NoteBook_TableRow Class Reference
#include <SalomeApp_NoteBook.h>
Inheritance diagram for NoteBook_TableRow:
 NoteBook_TableRow (int, NoteBook_Table *parentTable, QWidget *parent=0)
virtual ~NoteBook_TableRow ()
int GetIndex () const
void AddToTable (QTableWidget *theTable)
void SetName (const QString theName)
void SetValue (const QString theValue)
QString GetValue () const
QString GetName () const
bool CheckName ()
bool CheckValue ()
QTableWidgetItem * GetVariableItem ()
QTableWidgetItem * GetNameItem ()
QTableWidgetItem * GetHeaderItem ()
bool IsValidStringValue (const QString theName)
static bool IsRealValue (const QString theValue, double *theResult=0)
static bool IsIntegerValue (const QString theValue, int *theResult=0)
static bool IsBooleanValue (const QString theValue, bool *theResult=0)
int myIndex
NoteBook_Table * myParentTable
QTableWidgetItem * myRowHeader
QTableWidgetItem * myVariableName
QTableWidgetItem * myVariableValue
◆ NoteBook_TableRow()
NoteBook_TableRow::NoteBook_TableRow ( int  index,
NoteBook_Table *  parentTable,
QWidget *  parent = 0
Function : NoteBook_TableRow Purpose : Constructor
◆ ~NoteBook_TableRow()
NoteBook_TableRow::~NoteBook_TableRow ( )
Function : ~NoteBook_TableRow Purpose : Destructor
◆ AddToTable()
void NoteBook_TableRow::AddToTable ( QTableWidget *  theTable)
Function : AddToTable Purpose : Add this row to the table theTable
References myRowHeader, myVariableName, myVariableValue, NAME_COLUMN, and VALUE_COLUMN.
◆ CheckName()
bool NoteBook_TableRow::CheckName ( )
Function : CheckName Purpose : Return true if variable name correct, otherwise return false
References GetName().
◆ CheckValue()
bool NoteBook_TableRow::CheckValue ( )
Function : CheckValue Purpose : Return true if variable value correct, otherwise return false
References GetValue(), IsBooleanValue(), IsIntegerValue(), IsRealValue(), and IsValidStringValue().
◆ GetHeaderItem()
QTableWidgetItem * NoteBook_TableRow::GetHeaderItem ( )
Function : GetHeaderItem Purpose :
References myRowHeader.
◆ GetIndex()
int NoteBook_TableRow::GetIndex ( ) const
◆ GetName()
QString NoteBook_TableRow::GetName ( ) const
Function : GetName Purpose : Return variable name
References myVariableName.
◆ GetNameItem()
QTableWidgetItem * NoteBook_TableRow::GetNameItem ( )
Function : GetNameItem Purpose :
◆ GetValue()
QString NoteBook_TableRow::GetValue ( ) const
Function : GetValue Purpose : Return variable value
References myVariableValue.
◆ GetVariableItem()
QTableWidgetItem * NoteBook_TableRow::GetVariableItem ( )
Function : GetVariableItem Purpose :
◆ IsBooleanValue()
bool NoteBook_TableRow::IsBooleanValue ( const QString  theValue,
bool *  theResult = 0
Function : IsBooleanValue Purpose : Return true if theValue String is boolean value, otherwise return false
◆ IsIntegerValue()
bool NoteBook_TableRow::IsIntegerValue ( const QString  theValue,
int *  theResult = 0
Function : IsIntegerValue Purpose : Return true if theValue string is integer value, otherwise return false
◆ IsRealValue()
bool NoteBook_TableRow::IsRealValue ( const QString  theValue,
double *  theResult = 0
Function : IsRealValue Purpose : Return true if theValue string is real value, otherwise return false
◆ IsValidStringValue()
bool NoteBook_TableRow::IsValidStringValue ( const QString  theName)
Function : IsValidStringValue Purpose : Return true if theValue string is valid, otherwise return false The string are always valid for the moment The whole notebook is verified on apply
References SUIT_Session::activeApplication(), LightApp_Application::getPyInterp(), myParentTable, NoteBook_Table::myRows, LightApp_Application::pythonConsole(), and SUIT_Session::session().
◆ SetName()
void NoteBook_TableRow::SetName ( const QString  theName)
Function : SetName Purpose :
◆ SetValue()
void NoteBook_TableRow::SetValue ( const QString  theValue)
Function : SetValue Purpose :
◆ myIndex
int NoteBook_TableRow::myIndex
◆ myParentTable
NoteBook_Table* NoteBook_TableRow::myParentTable
◆ myRowHeader
QTableWidgetItem* NoteBook_TableRow::myRowHeader
◆ myVariableName
QTableWidgetItem* NoteBook_TableRow::myVariableName
◆ myVariableValue
QTableWidgetItem* NoteBook_TableRow::myVariableValue
