LightApp_ModuleAction::ActionSet Class Reference
Internal class to represent list of modules buttons. More...
Inheritance diagram for LightApp_ModuleAction::ActionSet:
 ActionSet (QObject *)
QAction * moduleAction (const QString &) const
 Get action corresponding to the specified module. More...
int moduleId (const QString &) const
 Get module action identifier. More...
int moduleId (QAction *) const
void setVisible (bool)
 Show/hide modules actions. More...
- Public Member Functions inherited from QtxActionSet
 QtxActionSet (QObject *=0)
virtual ~QtxActionSet ()
QList< QAction * > actions () const
 Get list of child actions. More...
void setActions (const QList< QAction * > &)
 Assign child actions. More...
void insertActions (const QList< QAction * > &, const int=-1)
 Insert actions at the specified position. More...
int insertAction (QAction *, const int id=-1, const int=-1)
 Insert action at the specified position. More...
int insertAction (const QString &, const int id=-1, const int=-1)
int insertAction (const QString &, const QIcon &, const int id=-1, const int=-1)
void removeAction (QAction *)
 Remove specified action. More...
void removeAction (const int)
void clear ()
 Remove all actions. More...
 QtxAction (QObject *=0, bool=false, const QString &=QString())
 QtxAction (QObject *, bool, const QString &, const QString &, const QString &=QString(), const QIcon &=QIcon())
 QtxAction (const QString &, const QString &, int, QObject *, bool=false, const QString &=QString())
 QtxAction (const QString &, const QString &, const QKeySequence &, QObject *, bool=false, const QString &=QString())
 QtxAction (const QString &, const QIcon &, const QString &, int, QObject *, bool=false, const QString &=QString())
 QtxAction (const QString &, const QIcon &, const QString &, const QKeySequence &, QObject *, bool=false, const QString &=QString())
virtual ~QtxAction ()
 Customize action events. More...
QString shortcutActionName () const
void setShortcutActionName (const QString &)
const QString & ID () const
 Unique for the entire application ID. More...
void setID (const QString &theID)
- Signals inherited from QtxActionSet
void triggered (int)
 Emitted when some child action is activated by the user. More...
void triggered (QAction *)
- Protected Member Functions inherited from QtxActionSet
virtual void addedTo (QWidget *)
 Called when this action set is added to the menu bar (or toolbar). More...
virtual void removedFrom (QWidget *)
 Called when this action set is removed from the menu bar (or toolbar). More...
virtual void actionAdded (QAction *)
 Notify that action was added. More...
virtual void actionRemoved (QAction *)
 Notify that action was removed. More...
QAction * action (int) const
 Get action by specified identifier. More...
int actionId (QAction *) const
 Get action identifier for the action. More...
void setActionId (QAction *, const int)
 Set action identifier for the action. More...
virtual bool isEmptyAction () const
 Check if the action itself should be invisible (only child action are shown) More...
virtual void updateAction ()
 Update action set. More...
virtual void updateAction (QWidget *)
 Update action set for the specified widget. More...
 Called when the action is added to the widget. More...
 Called when the action is removed from the widget. More...
virtual void customEvent (QEvent *)
 Process notification events. More...
◆ ActionSet()
LightApp_ModuleAction::ActionSet::ActionSet ( QObject *  parent)
parentparent object
◆ moduleAction()
QAction * LightApp_ModuleAction::ActionSet::moduleAction ( const QString &  name) const
namemodule name
module action or 0 if name is invalid
◆ moduleId() [1/2]
int LightApp_ModuleAction::ActionSet::moduleId ( const QString &  name) const
namemodule name
module action ID or -1 if name is invalid
◆ moduleId() [2/2]
int LightApp_ModuleAction::ActionSet::moduleId ( QAction *  a) const
amodule action
module action ID or -1 if a is null or invalid
◆ setVisible()
void LightApp_ModuleAction::ActionSet::setVisible ( bool  on)
onnew visibility state
