SUIT_PagePrefShortcutTreeItem.h
23#ifndef SUIT_PAGEPREFSHORTCUTTREEITEM_H
24#define SUIT_PAGEPREFSHORTCUTTREEITEM_H
26#include "SUIT.h"
27#include <QtxPagePrefMgr.h>
28
29#include <map>
30#include <memory>
31
32
35
36
38{
39public:
41 virtual ~SUIT_PagePrefShortcutTreeItem() = default;
42
43 virtual void retrieve();
44 virtual void retrieveDefault();
45 virtual void store();
46
47private:
48 // { root item (preference window), shortcut container of synchronized SUIT_ShortcutTabWidgets (widgets within the same window) }
49 static std::map<QtxPreferenceItem*, std::weak_ptr<SUIT_ShortcutContainer>> shortcutContainers;
60};
61
62#endif // SUIT_PAGEPREFSHORTCUTTREEITEM_H
#define SUIT_EXPORT
Definition: SUIT.h:36
Base class for implementation of all the widget-based preference items.
Definition: QtxPagePrefMgr.h:99
Retrieve preference item from the resource manager.
Definition: QtxPagePrefMgr.cxx:405
Store preference item to the resource manager.
Definition: QtxPagePrefMgr.cxx:393
Base class for implementing of all the preference items.
Definition: QtxPreferenceMgr.h:41
Restore preference item (for example, from the resource file, ignoring user preferences)....
Definition: QtxPreferenceMgr.cxx:517
Definition: SUIT_PagePrefShortcutTreeItem.h:38
virtual ~SUIT_PagePrefShortcutTreeItem()=default
static std::map< QtxPreferenceItem *, std::weak_ptr< SUIT_ShortcutContainer > > shortcutContainers
Definition: SUIT_PagePrefShortcutTreeItem.h:49
Provides means to keep and edit shortcuts in compliance with the application logics....
Definition: SUIT_ShortcutMgr.h:70
Definition: SUIT_ShortcutEditor.h:236
