OCCViewer_ClipPlaneInteractor Class Reference
The class provides mouse dragging operations with AIS_Plane: 1) Sliding plane by dragging it with point 2) Rotating plane around one or both of the rotation axes by dragging its point with "ctrl" key pressed. More...
#include <OCCViewer_ClipPlaneInteractor.h>
Inheritance diagram for OCCViewer_ClipPlaneInteractor:
enum  DragOperation { DragOperation_Undef , DragOperation_Slide , DragOperation_Rotate }
typedef std::vector< Handle(AIS_Plane)> SeqOfPlanes
Signals
void planeClicked (const Handle_AIS_Plane &thePlane)
void planeDragged (const Handle_AIS_Plane &thePlane)
 OCCViewer_ClipPlaneInteractor (OCCViewer_ViewManager *, QObject *theParent)
const SeqOfPlanes & planes () const
 Get sequence of planes to interact with. More...
void setPlanes (const SeqOfPlanes &)
 Sets sequence of planes allowed for interaction. More...
void setRotationCenter (const gp_Pnt &)
 Sets center of rotation for the scene. More...
void setMinMax (const Bnd_Box &)
 Sets minimum and maximum bounding of the scene. The sliding movements are limited to minimum and maximum bounds. More...
virtual void setEnabled (const bool)
 Enables or disables event processing within the viewer. More...
- Public Member Functions inherited from OCCViewer_ViewportInputFilter
 OCCViewer_ViewportInputFilter (OCCViewer_ViewManager *, QObject *)
 ~OCCViewer_ViewportInputFilter ()
bool isClickable (const Handle(AIS_Plane)&thePlane)
 Checks whether the interactive plane can be clicked. More...
bool isDraggable (const Handle(AIS_Plane)&thePlane)
 Checks whether the interactive plane can be dragged. More...
bool isPerforming () const
 Checks whether the interactive operation is in progress. More...
bool startDragging (const QPoint &thePickPos, const QPoint &theDragPos, const DragOperation theOperation, const Handle(AIS_Plane)&thePlane, const Handle(V3d_View)&theView)
 Checks whether it is possible to start interaction with plane. More...
void performDragging (const QPoint &theDragPos, const DragOperation theOperation, const Handle(AIS_Plane)&thePlane, const Handle(V3d_View)&theView)
 Performs dragging operation on the passed interactive plane. More...
void adjustBounds (gp_Ax3 &, const Bnd_Box &)
 Adjusts min-max bounds of the plane. More...
virtual bool mouseMove (QMouseEvent *, OCCViewer_ViewPort3d *)
 Handle mouse move events. Performs dragging if interaction is in progress. More...
virtual bool mousePress (QMouseEvent *, OCCViewer_ViewPort3d *)
 Handle mouse press events. Starts interaction with detected plane. More...
virtual bool mouseRelease (QMouseEvent *, OCCViewer_ViewPort3d *)
 Handle mouse release events. Stops interaction. More...
virtual bool mouseDoubleClick (QMouseEvent *, OCCViewer_ViewPort3d *)
 Handle mouse double clicking events events. Stops the event propagation if interaction with plane is in progress. More...
virtual bool keyPress (QKeyEvent *, OCCViewer_ViewPort3d *)
 Handle key pressing events. Stops the event propagation if interaction with plane is in progress. More...
virtual bool keyRelease (QKeyEvent *, OCCViewer_ViewPort3d *)
 Handle key releasing events. Stops the event propagation if interaction with plane is in progress. More...
 Handle (AIS_Plane) myInteractedPlane
- Protected Member Functions inherited from OCCViewer_ViewportInputFilter
virtual bool mouseMove (QMouseEvent *, OCCViewer_ViewPort3d *)=0
virtual bool mousePress (QMouseEvent *, OCCViewer_ViewPort3d *)=0
virtual bool mouseRelease (QMouseEvent *, OCCViewer_ViewPort3d *)=0
virtual bool mouseDoubleClick (QMouseEvent *, OCCViewer_ViewPort3d *)=0
virtual bool keyPress (QKeyEvent *, OCCViewer_ViewPort3d *)=0
virtual bool keyRelease (QKeyEvent *, OCCViewer_ViewPort3d *)=0
void connectView (SUIT_ViewWindow *)
 Connects view to event processing. More...
void disconnectView (SUIT_ViewWindow *)
 Disconnects view to event processing. More...
bool eventFilter (QObject *, QEvent *)
 Base-level implementation of event filtering. Routes user input events to associated implementation methods. More...
gp_Ax3 myPlaneReferenceCS
gp_Ax1 myRotationAxis
gp_Pln myMouseDragPln
QPoint myDragPos
QPoint myPickPos
DragOperation myPerformingOp
gp_Pnt myRotationCenter
Bnd_Box myMinMax
SeqOfPlanes myPlanes
bool myIsDraggable
bool myIsClickable
- Protected Attributes inherited from OCCViewer_ViewportInputFilter
OCCViewer_ViewManager * myVM
OCCViewer_Viewer * myViewer
bool myIsEnabled
- Protected Slots inherited from OCCViewer_ViewportInputFilter
void onViewCreated (SUIT_ViewWindow *)
 Connects newly created within viewer to event processing. More...
void onViewRemoved (SUIT_ViewWindow *)
 Disconnects view being removed from viewer. More...
◆ SeqOfPlanes
typedef std::vector<Handle(AIS_Plane)> OCCViewer_ClipPlaneInteractor::SeqOfPlanes
◆ DragOperation
DragOperation_Undef
DragOperation_Slide
◆ OCCViewer_ClipPlaneInteractor()
OCCViewer_ClipPlaneInteractor::OCCViewer_ClipPlaneInteractor ( OCCViewer_ViewManager *  theVM,
QObject *  theParent
theVM[in] the view manager.
theParent[in] the parent object.
◆ adjustBounds()
void OCCViewer_ClipPlaneInteractor::adjustBounds ( gp_Ax3 &  thePlane,
const Bnd_Box &  theMinMax
thePlane[in/out] the plane.
theMinMax[in] the min max bounds
◆ Handle()
OCCViewer_ClipPlaneInteractor::Handle ( AIS_Plane  )
◆ isClickable()
bool OCCViewer_ClipPlaneInteractor::isClickable ( const Handle(AIS_Plane)&  thePlane)
true if the click interaction is supported for the plane.
References Handle(), myPlanes, and OCCViewer_ViewportInputFilter::myViewer.
◆ isDraggable()
bool OCCViewer_ClipPlaneInteractor::isDraggable ( const Handle(AIS_Plane)&  thePlane)
true if the dragging interaction is supported for the plane.
◆ isPerforming()
bool OCCViewer_ClipPlaneInteractor::isPerforming ( ) const
true if the interaction is performed on IO object meaning that no other operations in viewer should be processed.
◆ keyPress()
bool OCCViewer_ClipPlaneInteractor::keyPress ( QKeyEvent *  theEvent,
OCCViewer_ViewPort3d *  theViewPort
theEvent[in] the user event.
theViewPort[in] the viewport.
Implements OCCViewer_ViewportInputFilter.
References DragOperation_Rotate, DragOperation_Slide, DragOperation_Undef, isDraggable(), isPerforming(), myIsDraggable, myPerformingOp, and myPickPos.
◆ keyRelease()
bool OCCViewer_ClipPlaneInteractor::keyRelease ( QKeyEvent *  theEvent,
◆ mouseDoubleClick()
bool OCCViewer_ClipPlaneInteractor::mouseDoubleClick ( QMouseEvent *  ,
References isPerforming().
◆ mouseMove()
bool OCCViewer_ClipPlaneInteractor::mouseMove ( QMouseEvent *  theEvent,
References DragOperation_Rotate, DragOperation_Slide, DragOperation_Undef, Handle(), isPerforming(), myDragPos, myIsDraggable, myPerformingOp, myPickPos, performDragging(), planeDragged(), and startDragging().
◆ mousePress()
bool OCCViewer_ClipPlaneInteractor::mousePress ( QMouseEvent *  theEvent,
References Handle(), isClickable(), isDraggable(), myIsClickable, myIsDraggable, myPickPos, OCCViewer_ViewportInputFilter::myViewer, and planeClicked().
◆ mouseRelease()
bool OCCViewer_ClipPlaneInteractor::mouseRelease ( QMouseEvent *  ,
References DragOperation_Undef, isPerforming(), myDragPos, myIsClickable, myIsDraggable, myMouseDragPln, myPerformingOp, myPickPos, and OCCViewer_ViewportInputFilter::myViewer.
◆ performDragging()
void OCCViewer_ClipPlaneInteractor::performDragging ( const QPoint &  theDragPos,
const DragOperation  theDragOp,
const Handle(AIS_Plane)&  thePlane,
const Handle(V3d_View)&  theView
theDragPos[in] the position of mouse dragging.
theDragOp[in] the drag operation to start.
thePlane[in] the operated plane.
theView[in] the view.
References adjustBounds(), DragOperation_Rotate, DragOperation_Slide, Handle(), myMinMax, myMouseDragPln, myPlaneReferenceCS, myRotationAxis, myRotationCenter, and OCCViewer_ViewportInputFilter::myViewer.
◆ planeClicked
void OCCViewer_ClipPlaneInteractor::planeClicked ( const Handle_AIS_Plane &  thePlane)
signal
◆ planeDragged
void OCCViewer_ClipPlaneInteractor::planeDragged ( const Handle_AIS_Plane &  thePlane)
signal
◆ planes()
const OCCViewer_ClipPlaneInteractor::SeqOfPlanes & OCCViewer_ClipPlaneInteractor::planes ( ) const
the sequence of accepted planes.
References myPlanes.
◆ setEnabled()
void OCCViewer_ClipPlaneInteractor::setEnabled ( const bool  theIsEnabled)
Reimplemented from OCCViewer_ViewportInputFilter.
References DragOperation_Undef, myDragPos, myIsClickable, myIsDraggable, myMouseDragPln, myPerformingOp, myPickPos, and OCCViewer_ViewportInputFilter::setEnabled().
◆ setMinMax()
void OCCViewer_ClipPlaneInteractor::setMinMax ( const Bnd_Box &  theMinMax)
theMinMax[in] the minimum and maximum bounds.
References myMinMax.
◆ setPlanes()
void OCCViewer_ClipPlaneInteractor::setPlanes ( const SeqOfPlanes &  thePlanes)
thePlanes[in] the sequence of accepted planes.
◆ setRotationCenter()
void OCCViewer_ClipPlaneInteractor::setRotationCenter ( const gp_Pnt &  theCenter)
theCenter[in] the center of rotation.
References myRotationCenter.
◆ startDragging()
bool OCCViewer_ClipPlaneInteractor::startDragging ( const QPoint &  thePickPos,
thePickPos[in] the position of mouse picking.
theDragPos[in] the position of initial mouse dragging.
thePlane[in] the detected plane.
References DragOperation_Rotate, DragOperation_Slide, Handle(), myMouseDragPln, myPlaneReferenceCS, myRotationAxis, and myRotationCenter.
◆ myDragPos
QPoint OCCViewer_ClipPlaneInteractor::myDragPos
◆ myIsClickable
bool OCCViewer_ClipPlaneInteractor::myIsClickable
◆ myIsDraggable
bool OCCViewer_ClipPlaneInteractor::myIsDraggable
◆ myMinMax
Bnd_Box OCCViewer_ClipPlaneInteractor::myMinMax
◆ myMouseDragPln
gp_Pln OCCViewer_ClipPlaneInteractor::myMouseDragPln
◆ myPerformingOp
DragOperation OCCViewer_ClipPlaneInteractor::myPerformingOp
◆ myPickPos
QPoint OCCViewer_ClipPlaneInteractor::myPickPos
◆ myPlaneReferenceCS
gp_Ax3 OCCViewer_ClipPlaneInteractor::myPlaneReferenceCS
◆ myPlanes
SeqOfPlanes OCCViewer_ClipPlaneInteractor::myPlanes
◆ myRotationAxis
gp_Ax1 OCCViewer_ClipPlaneInteractor::myRotationAxis
◆ myRotationCenter
gp_Pnt OCCViewer_ClipPlaneInteractor::myRotationCenter
