LightApp_ModuleAction Class Reference
An action, representing the list of modules to be inserted to the toolbar. More...
#include <LightApp_ModuleAction.h>
Inheritance diagram for LightApp_ModuleAction:
class  ActionSet
 Internal class to represent list of modules buttons. More...
class  ActivateEvent
 Internal class to represent custom event for transfer the activation item id. More...
class  ComboAction
 Internal class to represent combo box with the list of modules in the toolbar. More...
enum  Mode { Buttons = 0x01 , List = 0x02 , AddRemove = 0x04 , All = Buttons | List | AddRemove }
Public Slots
void setActiveModule (const QString &)
 Set active module. More...
Signals
void moduleActivated (const QString &)
 Emitted when the module is activated. More...
void adding ()
void removing (const QString &)
void showExtInfo ()
 LightApp_ModuleAction (QtxResourceMgr *, QObject *=0)
virtual ~LightApp_ModuleAction ()
int count () const
 Get number of registered modules. More...
QStringList modules () const
 Get list of modules. More...
QIcon moduleIcon (const QString &) const
 Get module icon. More...
void setModuleIcon (const QString &, const QIcon &)
 Set module icon. More...
QAction * moduleAction (const QString &) const
 Get module action. More...
void insertModule (const QString &, const QIcon &, const int=-1)
 Add module into the list. More...
void insertModule (const QString &, const QIcon &, bool, const int=-1)
void removeModule (const QString &)
 Remove module from the list. More...
void insertExtension (const QString &)
 Add an installed extension. Now only to the Remove button's menu. More...
void removeExtension (const QString &)
 Remove an installed extension. More...
void updateExtActions ()
 Update extension actions based on dependencies. More...
QString activeModule () const
 Get active module. More...
void setMode (const Mode &)
 Set action display mode. More...
void setModeEnabled (const Mode &, bool)
 Enable / disable action display mode. More...
bool isModeEnabled (const Mode &) const
 Get action display mode. More...
- Public Member Functions inherited from QtxAction
 QtxAction (QObject *=0, bool=false, const QString &=QString())
 QtxAction (QObject *, bool, const QString &, const QString &, const QString &=QString(), const QIcon &=QIcon())
 QtxAction (const QString &, const QString &, int, QObject *, bool=false, const QString &=QString())
 QtxAction (const QString &, const QString &, const QKeySequence &, QObject *, bool=false, const QString &=QString())
 QtxAction (const QString &, const QIcon &, const QString &, int, QObject *, bool=false, const QString &=QString())
 QtxAction (const QString &, const QIcon &, const QString &, const QKeySequence &, QObject *, bool=false, const QString &=QString())
virtual ~QtxAction ()
 Customize action events. More...
QString shortcutActionName () const
void setShortcutActionName (const QString &)
const QString & ID () const
 Unique for the entire application ID. More...
void setID (const QString &theID)
virtual void addedTo (QWidget *)
 Called when the action is added to the widget. More...
virtual void removedFrom (QWidget *)
 Remove action from widget. More...
virtual bool event (QEvent *)
 Perform delayed activation with specified id. More...
- Protected Member Functions inherited from QtxAction
 Called when the action is removed from the widget. More...
virtual void customEvent (QEvent *)
 Process notification events. More...
Private Slots
void onChanged ()
 Called when action state is changed. More...
void onTriggered (int)
 Called when module button is triggered. More...
void onComboActivated (int)
 Called when combo box item is activated. More...
void update ()
 Update an action. More...
void update (QtxComboBox *)
 Update combo box. More...
QAction * active () const
 Get an action corresponding to the active module. More...
void activate (int, bool=true)
 Activate a module item. More...
ComboAction * myCombo
QtxAction * myAdd
QtxAction * myRemove
QtxAction * myInfo
ActionSet * mySet
QAction * mySeparator
int myMode
QSignalMapper * myMapper
In the toolbar this action is represented as the combo box with the list of available modules, and a set of buttons for each module. Additionally, combo box contains an item representing "neutral point" of the application (i.e. no active module).
In menu, the action is represented as a plain list of items, one per module.
Only one module can be active at the moment. It can be set programmatically with setActiveModule() function. Use this method with empty string to turn to the "neutral point". To get active module, use activeModule() function.
When user activates/deactivates a module, the moduleActivated() signal is emitted.
The action also provides an additional separate item "Add modules"; when this button is pressed, a adding() signal is emitted. This signal can be connected to a dedicated slot aimed to dynamically add a new module into the application. In addition, a button "Remove module" shows a dropdown menu with the list of user modules; when any item is selected, the removing() signal is emitted. This signal may be connected to a slot aimed to dynamically remove selected user module from application.
It is possible to customize which elements to show via the setMode() of setModeEnabled() functions. By default, all elements are shown. The following choices are possible:
◆ Mode
Buttons
List
AddRemove
All
◆ LightApp_ModuleAction()
LightApp_ModuleAction::LightApp_ModuleAction ( QtxResourceMgr *  resMgr,
QObject *  parent = 0
◆ ~LightApp_ModuleAction()
LightApp_ModuleAction::~LightApp_ModuleAction ( )
◆ activate()
void LightApp_ModuleAction::activate ( int  id,
bool  fromAction = true
idmodule identifier
fromActiontrue if function is called from the module button
References QtxActionSet::actions(), activeModule(), moduleActivated(), LightApp_ModuleAction::ActionSet::moduleId(), myCombo, mySet, QtxComboBox::setCurrentId(), and LightApp_ModuleAction::ComboAction::widgets().
◆ active()
QAction * LightApp_ModuleAction::active ( ) const
active module action or 0 if there is no active module
References QtxActionSet::actions(), and mySet.
◆ activeModule()
QString LightApp_ModuleAction::activeModule ( ) const
Get active module.
If there is no active module ("neutral point"), then the null string is returned.
active module name
See also
setActiveModule()
References active().
◆ addedTo()
void LightApp_ModuleAction::addedTo ( QWidget *  w)
wwidget (not used)
Reimplemented from QtxAction.
References myAdd, myCombo, myInfo, myRemove, mySeparator, mySet, and update().
◆ adding
void LightApp_ModuleAction::adding ( )
signal
◆ count()
int LightApp_ModuleAction::count ( ) const
modules count
References modules().
◆ event()
bool LightApp_ModuleAction::event ( QEvent *  e)
ecustom event
true if the event was processed successfully and false otherwise.
References activate().
◆ insertExtension()
void LightApp_ModuleAction::insertExtension ( const QString &  name)
namean extension's name
See also
removeExtension()
References myMapper, and myRemove.
◆ insertModule() [1/2]
void LightApp_ModuleAction::insertModule ( const QString &  name,
const QIcon &  ico,
bool  isCustom,
const int  idx = -1
namemodule name
icomodule icon
isCustomfalse to insert regular module, true to insert user module
idxposition in the module list (if -1, the module is added to the end of list)
See also
removeModule()
References QtxActionSet::insertAction(), mySet, QtxAction::QtxAction(), and update().
◆ insertModule() [2/2]
const QIcon &  ico,
const int  idx = -1
namemodule name
icomodule icon
See also
removeModule()
References insertModule().
◆ isModeEnabled()
bool LightApp_ModuleAction::isModeEnabled ( const Mode &  mode) const
modeaction display mode
See also
setMode()
References myMode.
◆ moduleAction()
QAction * LightApp_ModuleAction::moduleAction ( const QString &  name) const
Get module action.
namemodule name
References LightApp_ModuleAction::ActionSet::moduleAction(), and mySet.
◆ moduleActivated
void LightApp_ModuleAction::moduleActivated ( const QString &  name)
signal
namemodule name (empty string for neutral point)
◆ moduleIcon()
QIcon LightApp_ModuleAction::moduleIcon ( const QString &  name) const
Get module icon.
namemodule name
module icon
See also
setModuleIcon()
◆ modules()
QStringList LightApp_ModuleAction::modules ( ) const
modules names list
◆ onChanged
void LightApp_ModuleAction::onChanged ( )
privateslot
This slot is used to prevent making the parent action visible.
◆ onComboActivated
void LightApp_ModuleAction::onComboActivated ( int  id)
privateslot
idmodule identifier
◆ onTriggered
void LightApp_ModuleAction::onTriggered ( int  id)
privateslot
idmodule identifier
◆ removedFrom()
void LightApp_ModuleAction::removedFrom ( QWidget *  w)
wwidget (menu or toolbar)
true if the action is removed successfully and false otherwise.
See also
addTo()
References myAdd, myCombo, myInfo, myRemove, mySeparator, and mySet.
◆ removeExtension()
void LightApp_ModuleAction::removeExtension ( const QString &  name)
See also
insertExtension()
References myRemove, update(), and updateExtActions().
◆ removeModule()
void LightApp_ModuleAction::removeModule ( const QString &  name)
namemodule name
See also
insertModule()
References LightApp_ModuleAction::ActionSet::moduleId(), mySet, QtxActionSet::removeAction(), and update().
◆ removing
void LightApp_ModuleAction::removing ( const QString &  )
signal
◆ setActiveModule
void LightApp_ModuleAction::setActiveModule ( const QString &  name)
slot
Set active module.
To turn to the "neutral point" (no active module), pass empty string.
namenew active module name
See also
activeModule()
References activate(), activeModule(), LightApp_ModuleAction::ActionSet::moduleId(), and mySet.
◆ setMode()
void LightApp_ModuleAction::setMode ( const Mode &  mode)
modeaction display options (combination of flags)
See also
mode()
References myMode, and update().
◆ setModeEnabled()
void LightApp_ModuleAction::setModeEnabled ( const Mode &  mode,
bool  enabled
enabledtrue to enable mode, false to disable mode
See also
mode()
◆ setModuleIcon()
void LightApp_ModuleAction::setModuleIcon ( const QString &  name,
const QIcon &  ico
Set module icon.
namemodule name
iconew module icon
See also
moduleIcon()
References LightApp_ModuleAction::ActionSet::moduleAction(), mySet, and update().
◆ showExtInfo
void LightApp_ModuleAction::showExtInfo ( )
signal
◆ update() [1/2]
void LightApp_ModuleAction::update ( )
◆ update() [2/2]
void LightApp_ModuleAction::update ( QtxComboBox *  cb)
◆ updateExtActions()
void LightApp_ModuleAction::updateExtActions ( )
References myRemove.
◆ myAdd
QtxAction* LightApp_ModuleAction::myAdd
◆ myCombo
ComboAction* LightApp_ModuleAction::myCombo
◆ myInfo
QtxAction* LightApp_ModuleAction::myInfo
◆ myMapper
QSignalMapper* LightApp_ModuleAction::myMapper
◆ myMode
int LightApp_ModuleAction::myMode
◆ myRemove
QtxAction* LightApp_ModuleAction::myRemove
◆ mySeparator
QAction* LightApp_ModuleAction::mySeparator
◆ mySet
ActionSet* LightApp_ModuleAction::mySet
