SalomeApp_DataModel.cxx File Reference
#include "SalomeApp_DataModel.h"
#include "SalomeApp_Study.h"
#include "SalomeApp_DataObject.h"
#include "SalomeApp_Module.h"
#include "SalomeApp_Application.h"
#include <CAM_DataObject.h>
#include <SUIT_TreeSync.h>
#include <SUIT_DataObjectIterator.h>
#include <CORBA_SERVER_HEADER(SALOME_Exception)>
class  SalomeApp_DataModelSync
Typedefs
typedef SUIT_DataObject * suitPtr
typedef _PTR (SObject) kerPtr
 Get SALOMEDS object. More...
void showTree (SUIT_DataObject *root)
Typedef Documentation
◆ suitPtr
◆ _PTR()
typedef _PTR ( SObject  )
SALOMEDS object
Returns the string identifier of the data objects referenced by this one.
Re-implemented from LightApp_DataObject using SALOMEDS API.
ID string of the referenced SObject
Check if the data object is a reference.
true if this data object actually refers to another one
Get the object referenced by this one.
referenced object
Check if object has children
true if object has at least one child sub-object and false otherwise
Check if the object is expandable (e.g. in the data tree view)
true if object is expandable and false otherwise
Check if the object is visible.
true if this object is displayable or false otherwise
Check if the specified column supports custom sorting.
idcolumn id
true if column sorting should be customized
See also
compare()
Compares data from two items for sorting purposes.
This method is called only for those columns for which customSorting() method returns true.
leftfirst data to compare
rightsecond data to compare
idcolumn id
result of the comparison
See also
customSorting()
Get data object IOR.
objdata object
data object IOR or null string if IOR is empty
Get data object entry identifier.
objdata object
data object entry identifier or empty object does not have entry
Get data object value.
objdata object
data object value or empty string if there is no value associated to the object
◆ showTree()
