QtxPagePrefSliderItem Class Reference
#include <QtxPagePrefMgr.h>
Inheritance diagram for QtxPagePrefSliderItem:
 QtxPagePrefSliderItem (const QString &, QtxPreferenceItem *=0, const QString &=QString(), const QString &=QString())
virtual ~QtxPagePrefSliderItem ()
int singleStep () const
 Get slider preference item step value. More...
int pageStep () const
int minimum () const
 Get slider preference item minimum value. More...
int maximum () const
 Get slider preference item maximum value. More...
QList< QIcon > icons () const
 Get the list of the icons associated with the selection widget items. More...
void setSingleStep (const int &)
 Set slider preference item step value. More...
void setPageStep (const int &)
void setMinimum (const int &)
 Set slider preference item minimum value. More...
void setMaximum (const int &)
 Set slider preference item maximum value. More...
void setIcons (const QList< QIcon > &)
 Set the list of the icons to the selection widget items. More...
virtual void store ()
 Store preference item to the resource manager. More...
virtual void retrieve ()
 Retrieve preference item from the resource manager. More...
- Public Member Functions inherited from QtxPageNamedPrefItem
 QtxPageNamedPrefItem (const QString &, QtxPreferenceItem *=0, const QString &=QString(), const QString &=QString())
virtual ~QtxPageNamedPrefItem ()
virtual void setTitle (const QString &)
 Set preference title. More...
- Public Member Functions inherited from QtxPagePrefItem
 QtxPagePrefItem (const QString &, QtxPreferenceItem *=0, const QString &=QString(), const QString &=QString())
virtual ~QtxPagePrefItem ()
QWidget * widget () const
 Get preference item editor widget. More...
virtual void activate ()
- Public Member Functions inherited from QtxPreferenceItem
 QtxPreferenceItem (QtxPreferenceItem *=0)
 QtxPreferenceItem (const QString &, QtxPreferenceItem *)
 QtxPreferenceItem (const QString &, const QString &, const QString &, QtxPreferenceItem *)
virtual ~QtxPreferenceItem ()
int id () const
 Get unique item identifier. More...
virtual int rtti () const
 Get unique item type identifier. More...
QtxPreferenceItem * rootItem () const
 Get root preference item. More...
QtxPreferenceItem * parentItem () const
 Get parent preference item. More...
QList< QtxPreferenceItem * > childItems (const bool=false) const
 Get all child preference items. More...
int depth () const
 Get preference item depth. More...
int count () const
 Get child preference items number. More...
virtual bool isEmpty () const
 Check if the item has children. More...
void appendItem (QtxPreferenceItem *)
 Append child preference item. More...
void removeItem (QtxPreferenceItem *)
 Remove child preference item. More...
void insertItem (QtxPreferenceItem *, QtxPreferenceItem *=0)
 Insert child preference item before specified item. If the before item is 0, then new item is appended. More...
QIcon icon () const
 Get preference item icon. More...
QString title () const
 Get preference item title. More...
void resource (QString &, QString &) const
 Get resource file settings associated to the preference item. More...
virtual void setIcon (const QIcon &)
 Set prefence item icon. More...
 Set preference item title . More...
virtual void setResource (const QString &, const QString &)
 Assign resource file settings to the preference item. More...
virtual void updateContents ()
 Update preference item. More...
 Get preference item option value. More...
void setOption (const QString &, const QVariant &)
 Set preference item option value. More...
bool isEvaluateValues () const
 Get variables auto-conversion option value. More...
void setEvaluateValues (const bool)
 Switch variables auto-conversion option on/off. More...
bool isRestartRequired () const
 Get restart needed option value. More...
void setRestartRequired (const bool)
 Switch restart needed option on/off. More...
virtual void store ()=0
 Save preference item (for example, to the resource file). More...
virtual void retrieve ()=0
 Restore preference item (for example, from the resource file). More...
virtual void retrieveDefault ()
 Restore preference item (for example, from the resource file, ignoring user preferences). If not overridden, it is equivalent to retrieve(). More...
QString resourceValue () const
 Get the value of the associated resource file setting. More...
void setResourceValue (const QString &)
QtxPreferenceItem * findItem (const int, const bool=false) const
 Find the item by the specified identifier. More...
QtxPreferenceItem * findItem (const QString &, const bool=false) const
 Find the item by the specified title. More...
QtxPreferenceItem * findItem (const QString &, const int, const bool=false) const
 Find the item by the specified title and identifier. More...
virtual QtxResourceMgr * resourceMgr () const
 Get the resources manager. More...
virtual QtxPreferenceMgr * preferenceMgr () const
 Get the parent preferences manager. More...
void ensureVisible ()
virtual QVariant optionValue (const QString &) const
virtual void setOptionValue (const QString &, const QVariant &)
- Protected Member Functions inherited from QtxPageNamedPrefItem
QLabel * label () const
 Get label widget corresponding to the preference item. More...
QWidget * control () const
 Get control widget corresponding to the preference item. More...
void setControl (QWidget *)
 Set control widget corresponding to the preference item. More...
- Protected Member Functions inherited from QtxPagePrefItem
void setWidget (QWidget *)
 Set preference item editor widget. More...
virtual void itemAdded (QtxPreferenceItem *)
 Callback function which is called when the child preference item is added. More...
virtual void itemRemoved (QtxPreferenceItem *)
 Callback function which is called when the child preference item is removed. More...
virtual void itemChanged (QtxPreferenceItem *)
 Callback function which is called when the child preference item is modified. More...
void pageChildItems (QList< QtxPagePrefItem * > &, const bool=false) const
 Find all child items of the QtxPagePrefItem type. More...
virtual void widgetShown ()
 Invoked when preference item widget is shown. More...
virtual void widgetHided ()
 Invoked when preference item widget is hided. More...
virtual void ensureVisible (QtxPreferenceItem *)
- Protected Member Functions inherited from QtxPreferenceItem
int getInteger (const int=0) const
 Get integer resources value corresponding to the item. More...
double getDouble (const double=0.0) const
 Get double resources value corresponding to the item. More...
bool getBoolean (const bool=false) const
 Get boolean resources value corresponding to the item. More...
QColor getColor (const QColor &=QColor()) const
 Get color resources value corresponding to the item. More...
QFont getFont (const QFont &=QFont()) const
 Get font resources value corresponding to the item. More...
QString getString (const QString &=QString()) const
 Get string resources value corresponding to the item. More...
void setInteger (const int)
 Set integer resources value corresponding to the item. More...
void setDouble (const double)
 Set double resources value corresponding to the item. More...
void setBoolean (const bool)
 Set boolean resources value corresponding to the item. More...
void setColor (const QColor &)
 Set color resources value corresponding to the item. More...
void setFont (const QFont &)
 Set font resources value corresponding to the item. More...
void setString (const QString &)
 Set string resources value corresponding to the item. More...
void sendItemChanges ()
 Initiate item changing call back operation. More...
virtual void triggerUpdate ()
 Initiate item updating. More...
Private Slots
void setIcon (int)
void updateSlider ()
 Update slider widget. More...
void setIcons (const QVariant &)
 Set the list of the icons from the resource manager. More...
QSlider * mySlider
QLabel * myLabel
QList< QIcon > myIcons
- Static Public Member Functions inherited from QtxPageNamedPrefItem
static void adjustLabels (QtxPagePrefItem *)
- Static Public Member Functions inherited from QtxPreferenceItem
static int RTTI ()
 Specify unique item class identifier. More...
- Protected Types inherited from QtxPreferenceItem
typedef QList< QtxPreferenceItem * > ItemList
◆ QtxPagePrefSliderItem()
QtxPagePrefSliderItem::QtxPagePrefSliderItem ( const QString &  title,
QtxPreferenceItem *  parent = 0,
const QString &  sect = QString(),
const QString &  param = QString()
Creates preference item with slider widget
titlepreference item title
parentparent preference item
sectresource file section associated with the preference item
paramresource file parameter associated with the preference item
References Horizontal, myLabel, mySlider, QtxPageNamedPrefItem::setControl(), setIcon(), setMaximum(), setMinimum(), setPageStep(), setSingleStep(), updateSlider(), and QtxPagePrefItem::widget().
◆ ~QtxPagePrefSliderItem()
QtxPagePrefSliderItem::~QtxPagePrefSliderItem ( )
◆ icons()
QList< QIcon > QtxPagePrefSliderItem::icons ( ) const
list of icons
See also
setIcons()
References myIcons.
◆ maximum()
int QtxPagePrefSliderItem::maximum ( ) const
slider maximum value
See also
setMaximum()
References mySlider.
◆ minimum()
int QtxPagePrefSliderItem::minimum ( ) const
slider minimum value
See also
setMinimum()
◆ optionValue()
QVariant QtxPagePrefSliderItem::optionValue ( const QString &  name) const
nameoption name
property value or null integer if option is not set
See also
setOptionValue()
Reimplemented from QtxPreferenceItem.
References icons(), maximum(), minimum(), QtxPreferenceItem::optionValue(), pageStep(), and singleStep().
◆ pageStep()
int QtxPagePrefSliderItem::pageStep ( ) const
slider page step value
See also
setPageStep()
◆ retrieve()
void QtxPagePrefSliderItem::retrieve ( )
See also
store()
Reimplemented from QtxPagePrefItem.
References QtxPreferenceItem::getInteger(), and mySlider.
◆ setIcon
void QtxPagePrefSliderItem::setIcon ( int  pos)
privateslot
References myIcons, myLabel, and mySlider.
◆ setIcons() [1/2]
void QtxPagePrefSliderItem::setIcons ( const QList< QIcon > &  icns)
icnsnew list of icons
See also
icons()
References myIcons, myLabel, and updateSlider().
◆ setIcons() [2/2]
void QtxPagePrefSliderItem::setIcons ( const QVariant &  var)
varnew icons list
References setIcons().
◆ setMaximum()
void QtxPagePrefSliderItem::setMaximum ( const int &  max)
maxnew slider maximum value
See also
maximum()
References mySlider, and setIcon().
◆ setMinimum()
void QtxPagePrefSliderItem::setMinimum ( const int &  min)
minnew slider minimum value
See also
minimum()
◆ setOptionValue()
void QtxPagePrefSliderItem::setOptionValue ( const QString &  name,
const QVariant &  val
nameoption name
valnew property value
See also
optionValue()
References setIcons(), setMaximum(), setMinimum(), QtxPreferenceItem::setOptionValue(), setPageStep(), and setSingleStep().
◆ setPageStep()
void QtxPagePrefSliderItem::setPageStep ( const int &  step)
stepnew slider single step value
See also
step()
◆ setSingleStep()
void QtxPagePrefSliderItem::setSingleStep ( const int &  step)
See also
step()
◆ singleStep()
int QtxPagePrefSliderItem::singleStep ( ) const
See also
setSingleStep()
◆ store()
void QtxPagePrefSliderItem::store ( )
See also
retrieve()
References mySlider, and QtxPreferenceItem::setInteger().
◆ updateSlider()
void QtxPagePrefSliderItem::updateSlider ( )
◆ myIcons
QList<QIcon> QtxPagePrefSliderItem::myIcons
◆ myLabel
QLabel* QtxPagePrefSliderItem::myLabel
◆ mySlider
QSlider* QtxPagePrefSliderItem::mySlider
