QtxPreferenceItem Class Referenceabstract
Base class for implementing of all the preference items. More...
#include <QtxPreferenceMgr.h>
Inheritance diagram for QtxPreferenceItem:
class  Updater
 Preference item updater. More...
 QtxPreferenceItem (QtxPreferenceItem *=0)
 QtxPreferenceItem (const QString &, QtxPreferenceItem *)
 QtxPreferenceItem (const QString &, const QString &, const QString &, QtxPreferenceItem *)
virtual ~QtxPreferenceItem ()
int id () const
 Get unique item identifier. More...
virtual int rtti () const
 Get unique item type identifier. More...
QtxPreferenceItem * rootItem () const
 Get root preference item. More...
QtxPreferenceItem * parentItem () const
 Get parent preference item. More...
QList< QtxPreferenceItem * > childItems (const bool=false) const
 Get all child preference items. More...
int depth () const
 Get preference item depth. More...
int count () const
 Get child preference items number. More...
virtual bool isEmpty () const
 Check if the item has children. More...
void appendItem (QtxPreferenceItem *)
 Append child preference item. More...
void removeItem (QtxPreferenceItem *)
 Remove child preference item. More...
void insertItem (QtxPreferenceItem *, QtxPreferenceItem *=0)
 Insert child preference item before specified item. If the before item is 0, then new item is appended. More...
QIcon icon () const
 Get preference item icon. More...
QString title () const
 Get preference item title. More...
void resource (QString &, QString &) const
 Get resource file settings associated to the preference item. More...
virtual void setIcon (const QIcon &)
 Set prefence item icon. More...
virtual void setTitle (const QString &)
 Set preference item title . More...
virtual void setResource (const QString &, const QString &)
 Assign resource file settings to the preference item. More...
virtual void updateContents ()
 Update preference item. More...
 Get preference item option value. More...
void setOption (const QString &, const QVariant &)
 Set preference item option value. More...
bool isEvaluateValues () const
 Get variables auto-conversion option value. More...
void setEvaluateValues (const bool)
 Switch variables auto-conversion option on/off. More...
bool isRestartRequired () const
 Get restart needed option value. More...
void setRestartRequired (const bool)
 Switch restart needed option on/off. More...
virtual void store ()=0
 Save preference item (for example, to the resource file). More...
virtual void retrieve ()=0
 Restore preference item (for example, from the resource file). More...
virtual void retrieveDefault ()
 Restore preference item (for example, from the resource file, ignoring user preferences). If not overridden, it is equivalent to retrieve(). More...
QString resourceValue () const
 Get the value of the associated resource file setting. More...
void setResourceValue (const QString &)
QtxPreferenceItem * findItem (const int, const bool=false) const
 Find the item by the specified identifier. More...
QtxPreferenceItem * findItem (const QString &, const bool=false) const
 Find the item by the specified title. More...
QtxPreferenceItem * findItem (const QString &, const int, const bool=false) const
 Find the item by the specified title and identifier. More...
virtual QtxResourceMgr * resourceMgr () const
 Get the resources manager. More...
virtual QtxPreferenceMgr * preferenceMgr () const
 Get the parent preferences manager. More...
virtual void activate ()
void ensureVisible ()
static int RTTI ()
 Specify unique item class identifier. More...
Protected Types
typedef QList< QtxPreferenceItem * > ItemList
int getInteger (const int=0) const
 Get integer resources value corresponding to the item. More...
double getDouble (const double=0.0) const
 Get double resources value corresponding to the item. More...
bool getBoolean (const bool=false) const
 Get boolean resources value corresponding to the item. More...
QColor getColor (const QColor &=QColor()) const
 Get color resources value corresponding to the item. More...
QFont getFont (const QFont &=QFont()) const
 Get font resources value corresponding to the item. More...
QString getString (const QString &=QString()) const
 Get string resources value corresponding to the item. More...
void setInteger (const int)
 Set integer resources value corresponding to the item. More...
void setDouble (const double)
 Set double resources value corresponding to the item. More...
void setBoolean (const bool)
 Set boolean resources value corresponding to the item. More...
void setColor (const QColor &)
 Set color resources value corresponding to the item. More...
void setFont (const QFont &)
 Set font resources value corresponding to the item. More...
void setString (const QString &)
 Set string resources value corresponding to the item. More...
virtual void itemAdded (QtxPreferenceItem *)
 Callback function which is called when the child preference item is added. More...
virtual void itemRemoved (QtxPreferenceItem *)
 Callback function which is called when the child preference item is removed. More...
virtual void itemChanged (QtxPreferenceItem *)
 Callback function which is called when the child preference item is modified. More...
virtual void ensureVisible (QtxPreferenceItem *)
void sendItemChanges ()
 Initiate item changing call back operation. More...
virtual void triggerUpdate ()
 Initiate item updating. More...
virtual QVariant optionValue (const QString &) const
virtual void setOptionValue (const QString &, const QVariant &)
static int generateId ()
 Generate unique preference item identifier. More...
int myId
QtxPreferenceItem * myParent
ItemList myChildren
bool myEval
bool myRestartNeeded
QIcon myIcon
QString myTitle
QString mySection
QString myParameter
To implement any specific preference item, subclass from the QtxPreferenceItem and redefine store() and retrieve() methods.
◆ ItemList
◆ QtxPreferenceItem() [1/3]
QtxPreferenceItem::QtxPreferenceItem ( QtxPreferenceItem *  parent = 0)
parentparent preference item
References generateId(), insertItem(), and myId.
◆ QtxPreferenceItem() [2/3]
QtxPreferenceItem::QtxPreferenceItem ( const QString &  title,
titleitem title
◆ QtxPreferenceItem() [3/3]
const QString &  sect,
const QString &  param,
titleitem title
sectresource file section to be associated with the item
paramresource file parameter to be associated with the item
◆ ~QtxPreferenceItem()
QtxPreferenceItem::~QtxPreferenceItem ( )
◆ activate()
void QtxPreferenceItem::activate ( )
Reimplemented in QtxPagePrefItem.
◆ appendItem()
void QtxPreferenceItem::appendItem ( QtxPreferenceItem *  item)
Removes (if necessary) the item from the previous parent.
itemitem to be added
See also
removeItem()
References insertItem().
◆ childItems()
QList< QtxPreferenceItem * > QtxPreferenceItem::childItems ( const bool  rec = false) const
recrecursion boolean flag
list of child items
References myChildren.
◆ count()
int QtxPreferenceItem::count ( ) const
number of child items
See also
isEmpty()
◆ depth()
int QtxPreferenceItem::depth ( ) const
item depth
References depth(), and parentItem().
◆ ensureVisible() [1/2]
void QtxPreferenceItem::ensureVisible ( )
References ensureVisible(), and parentItem().
◆ ensureVisible() [2/2]
void QtxPreferenceItem::ensureVisible ( QtxPreferenceItem *  )
◆ findItem() [1/3]
QtxPreferenceItem * QtxPreferenceItem::findItem ( const int  id,
idchild item ID
recif true recursive search is done
child item or 0 if it is not found
References findItem(), id(), and myChildren.
◆ findItem() [2/3]
QtxPreferenceItem * QtxPreferenceItem::findItem ( const QString &  title,
titlechild item title
References findItem(), myChildren, and title().
◆ findItem() [3/3]
const int  id,
idchild item ID
References findItem(), id(), myChildren, and title().
◆ generateId()
int QtxPreferenceItem::generateId ( )
staticprivate
unique item ID
◆ getBoolean()
bool QtxPreferenceItem::getBoolean ( const bool  val = false) const
valdefault value (returned if there is no such resource)
boolean value of the associated resource
See also
setBoolean()
References QtxResourceMgr::booleanValue(), myParameter, mySection, and resourceMgr().
◆ getColor()
QColor QtxPreferenceItem::getColor ( const QColor &  val = QColor()) const
color value of the associated resource
See also
setColor()
References QtxResourceMgr::colorValue(), myParameter, mySection, and resourceMgr().
◆ getDouble()
double QtxPreferenceItem::getDouble ( const double  val = 0.0) const
double value of the associated resource
See also
setDouble()
References QtxResourceMgr::doubleValue(), myParameter, mySection, and resourceMgr().
◆ getFont()
QFont QtxPreferenceItem::getFont ( const QFont &  val = QFont()) const
font value of the associated resource
See also
setFont()
References QtxResourceMgr::fontValue(), myParameter, mySection, and resourceMgr().
◆ getInteger()
int QtxPreferenceItem::getInteger ( const int  val = 0) const
integer value of the associated resource
See also
setInteger()
References QtxResourceMgr::integerValue(), myParameter, mySection, and resourceMgr().
◆ getString()
QString QtxPreferenceItem::getString ( const QString &  val = QString()) const
string value of the associated resource
See also
setString()
References isEvaluateValues(), myParameter, mySection, resourceMgr(), and QtxResourceMgr::value().
◆ icon()
QIcon QtxPreferenceItem::icon ( ) const
item icon
See also
setIcon()
References myIcon.
◆ id()
int QtxPreferenceItem::id ( ) const
item ID
References myId.
◆ insertItem()
void QtxPreferenceItem::insertItem ( QtxPreferenceItem *  item,
QtxPreferenceItem *  before = 0
beforeitem before which is inserted new \aitem
See also
removeItem()
References itemAdded(), myChildren, myParent, parentItem(), and removeItem().
◆ isEmpty()
bool QtxPreferenceItem::isEmpty ( ) const
true if item does not have children
See also
count()
◆ isEvaluateValues()
bool QtxPreferenceItem::isEvaluateValues ( ) const
option value
References myEval.
◆ isRestartRequired()
bool QtxPreferenceItem::isRestartRequired ( ) const
option value
References myRestartNeeded.
◆ itemAdded()
void QtxPreferenceItem::itemAdded ( QtxPreferenceItem *  )
This function can be reimplemented in the subclasses to customize child item addition operation. Base implementation does nothing.
itemchild item being added
See also
itemRemoved(), itemChanged()
Reimplemented in QtxPagePrefMgr, and QtxPagePrefItem.
◆ itemChanged()
void QtxPreferenceItem::itemChanged ( QtxPreferenceItem *  )
This function can be reimplemented in the subclasses to customize child item modifying operation. Base implementation does nothing.
itemchild item being modified
See also
itemAdded(), itemRemoved()
◆ itemRemoved()
void QtxPreferenceItem::itemRemoved ( QtxPreferenceItem *  )
This function can be reimplemented in the subclasses to customize child item removal operation. Base implementation does nothing.
itemchild item being removed
See also
itemAdded(), itemChanged()
◆ option()
QVariant QtxPreferenceItem::option ( const QString &  name) const
nameoption name
property value or null QVariant if option is not set
See also
setOption()
References optionValue().
◆ optionValue()
QVariant QtxPreferenceItem::optionValue ( const QString &  name) const
This function can be reimplemented in the subclasses. Base implementation does nothing.
nameoption name
See also
setOptionValue()
Reimplemented in QtxPagePrefMgr, QtxPagePrefListItem, QtxPagePrefTabsItem, QtxPagePrefFrameItem, QtxPagePrefGroupItem, QtxPagePrefLabelItem, QtxPagePrefSpaceItem, QtxPagePrefEditItem, QtxPagePrefSliderItem, QtxPagePrefSelectItem, QtxPagePrefSpinItem, QtxPagePrefBiColorItem, QtxPagePrefFontItem, QtxPagePrefPathItem, QtxPagePrefPathListItem, QtxPagePrefDateTimeItem, QtxPagePrefBackgroundItem, SUIT_PreferenceMgr, and QtxUserDefinedItem.
References isEvaluateValues(), isRestartRequired(), and title().
◆ parentItem()
QtxPreferenceItem * QtxPreferenceItem::parentItem ( ) const
parent item
References myParent.
◆ preferenceMgr()
QtxPreferenceMgr * QtxPreferenceItem::preferenceMgr ( ) const
preferences manager or 0 if it is not defined
Reimplemented in QtxPreferenceMgr.
References parentItem(), and preferenceMgr().
◆ removeItem()
void QtxPreferenceItem::removeItem ( QtxPreferenceItem *  item)
itemitem to be removed
See also
insertItem()
References itemRemoved(), myChildren, and myParent.
◆ resource()
void QtxPreferenceItem::resource ( QString &  sec,
QString &  param
secused to return resource file section name
paramused to return resource file parameter name
See also
setResource()
References myParameter, and mySection.
◆ resourceMgr()
QtxResourceMgr * QtxPreferenceItem::resourceMgr ( ) const
resource manager pointer or 0 if it is not defined
References preferenceMgr(), and QtxPreferenceMgr::resourceMgr().
◆ resourceValue()
QString QtxPreferenceItem::resourceValue ( ) const
associated resource file setting value
See also
setResourceValue()
References getString().
◆ retrieve()
◆ retrieveDefault()
void QtxPreferenceItem::retrieveDefault ( )
Reimplemented in QtxPreferenceMgr, and SUIT_PagePrefShortcutTreeItem.
References retrieve().
◆ rootItem()
QtxPreferenceItem * QtxPreferenceItem::rootItem ( ) const
root item
References parentItem().
◆ RTTI()
int QtxPreferenceItem::RTTI ( )
item class ID
◆ rtti()
int QtxPreferenceItem::rtti ( ) const
item type ID
References RTTI().
◆ sendItemChanges()
void QtxPreferenceItem::sendItemChanges ( )
References itemChanged(), and parentItem().
◆ setBoolean()
void QtxPreferenceItem::setBoolean ( const bool  val)
valnew value
See also
getBoolean()
References myParameter, mySection, resourceMgr(), and QtxResourceMgr::setValue().
◆ setColor()
void QtxPreferenceItem::setColor ( const QColor &  val)
valnew value
See also
getColor()
◆ setDouble()
void QtxPreferenceItem::setDouble ( const double  val)
valnew value
See also
getDouble()
◆ setEvaluateValues()
void QtxPreferenceItem::setEvaluateValues ( const bool  on)
onoption value
References myEval.
◆ setFont()
void QtxPreferenceItem::setFont ( const QFont &  val)
valnew value
See also
getFont()
◆ setIcon()
void QtxPreferenceItem::setIcon ( const QIcon &  ico)
iconew item icon
See also
icon()
References myIcon, and sendItemChanges().
◆ setInteger()
void QtxPreferenceItem::setInteger ( const int  val)
valnew value
See also
getInteger()
◆ setOption()
void QtxPreferenceItem::setOption ( const QString &  name,
const QVariant &  val
nameoption name
valnew property value
See also
option()
References optionValue(), sendItemChanges(), and setOptionValue().
◆ setOptionValue()
void QtxPreferenceItem::setOptionValue ( const QString &  name,
◆ setResource()
void QtxPreferenceItem::setResource ( const QString &  sec,
secresource file section name
paramresource file parameter name
See also
resource()
Reimplemented in QtxPagePrefGroupItem.
◆ setResourceValue()
void QtxPreferenceItem::setResourceValue ( const QString &  val)
valnew associated resource file setting value
See also
resourceValue()
References setString().
◆ setRestartRequired()
void QtxPreferenceItem::setRestartRequired ( const bool  on)
onoption value
◆ setString()
void QtxPreferenceItem::setString ( const QString &  val)
valnew value
See also
getString()
◆ setTitle()
void QtxPreferenceItem::setTitle ( const QString &  title)
titlenew item title
See also
title()
Reimplemented in QtxPageNamedPrefItem, QtxPagePrefLabelItem, and QtxPagePrefCheckItem.
References myTitle, sendItemChanges(), and title().
◆ store()
◆ title()
QString QtxPreferenceItem::title ( ) const
item title
See also
setTitle()
References myTitle.
◆ triggerUpdate()
void QtxPreferenceItem::triggerUpdate ( )
◆ updateContents()
void QtxPreferenceItem::updateContents ( )
◆ myChildren
ItemList QtxPreferenceItem::myChildren
◆ myEval
bool QtxPreferenceItem::myEval
◆ myIcon
QIcon QtxPreferenceItem::myIcon
◆ myId
int QtxPreferenceItem::myId
◆ myParameter
QString QtxPreferenceItem::myParameter
◆ myParent
QtxPreferenceItem* QtxPreferenceItem::myParent
◆ myRestartNeeded
bool QtxPreferenceItem::myRestartNeeded
◆ mySection
QString QtxPreferenceItem::mySection
◆ myTitle
QString QtxPreferenceItem::myTitle
