OCCViewer_ViewportInputFilter Class Referenceabstract
The user input filter of OCC viewports. The class can be used to introduce custom interactive operations in OCC viewer, e.g. manipulating IO. The filter receives events in priority to the viewport itself and can bypass some events if it provides custom handling. More...
#include <OCCViewer_ViewportInputFilter.h>
Inheritance diagram for OCCViewer_ViewportInputFilter:
 OCCViewer_ViewportInputFilter (OCCViewer_ViewManager *, QObject *)
 ~OCCViewer_ViewportInputFilter ()
virtual void setEnabled (const bool)
 Enables or disables event processing within the viewer. More...
Protected Slots
void onViewCreated (SUIT_ViewWindow *)
 Connects newly created within viewer to event processing. More...
void onViewRemoved (SUIT_ViewWindow *)
 Disconnects view being removed from viewer. More...
virtual bool mouseMove (QMouseEvent *, OCCViewer_ViewPort3d *)=0
virtual bool mousePress (QMouseEvent *, OCCViewer_ViewPort3d *)=0
virtual bool mouseRelease (QMouseEvent *, OCCViewer_ViewPort3d *)=0
virtual bool mouseDoubleClick (QMouseEvent *, OCCViewer_ViewPort3d *)=0
virtual bool keyPress (QKeyEvent *, OCCViewer_ViewPort3d *)=0
virtual bool keyRelease (QKeyEvent *, OCCViewer_ViewPort3d *)=0
void connectView (SUIT_ViewWindow *)
 Connects view to event processing. More...
void disconnectView (SUIT_ViewWindow *)
 Disconnects view to event processing. More...
bool eventFilter (QObject *, QEvent *)
 Base-level implementation of event filtering. Routes user input events to associated implementation methods. More...
OCCViewer_ViewManager * myVM
OCCViewer_Viewer * myViewer
bool myIsEnabled
This class is abstract and required implementation of custom reaction on hooked viewport events. The role of the code behind this class is to properly embed the event filter into OCC viewer's structure.
◆ OCCViewer_ViewportInputFilter()
OCCViewer_ViewportInputFilter::OCCViewer_ViewportInputFilter ( OCCViewer_ViewManager *  theVM,
QObject *  theParent
theVM[in] the view manager to embed the filter into.
theParent[in] the parent object.
◆ ~OCCViewer_ViewportInputFilter()
OCCViewer_ViewportInputFilter::~OCCViewer_ViewportInputFilter ( )
References setEnabled().
◆ connectView()
void OCCViewer_ViewportInputFilter::connectView ( SUIT_ViewWindow *  theView)
theView[in] the view to connect.
◆ disconnectView()
void OCCViewer_ViewportInputFilter::disconnectView ( SUIT_ViewWindow *  theView)
theView[in] the view to disconnect.
◆ eventFilter()
bool OCCViewer_ViewportInputFilter::eventFilter ( QObject *  theObject,
QEvent *  theEvent
theObject[in] the filtered object.
theEvent[in] the incoming event.
References keyPress(), keyRelease(), mouseDoubleClick(), mouseMove(), mousePress(), and mouseRelease().
◆ keyPress()
virtual bool OCCViewer_ViewportInputFilter::keyPress ( QKeyEvent *  ,
protectedpure virtual
◆ keyRelease()
virtual bool OCCViewer_ViewportInputFilter::keyRelease ( QKeyEvent *  ,
◆ mouseDoubleClick()
virtual bool OCCViewer_ViewportInputFilter::mouseDoubleClick ( QMouseEvent *  ,
◆ mouseMove()
virtual bool OCCViewer_ViewportInputFilter::mouseMove ( QMouseEvent *  ,
◆ mousePress()
virtual bool OCCViewer_ViewportInputFilter::mousePress ( QMouseEvent *  ,
◆ mouseRelease()
virtual bool OCCViewer_ViewportInputFilter::mouseRelease ( QMouseEvent *  ,
◆ onViewCreated
void OCCViewer_ViewportInputFilter::onViewCreated ( SUIT_ViewWindow *  theView)
protectedslot
References connectView().
◆ onViewRemoved
void OCCViewer_ViewportInputFilter::onViewRemoved ( SUIT_ViewWindow *  theView)
protectedslot
References disconnectView().
◆ setEnabled()
void OCCViewer_ViewportInputFilter::setEnabled ( const bool  theIsEnabled)
◆ myIsEnabled
bool OCCViewer_ViewportInputFilter::myIsEnabled
◆ myViewer
OCCViewer_Viewer* OCCViewer_ViewportInputFilter::myViewer
◆ myVM
OCCViewer_ViewManager* OCCViewer_ViewportInputFilter::myVM
