )
the number of components.
◆ countElements()
int XAO::Step::countElements ( )
the number of elements.
◆ countValues()
int XAO::Step::countValues ( )
the number of values.
◆ getStamp()
int XAO::Step::getStamp ( )
◆ getStep()
int XAO::Step::getStep ( )
◆ getStringValue()
virtual const std::string XAO::Step::getStringValue ( int  element,
int  component
pure virtual
elementthe index of the element.
componentthe index of the component.
the value as a string.
Implemented in XAO::BooleanStep, XAO::DoubleStep, XAO::IntegerStep, and XAO::StringStep.
◆ getType()
virtual XAO::Type XAO::Step::getType ( )
pure virtual
◆ setStamp()
void XAO::Step::setStamp ( int  stamp)
stampthe stamp to set.
◆ setStep()
void XAO::Step::setStep ( int  step)
stepthe index to set.
◆ setStringValue()
virtual void XAO::Step::setStringValue ( int  element,
int  component,
const std::string &  value
pure virtual
valuethe string value.
Exceptions
XAO_Exceptionif the value is not valid.
◆ m_nbComponents
int XAO::Step::m_nbComponents
◆ m_nbElements
int XAO::Step::m_nbElements
◆ m_stamp
int XAO::Step::m_stamp
◆ m_step
int XAO::Step::m_step
