XAO::IntegerStep Class Reference
Step with integer values.
#include <XAO_IntegerStep.hxx>
Inheritance diagram for XAO::IntegerStep:
 IntegerStep (int step, int stamp, int nbElements, int nbComponents)
virtual XAO::Type getType ()
 Gets the type of the step. More...
std::vector< int > getValues ()
 Gets all the values of the step as a list. More...
std::vector< int > getElement (int element)
 Gets all the values for a given element. More...
std::vector< int > getComponent (int component)
 Gets all the values for a given component. More...
int getValue (int element, int component)
 Gets the value for an element and a component. More...
void setValues (const std::vector< int > &values)
 Sets all the values from a list. More...
void setElement (int element, const std::vector< int > &elements)
 Sets the values for an element. More...
void setComponent (int component, const std::vector< int > &components)
 Sets the values for a component. More...
void setValue (int element, int component, int value)
 Sets the value for an element and a component. More...
virtual const std::string getStringValue (int element, int component)
 Gets a value as a string. More...
virtual void setStringValue (int element, int component, const std::string &value)
 Sets a value as a string. More...
- Public Member Functions inherited from XAO::Step
virtual ~Step ()
virtual XAO::Type getType ()=0
int getStep ()
 Gets the step index. More...
void setStep (int step)
 Sets the number of the step. More...
int getStamp ()
 Gets the stamp of the index. More...
void setStamp (int stamp)
 Sets the stamp of the index. More...
int countComponents ()
 Gets the number of components of the step. More...
int countElements ()
 Gets the number of elements for the step. More...
int countValues ()
 Gets the number of values for the step. More...
virtual const std::string getStringValue (int element, int component)=0
virtual void setStringValue (int element, int component, const std::string &value)=0
std::vector< std::vector< int > > m_values
- Protected Member Functions inherited from XAO::Step
 Step ()
 Default constructor. More...
void checkElementIndex (int element)
 Checks that given element index is in the range of element indexes. More...
void checkComponentIndex (int component)
 Checks that given component index is in the range of component indexes. More...
void checkNbElements (int nbElements)
 Checks that the given number of elements is correct. More...
void checkNbComponents (int nbComponents)
 Checks that the given number of components is correct. More...
void checkNbValues (int nbValues)
 checks that the given number of values is correct. More...
- Protected Attributes inherited from XAO::Step
int m_step
 the index of the step. More...
int m_stamp
 The stamp of the step. More...
int m_nbComponents
 The number of components. More...
int m_nbElements
 The number of elements. More...
◆ IntegerStep()
IntegerStep::IntegerStep ( int  step,
int  stamp,
int  nbElements,
int  nbComponents
stepthe step number.
stampthe stamp of the step.
nbElementsthe number elements of the geometry.
nbComponentsthe number of components of the field.
References XAO::Step::m_nbComponents, XAO::Step::m_nbElements, XAO::Step::m_stamp, XAO::Step::m_step, and m_values.
◆ getComponent()
std::vector< int > IntegerStep::getComponent ( int  component)
componentthe index of the component.
a vector containing all the values for the given component.
References XAO::Step::checkComponentIndex(), XAO::Step::m_nbElements, and m_values.
◆ getElement()
std::vector< int > IntegerStep::getElement ( int  element)
elementthe index of the element.
a vector containing all the values for the given element.
References XAO::Step::checkElementIndex(), and m_values.
◆ getStringValue()
const std::string IntegerStep::getStringValue ( int  element,
int  component
the value as a string.
Implements XAO::Step.
References getValue(), and XAO::XaoUtils::intToString().
◆ getType()
virtual XAO::Type XAO::IntegerStep::getType ( )
References XAO::INTEGER.
◆ getValue()
int IntegerStep::getValue ( int  element,
int  component
the value for the given element and component.
References XAO::Step::checkComponentIndex(), XAO::Step::checkElementIndex(), and m_values.
◆ getValues()
std::vector< int > IntegerStep::getValues ( )
a vector containing all the values of the step.
References XAO::Step::m_nbComponents, XAO::Step::m_nbElements, and m_values.
◆ setComponent()
void IntegerStep::setComponent ( int  component,
const std::vector< int > &  components
componentthe index of the component to set.
componentsthe values to set.
References XAO::Step::checkElementIndex(), XAO::Step::checkNbElements(), XAO::Step::m_nbElements, and m_values.
◆ setElement()
void IntegerStep::setElement ( int  element,
const std::vector< int > &  elements
elementthe index of the element to set.
elementsthe values to set.
References XAO::Step::checkElementIndex(), XAO::Step::checkNbComponents(), XAO::Step::m_nbComponents, and m_values.
◆ setStringValue()
void IntegerStep::setStringValue ( int  element,
int  component,
const std::string &  value
valuethe string value.
Exceptions
XAO_Exceptionif the value is not valid.
References setValue(), and XAO::XaoUtils::stringToInt().
◆ setValue()
void IntegerStep::setValue ( int  element,
int  component,
int  value
valuethe value.
◆ setValues()
void IntegerStep::setValues ( const std::vector< int > &  values)
valuesthe list of values to set.
References XAO::Step::checkNbValues(), XAO::Step::m_nbComponents, XAO::Step::m_nbElements, and m_values.
◆ m_values
std::vector< std::vector<int> > XAO::IntegerStep::m_values
