LightApp_Dialog Class Reference
#include <LightApp_Dialog.h>
Inheritance diagram for LightApp_Dialog:
struct  Object
enum  ObjectWg { Label = 0x00000001 , Btn = 0x00000002 , Control = 0x00000004 }
enum  NameIndication { OneName , OneNameOrCount , ListOfNames , Count }
typedef QList< int > TypesList
typedef QMap< int, QStringList > SelectedObjects
- Public Types inherited from QtxDialog
enum  PlacePolicy { Position , Expand , Uniform }
 Buttons alignment type. More...
enum  ButtonArea { TopArea , BottomArea , LeftArea , RightArea }
 Buttons area. More...
enum  ButtonPosition {
  Left , Right , Center , Top = Left ,
  Bottom = Right
 Button position. More...
enum  ButtonFlags {
  None = 0x00000000 , OK = 0x00000001 , Apply = 0x00000002 , Cancel = 0x00000004 ,
  Yes = 0x00000008 , No = 0x00000010 , Close = 0x00000020 , Help = 0x00000040 ,
  OKCancel = OK | Cancel , YesNo = Yes | No , Standard = OK | Cancel | Help , All = Standard | YesNo | Apply | Close
 Button ID flags. More...
enum  DialogFlags { Accept = 0x000001 , Reject = 0x000002 , AlignOnce = 0x000004 , SetFocus = 0x000008 }
 Dialog box flags. More...
Signals
void selectionChanged (int)
 selection in certain widget is changed More...
void objectActivated (int)
 selection in certain widget is on More...
void objectDeactivated (int)
 selection in certain widget is off
More...
void objectChanged (int, const QStringList &)
- Signals inherited from QtxDialog
void dlgButton (int)
 Emitted when the user button is clicked. More...
void dlgParamChanged ()
 This signal can be used in successor classes to signalize about some dialog parameter changing. More...
void dlgHelp ()
 Emitted when the "Help" button is clicked. More...
void dlgApply ()
 Emitted when the "Apply" button is clicked. More...
void dlgOk ()
 Emitted when the "OK" button is clicked. More...
void dlgNo ()
 Emitted when the "No" button is clicked. More...
void dlgYes ()
 Emitted when the "Yes" button is clicked. More...
void dlgClose ()
 Emitted when the "Close" button is clicked. More...
void dlgCancel ()
 Emitted when the "Cancel" button is clicked. More...
 LightApp_Dialog (QWidget *=0, const char *=0, bool=false, bool=false, const int=Standard, Qt::WindowFlags=0)
 The enumeration describing how names of selected objects will be shown in line edit For more details see above. More...
virtual ~LightApp_Dialog ()
virtual void show ()
bool isExclusive () const
 Check if buttons is exclusive (as radiobuttons) More...
void setExclusive (const bool)
 Set exclusive state
More...
bool isAutoResumed () const
 Check if operation according to dialog will be resumed automatically when mouse enter the dialog. More...
void setAutoResumed (const bool)
 Set auto resumed state. More...
void showObject (const int)
 Show widgets corresponding to id. More...
void hideObject (const int)
 Hide widgets corresponding to id. More...
void setObjectShown (const int, const bool)
 Change the shown state of widgets corresponding to id
More...
bool isObjectShown (const int) const
 Check the shown state. More...
void setObjectEnabled (const int, const bool)
 Change the enabled state of widgets corresponding to id. More...
bool isObjectEnabled (const int) const
 Check the enabled state. More...
QWidget * objectWg (const int theId, const int theWgId) const
 Get widget of object (see ObjectWg enumeration) More...
void selectObject (const QString &, const int, const QString &, const bool=true)
 Pass to all active widgets name, type and id of selected object
More...
void selectObject (const QStringList &, const TypesList &, const QStringList &, const bool=true)
QString objectText (const int) const
 Get text of object's control. More...
void setObjectText (const int, const QString &)
 Set text of object's control. More...
void selectObject (const int, const QString &, const int, const QString &, const bool=true)
 Select in certain widget avoiding check if there is active widget. More...
void selectObject (const int, const QStringList &, const TypesList &, const QStringList &, const bool=true)
bool hasSelection (const int) const
 Check if certain widget has selection
More...
void clearSelection (const int=-1)
 Clear selection in widgets. If parameter is -1, then selection in all widgets will be cleared. More...
void selectedObject (const int, QStringList &) const
 Get ids list of object selected in certain widget. More...
QString selectedObject (const int) const
void objectSelection (SelectedObjects &) const
 Get map "widget id -> ids list". More...
void activateObject (const int)
 Activate object selection button. More...
void deactivateAll ()
 Set all object selection buttons to inactive state. More...
- Public Member Functions inherited from QtxDialog
 QtxDialog (QWidget *=0, bool=false, bool=false, const int=Standard, Qt::WindowFlags=0)
virtual ~QtxDialog ()
void setDialogFlags (const int)
 Set specified dialog box flags. More...
void clearDialogFlags (const int)
 Clear specified the dialog flags. More...
bool testDialogFlags (const int) const
 Test specified dialog flags. More...
void setButtonFlags (const int)
 Add specified control button(s) to the dialog box. More...
void clearButtonFlags (const int)
 Remove specified control button(s) from the dialog box. More...
bool testButtonFlags (const int) const
 Test specified buttons. More...
int buttonPosition (const int) const
 Get specified control button position. More...
void setButtonPosition (const int, const int=-1)
 Set the specified control button(s) position. More...
void setPlacePosition (const int, const int)
 Set button position for all buttons in specified area. More...
int placePolicy (const int) const
 Get buttons layouting policy for the specified area. More...
void setPlacePolicy (const int, const int)
 set buttons layouting policy for the specified area. More...
void setButtonPlace (const int, const int)
 Move specified button(s) into specified area. More...
QString buttonText (const int)
 Get specified button's text. More...
void setButtonText (const int, const QString &text)
 Set specified button's text. More...
void setButtonFocus (const int)
 Sets the keyboard focus to the specified button. More...
bool hasButtonFocus (const int) const
 Check if specified button has keyboard focus. More...
bool isButtonEnabled (const int) const
 Get "enabled" status of the specified button(s). More...
void setButtonEnabled (const bool, const int)
 Enable/disable specified button(s). More...
bool isBorderEnabled (const int) const
 Check if border is enabled. More...
void setBorderEnabled (const bool, const int)
 Show/hide border for the specified button area. More...
void removeButton (const int)
 Remove user button. More...
int insertButton (const QString &, const int=BottomArea)
 Add user button to the dialog box. More...
QIntList userButtonIds () const
 Get all user button IDs. More...
QAbstractButton * userButton (const int) const
 Get user button by the specified id. More...
uint setAlignment (uint align)
 Sets alignment policy. More...
SUIT_ResourceMgr * resMgr () const
 Finds and returns resource manager. More...
int createObject (const QString &, QWidget *, const int=-1)
void setObjectPixmap (const QPixmap &)
 Set pixmap as icon for all selection buttons. More...
void setObjectPixmap (const QString &, const QString &)
 Load pixmap with section, name using resource manager and set as icon for all selection buttons. More...
void renameObject (const int, const QString &)
 Change label. More...
void setObjectType (const int, const int,...)
 Set possible types for certain id. The list of arguments must be finished by negative integer. More...
void setObjectType (const int, const TypesList &)
 Set list as possible types for object selection. More...
void addObjectType (const int, const int, const int,...)
void addObjectType (const int, const TypesList &)
 Add types to list of possible types. More...
void addObjectType (const int, const int)
 Add type to list of possible types. More...
void removeObjectType (const int)
 Clear list of possible types (it means, that all types are welcome)
More...
void removeObjectType (const int, const TypesList &)
 Remove types in list from list of possible types. More...
void removeObjectType (const int, const int)
 Remove a type from list of possible types. More...
bool hasObjectType (const int, const int) const
 Check if list of possible types contains this one. More...
void objectTypes (const int, TypesList &) const
 Return list of possible types. More...
QString & typeName (const int)
 Change and get type name for indicating in selection widget. More...
const QString typeName (const int) const
virtual QString selectionDescription (const QStringList &, const TypesList &, const NameIndication) const
 Create string contains selection list by list of names, list of types and current name indication state. More...
virtual QString countOfTypes (const TypesList &) const
 Create string by pattern "<count> <type>" for current list of types. More...
NameIndication nameIndication (const int) const
 Get and set name indication for certain widget. More...
void setNameIndication (const int, const NameIndication)
bool multipleSelection (const int) const
 Check using name indication if multiple selection in possible. More...
void setReadOnly (const int, const bool)
 Set the "read only" state of object selection line edit The "read only" will be false only if name indication is ListOfNames. More...
bool isReadOnly (const int) const
 Check the "read only" state of object selection line edit. More...
- Protected Member Functions inherited from QtxDialog
QFrame * mainFrame () const
 Get dialog box main frame widget. More...
virtual bool acceptData () const
 Check if data entered by the user is valid. More...
virtual bool rejectData () const
 Check if dialog box can be cancelled. More...
virtual QAbstractButton * createButton (QWidget *)
 Create new user button. More...
QAbstractButton * button (const int) const
 Get button by the specified ID. More...
ButtonMap buttons (const int=All) const
 Get buttons by the specified IDs. More...
int buttonId (const QAbstractButton *) const
 Get specified button's identifier. More...
int buttonPosition (QAbstractButton *) const
 Get position of specified button. More...
virtual void showEvent (QShowEvent *)
 Align this dialog according to the parent widget and alignment policy before the dialog box is shown. More...
virtual void hideEvent (QHideEvent *)
 Process all existing events when dialog box is hidden. More...
virtual void closeEvent (QCloseEvent *)
 Called when user closes dialog box. More...
virtual void childEvent (QChildEvent *)
 Update dialog box layout when the size grip is added. More...
virtual void keyPressEvent (QKeyEvent *)
 Process key pressing event. More...
Private Types
typedef QMap< int, Object > ObjectMap
Private Slots
void onToggled (bool)
 emits if the object selection button changes state More...
void onTextChanged (const QString &)
 text in some line edit is changed More...
void updateButtons (const int=-1)
void updateObject (const int, bool=true)
void filterTypes (const int, QStringList &, TypesList &, QStringList &) const
 Remove from list not possible types and remove from names and ids lists the corresponding items. More...
ObjectMap myObjects
QMap< int, QString > myTypeNames
bool myIsExclusive
bool myIsBusy
QPixmap myPixmap
- Public Slots inherited from QtxDialog
void update ()
 Update dialog box. More...
virtual void setVisible (bool)
 Show/hide dialog box, set keyboard focus to the dialog. More...
- Static Public Member Functions inherited from QtxDialog
static void setUnits (QLabel *, const QString &)
 Set measure units to the specified label. More...
- Protected Types inherited from QtxDialog
typedef QMap< int, QAbstractButton * > ButtonMap
 button map More...
- Protected Slots inherited from QtxDialog
virtual void accept ()
 Accept the dialog box. More...
virtual void reject ()
 Reject the dialog box. More...
Base class for all LightApp dialogs. Provides standard widget for object selection: line edit, button; it is necessary to call corresponding methods on selection change. Standard dialog provides filtering, selection string representation, possibility to indicate necessary selection by text with list of ids.
◆ ObjectMap
typedef QMap<int, Object> LightApp_Dialog::ObjectMap
◆ SelectedObjects
typedef QMap<int,QStringList> LightApp_Dialog::SelectedObjects
◆ TypesList
◆ NameIndication
OneName
OneNameOrCount
ListOfNames
Count
list of all names is shown
In every case "<count> <type>" is shown
◆ ObjectWg
Label
Btn
Control
◆ LightApp_Dialog()
LightApp_Dialog::LightApp_Dialog ( QWidget *  parent = 0,
const char *  name = 0,
bool  modal = false,
bool  allowResize = false,
const int  f = Standard,
Qt::WindowFlags  wf = 0
Constructor
References setObjectPixmap().
◆ ~LightApp_Dialog()
LightApp_Dialog::~LightApp_Dialog ( )
Destructor
◆ activateObject()
void LightApp_Dialog::activateObject ( const int  theId)
Activates object selection widget
id- identificator of object selection widget
References myObjects.
◆ addObjectType() [1/3]
void LightApp_Dialog::addObjectType ( const int  id,
const int  type
Adds new possible type to object selection widget
type- new type
References objectTypes(), and setObjectType().
◆ addObjectType() [2/3]
const int  type1,
const int  ,
Add types to list of possible types The list of arguments must be finished by negative integer
Adds new possible types to object selection widget
type1,...- new types
◆ addObjectType() [3/3]
const TypesList &  list
list- new types
◆ clearSelection()
void LightApp_Dialog::clearSelection ( const int  id = -1)
Clears selection of widget
References clearSelection(), myObjects, and selectionChanged().
◆ countOfTypes()
QString LightApp_Dialog::countOfTypes ( const TypesList &  types) const
string representation of count of types
types- list of types
References typeName().
◆ createObject()
int LightApp_Dialog::createObject ( const QString &  label,
QWidget *  parent,
const int  id = -1
Create label, button and line edit for object selection If passed id is negative, then id will be calculated automatically (first free id) Returns the same id (if id>=0) or calculated
Creates object selection widget
id \label - label text \parent - parent object \id - proposed id for widget (if it is less than 0, the free id will be used)
References myObjects, myPixmap, OneNameOrCount, onTextChanged(), and onToggled().
◆ deactivateAll()
void LightApp_Dialog::deactivateAll ( )
Deactivates all object selection widgets
◆ filterTypes()
void LightApp_Dialog::filterTypes ( const int  id,
QStringList &  names,
TypesList &  types,
QStringList &  ids
Finds in list possible types
names- list of selected objects names
types- list of selected objects types
ids- list of selected objects ids
References multipleSelection(), myObjects, and LightApp_Dialog::Object::myPossibleTypes.
◆ hasObjectType()
bool LightApp_Dialog::hasObjectType ( const int  id,
const int  type
true if widget has such type
type- type to be checked
◆ hasSelection()
bool LightApp_Dialog::hasSelection ( const int  id) const
true if widget has selection
◆ hideObject()
void LightApp_Dialog::hideObject ( const int  id)
Hides object selection widget
References setObjectShown().
◆ isAutoResumed()
bool LightApp_Dialog::isAutoResumed ( ) const
◆ isExclusive()
bool LightApp_Dialog::isExclusive ( ) const
isExclusive status of selection buttons
References myIsExclusive.
◆ isObjectEnabled()
bool LightApp_Dialog::isObjectEnabled ( const int  id) const
enable state of object selection widget
◆ isObjectShown()
bool LightApp_Dialog::isObjectShown ( const int  id) const
isShown state of object selection widget
◆ isReadOnly()
bool LightApp_Dialog::isReadOnly ( const int  id) const
read only state of object selection line edit
◆ multipleSelection()
bool LightApp_Dialog::multipleSelection ( const int  id) const
true, if it is enable multiple selection
References nameIndication(), and OneName.
◆ nameIndication()
LightApp_Dialog::NameIndication LightApp_Dialog::nameIndication ( const int  id) const
type of name indication
References myObjects, and OneNameOrCount.
◆ objectActivated
void LightApp_Dialog::objectActivated ( int  )
signal
◆ objectChanged
void LightApp_Dialog::objectChanged ( int  ,
const QStringList &
signal
◆ objectDeactivated
void LightApp_Dialog::objectDeactivated ( int  )
signal
◆ objectSelection()
void LightApp_Dialog::objectSelection ( SelectedObjects &  objs) const
all selected objects
objs- map: widget id -> string id to be filled with selected objects
References myObjects, and selectedObject().
◆ objectText()
QString LightApp_Dialog::objectText ( const int  theId) const
object selection widget text
theId- identificator of object selection widget
◆ objectTypes()
void LightApp_Dialog::objectTypes ( const int  id,
TypesList &  list
Returns list of possible types for widget
list- list to be filled with possible types
◆ objectWg()
QWidget * LightApp_Dialog::objectWg ( const int  theId,
const int  theWgId
theWgIdmay be "Label", "Btn" or "Control"
References Btn, Control, Label, and myObjects.
◆ onTextChanged
void LightApp_Dialog::onTextChanged ( const QString &  text)
privateslot
SLOT: called if text of object selection line edit is changed
References isReadOnly(), myIsBusy, myObjects, and objectChanged().
◆ onToggled
void LightApp_Dialog::onToggled ( bool  on)
privateslot
SLOT: called if selection button is clicked
References myObjects, objectActivated(), objectDeactivated(), and updateButtons().
◆ removeObjectType() [1/3]
void LightApp_Dialog::removeObjectType ( const int  id)
Clears list of possibles types for object selection widget
References setObjectType().
◆ removeObjectType() [2/3]
void LightApp_Dialog::removeObjectType ( const int  id,
const int  type
Removes type from list of possibles for object selection widget
type- type to be removed
References removeObjectType().
◆ removeObjectType() [3/3]
Removes types from list of possibles for object selection widget
list- list of types to be removed
References myObjects, and updateObject().
◆ renameObject()
void LightApp_Dialog::renameObject ( const int  id,
Change label.
Changes label of object selection widget
label- new text of label
◆ resMgr()
SUIT_ResourceMgr * LightApp_Dialog::resMgr ( ) const
global resource manager
References SUIT_Session::resourceMgr(), and SUIT_Session::session().
◆ selectedObject() [1/2]
QString LightApp_Dialog::selectedObject ( const int  id) const
selected object id
◆ selectedObject() [2/2]
void LightApp_Dialog::selectedObject ( const int  id,
QStringList &  list
objects selected by widget
list- list to be filled by selected objects
◆ selectionChanged
void LightApp_Dialog::selectionChanged ( int  )
signal
◆ selectionDescription()
QString LightApp_Dialog::selectionDescription ( const QStringList &  names,
const TypesList &  types,
const NameIndication  ni
string representation of selection by selection data
ni- type of name indication
References Count, countOfTypes(), ListOfNames, OneName, and OneNameOrCount.
◆ selectObject() [1/4]
void LightApp_Dialog::selectObject ( const int  id,
const QString &  name,
const int  type,
const QString &  selid,
const bool  update = true
Passes to widget name, type and id of selected object
name- name of selected object
type- type of selected object
selid- id of selected object
update- is need to update selection description string
References selectObject(), and QtxDialog::update().
◆ selectObject() [2/4]
const QStringList &  _names,
const TypesList &  _types,
const QStringList &  _ids,
Passes to widget names, types and ids of selected objects
_names- names of selected object
_types- types of selected object
_ids- ids of selected object
References filterTypes(), LightApp_Dialog::Object::myEdit, LightApp_Dialog::Object::myIds, LightApp_Dialog::Object::myNames, LightApp_Dialog::Object::myNI, myObjects, LightApp_Dialog::Object::myTypes, selectionChanged(), selectionDescription(), and QtxDialog::update().
◆ selectObject() [3/4]
void LightApp_Dialog::selectObject ( const QString &  name,
const int  type,
const QString &  id,
Passes to all active widgets name, type and id of selected object
◆ selectObject() [4/4]
void LightApp_Dialog::selectObject ( const QStringList &  _names,
Pass to all active widgets list of names, types and ids of selected objects Every active widget filters list and accept only objects with possible types
Passes to all active widgets names, types and ids of selected objects
_names- names of selected objects
_types- types of selected objects
_ids- ids of selected objects
References myObjects, selectObject(), and QtxDialog::update().
◆ setAutoResumed()
void LightApp_Dialog::setAutoResumed ( const bool  )
◆ setExclusive()
void LightApp_Dialog::setExclusive ( const bool  ex)
Set exclusive state
Sets isExclusive status of selection buttons
ex- new value of isExclusive status
References myIsExclusive, and updateButtons().
◆ setNameIndication()
void LightApp_Dialog::setNameIndication ( const int  id,
Sets type of name indication
ni- new type of name indication
References isReadOnly(), myObjects, setReadOnly(), and updateObject().
◆ setObjectEnabled()
void LightApp_Dialog::setObjectEnabled ( const int  id,
const bool  en
Change enable state of object selection widget
en- new value of enable state
References isObjectEnabled(), LightApp_Dialog::Object::myBtn, LightApp_Dialog::Object::myEdit, and myObjects.
◆ setObjectPixmap() [1/2]
void LightApp_Dialog::setObjectPixmap ( const QPixmap &  p)
Sets pixmap for all object selection button
p- image
References myObjects, and myPixmap.
◆ setObjectPixmap() [2/2]
void LightApp_Dialog::setObjectPixmap ( const QString &  section,
const QString &  file
Sets pixmap all for object selection button
section- name of section of resource manager
file- name of file
References QtxResourceMgr::loadPixmap(), resMgr(), and setObjectPixmap().
◆ setObjectShown()
void LightApp_Dialog::setObjectShown ( const int  id,
const bool  shown
Shows/hides object selection widget
shown- if it is true, widget will be shown
References isObjectShown(), LightApp_Dialog::Object::myBtn, LightApp_Dialog::Object::myEdit, LightApp_Dialog::Object::myLabel, and myObjects.
◆ setObjectText()
void LightApp_Dialog::setObjectText ( const int  theId,
const QString &  theText
Sets object selection widget text
theText- new text
◆ setObjectType() [1/2]
void LightApp_Dialog::setObjectType ( const int  id,
const int  type1,
Sets possible types for widget
type1,...- type
◆ setObjectType() [2/2]
list- list of possible types
◆ setReadOnly()
void LightApp_Dialog::setReadOnly ( const int  id,
const bool  ro
Sets read only state of object selection line edit
ro- new read only state
References ListOfNames, myObjects, nameIndication(), and OneName.
◆ show()
void LightApp_Dialog::show ( )
Show dialog
◆ showObject()
void LightApp_Dialog::showObject ( const int  id)
Shows object selection widget
◆ typeName() [1/2]
QString & LightApp_Dialog::typeName ( const int  type)
reference to type name
type- integer id of type
References myTypeNames.
◆ typeName() [2/2]
const QString LightApp_Dialog::typeName ( const int  type) const
const reference to type name
◆ updateButtons()
void LightApp_Dialog::updateButtons ( const int  _id = -1)
If buttons are exclusive, set to "off" all buttons except one with id If id=-1, then all buttons, except first with "on" state, will be set to "off"
Updates "on" state of buttons according to special button
_id- id of special button (if it is -1, then first selected button will be treated as special)
References myIsExclusive, and myObjects.
◆ updateObject()
void LightApp_Dialog::updateObject ( const int  id,
bool  emit_signal = true
Filter types and update selection string in line edit If bool is true, then signal is emitted
Updates selection description of widget
emit_signal- if it is true, the signal "selection changed" is emitted
References filterTypes(), hasSelection(), LightApp_Dialog::Object::myEdit, LightApp_Dialog::Object::myIds, LightApp_Dialog::Object::myNames, LightApp_Dialog::Object::myNI, myObjects, LightApp_Dialog::Object::myTypes, selectionChanged(), and selectionDescription().
◆ myIsBusy
bool LightApp_Dialog::myIsBusy
◆ myIsExclusive
bool LightApp_Dialog::myIsExclusive
◆ myObjects
ObjectMap LightApp_Dialog::myObjects
◆ myPixmap
QPixmap LightApp_Dialog::myPixmap
◆ myTypeNames
QMap<int,QString> LightApp_Dialog::myTypeNames
