Plot2d_SetupViewDlg Class Reference
Dialog box to setup Plot2d view window. More...
#include <Plot2d_SetupViewDlg.h>
Inheritance diagram for Plot2d_SetupViewDlg:
 Plot2d_SetupViewDlg (QWidget *=0, bool=false, bool=false)
 ~Plot2d_SetupViewDlg ()
void setMainTitle (bool, const QString &=QString())
 Set main title attributes. More...
bool isMainTitleEnabled ()
 Check if main title is enabled. More...
QString getMainTitle ()
 Get main title. More...
void setXTitle (bool, const QString &=QString())
 Set horizontal axis title attributes. More...
bool isXTitleEnabled ()
QString getXTitle ()
 Get horizontal axis title. More...
void setYTitle (bool, const QString &=QString())
 Set left vertical axis title attributes. More...
void setY2Title (bool, const QString &=QString())
 Set right vertical axis title attributes. More...
bool isYTitleEnabled ()
 Check if left vertical axis title is enabled. More...
bool isY2TitleEnabled ()
 Check if right vertical axis title is enabled. More...
QString getYTitle ()
 Get left vertical axis title. More...
QString getY2Title ()
 Get right vertical axis title. More...
void setCurveType (const int)
 Set curve type. More...
int getCurveType ()
 Get curve type. More...
bool getLMaxNormMode ()
 Check if normalization to maximum by left Y axis sets. More...
void setLMaxNormMode (const bool)
 Set normalization to maximum by left Y axis. More...
bool getLMinNormMode ()
 Check if normalization to minimum by left Y axis sets. More...
void setLMinNormMode (const bool)
 Set normalization to minimum by left Y axis. More...
bool getRMaxNormMode ()
 Check if normalization to maximum by right Y axis sets. More...
void setRMaxNormMode (const bool)
 Set normalization to maximum by right Y axis. More...
bool getRMinNormMode ()
 Check if normalization to minimum by right Y axis sets. More...
void setRMinNormMode (const bool)
 Set normalization to minimum by right Y axis. More...
void setLegend (bool, int, int, const QFont &, const QColor &, const QColor &)
 Set legend attribute. More...
bool isLegendEnabled ()
 Check if legend is enabled. More...
int getLegendPos ()
 Get legend position. More...
int getLegendSymbolType ()
 Get legend symbol type. More...
QFont getLegendFont ()
 Get legend font. More...
QColor getLegendColor ()
 Get legend font color. More...
QColor getSelectedLegendColor ()
 Get selected legend font color. More...
void setMarkerSize (const int)
 Set marker size. More...
int getMarkerSize ()
 Get marker size. More...
void setBackgroundColor (const QColor &)
 Set background color. More...
QColor getBackgroundColor ()
 Get background color. More...
void setSelectionColor (const QColor &)
 Set selection color. More...
QColor getSelectionColor ()
 Get selection color. More...
void setMajorGrid (bool, const int, bool, const int, bool, const int)
 Set major grid parameters. More...
void getMajorGrid (bool &, int &, bool &, int &, bool &, int &)
 Get major grid parameters. More...
void setMinorGrid (bool, const int, bool, const int, bool, const int)
 Set minor grid parameters. More...
void getMinorGrid (bool &, int &, bool &, int &, bool &, int &)
 Get minor grid parameters. More...
void setScaleMode (const int, const int)
 Set scale mode for horizontal and vertical axes. More...
int getXScaleMode ()
 Get scale mode for horizontal axis. More...
int getYScaleMode ()
 Get scale mode for vertical axis. More...
void setDeviationMarkerLw (const int)
 Set deviation marker line width. More...
int getDeviationMarkerLw () const
 Get deviation marker line width. More...
void setDeviationMarkerTs (const int)
 Set deviation marker tick size. More...
int getDeviationMarkerTs () const
 Get deviation marker tick size. More...
void setDeviationMarkerCl (const QColor &)
 Set color of the deviation marker. More...
QColor getDeviationMarkerCl () const
 Get color of the deviation marker. More...
bool isSetAsDefault ()
 Get "Set settings as default" check box value. More...
Protected Slots
void onMainTitleChecked ()
 Called when user clicks "Show main title" check box. More...
void onXTitleChecked ()
 Called when user clicks "Show horizontal axis title" check box. More...
void onYTitleChecked ()
 Called when user clicks "Show vertical left axis title" check box. More...
void onY2TitleChecked ()
 Called when user clicks "Show vertical right axis title" check box. More...
void onLegendChecked ()
 Called when user clicks "Show Legend" check box. More...
void onXGridMajorChecked ()
 Called when user clicks "Enable horizontal major grid" check box. More...
void onYGridMajorChecked ()
 Called when user clicks "Enable left vertical major grid" check box. More...
void onY2GridMajorChecked ()
 Called when user clicks "Enable right vertical major grid" check box. More...
void onXGridMinorChecked ()
 Called when user clicks "Enable horizontal minor grid" check box. More...
void onYGridMinorChecked ()
 Called when user clicks "Enable left vertical minor grid" check box. More...
void onY2GridMinorChecked ()
 Called when user clicks "Enable right vertical minor grid" check box. More...
void onNormLMaxChecked ()
 Called when user clicks "Left Y Axis: Normalize to maximum" check box. More...
void onNormLMinChecked ()
 Called when user clicks "Left Y Axis: Normalize to minimum" check box. More...
void onNormRMaxChecked ()
 Called when user clicks "Right Y Axis: Normalize to maximum" check box. More...
void onNormRMinChecked ()
 Called when user clicks "Right Y Axis: Normalize to minimum" check box. More...
void onHelp ()
QCheckBox * myTitleCheck
QLineEdit * myTitleEdit
QCheckBox * myTitleXCheck
QLineEdit * myTitleXEdit
QCheckBox * myTitleYCheck
QCheckBox * myTitleY2Check
QLineEdit * myTitleYEdit
QLineEdit * myTitleY2Edit
QtxColorButton * myBackgroundBtn
QtxColorButton * mySelectionBtn
QtxColorButton * myLegendFontColor
QtxColorButton * mySelectedLegendFontColor
QtxFontEdit * myLegendFont
QCheckBox * myXGridCheck
QSpinBox * myXGridSpin
QCheckBox * myYGridCheck
QCheckBox * myY2GridCheck
QSpinBox * myYGridSpin
QSpinBox * myY2GridSpin
QCheckBox * myXMinGridCheck
QSpinBox * myXMinGridSpin
QCheckBox * myYMinGridCheck
QCheckBox * myY2MinGridCheck
QSpinBox * myYMinGridSpin
QSpinBox * myY2MinGridSpin
QComboBox * myCurveCombo
QCheckBox * myLegendCheck
QComboBox * myLegendCombo
QComboBox * myLegendSymbolType
QSpinBox * myMarkerSpin
QComboBox * myXModeCombo
QComboBox * myYModeCombo
QCheckBox * myNormLMaxCheck
QCheckBox * myNormLMinCheck
QCheckBox * myNormRMaxCheck
QCheckBox * myNormRMinCheck
QComboBox * myY2ModeCombo
QCheckBox * myDefCheck
QPushButton * myOkBtn
QPushButton * myCancelBtn
QPushButton * myHelpBtn
QSpinBox * myDeviationLw
QSpinBox * myDeviationTs
QtxColorButton * myDeviationCl
bool mySecondAxisY
◆ Plot2d_SetupViewDlg()
◆ ~Plot2d_SetupViewDlg()
Plot2d_SetupViewDlg::~Plot2d_SetupViewDlg ( )
◆ getBackgroundColor()
QColor Plot2d_SetupViewDlg::getBackgroundColor ( )
background color
See also
setBackgroundColor()
References QtxColorButton::color(), and myBackgroundBtn.
◆ getCurveType()
int Plot2d_SetupViewDlg::getCurveType ( )
Get curve type.
curve type: 0 (points), 1 (lines) or 2 (splines)
See also
setCurveType()
References myCurveCombo.
◆ getDeviationMarkerCl()
QColor Plot2d_SetupViewDlg::getDeviationMarkerCl ( ) const
marker color
See also
setDeviationMarkerCl()
References QtxColorButton::color(), and myDeviationCl.
◆ getDeviationMarkerLw()
int Plot2d_SetupViewDlg::getDeviationMarkerLw ( ) const
marker line width
See also
setMarkerSize()
References myDeviationLw.
◆ getDeviationMarkerTs()
int Plot2d_SetupViewDlg::getDeviationMarkerTs ( ) const
marker tick size
See also
setDeviationMarkerTs()
References myDeviationTs.
◆ getLegendColor()
QColor Plot2d_SetupViewDlg::getLegendColor ( )
legend font color
See also
setLegend()
References QtxColorButton::color(), and myLegendFontColor.
◆ getLegendFont()
QFont Plot2d_SetupViewDlg::getLegendFont ( )
Get legend font.
legend font
See also
setLegend()
References QtxFontEdit::currentFont(), and myLegendFont.
◆ getLegendPos()
int Plot2d_SetupViewDlg::getLegendPos ( )
legend position: 0 (left), 1 (right), 2 (top), 3 (bottom)
See also
setLegend()
References myLegendCombo.
◆ getLegendSymbolType()
int Plot2d_SetupViewDlg::getLegendSymbolType ( )
legend symbol type: 0 (marker on line), 1 (marker above line)
See also
setLegend()
References myLegendSymbolType.
◆ getLMaxNormMode()
bool Plot2d_SetupViewDlg::getLMaxNormMode ( )
curve normalizatoin type: true,false
See also
setMaxNormMode()
References myNormLMaxCheck.
◆ getLMinNormMode()
bool Plot2d_SetupViewDlg::getLMinNormMode ( )
See also
setMinNormMode()
References myNormLMinCheck.
◆ getMainTitle()
QString Plot2d_SetupViewDlg::getMainTitle ( )
Get main title.
main title
See also
setMainTitle()
References myTitleEdit.
◆ getMajorGrid()
void Plot2d_SetupViewDlg::getMajorGrid ( bool &  enableX,
int &  divX,
bool &  enableY,
int &  divY,
bool &  enableY2,
int &  divY2
enableXtrue if horizontal major grid is enabled
divXmaximum number of ticks for horizontal major grid
enableYtrue if left vertical major grid is enabled
divYmaximum number of ticks for left vertical major grid
enableY2true if right vertical major grid is enabled
divY2maximum number of ticks for right vertical major grid
See also
setMajorGrid()
References mySecondAxisY, myXGridCheck, myXGridSpin, myY2GridCheck, myY2GridSpin, myYGridCheck, and myYGridSpin.
◆ getMarkerSize()
int Plot2d_SetupViewDlg::getMarkerSize ( )
Get marker size.
marker size
See also
setMarkerSize()
References myMarkerSpin.
◆ getMinorGrid()
void Plot2d_SetupViewDlg::getMinorGrid ( bool &  enableX,
int &  divX,
bool &  enableY,
int &  divY,
bool &  enableY2,
int &  divY2
enableXtrue if horizontal minor grid is enabled
divXmaximum number of ticks for horizontal minor grid
enableYtrue if left vertical minor grid is enabled
divYmaximum number of ticks for left vertical minor grid
enableY2true if right vertical minor grid is enabled
divY2maximum number of ticks for right vertical minor grid
See also
setMinorGrid()
References mySecondAxisY, myXMinGridCheck, myXMinGridSpin, myY2MinGridCheck, myY2MinGridSpin, myYMinGridCheck, and myYMinGridSpin.
◆ getRMaxNormMode()
bool Plot2d_SetupViewDlg::getRMaxNormMode ( )
See also
setMaxNormMode()
References myNormRMaxCheck.
◆ getRMinNormMode()
bool Plot2d_SetupViewDlg::getRMinNormMode ( )
See also
setMinNormMode()
References myNormRMinCheck.
◆ getSelectedLegendColor()
QColor Plot2d_SetupViewDlg::getSelectedLegendColor ( )
See also
setLegend()
References QtxColorButton::color(), and mySelectedLegendFontColor.
◆ getSelectionColor()
QColor Plot2d_SetupViewDlg::getSelectionColor ( )
selection color
See also
setSelectionColor()
References QtxColorButton::color(), and mySelectionBtn.
◆ getXScaleMode()
int Plot2d_SetupViewDlg::getXScaleMode ( )
horizontal axis scale mode: 0 (linear), 1 (logarithmic)
See also
setScaleMode()
References myXModeCombo.
◆ getXTitle()
QString Plot2d_SetupViewDlg::getXTitle ( )
See also
setXTitle()
References myTitleXEdit.
◆ getY2Title()
QString Plot2d_SetupViewDlg::getY2Title ( )
See also
setY2Title()
References myTitleY2Edit.
◆ getYScaleMode()
int Plot2d_SetupViewDlg::getYScaleMode ( )
vertical axis scale mode: 0 (linear), 1 (logarithmic)
See also
setScaleMode()
References myYModeCombo.
◆ getYTitle()
QString Plot2d_SetupViewDlg::getYTitle ( )
See also
setYTitle()
References myTitleYEdit.
◆ isLegendEnabled()
bool Plot2d_SetupViewDlg::isLegendEnabled ( )
true if legend is enabled
See also
setLegend()
References myLegendCheck.
◆ isMainTitleEnabled()
bool Plot2d_SetupViewDlg::isMainTitleEnabled ( )
true if main title is enabled
See also
setMainTitle()
References myTitleCheck.
◆ isSetAsDefault()
bool Plot2d_SetupViewDlg::isSetAsDefault ( )
true if "Set settings as default" check box is on
References myDefCheck.
◆ isXTitleEnabled()
bool Plot2d_SetupViewDlg::isXTitleEnabled ( )
true if horizontal axis title is enabled
See also
setXTitle()
References myTitleXCheck.
◆ isY2TitleEnabled()
bool Plot2d_SetupViewDlg::isY2TitleEnabled ( )
true if right vertical axis title is enabled
See also
setY2Title()
References myTitleY2Check.
◆ isYTitleEnabled()
bool Plot2d_SetupViewDlg::isYTitleEnabled ( )
See also
setYTitle()
References myTitleYCheck.
◆ onHelp
void Plot2d_SetupViewDlg::onHelp ( )
protectedslot
Slot, called when user clicks "Help" button
References SUIT_Session::activeApplication(), SUIT_Application::onHelpContextModule(), and SUIT_Session::session().
◆ onLegendChecked
void Plot2d_SetupViewDlg::onLegendChecked ( )
protectedslot
References myLegendCheck, and myLegendCombo.
◆ onMainTitleChecked
void Plot2d_SetupViewDlg::onMainTitleChecked ( )
protectedslot
References myTitleCheck, and myTitleEdit.
◆ onNormLMaxChecked
void Plot2d_SetupViewDlg::onNormLMaxChecked ( )
protectedslot
◆ onNormLMinChecked
void Plot2d_SetupViewDlg::onNormLMinChecked ( )
protectedslot
◆ onNormRMaxChecked
void Plot2d_SetupViewDlg::onNormRMaxChecked ( )
protectedslot
◆ onNormRMinChecked
void Plot2d_SetupViewDlg::onNormRMinChecked ( )
protectedslot
◆ onXGridMajorChecked
void Plot2d_SetupViewDlg::onXGridMajorChecked ( )
protectedslot
References myXGridCheck, and myXMinGridCheck.
◆ onXGridMinorChecked
void Plot2d_SetupViewDlg::onXGridMinorChecked ( )
protectedslot
◆ onXTitleChecked
void Plot2d_SetupViewDlg::onXTitleChecked ( )
protectedslot
References myTitleXCheck, and myTitleXEdit.
◆ onY2GridMajorChecked
void Plot2d_SetupViewDlg::onY2GridMajorChecked ( )
protectedslot
References myY2GridCheck, and myY2MinGridCheck.
◆ onY2GridMinorChecked
void Plot2d_SetupViewDlg::onY2GridMinorChecked ( )
protectedslot
◆ onY2TitleChecked
void Plot2d_SetupViewDlg::onY2TitleChecked ( )
protectedslot
References myTitleY2Check, and myTitleY2Edit.
◆ onYGridMajorChecked
void Plot2d_SetupViewDlg::onYGridMajorChecked ( )
protectedslot
References myYGridCheck, and myYMinGridCheck.
◆ onYGridMinorChecked
void Plot2d_SetupViewDlg::onYGridMinorChecked ( )
protectedslot
◆ onYTitleChecked
void Plot2d_SetupViewDlg::onYTitleChecked ( )
protectedslot
References myTitleYCheck, and myTitleYEdit.
◆ setBackgroundColor()
void Plot2d_SetupViewDlg::setBackgroundColor ( const QColor &  color)
colorbackground color
See also
References OCCViewer::color(), myBackgroundBtn, and QtxColorButton::setColor().
◆ setCurveType()
void Plot2d_SetupViewDlg::setCurveType ( const int  type)
Set curve type.
typecurve type: 0 (points), 1 (lines) or 2 (splines)
See also
getCurveType()
◆ setDeviationMarkerCl()
void Plot2d_SetupViewDlg::setDeviationMarkerCl ( const QColor &  col)
colormarker color
See also
References myDeviationCl, and QtxColorButton::setColor().
◆ setDeviationMarkerLw()
void Plot2d_SetupViewDlg::setDeviationMarkerLw ( const int  width)
widthmarker line width
See also
◆ setDeviationMarkerTs()
void Plot2d_SetupViewDlg::setDeviationMarkerTs ( const int  size)
sizemarker tick size
See also
◆ setLegend()
void Plot2d_SetupViewDlg::setLegend ( bool  enable,
int  pos,
int  symbolType,
const QFont &  fnt,
const QColor &  fontColor,
const QColor &  selFontColor
iftrue legend is shown
poslegend position: 0 (left), 1 (right), 2 (top), 3 (bottom)
fntlegend font
collegend font color
See also
isLegendEnabled(), getLegendPos(), getLegendFont()
References myLegendCheck, myLegendCombo, myLegendFont, myLegendFontColor, myLegendSymbolType, mySelectedLegendFontColor, onLegendChecked(), QtxColorButton::setColor(), and QtxFontEdit::setCurrentFont().
◆ setLMaxNormMode()
void Plot2d_SetupViewDlg::setLMaxNormMode ( const bool  type)
typenormalizatoin type: true,false
See also
getMaxNormMode()
◆ setLMinNormMode()
void Plot2d_SetupViewDlg::setLMinNormMode ( const bool  type)
See also
getMinNormMode()
◆ setMainTitle()
void Plot2d_SetupViewDlg::setMainTitle ( bool  enable,
const QString &  title = QString()
enableif true main title is enabled
titlemain title
See also
isMainTitleEnabled(), getMainTitle()
References myTitleCheck, myTitleEdit, and onMainTitleChecked().
◆ setMajorGrid()
void Plot2d_SetupViewDlg::setMajorGrid ( bool  enableX,
const int  divX,
bool  enableY,
const int  divY,
bool  enableY2,
const int  divY2
enableXif true, horizontal major grid is enabled
enableYif true, left vertical major grid is enabled
enableY2if true, right vertical major grid is enabled
See also
getMajorGrid()
References mySecondAxisY, myXGridCheck, myXGridSpin, myY2GridCheck, myY2GridSpin, myYGridCheck, myYGridSpin, onXGridMajorChecked(), onY2GridMajorChecked(), and onYGridMajorChecked().
◆ setMarkerSize()
void Plot2d_SetupViewDlg::setMarkerSize ( const int  size)
Set marker size.
sizemarker size
See also
getMarkerSize()
◆ setMinorGrid()
void Plot2d_SetupViewDlg::setMinorGrid ( bool  enableX,
const int  divX,
bool  enableY,
const int  divY,
bool  enableY2,
const int  divY2
enableXif true, horizontal minor grid is enabled
enableYif true, left vertical minor grid is enabled
enableY2if true, right vertical minor grid is enabled
See also
getMinorGrid()
References mySecondAxisY, myXMinGridCheck, myXMinGridSpin, myY2MinGridCheck, myY2MinGridSpin, myYMinGridCheck, myYMinGridSpin, onXGridMinorChecked(), onY2GridMinorChecked(), and onYGridMinorChecked().
◆ setRMaxNormMode()
void Plot2d_SetupViewDlg::setRMaxNormMode ( const bool  type)
See also
getMaxNormMode()
◆ setRMinNormMode()
void Plot2d_SetupViewDlg::setRMinNormMode ( const bool  type)
See also
getMinNormMode()
◆ setScaleMode()
void Plot2d_SetupViewDlg::setScaleMode ( const int  xMode,
const int  yMode
xModehorizontal axis scale mode: 0 (linear), 1 (logarithmic)
yModevertical axis scale mode: 0 (linear), 1 (logarithmic)
See also
getXScaleMode(), getYScaleMode()
References myXModeCombo, and myYModeCombo.
◆ setSelectionColor()
void Plot2d_SetupViewDlg::setSelectionColor ( const QColor &  color)
colorselection color
See also
getSelectionColor()
References OCCViewer::color(), mySelectionBtn, and QtxColorButton::setColor().
◆ setXTitle()
void Plot2d_SetupViewDlg::setXTitle ( bool  enable,
enableif true horizontal axis title is enabled
titlehorizontal axis title
See also
isXTitleEnabled(), getXTitle()
References myTitleXCheck, myTitleXEdit, and onXTitleChecked().
◆ setY2Title()
void Plot2d_SetupViewDlg::setY2Title ( bool  enable,
enableif true right vertical axis title is enabled
titleright vertical axis title
See also
setYTitle(), isY2TitleEnabled(), getY2Title()
References myTitleY2Check, myTitleY2Edit, and onY2TitleChecked().
◆ setYTitle()
void Plot2d_SetupViewDlg::setYTitle ( bool  enable,
enableif true left vertical axis title is enabled
titleleft vertical axis title
See also
setY2Title(), isYTitleEnabled(), getYTitle()
References myTitleYCheck, myTitleYEdit, and onYTitleChecked().
◆ myBackgroundBtn
QtxColorButton* Plot2d_SetupViewDlg::myBackgroundBtn
◆ myCancelBtn
QPushButton* Plot2d_SetupViewDlg::myCancelBtn
◆ myCurveCombo
QComboBox* Plot2d_SetupViewDlg::myCurveCombo
◆ myDefCheck
QCheckBox* Plot2d_SetupViewDlg::myDefCheck
◆ myDeviationCl
QtxColorButton* Plot2d_SetupViewDlg::myDeviationCl
◆ myDeviationLw
QSpinBox* Plot2d_SetupViewDlg::myDeviationLw
◆ myDeviationTs
QSpinBox* Plot2d_SetupViewDlg::myDeviationTs
◆ myHelpBtn
QPushButton* Plot2d_SetupViewDlg::myHelpBtn
◆ myLegendCheck
QCheckBox* Plot2d_SetupViewDlg::myLegendCheck
◆ myLegendCombo
QComboBox* Plot2d_SetupViewDlg::myLegendCombo
◆ myLegendFont
QtxFontEdit* Plot2d_SetupViewDlg::myLegendFont
◆ myLegendFontColor
QtxColorButton* Plot2d_SetupViewDlg::myLegendFontColor
◆ myLegendSymbolType
QComboBox* Plot2d_SetupViewDlg::myLegendSymbolType
◆ myMarkerSpin
QSpinBox* Plot2d_SetupViewDlg::myMarkerSpin
◆ myNormLMaxCheck
QCheckBox* Plot2d_SetupViewDlg::myNormLMaxCheck
◆ myNormLMinCheck
QCheckBox* Plot2d_SetupViewDlg::myNormLMinCheck
◆ myNormRMaxCheck
QCheckBox* Plot2d_SetupViewDlg::myNormRMaxCheck
◆ myNormRMinCheck
QCheckBox* Plot2d_SetupViewDlg::myNormRMinCheck
◆ myOkBtn
QPushButton* Plot2d_SetupViewDlg::myOkBtn
◆ mySecondAxisY
bool Plot2d_SetupViewDlg::mySecondAxisY
◆ mySelectedLegendFontColor
QtxColorButton* Plot2d_SetupViewDlg::mySelectedLegendFontColor
◆ mySelectionBtn
QtxColorButton* Plot2d_SetupViewDlg::mySelectionBtn
◆ myTitleCheck
QCheckBox* Plot2d_SetupViewDlg::myTitleCheck
◆ myTitleEdit
QLineEdit* Plot2d_SetupViewDlg::myTitleEdit
◆ myTitleXCheck
QCheckBox* Plot2d_SetupViewDlg::myTitleXCheck
◆ myTitleXEdit
QLineEdit* Plot2d_SetupViewDlg::myTitleXEdit
◆ myTitleY2Check
QCheckBox* Plot2d_SetupViewDlg::myTitleY2Check
◆ myTitleY2Edit
QLineEdit* Plot2d_SetupViewDlg::myTitleY2Edit
◆ myTitleYCheck
QCheckBox* Plot2d_SetupViewDlg::myTitleYCheck
◆ myTitleYEdit
QLineEdit* Plot2d_SetupViewDlg::myTitleYEdit
◆ myXGridCheck
QCheckBox* Plot2d_SetupViewDlg::myXGridCheck
◆ myXGridSpin
QSpinBox* Plot2d_SetupViewDlg::myXGridSpin
◆ myXMinGridCheck
QCheckBox* Plot2d_SetupViewDlg::myXMinGridCheck
◆ myXMinGridSpin
QSpinBox* Plot2d_SetupViewDlg::myXMinGridSpin
◆ myXModeCombo
QComboBox* Plot2d_SetupViewDlg::myXModeCombo
◆ myY2GridCheck
QCheckBox* Plot2d_SetupViewDlg::myY2GridCheck
◆ myY2GridSpin
QSpinBox* Plot2d_SetupViewDlg::myY2GridSpin
◆ myY2MinGridCheck
QCheckBox* Plot2d_SetupViewDlg::myY2MinGridCheck
◆ myY2MinGridSpin
QSpinBox* Plot2d_SetupViewDlg::myY2MinGridSpin
◆ myY2ModeCombo
QComboBox* Plot2d_SetupViewDlg::myY2ModeCombo
◆ myYGridCheck
QCheckBox* Plot2d_SetupViewDlg::myYGridCheck
◆ myYGridSpin
QSpinBox* Plot2d_SetupViewDlg::myYGridSpin
◆ myYMinGridCheck
QCheckBox* Plot2d_SetupViewDlg::myYMinGridCheck
◆ myYMinGridSpin
QSpinBox* Plot2d_SetupViewDlg::myYMinGridSpin
◆ myYModeCombo
QComboBox* Plot2d_SetupViewDlg::myYModeCombo
