DDS_DicItem.h File Reference
#include "DDS.h"
#include <Standard_Transient.hxx>
#include <TColStd_HArray1OfInteger.hxx>
#include <TColStd_HArray1OfExtendedString.hxx>
#include <NCollection_DataMap.hxx>
#include <NCollection_IndexedDataMap.hxx>
#include <TColStd_MapOfReal.hxx>
#include <TColStd_SequenceOfInteger.hxx>
#include <TColStd_SequenceOfAsciiString.hxx>
#include <TColStd_SequenceOfExtendedString.hxx>
class  DDS_DicItem
 This class provides an information about datum (phisical characteristic parameter). More...
struct  DDS_DicItem::UnitData
 DEFINE_STANDARD_HANDLE (DDS_DicItem, Standard_Transient) typedef NCollection_IndexedDataMap< TCollection_AsciiString
 Handle (DDS_DicItem)> DDS_IndexedDataMapOfDicItems
 Get the dictionary item with specified identifier theID. More...
◆ DEFINE_STANDARD_HANDLE()
DEFINE_STANDARD_HANDLE ( DDS_DicItem  ,
Standard_Transient
◆ Handle()
Handle ( DDS_DicItem  )
If dictionary item is not found, null handle is returned.
theIDitem identifier
dictionary item
Return all keys of the group
seq- string container to be filled with keys
Instantiate new dictionary item, used for customization of data dictionary items.
New dictionary item instance.
Bind dictionary item to ID
Standard_True if the item has been succesfully bound. Standard_False if there is an item with same id.
If the component or item is not found, null handle is returned.
theIDdata dictionary item ID
theComponentcomponent name
handle to the data dictionary item
Get the data dictionary item by specified identifier theID.
Function searches the item in all components. If item is not found in all components, null handle is returned.
Fill the internal data structures from the XML node.
theDocElementdocument XML node
handle to data dictionary item
Set the dictionary item to the datum.
itemhandle to data dictionary item
References Handle().
