#include "SALOME_PYQT_PyModule.h"#include "SALOME_PYQT_PyInterp.h"#include "LightApp_Application.h"#include "LightApp_DataObject.h"#include "LightApp_Module.h"#include "LightApp_Study.h"#include "PyInterp_Dispatcher.h"#include "QtxActionMenuMgr.h"#include "QtxWorkspace.h"#include "QtxWorkstack.h"#include "STD_MDIDesktop.h"#include "STD_TabDesktop.h"#include "SUITApp_init_python.hxx"#include "SUIT_ResourceMgr.h"#include "SUIT_ViewManager.h"#include "SUIT_ViewModel.h"#include "SUIT_ViewWindow.h"#include <QApplication>#include <QDomDocument>#include <QDomElement>#include <QDomNode>#include <QFile>#include <QMenu>#include <QMutex>#include <utilities.h>#include "sipAPISalomePyQtGUILight.h"Classes | |
| class | FuncMsg |
| Function call in/out tracer. More... | |
| class | PyModuleHelper::InitLocker |
| Initialization locker. More... | |
| class | PyModuleHelper::XmlHandler |
| XML resource files parser. More... | |
Macros | |
| #define | PyObject_IsEnum(obj, enumtype) ((strcmp(Py_TYPE(obj)->tp_name, enumtype) == 0) && (PyLong_AsLong(obj) != -1)) |
Functions | |
| static QString | tagName (const QDomElement &element) |
| Get tag name for the DOM element. More... | |
| static QString | attribute (const QDomElement &element, const QString &attName) |
| Get value of DOM element's attribute. More... | |
| static bool | checkBool (const QString &value, const int check=-1) |
| Inspect specified string for the boolean value. More... | |
| static int | checkInt (const QString &value, const int def=-1, const int shift=-1) |
| Inspect specified string for the integer value. More... | |
Variables | |
| const int | DEFAULT_GROUP = 40 |
| Default menu group number. More... | |
| QMutex | myInitMutex |
| Mutex used to lock access from several threads to the shared (static) data. More... | |
| const bool | theDEBUG = false |
| const bool | IsCallOldMethods = false |
| Allow calling obsolete callback methods. More... | |
| #define PyObject_IsEnum | ( | obj, | |
| enumtype | |||
| ) | ((strcmp(Py_TYPE(obj)->tp_name, enumtype) == 0) && (PyLong_AsLong(obj) != -1)) |
static |
| element | DOM element |
| attName | attribute name |
static |
This function returns true if string represents boolean value:
true false Second parameter allows to specify what boolean value is expected:true false | value | inspected string |
| check | expected boolean value |
true if value correspond to the specified check Inspect specified string for the integer value.
This function returns returns -1 if item is empty or represents an invalid number.
| def | default value |
| shift | shift value (it is added to the integer value to produce shifted result) |
static |
| const int DEFAULT_GROUP = 40 |
If the macro CALL_OLD_METHODS is not defined, the invoking of obsolete Python module's methods like setSetting(), definePopup(), etc. is blocked.
CALL_OLD_METHODS macro can be defined, for example, by adding -DCALL_OLD_METHODS compilation option to the CMakeLists.txt.
| QMutex myInitMutex |
| const bool theDEBUG = false |
DEBUG mode
