PyModuleHelper::XmlHandler Class Reference
XML resource files parser. More...
 XmlHandler (PyModuleHelper *helper, const QString &fileName)
void createActions ()
 Parse XML file and create actions. More...
void createPopup (QMenu *menu, const QString &context, const QString &parent, const QString &object)
 Create popup menu. More...
void activateMenus (bool)
 Activate/deactivate menus. More...
LightApp_Module * module () const
 Get owner module. More...
QIcon loadIcon (const QString &fileName)
 Load an icon from the module resources by the specified file name. More...
void createMenu (QDomNode &parentNode, const int parentMenuId=-1, QMenu *parentPopup=0)
 Create main menu item and insert actions to it. More...
void createToolBar (QDomNode &parentNode)
 Create a toolbar and insert actions to it. More...
void insertPopupItems (QDomNode &parentNode, QMenu *menu)
 Fill popup menu with the items. More...
PyModuleHelper * myHelper
QDomDocument myDoc
QList< int > myMenuItems
This class is used to provide backward compatibility with existing Python modules in which obsolete menu definition system (via XML files) is used.
◆ XmlHandler()
PyModuleHelper::XmlHandler::XmlHandler ( PyModuleHelper *  helper,
const QString &  fileName
modulepointer to the GUI module
fileNamepath to the XML menu description file
References myDoc.
◆ activateMenus()
void PyModuleHelper::XmlHandler::activateMenus ( bool  enable)
enableif true menus are activated, otherwise menus are deactivated
References CAM_Module::menuMgr(), PyModuleHelper::module(), and QtxActionMenuMgr::setEmptyEnabled().
◆ createActions()
void PyModuleHelper::XmlHandler::createActions ( )
Called by PyModuleHelper::initialize() in order to create actions (menus, toolbars).
◆ createMenu()
void PyModuleHelper::XmlHandler::createMenu ( QDomNode &  parentNode,
const int  parentMenuId = -1,
QMenu *  parentPopup = 0
parentNodeXML node with menu description
parentMenuIdparent menu ID (-1 for top-level menu)
parentPopupparent popup menu (0 for top-level menu)
References attribute(), checkBool(), checkInt(), CAM_Module::createAction(), CAM_Module::createMenu(), PyModuleHelper::defaultMenuGroup(), PyModuleHelper::module(), CAM_Module::separator(), and tagName().
◆ createPopup()
void PyModuleHelper::XmlHandler::createPopup ( QMenu *  menu,
const QString &  context,
const QString &  parent,
const QString &  object
Create popup menu.
menupopup menu
contextpopup menu context
contextpopup menu parent object name
contextpopup menu object name
References attribute().
◆ createToolBar()
void PyModuleHelper::XmlHandler::createToolBar ( QDomNode &  parentNode)
parentNodeXML node with toolbar description
References attribute(), checkBool(), checkInt(), CAM_Module::createAction(), CAM_Module::createTool(), PyModuleHelper::module(), CAM_Module::separator(), and tagName().
◆ insertPopupItems()
void PyModuleHelper::XmlHandler::insertPopupItems ( QDomNode &  parentNode,
QMenu *  menu
parentNodeXML node with popup menu description
menupopup menu
References attribute(), checkBool(), checkInt(), CAM_Module::createAction(), LightApp_Module::getApp(), QtxResourceMgr::loadPixmap(), PyModuleHelper::module(), SUIT_Application::resourceMgr(), CAM_Module::separator(), and tagName().
◆ loadIcon()
QIcon PyModuleHelper::XmlHandler::loadIcon ( const QString &  fileName)
fileNameicon file name
icon object
References LightApp_Module::getApp(), QtxResourceMgr::loadPixmap(), PyModuleHelper::module(), and SUIT_Application::resourceMgr().
◆ module()
LightApp_Module * PyModuleHelper::XmlHandler::module ( ) const
Get owner module.
◆ myDoc
QDomDocument PyModuleHelper::XmlHandler::myDoc
◆ myHelper
PyModuleHelper* PyModuleHelper::XmlHandler::myHelper
◆ myMenuItems
QList<int> PyModuleHelper::XmlHandler::myMenuItems
