SUIT_Session Class Reference
#include <SUIT_Session.h>
Inheritance diagram for SUIT_Session:
enum  { ASK = 0 , SAVE , DONT_SAVE }
enum  { NORMAL = 0 , FORCED }
typedef void * AppLib
Signals
void applicationClosed (SUIT_Application *)
 SUIT_Session ()
virtual ~SUIT_Session ()
SUIT_Application * startApplication (const QString &, int=0, char **=0)
QList< SUIT_Application * > applications () const
SUIT_Application * activeApplication () const
SUIT_ResourceMgr * resourceMgr () const
void closeSession (int mode=ASK, int flags=0)
int exitFlags () const
SUIT_ExceptionHandler * handler () const
void insertApplication (SUIT_Application *)
static SUIT_Session * session ()
Public Attributes
enum SUIT_Session:: { ... }  CloseMode
enum SUIT_Session:: { ... }  ExitStatus
virtual SUIT_ResourceMgr * createResourceMgr (const QString &) const
Private Types
typedef QList< SUIT_Application * > AppList
typedef QMap< QString, AppLib > AppLibMap
Private Slots
void onApplicationClosed (SUIT_Application *)
void onApplicationActivated (SUIT_Application *)
QString lastError () const
AppLib loadLibrary (const QString &, QString &)
QString applicationName (const QString &) const
SUIT_ResourceMgr * myResMgr
AppList myAppList
AppLibMap myAppLibs
SUIT_Application * myActiveApp
SUIT_ExceptionHandler * myHandler
int myExitStatus
int myExitFlags
Static Private Attributes
static SUIT_Session * mySession = 0
The class Sesssion manages launching of Applications. Application must be returned
by static function "createApplication" in external library. The Library must be loaded with
loadLibrary method and after that application can be started.
◆ AppLib
typedef void* SUIT_Session::AppLib
◆ AppLibMap
typedef QMap<QString, AppLib> SUIT_Session::AppLibMap
◆ AppList
◆ anonymous enum
anonymous enum
ASK
SAVE
DONT_SAVE
◆ anonymous enum
anonymous enum
NORMAL
FORCED
◆ SUIT_Session()
SUIT_Session::SUIT_Session ( )
References mySession, and SUIT_ASSERT.
◆ ~SUIT_Session()
SUIT_Session::~SUIT_Session ( )
destructor. Clear applications list and set mySession to zero.
References myAppList, myResMgr, and mySession.
◆ activeApplication()
SUIT_Application * SUIT_Session::activeApplication ( ) const
Returns the active application
References myActiveApp.
◆ applicationClosed
void SUIT_Session::applicationClosed ( SUIT_Application *  )
signal
◆ applicationName()
QString SUIT_Session::applicationName ( const QString &  str) const
Returnfile name by application name.
References Qtx::file().
◆ applications()
QList< SUIT_Application * > SUIT_Session::applications ( ) const
Gets the list of all applications
References myAppList.
◆ closeSession()
◆ createResourceMgr()
SUIT_ResourceMgr * SUIT_Session::createResourceMgr ( const QString &  appName) const
Virtual method, creates an instance of ResourceManager
References applicationName().
◆ exitFlags()
int SUIT_Session::exitFlags ( ) const
Get session exit flags.
By default, exit flags are set to 0. You can use pass any flags to the closeSession() method if you need to process them later on application quiting.
exit flags
References myExitFlags.
◆ handler()
SUIT_ExceptionHandler * SUIT_Session::handler ( ) const
returnmyHandler
References myHandler.
◆ insertApplication()
void SUIT_Session::insertApplication ( SUIT_Application *  app)
◆ lastError()
QString SUIT_Session::lastError ( ) const
returnlast error string.
References Qtx::toQString().
◆ loadLibrary()
SUIT_Session::AppLib SUIT_Session::loadLibrary ( const QString &  name,
QString &  libName
Load library to session.
Loadedlibrary.
References Qtx::library().
◆ onApplicationActivated
void SUIT_Session::onApplicationActivated ( SUIT_Application *  app)
privateslot
Slot, called on activation of some application's desktop
◆ onApplicationClosed
void SUIT_Session::onApplicationClosed ( SUIT_Application *  theApp)
privateslot
Removes the application from the list of launched applications. If it is a last application the session will be closed.
References applicationClosed(), myActiveApp, myAppList, and myExitStatus.
◆ resourceMgr()
SUIT_ResourceMgr * SUIT_Session::resourceMgr ( ) const
Returns the resource manager for the specified application name.
References myResMgr.
◆ session()
SUIT_Session * SUIT_Session::session ( )
returnmySession
References mySession.
◆ startApplication()
SUIT_Application * SUIT_Session::startApplication ( const QString &  name,
int  = 0,
char **  = 0
enum { ... } SUIT_Session::CloseMode
enum { ... } SUIT_Session::ExitStatus
◆ myActiveApp
SUIT_Application* SUIT_Session::myActiveApp
◆ myAppLibs
AppLibMap SUIT_Session::myAppLibs
◆ myAppList
AppList SUIT_Session::myAppList
◆ myExitFlags
int SUIT_Session::myExitFlags
◆ myExitStatus
int SUIT_Session::myExitStatus
◆ myHandler
SUIT_ExceptionHandler* SUIT_Session::myHandler
◆ myResMgr
SUIT_ResourceMgr* SUIT_Session::myResMgr
◆ mySession
SUIT_Session * SUIT_Session::mySession = 0
staticprivate
