QtxActionMgr::Creator Class Referenceabstract
Generic actions creator class. More...
#include <QtxActionMgr.h>
Inheritance diagram for QtxActionMgr::Creator:
 Creator (QtxActionMgr::Reader *)
virtual ~Creator ()
Reader * reader () const
 Get actions reader. More...
virtual int append (const QString &, const bool, const ItemAttributes &, const int)=0
 Create (and probably append to the action manager) new action. More...
virtual void connect (QAction *) const
 Connect action to some specific slot(s). More...
virtual bool loadPixmap (const QString &, QPixmap &) const
 Load pixmap from the file. More...
static int intValue (const ItemAttributes &, const QString &, const int)
 Get integer attribute value from the attribute map. More...
static QString strValue (const ItemAttributes &, const QString &, const QString &=QString())
 Get string attribute value from the attribute map. More...
QtxActionMgr::Reader * myReader
 actions reader More...
Used by Reader to create actions and fill in the action manager with the actions.
◆ Creator()
QtxActionMgr::Creator::Creator ( QtxActionMgr::Reader *  r)
raction reader
◆ ~Creator()
QtxActionMgr::Creator::~Creator ( )
◆ append()
int QtxActionMgr::Creator::append ( const QString &  tag,
const bool  subMenu,
const ItemAttributes &  attr,
const int  pId
pure virtual
This method should be redefined in the subclasses.
tagitem tag name
subMenutrue if this item is submenu
attrattributes map
pIdparent action ID
item (for example action) ID
Implemented in QtxActionMenuMgr::MenuCreator, QtxActionToolMgr::ToolCreator, and QtxPopupMgr::PopupCreator.
◆ connect()
void QtxActionMgr::Creator::connect ( QAction *  ) const
This method can be redefined in subclasses. Base implementation does nothing.
aaction
◆ intValue()
int QtxActionMgr::Creator::intValue ( const ItemAttributes &  attrs,
const QString &  name,
const int  def
staticprotected
Returns default value (def) if the attribute is not found.
attrsattributes map
nameattribute name
defdefault attribute value
attribute value
◆ loadPixmap()
bool QtxActionMgr::Creator::loadPixmap ( const QString &  fname,
QPixmap &  pix
fnamefile name
pixused to return pixmap
true if pixmap is loaded successfully and false in case of error
References Qtx::addSlash().
◆ reader()
QtxActionMgr::Reader * QtxActionMgr::Creator::reader ( ) const
Get actions reader.
actions reader
◆ strValue()
QString QtxActionMgr::Creator::strValue ( const ItemAttributes &  attrs,
const QString &  def = QString()
staticprotected
attrsattributes map
nameattribute name
attribute value
◆ myReader
QtxActionMgr::Reader* QtxActionMgr::Creator::myReader
actions reader
