DDS_Dictionary.cxx File Reference
#include "DDS_Dictionary.h"
#include "DDS_KeyWords.h"
#include <LDOMString.hxx>
#include <LDOMParser.hxx>
#include <UnitsAPI.hxx>
#include <TColStd_SequenceOfInteger.hxx>
#include <TColStd_SequenceOfAsciiString.hxx>
#include <TColStd_SequenceOfExtendedString.hxx>
#include <NCollection_Map.hxx>
#include <Standard_Failure.hxx>
 Handle (DDS_Dictionary) DDS_Dictionary
 Get the only instance of the data dictionary. More...
 Handle (DDS_DicItem) DDS_Dictionary
 Get the data dictionary item by specified identifier theID from the component theComponent. More...
 Handle (DDS_DicGroup) DDS_Dictionary
 Create instance of a dictionary group. This method can be used for customization data dictionary by specific groups design. More...
◆ Handle() [1/3]
Handle ( DDS_DicGroup  )
New dictionary group instance.
Set instance of dictionary. This method might be used in descendant classes to initialize custom dictionary and replace the default implementation. This method overrides static handle on dictionary that is available through Get() method
◆ Handle() [2/3]
Handle ( DDS_DicItem  )
Get the dictionary item with specified identifier theID.
If the component or item is not found, null handle is returned.
theIDdata dictionary item ID
theComponentcomponent name
handle to the data dictionary item
Get the data dictionary item by specified identifier theID.
Function searches the item in all components. If item is not found in all components, null handle is returned.
Fill the internal data structures from the XML node.
theDocElementdocument XML node
References Handle().
◆ Handle() [3/3]
Handle ( DDS_Dictionary  )
