QtxPagePrefDateTimeItem Class Reference
GUI implementation of resources date/time item. More...
#include <QtxPagePrefMgr.h>
Inheritance diagram for QtxPagePrefDateTimeItem:
enum  InputType { Date , Time , DateTime }
 QtxPagePrefDateTimeItem (const QString &, QtxPreferenceItem *=0, const QString &=QString(), const QString &=QString())
 QtxPagePrefDateTimeItem (const int, const QString &, QtxPreferenceItem *=0, const QString &=QString(), const QString &=QString())
virtual ~QtxPagePrefDateTimeItem ()
int inputType () const
 Get date/time box preference item input type. More...
void setInputType (const int)
 Set date/time box preference item input type. More...
bool calendar () const
 Check if the popup calendar menu is enabled. More...
void setCalendar (const bool)
 Enable/disable popup calendar menu. More...
QDate maximumDate () const
 Get maximum date value. More...
QTime maximumTime () const
 Get maximum time value. More...
QDate minimumDate () const
 Get minimum date value. More...
QTime minimumTime () const
 Get minimum time value. More...
void setMaximumDate (const QDate &)
 Set maximum date value. More...
void setMaximumTime (const QTime &)
 Set maximum time value. More...
void setMinimumDate (const QDate &)
 Set minimum date value. More...
void setMinimumTime (const QTime &)
 Set minimum time value. More...
virtual void store ()
 Store preference item to the resource manager. More...
virtual void retrieve ()
 Retrieve preference item from the resource manager. More...
- Public Member Functions inherited from QtxPageNamedPrefItem
 QtxPageNamedPrefItem (const QString &, QtxPreferenceItem *=0, const QString &=QString(), const QString &=QString())
virtual ~QtxPageNamedPrefItem ()
virtual void setTitle (const QString &)
 Set preference title. More...
- Public Member Functions inherited from QtxPagePrefItem
 QtxPagePrefItem (const QString &, QtxPreferenceItem *=0, const QString &=QString(), const QString &=QString())
virtual ~QtxPagePrefItem ()
QWidget * widget () const
 Get preference item editor widget. More...
virtual void activate ()
- Public Member Functions inherited from QtxPreferenceItem
 QtxPreferenceItem (QtxPreferenceItem *=0)
 QtxPreferenceItem (const QString &, QtxPreferenceItem *)
 QtxPreferenceItem (const QString &, const QString &, const QString &, QtxPreferenceItem *)
virtual ~QtxPreferenceItem ()
int id () const
 Get unique item identifier. More...
virtual int rtti () const
 Get unique item type identifier. More...
QtxPreferenceItem * rootItem () const
 Get root preference item. More...
QtxPreferenceItem * parentItem () const
 Get parent preference item. More...
QList< QtxPreferenceItem * > childItems (const bool=false) const
 Get all child preference items. More...
int depth () const
 Get preference item depth. More...
int count () const
 Get child preference items number. More...
virtual bool isEmpty () const
 Check if the item has children. More...
void appendItem (QtxPreferenceItem *)
 Append child preference item. More...
void removeItem (QtxPreferenceItem *)
 Remove child preference item. More...
void insertItem (QtxPreferenceItem *, QtxPreferenceItem *=0)
 Insert child preference item before specified item. If the before item is 0, then new item is appended. More...
QIcon icon () const
 Get preference item icon. More...
QString title () const
 Get preference item title. More...
void resource (QString &, QString &) const
 Get resource file settings associated to the preference item. More...
virtual void setIcon (const QIcon &)
 Set prefence item icon. More...
 Set preference item title . More...
virtual void setResource (const QString &, const QString &)
 Assign resource file settings to the preference item. More...
virtual void updateContents ()
 Update preference item. More...
 Get preference item option value. More...
void setOption (const QString &, const QVariant &)
 Set preference item option value. More...
bool isEvaluateValues () const
 Get variables auto-conversion option value. More...
void setEvaluateValues (const bool)
 Switch variables auto-conversion option on/off. More...
bool isRestartRequired () const
 Get restart needed option value. More...
void setRestartRequired (const bool)
 Switch restart needed option on/off. More...
virtual void store ()=0
 Save preference item (for example, to the resource file). More...
virtual void retrieve ()=0
 Restore preference item (for example, from the resource file). More...
virtual void retrieveDefault ()
 Restore preference item (for example, from the resource file, ignoring user preferences). If not overridden, it is equivalent to retrieve(). More...
QString resourceValue () const
 Get the value of the associated resource file setting. More...
void setResourceValue (const QString &)
QtxPreferenceItem * findItem (const int, const bool=false) const
 Find the item by the specified identifier. More...
QtxPreferenceItem * findItem (const QString &, const bool=false) const
 Find the item by the specified title. More...
QtxPreferenceItem * findItem (const QString &, const int, const bool=false) const
 Find the item by the specified title and identifier. More...
virtual QtxResourceMgr * resourceMgr () const
 Get the resources manager. More...
virtual QtxPreferenceMgr * preferenceMgr () const
 Get the parent preferences manager. More...
void ensureVisible ()
virtual QVariant optionValue (const QString &) const
virtual void setOptionValue (const QString &, const QVariant &)
- Protected Member Functions inherited from QtxPageNamedPrefItem
QLabel * label () const
 Get label widget corresponding to the preference item. More...
QWidget * control () const
 Get control widget corresponding to the preference item. More...
void setControl (QWidget *)
 Set control widget corresponding to the preference item. More...
- Protected Member Functions inherited from QtxPagePrefItem
void setWidget (QWidget *)
 Set preference item editor widget. More...
virtual void itemAdded (QtxPreferenceItem *)
 Callback function which is called when the child preference item is added. More...
virtual void itemRemoved (QtxPreferenceItem *)
 Callback function which is called when the child preference item is removed. More...
virtual void itemChanged (QtxPreferenceItem *)
 Callback function which is called when the child preference item is modified. More...
void pageChildItems (QList< QtxPagePrefItem * > &, const bool=false) const
 Find all child items of the QtxPagePrefItem type. More...
virtual void widgetShown ()
 Invoked when preference item widget is shown. More...
virtual void widgetHided ()
 Invoked when preference item widget is hided. More...
virtual void ensureVisible (QtxPreferenceItem *)
- Protected Member Functions inherited from QtxPreferenceItem
int getInteger (const int=0) const
 Get integer resources value corresponding to the item. More...
double getDouble (const double=0.0) const
 Get double resources value corresponding to the item. More...
bool getBoolean (const bool=false) const
 Get boolean resources value corresponding to the item. More...
QColor getColor (const QColor &=QColor()) const
 Get color resources value corresponding to the item. More...
QFont getFont (const QFont &=QFont()) const
 Get font resources value corresponding to the item. More...
QString getString (const QString &=QString()) const
 Get string resources value corresponding to the item. More...
void setInteger (const int)
 Set integer resources value corresponding to the item. More...
void setDouble (const double)
 Set double resources value corresponding to the item. More...
void setBoolean (const bool)
 Set boolean resources value corresponding to the item. More...
void setColor (const QColor &)
 Set color resources value corresponding to the item. More...
void setFont (const QFont &)
 Set font resources value corresponding to the item. More...
void setString (const QString &)
 Set string resources value corresponding to the item. More...
void sendItemChanges ()
 Initiate item changing call back operation. More...
virtual void triggerUpdate ()
 Initiate item updating. More...
void updateDateTime ()
 Update date/time widget. More...
int myType
QDateTimeEdit * myDateTime
- Static Public Member Functions inherited from QtxPageNamedPrefItem
static void adjustLabels (QtxPagePrefItem *)
- Static Public Member Functions inherited from QtxPreferenceItem
static int RTTI ()
 Specify unique item class identifier. More...
- Protected Types inherited from QtxPreferenceItem
typedef QList< QtxPreferenceItem * > ItemList
◆ InputType
Date
Time
DateTime
◆ QtxPagePrefDateTimeItem() [1/2]
QtxPagePrefDateTimeItem::QtxPagePrefDateTimeItem ( const QString &  title,
QtxPreferenceItem *  parent = 0,
const QString &  sect = QString(),
const QString &  param = QString()
Creates an item to enter date and time.
titlepreference item title
parentparent preference item
sectresource file section associated with the preference item
paramresource file parameter associated with the preference item
References myDateTime, QtxPageNamedPrefItem::setControl(), and updateDateTime().
◆ QtxPagePrefDateTimeItem() [2/2]
QtxPagePrefDateTimeItem::QtxPagePrefDateTimeItem ( const int  type,
Creates preference item for editing of the date and/or time value: the type is specified by parameter type.
typepreference item input type (QtxPagePrefDateTimeItem::InputType)
◆ ~QtxPagePrefDateTimeItem()
QtxPagePrefDateTimeItem::~QtxPagePrefDateTimeItem ( )
◆ calendar()
bool QtxPagePrefDateTimeItem::calendar ( ) const
true if calendar popup menu is enabled
References myDateTime.
◆ inputType()
int QtxPagePrefDateTimeItem::inputType ( ) const
See also
setInputType()
References myType.
◆ maximumDate()
QDate QtxPagePrefDateTimeItem::maximumDate ( ) const
maximum date value
See also
setMaximumDate(), minimumDate(), maximumTime(), minimumTime()
◆ maximumTime()
QTime QtxPagePrefDateTimeItem::maximumTime ( ) const
maximum time value
See also
setMaximumTime(), minimumTime(), maximumDate(), minimumDate()
◆ minimumDate()
QDate QtxPagePrefDateTimeItem::minimumDate ( ) const
minimum date value
See also
setMinimumDate(), maximumDate(), maximumTime(), minimumTime()
◆ minimumTime()
QTime QtxPagePrefDateTimeItem::minimumTime ( ) const
maximum time value
See also
setMinimumTime(), maximumTime(), maximumDate(), minimumDate()
◆ optionValue()
QVariant QtxPagePrefDateTimeItem::optionValue ( const QString &  name) const
nameoption name
property value or null QVariant if option is not set
See also
setOptionValue()
Reimplemented from QtxPreferenceItem.
References inputType(), maximumDate(), maximumTime(), minimumDate(), minimumTime(), and QtxPreferenceItem::optionValue().
◆ retrieve()
void QtxPagePrefDateTimeItem::retrieve ( )
See also
store()
Reimplemented from QtxPagePrefItem.
References Date, DateTime, QtxPreferenceItem::getString(), inputType(), myDateTime, and Time.
◆ setCalendar()
void QtxPagePrefDateTimeItem::setCalendar ( const bool  on)
onnew flag state
◆ setInputType()
void QtxPagePrefDateTimeItem::setInputType ( const int  type)
typenew preference item input type (QtxPagePrefDateTimeItem::InputType)
See also
inputType()
References myType, and updateDateTime().
◆ setMaximumDate()
void QtxPagePrefDateTimeItem::setMaximumDate ( const QDate &  d)
dnew maximum date value
See also
maximumDate(), minimumDate(), maximumTime(), minimumTime()
◆ setMaximumTime()
void QtxPagePrefDateTimeItem::setMaximumTime ( const QTime &  t)
tnew maximum time value
See also
maximumTime(), minimumTime(), maximumDate(), minimumDate()
◆ setMinimumDate()
void QtxPagePrefDateTimeItem::setMinimumDate ( const QDate &  d)
dnew minimum date value
See also
minimumDate(), maximumDate(), maximumTime(), minimumTime()
◆ setMinimumTime()
void QtxPagePrefDateTimeItem::setMinimumTime ( const QTime &  t)
tnew minimum time value
See also
minimumTime(), maximumTime(), maximumDate(), minimumDate()
◆ setOptionValue()
void QtxPagePrefDateTimeItem::setOptionValue ( const QString &  name,
const QVariant &  val
nameoption name
valnew property value
See also
optionValue()
References setInputType(), setMaximumDate(), setMaximumTime(), setMinimumDate(), setMinimumTime(), and QtxPreferenceItem::setOptionValue().
◆ store()
void QtxPagePrefDateTimeItem::store ( )
See also
retrieve()
References Date, DateTime, inputType(), myDateTime, QtxPreferenceItem::setString(), and Time.
◆ updateDateTime()
void QtxPagePrefDateTimeItem::updateDateTime ( )
References Date, DateTime, inputType(), myDateTime, and Time.
◆ myDateTime
QDateTimeEdit* QtxPagePrefDateTimeItem::myDateTime
◆ myType
int QtxPagePrefDateTimeItem::myType
