LightApp_AboutDlg Class Reference
#include <LightApp_AboutDlg.h>
Inheritance diagram for LightApp_AboutDlg:
 LightApp_AboutDlg (const QString &, const QString &, QWidget *=0)
virtual ~LightApp_AboutDlg ()
- Public Member Functions inherited from QtxDialog
 QtxDialog (QWidget *=0, bool=false, bool=false, const int=Standard, Qt::WindowFlags=0)
virtual ~QtxDialog ()
void setDialogFlags (const int)
 Set specified dialog box flags. More...
void clearDialogFlags (const int)
 Clear specified the dialog flags. More...
bool testDialogFlags (const int) const
 Test specified dialog flags. More...
void setButtonFlags (const int)
 Add specified control button(s) to the dialog box. More...
void clearButtonFlags (const int)
 Remove specified control button(s) from the dialog box. More...
bool testButtonFlags (const int) const
 Test specified buttons. More...
int buttonPosition (const int) const
 Get specified control button position. More...
void setButtonPosition (const int, const int=-1)
 Set the specified control button(s) position. More...
void setPlacePosition (const int, const int)
 Set button position for all buttons in specified area. More...
int placePolicy (const int) const
 Get buttons layouting policy for the specified area. More...
void setPlacePolicy (const int, const int)
 set buttons layouting policy for the specified area. More...
void setButtonPlace (const int, const int)
 Move specified button(s) into specified area. More...
QString buttonText (const int)
 Get specified button's text. More...
void setButtonText (const int, const QString &text)
 Set specified button's text. More...
void setButtonFocus (const int)
 Sets the keyboard focus to the specified button. More...
bool hasButtonFocus (const int) const
 Check if specified button has keyboard focus. More...
bool isButtonEnabled (const int) const
 Get "enabled" status of the specified button(s). More...
void setButtonEnabled (const bool, const int)
 Enable/disable specified button(s). More...
bool isBorderEnabled (const int) const
 Check if border is enabled. More...
void setBorderEnabled (const bool, const int)
 Show/hide border for the specified button area. More...
void removeButton (const int)
 Remove user button. More...
int insertButton (const QString &, const int=BottomArea)
 Add user button to the dialog box. More...
QIntList userButtonIds () const
 Get all user button IDs. More...
QAbstractButton * userButton (const int) const
 Get user button by the specified id. More...
uint setAlignment (uint align)
 Sets alignment policy. More...
void checkLabel (QLabel *) const
void changeFont (QWidget *, const bool=false, const bool=false, const bool=false, const int=0) const
QWidget * getModulesInfoWidget (QWidget *parent) const
- Public Types inherited from QtxDialog
enum  PlacePolicy { Position , Expand , Uniform }
 Buttons alignment type. More...
enum  ButtonArea { TopArea , BottomArea , LeftArea , RightArea }
 Buttons area. More...
enum  ButtonPosition {
  Left , Right , Center , Top = Left ,
  Bottom = Right
 Button position. More...
enum  ButtonFlags {
  None = 0x00000000 , OK = 0x00000001 , Apply = 0x00000002 , Cancel = 0x00000004 ,
  Yes = 0x00000008 , No = 0x00000010 , Close = 0x00000020 , Help = 0x00000040 ,
  OKCancel = OK | Cancel , YesNo = Yes | No , Standard = OK | Cancel | Help , All = Standard | YesNo | Apply | Close
 Button ID flags. More...
enum  DialogFlags { Accept = 0x000001 , Reject = 0x000002 , AlignOnce = 0x000004 , SetFocus = 0x000008 }
 Dialog box flags. More...
- Public Slots inherited from QtxDialog
void update ()
 Update dialog box. More...
virtual void setVisible (bool)
 Show/hide dialog box, set keyboard focus to the dialog. More...
- Signals inherited from QtxDialog
void dlgButton (int)
 Emitted when the user button is clicked. More...
void dlgParamChanged ()
 This signal can be used in successor classes to signalize about some dialog parameter changing. More...
void dlgHelp ()
 Emitted when the "Help" button is clicked. More...
void dlgApply ()
 Emitted when the "Apply" button is clicked. More...
void dlgOk ()
 Emitted when the "OK" button is clicked. More...
void dlgNo ()
 Emitted when the "No" button is clicked. More...
void dlgYes ()
 Emitted when the "Yes" button is clicked. More...
void dlgClose ()
 Emitted when the "Close" button is clicked. More...
void dlgCancel ()
 Emitted when the "Cancel" button is clicked. More...
- Static Public Member Functions inherited from QtxDialog
static void setUnits (QLabel *, const QString &)
 Set measure units to the specified label. More...
- Protected Types inherited from QtxDialog
typedef QMap< int, QAbstractButton * > ButtonMap
 button map More...
- Protected Slots inherited from QtxDialog
virtual void accept ()
 Accept the dialog box. More...
virtual void reject ()
 Reject the dialog box. More...
- Protected Member Functions inherited from QtxDialog
QFrame * mainFrame () const
 Get dialog box main frame widget. More...
virtual bool acceptData () const
 Check if data entered by the user is valid. More...
virtual bool rejectData () const
 Check if dialog box can be cancelled. More...
virtual QAbstractButton * createButton (QWidget *)
 Create new user button. More...
QAbstractButton * button (const int) const
 Get button by the specified ID. More...
ButtonMap buttons (const int=All) const
 Get buttons by the specified IDs. More...
int buttonId (const QAbstractButton *) const
 Get specified button's identifier. More...
int buttonPosition (QAbstractButton *) const
 Get position of specified button. More...
virtual void showEvent (QShowEvent *)
 Align this dialog according to the parent widget and alignment policy before the dialog box is shown. More...
virtual void hideEvent (QHideEvent *)
 Process all existing events when dialog box is hidden. More...
virtual void closeEvent (QCloseEvent *)
 Called when user closes dialog box. More...
virtual void childEvent (QChildEvent *)
 Update dialog box layout when the size grip is added. More...
virtual void keyPressEvent (QKeyEvent *)
 Process key pressing event. More...
LightApp help about dialog
◆ LightApp_AboutDlg()
LightApp_AboutDlg::LightApp_AboutDlg ( const QString &  defName,
const QString &  defVer,
QWidget *  parent = 0
◆ ~LightApp_AboutDlg()
LightApp_AboutDlg::~LightApp_AboutDlg ( )
Do nothing.
◆ changeFont()
void LightApp_AboutDlg::changeFont ( QWidget *  wid,
const bool  bold = false,
const bool  italic = false,
const bool  underline = false,
const int  inc = 0
Change font of widget wid.
wid- QWidget
bold- boolean value
italic- boolean value
underline- boolean value
inc- integer increment for font point size.
◆ checkLabel()
void LightApp_AboutDlg::checkLabel ( QLabel *  lab) const
Check lable lab.
◆ getModulesInfoWidget()
QWidget * LightApp_AboutDlg::getModulesInfoWidget ( QWidget *  parent) const
Return widget with info about versions of modules
References SUIT_Session::activeApplication(), CAM_Application::getVersionInfo(), and SUIT_Session::session().
